Wyze Cam v3 Illumination Kit for Clear Low Light Video
When it comes to capturing clear, detailed video in low light conditions, the right combination of camera and illumination is essential. The Wyze Cam v3 Illumination Kit is designed to enhance your security footage by providing superior lighting and smart power solutions that ensure your camera performs optimally even in the darkest environments.
Wyze Cam v4: Advanced Low Light Video Performance
Crystal-Clear 2.5K QHD Resolution with Enhanced Color Night Vision
The Wyze Cam v4 is a cutting-edge security camera that delivers stunning 2.5K QHD video quality. Its CMOS Starlight Sensor combined with Enhanced Color Night Vision technology allows the camera to capture vibrant, full-color footage even in near-total darkness. This makes it ideal for monitoring your home or business during nighttime hours without losing critical details.
Motion-Activated Spotlight and Wide Dynamic Range
Equipped with a motion-activated spotlight, the Wyze Cam v4 automatically illuminates the scene when movement is detected, providing clear visibility and deterring unwanted visitors. The camera also features Wide Dynamic Range (WDR) to balance bright and dark areas in the video, ensuring every detail is visible regardless of lighting conditions.
Smart Features and Connectivity
- 24/7 local recording with microSD card support up to 512GB
- Wi-Fi 6 support for faster, more reliable connections
- Compatibility with Alexa and Google Assistant for voice control
- Built-in siren and two-way audio for interactive security
- Weather-resistant IP65 rating for outdoor use
This camera is perfect for users seeking a reliable, high-resolution camera that excels in low light without needing additional lighting equipment.
Cam v4 + Lamp Socket v2 Bundle: The Ultimate Illumination Kit
Power Your Wyze Cam v3 and v4 Without an Outlet
The Cam v4 + Lamp Socket v2 Bundle is a smart solution designed to power your Wyze Cam v3, v3 Pro, and v4 cameras directly from a lamp socket. This eliminates the need for nearby power outlets, making installation more flexible and convenient.
Motion-Activated Lighting for Enhanced Night Vision
This lamp socket features motion-activated lights that turn on automatically when movement is detected, providing additional illumination to improve your camera’s night vision capabilities. The dusk-to-dawn scheduling ensures your camera is always well-lit during nighttime hours without manual intervention.
Key Features of the Lamp Socket v2
- Compatible with E26 lamp sockets and supports bulbs up to 20W (LED or CFL recommended)
- Linkability allows multiple sockets to work together seamlessly
- Bluetooth and 2.4GHz Wi-Fi connectivity for easy setup and control
- Suitable for damp locations (not fully weatherproof)
- Compact and lightweight design for easy installation
This bundle is ideal for users who want to enhance their Wyze Cam’s low light video clarity with smart, integrated lighting.
Why Choose Wyze for Low Light Security?
"Clear video in low light is critical for effective security monitoring. Wyze’s combination of advanced camera sensors and smart illumination solutions ensures you never miss a detail, day or night."
Wyze’s cameras and accessories are designed with user convenience and cutting-edge technology in mind. Whether you need a standalone camera with excellent night vision or a complete illumination kit that powers your camera and lights your space, Wyze offers reliable, affordable options.
Summary of Products for Low Light Video Illumination
Product Name | Key Features | Price (USD) |
Wyze Cam v4 | 2.5K QHD, Enhanced Color Night Vision, Spotlight, Wi-Fi 6 | $69.99 |
Cam v4 + Lamp Socket v2 Bundle | Powers Wyze Cam v3/v4, Motion-Activated Lights, Dusk-to-Dawn Scheduling | $49.96 |
Experience clear, color night vision with Wyze Cam v4 and smart lighting.
Enhance Your Nighttime Security Today
Investing in the Wyze Cam v3 Illumination Kit or the Cam v4 + Lamp Socket v2 Bundle ensures your security cameras deliver crisp, clear video even in the darkest conditions. With smart lighting and powerful sensors working together, you can rest easy knowing your property is monitored with the best low light technology available.
What is the Wyze Cam v3 Illumination Kit and how does it improve low light video?
The Wyze Cam v3 Illumination Kit is designed to enhance your security camera's performance in low light conditions by providing superior lighting and smart power solutions. This kit ensures your Wyze Cam v3 captures clear, detailed video even in the darkest environments, making it ideal for nighttime security monitoring.What are the key features of the Wyze Cam v4 for low light video?
The Wyze Cam v4 offers 2.5K QHD resolution, a CMOS Starlight Sensor, and Enhanced Color Night Vision technology, allowing it to capture vibrant, full-color footage in near-total darkness. It also includes a motion-activated spotlight, Wide Dynamic Range (WDR), 24/7 local recording with microSD support up to 512GB, Wi-Fi 6 connectivity, compatibility with Alexa and Google Assistant, a built-in siren, two-way audio, and an IP65 weather-resistant rating.How does the motion-activated spotlight on Wyze Cam v4 work?
The Wyze Cam v4 features a motion-activated spotlight that automatically illuminates the area when movement is detected. This provides clear visibility for your security footage and helps deter unwanted visitors, ensuring every detail is captured even in low light.What is included in the Cam v4 + Lamp Socket v2 Bundle?
The Cam v4 + Lamp Socket v2 Bundle includes a Wyze Cam v4 (compatible with v3 and v3 Pro as well) and a Lamp Socket v2. The lamp socket powers your camera directly from a standard E26 lamp socket, eliminating the need for a nearby power outlet. It also features motion-activated lighting and dusk-to-dawn scheduling to enhance your camera’s night vision.Can I use the Lamp Socket v2 with any Wyze camera?
The Lamp Socket v2 is compatible with Wyze Cam v3, v3 Pro, and v4 cameras. It is designed to power these cameras directly from an E26 lamp socket and supports bulbs up to 20W (LED or CFL recommended).Is the Lamp Socket v2 weatherproof?
The Lamp Socket v2 is suitable for damp locations but is not fully weatherproof. It is designed for easy installation in areas where it may be exposed to some moisture, but it should not be used in locations with direct exposure to heavy rain or water.What are the benefits of using Wyze cameras for low light security?
Wyze cameras combine advanced sensors and smart illumination solutions to deliver clear, detailed video in low light conditions. With features like Enhanced Color Night Vision, motion-activated spotlights, and flexible power options, Wyze ensures you never miss a detail, day or night, making them a reliable and affordable choice for home and business security.How much do the Wyze Cam v4 and Cam v4 + Lamp Socket v2 Bundle cost?
The Wyze Cam v4 is priced at $69.99, while the Cam v4 + Lamp Socket v2 Bundle is available for $49.96. Both options provide excellent value for enhancing your security camera’s low light performance.Does the Wyze Cam v4 support local video recording?
Yes, the Wyze Cam v4 supports 24/7 local recording with a microSD card, with support for cards up to 512GB. This allows you to continuously record and store footage locally for added security.Can I control Wyze Cam v4 with voice assistants?
Yes, the Wyze Cam v4 is compatible with Alexa and Google Assistant, allowing you to control your camera and access live feeds using voice commands for added convenience.
