Best Spotlight Kit for Wyze Cam v3 in Dark Environments
When it comes to securing your home or property with Wyze Cam v3, having the right spotlight kit is essential for clear visibility in dark environments. The Wyze Cam v3 Spotlight Kit is specifically designed to enhance night-time surveillance by providing powerful, motion-activated lighting that complements the camera’s night vision capabilities. Below, we explore the best spotlight options and compatible Wyze Cam models that deliver outstanding performance in low-light conditions.
The Wyze Cam v3 Spotlight Kit is the perfect accessory to boost your Wyze Cam v3’s night vision. This motion-activated spotlight is IP65 rated, making it weather-resistant and suitable for outdoor use. It emits a bright 70 lumens of light with a wide 130-degree beam angle, illuminating dark areas effectively.
  • Brightness: 70 lumens
  • Beam Angle: 130 degrees for wide coverage
  • Power Supply: 5V 1A via Micro USB connection
  • Weather Resistance: IP65 rating ensures durability in rain or snow
  • Operating Temperature: -4°F to 131°F (-20°C to 55°C)
  • Compact Size: 21.5 x 55.8 x 34.4 mm
  • Included in Box: Spotlight unit and USB cable splitter
  • Warranty: 1 year
This spotlight kit is designed to seamlessly integrate with Wyze Cam v3, activating automatically when motion is detected to provide clear, color-accurate footage even in complete darkness.
"Wyze Cam v3 can watch it even better with this state-of-the-art, motion-activated, IP65 rated headlamp."
Wyze Cam v4 and Spotlight Features for Dark Environments
While the spotlight kit is tailored for Wyze Cam v3, the Wyze Cam v4 and its bundles also come equipped with advanced lighting and night vision features that excel in dark environments.
Wyze Cam v4
The Wyze Cam v4 offers enhanced night vision capabilities with built-in 2 white spotlight LEDs (72 lumens) alongside 4 IR LEDs. This combination provides color night vision and clear video quality in low-light settings without needing an external spotlight.
  • Video Resolution: 2.5K QHD (2560x1440)
  • Night Vision: 4 IR LEDs (850 nm) + 2 white spotlight LEDs (72 lumens)
  • Color Night Vision: Yes, for vivid nighttime footage
  • Field of View: 115.8° diagonal, 98.5° horizontal, 53.1° vertical
  • Weather Resistance: IP65 rated for outdoor use
  • Mounting Options: Stand, wall, ceiling, magnetic adhesive mount
  • Connectivity: Wi-Fi 6 and Bluetooth 5.2
  • Audio: 99dB waterproof speaker with two-way talk and built-in siren
  • Power: Indoor 5V/1A adapter (outdoor adapter sold separately)
Wyze Cam v4 Outdoor Bundle
For those seeking a complete outdoor security solution, the Wyze Cam v4 Outdoor Bundle includes the camera plus an outdoor power adapter and a 128GB microSD card for continuous local recording. It features Enhanced Color Night Vision and a motion-activated spotlight that automatically lights up when activity is detected.
  • Included Items: Wyze Cam v4, Outdoor Power Adapter, 128GB microSD Card
  • Night Vision: Enhanced Color Night Vision with motion-activated spotlight
  • Recording: 24/7 local recording capability
  • Wi-Fi Support: Wi-Fi 6 for stable connectivity
  • Smart Home Integration: Compatible with Alexa and Google Assistant
  • Outdoor Ready: Weather-resistant and wired power source for reliable operation
This bundle offers the same advanced features as the standalone Wyze Cam v4 but includes additional accessories for a comprehensive security setup. It supports motion-activated spotlight, person detection, and wide dynamic range (WDR) for superior image quality day and night.
  • Video FPS: 20 FPS daytime, 15 FPS nighttime
  • MicroSD Card: 128GB Class 10 UHS-3 included
  • Storage: Supports up to 512GB microSD card
  • Mounting: Multiple mounting options for flexible installation
  • Warranty: 1 year
Why Choose Wyze Spotlight Solutions for Dark Environments?
Wyze cameras paired with their spotlight kits or built-in spotlight features provide:
  • Enhanced Night Vision: Color night vision with white spotlight LEDs for clear, detailed images.
  • Motion-Activated Lighting: Spotlights activate only when needed, conserving energy and avoiding light pollution.
  • Weather Resistance: IP65 rating ensures durability in harsh outdoor conditions.
  • Smart Integration: Works seamlessly with Alexa, Google Assistant, and IFTTT for smart home automation.
  • High Resolution: 2.5K QHD video quality captures crisp footage day and night.
Lifestyle Image Highlighting Wyze Cam Outdoor Security
Outdoor home security with Wyze Cam Experience reliable night-time security with Wyze Cam and motion-activated spotlight.
Conclusion
For the best spotlight kit tailored specifically for the Wyze Cam v3, the Wyze Cam v3 Spotlight Kit is your go-to accessory, delivering bright, motion-activated illumination that enhances your camera’s night vision. If you are considering an upgrade or a more integrated solution, the Wyze Cam v4 and its outdoor bundles come with built-in spotlight LEDs and enhanced color night vision, providing excellent visibility in dark environments without the need for additional accessories. Choose the solution that fits your security needs and enjoy peace of mind with clear, color-accurate surveillance even in the darkest conditions.
FeatureWyze Cam v3 Spotlight KitWyze Cam v4Wyze Cam v4 Outdoor Bundle
Product TypeAccessory (Spotlight Kit)CameraCamera Bundle
Price$16.98$35.98 (1 Pack)$69.99
ResolutionN/A (Accessory)2.5K QHD (2560x1440)2.5K QHD (2560x1440)
Night VisionNo (Spotlight only)Enhanced Color Night VisionEnhanced Color Night Vision
SpotlightMotion-activated, IP65 rated headlampMotion-activated spotlightMotion-activated spotlight
Weather ResistanceIP65IP65IP65
Local RecordingN/A24/7 local recording (microSD card required)24/7 local recording (microSD card included)
Wi-Fi SupportN/AWi-Fi 6Wi-Fi 6
CompatibilityWyze Cam v3Alexa, Google AssistantAlexa, Google Assistant
Power SourceN/A (Accessory)WiredWired
MicroSD Card SlotN/AYes (up to 256GB)Yes (128GB included)
Motion DetectionN/AYesYes
Sound DetectionN/AYesYes
Motion Detection ZonesN/AYesYes
Smoke & CO AlertsN/AYesYes
Field of ViewN/A115.9° (D) x 98.5° (H) x 53.1° (V)115.9° (D) x 98.5° (H) x 53.1° (V)
Spotlight Kit IncludedYesBuilt-in spotlightBuilt-in spotlight
Outdoor CompatibilityYes (IP65 rated spotlight)YesYes
Return Policy30-day hassle-free returns30-day hassle-free returns30-day hassle-free returns
What is the best spotlight kit for Wyze Cam v3 in dark environments?The Wyze Cam v3 Spotlight Kit is the best accessory for enhancing your Wyze Cam v3’s night vision in dark environments. It provides a bright, motion-activated 70-lumen light with a wide 130-degree beam angle, ensuring clear and color-accurate footage even in complete darkness.
Is the Wyze Cam v3 Spotlight Kit weather-resistant?Yes, the Wyze Cam v3 Spotlight Kit is IP65 rated, making it weather-resistant and suitable for outdoor use in rain or snow.
How does the Wyze Cam v3 Spotlight Kit improve night vision?The Wyze Cam v3 Spotlight Kit activates automatically when motion is detected, providing powerful illumination that enhances the camera’s night vision capabilities and delivers clear, color-accurate video footage in low-light conditions.
What is included in the Wyze Cam v3 Spotlight Kit package?The Wyze Cam v3 Spotlight Kit package includes the spotlight unit and a USB cable splitter for easy installation and integration with your Wyze Cam v3.
What are the technical specifications of the Wyze Cam v3 Spotlight Kit?The Wyze Cam v3 Spotlight Kit features 70 lumens brightness, a 130-degree beam angle, IP65 weather resistance, operates at -4°F to 131°F (-20°C to 55°C), and is powered via a 5V 1A Micro USB connection.
Does the Wyze Cam v4 have a built-in spotlight for night vision?Yes, the Wyze Cam v4 comes with two built-in white spotlight LEDs (72 lumens) and four IR LEDs, providing enhanced color night vision and clear video quality in low-light settings without the need for an external spotlight.
What is included in the Wyze Cam v4 Outdoor Bundle?The Wyze Cam v4 Outdoor Bundle includes the Wyze Cam v4, an outdoor power adapter, and a 128GB microSD card for continuous 24/7 local recording. It also features enhanced color night vision and a motion-activated spotlight.
Are Wyze spotlight solutions compatible with smart home systems?Yes, Wyze spotlight solutions work seamlessly with Alexa, Google Assistant, and IFTTT, allowing for easy smart home integration and automation.
What are the benefits of using a motion-activated spotlight with Wyze cameras?Motion-activated spotlights provide enhanced night vision by illuminating only when activity is detected, conserving energy, reducing light pollution, and ensuring clear, detailed surveillance footage.
What is the video resolution of the Wyze Cam v4?The Wyze Cam v4 offers 2.5K QHD (2560x1440) video resolution, delivering crisp and detailed footage both day and night.
How much local storage is supported by Wyze Cam v4 bundles?Wyze Cam v4 bundles include a 128GB microSD card and support up to 512GB microSD cards for continuous local recording.
Are Wyze spotlight kits and cameras suitable for outdoor use?Yes, both the Wyze Cam v3 Spotlight Kit and Wyze Cam v4 are IP65 rated, making them weather-resistant and ideal for outdoor security in various weather conditions.
What are the key features of the Wyze Cam v4 compared to the Wyze Cam v3?Can the Wyze Cam v4 be used outdoors without additional accessories?What is the warranty period for the Wyze Cam v3 Spotlight Kit?
