Best 2K Resolution Floodlight Cameras with Customizable Detection Zones
Looking for a powerful floodlight camera that offers crystal-clear 2K resolution and customizable detection zones? Whether you want to secure your driveway, backyard, or front porch, Wyze offers top-tier floodlight cameras designed to illuminate your property while providing smart, AI-powered security features. Below, we explore the best Wyze floodlight cameras that combine high-resolution video, wide-angle views, and intelligent motion detection to keep your home safe day and night.
Wyze Cam Floodlight v2: Brilliant 2K Video with Smart Detection
Brighten your outdoor spaces with Wyze Cam Floodlight v2
The Wyze Cam Floodlight v2 is a standout choice for those seeking vibrant 2K video quality paired with a wide 160° field of view. This camera floods your property with 2800 lumens of adjustable LED light, ensuring clear visibility even in the darkest conditions. Its color night vision lets you see more detail at night, making it easier to identify visitors or potential intruders.
Key Features:
- 2K HD Video Resolution: Capture crisp, detailed footage that reveals every important detail.
- 160° Wide-Angle View: Double the visibility compared to previous models, covering more area with fewer blind spots.
- Customizable Detection Zones: Tailor motion alerts to specific areas, so you only get notified about what matters most.
- AI-Powered Light Control: Motion-activated LEDs with Ambient Light Mode provide constant low-level lighting that brightens when motion is detected.
- 24/7 Local Recording: Supports microSD cards up to 256GB for continuous local video storage without subscription fees.
- Two-Way Talk & 105dB Siren: Communicate with visitors or deter unwanted guests with a loud siren.
- Dusk-to-Dawn Automation & IP65 Weather Resistance: Automatically turns on/off based on ambient light and withstands harsh weather conditions.
- Smart Assistant Integration: Works seamlessly with Alexa, Google Assistant, and IFTTT for voice control and automation.
This model is perfect for homeowners who want a reliable, high-quality floodlight camera with flexible detection zones and easy DIY installation.
Wyze Cam Floodlight Pro: Ultra-Wide 180° View with 2.5K QHD Clarity
Protect your entire yard with the ultra-wide Wyze Cam Floodlight Pro
For those who want the ultimate in floodlight camera technology, the Wyze Cam Floodlight Pro offers a 180° ultra-wide field of view and stunning 2.5K QHD video resolution. This camera uses advanced onboard AI computer vision to detect motion intelligently, turning on its powerful 3000 lumen LED lights only for selected objects like people and vehicles.
Key Features:
- 2.5K QHD Video Resolution: See your property in ultra-clear Quad HD, day or night.
- 180° Ultra-Wide Field of View: Covers more ground with fewer blind spots, ideal for large yards or multiple entry points.
- AI-Powered Motion Detection: Vision AI detects and distinguishes people, vehicles, and other objects for precise alerts.
- Adjustable & Dimmable LEDs: Three independently articulating floodlight panels let you customize light coverage and brightness.
- Motion-Activated Voice Deterrence & 105dB Siren: Play voice prompts and sound a loud siren to deter intruders effectively.
- Dual-Band Wi-Fi Support: Connects easily to both 2.4 GHz and 5 GHz networks for faster, more reliable streaming.
- Dusk-to-Dawn Automation & IP65 Weatherproofing: Automatically adjusts lighting based on time and withstands all weather conditions.
- 24/7 Local Recording: Supports up to 256GB microSD cards for continuous recording.
- Easy DIY Installation: Replace your existing floodlight in under 20 minutes with no electrician needed.
The Floodlight Pro is ideal for users who want the most comprehensive coverage and the sharpest video quality with smart, customizable detection zones.
Wyze Cam Floodlight Plug-In Mount: Simplify Your Installation
If you want to avoid the hassle and cost of installing a junction box, the Wyze Cam Floodlight Plug-In Mount is the perfect accessory. Compatible with Wyze Cam Floodlight v1, v2, and Floodlight Pro, this plug-and-play solution lets you power your floodlight camera through a standard outdoor outlet.
Key Features:
- Easy Plug-In Installation: No electrician or junction box required, making setup quick and affordable.
- 20 ft Power Cord: Provides flexible placement options around your home.
- Outdoor Safe & Weather Resistant: Rated for outdoor use with a durable design.
- Compatible with All Wyze Floodlight Cameras: Works seamlessly with v1, v2, and Pro models.
- Complete Mounting Kit Included: Comes with mounting screws, foam tape, and a quick start guide for hassle-free setup.
This mount is perfect for renters or anyone with an accessible outdoor power outlet who wants a simple, no-fuss floodlight camera installation.
Why Choose Wyze Floodlight Cameras with Customizable Detection Zones?
"Custom detection zones mean you only get alerts that matter, reducing false alarms and increasing your peace of mind."
Wyze floodlight cameras stand out by combining high-resolution video with intelligent AI-powered detection that you can customize. This means you can focus on monitoring specific areas like your driveway, front porch, or backyard, without being overwhelmed by irrelevant motion alerts from passing cars or animals.
Both the Wyze Cam Floodlight v2 and Floodlight Pro offer this feature, along with powerful LED lighting, weatherproof designs, and easy integration with smart home assistants. Whether you want a budget-friendly 2K camera or a premium 2.5K QHD model with ultra-wide coverage, Wyze has you covered.
Summary of 2K Resolution Floodlight Cameras with Custom Detection
Product | Resolution | Field of View | LED Brightness | AI Detection | Custom Zones | Price |
Wyze Cam Floodlight v2 | 2K (1440p) | 160° | 2800 lumens | Yes | Yes | $89.98 |
Wyze Cam Floodlight Pro | 2.5K QHD | 180° | 3000 lumens | Advanced AI | Yes | $149.98 |
Wyze Cam Floodlight Plug-In Mount | N/A | N/A | N/A | N/A | N/A | $19.98 |
Enhance Your Setup with Bundles
For added convenience, Wyze offers bundles combining the Floodlight Pro or Floodlight v2 with the Plug-In Mount, providing a complete, easy-to-install security lighting solution.
Protect your home with Wyze’s advanced 2K resolution floodlight cameras featuring customizable detection zones. Enjoy peace of mind with crystal-clear video, smart AI detection, and powerful lighting that keeps your property safe and well-lit.
What are the benefits of Wyze floodlight cameras with customizable detection zones?
Wyze floodlight cameras with customizable detection zones allow you to focus motion alerts on specific areas, such as your driveway, front porch, or backyard. This reduces false alarms from irrelevant motion, like passing cars or animals, and ensures you only receive notifications that matter, increasing your peace of mind.What is the video resolution of Wyze Cam Floodlight v2?
The Wyze Cam Floodlight v2 offers 2K HD video resolution (1440p), providing crisp, detailed footage that helps you clearly identify people, vehicles, and other important details on your property.How wide is the field of view on Wyze Cam Floodlight v2?
Wyze Cam Floodlight v2 features a 160° wide-angle field of view, which covers more area and reduces blind spots compared to previous models.What makes Wyze Cam Floodlight Pro different from the v2 model?
Wyze Cam Floodlight Pro offers a higher 2.5K QHD video resolution and an ultra-wide 180° field of view. It also features advanced onboard AI computer vision for more precise motion detection, three independently adjustable LED panels, dual-band Wi-Fi support, and motion-activated voice deterrence.Can Wyze floodlight cameras record video 24/7 without a subscription?
Yes, both Wyze Cam Floodlight v2 and Floodlight Pro support 24/7 local recording with microSD cards up to 256GB, allowing continuous video storage without the need for a subscription.Are Wyze floodlight cameras weatherproof?
Yes, Wyze floodlight cameras are rated IP65 weather resistant, making them suitable for outdoor use in various weather conditions.Do Wyze floodlight cameras work with smart home assistants?
Yes, Wyze floodlight cameras integrate seamlessly with Alexa, Google Assistant, and IFTTT, allowing for voice control and smart home automation.What is the Wyze Cam Floodlight Plug-In Mount and who is it for?
The Wyze Cam Floodlight Plug-In Mount is an accessory that allows you to power your Wyze floodlight camera through a standard outdoor outlet, eliminating the need for a junction box or electrician. It's ideal for renters or anyone seeking a simple, no-fuss installation.Which Wyze floodlight cameras are compatible with the Plug-In Mount?
The Plug-In Mount is compatible with Wyze Cam Floodlight v1, v2, and Floodlight Pro models.How bright are the LED lights on Wyze floodlight cameras?
Wyze Cam Floodlight v2 features 2800 lumens of adjustable LED light, while the Floodlight Pro offers even brighter 3000 lumens with three independently articulating panels for customizable coverage.Is DIY installation possible with Wyze floodlight cameras?
Yes, Wyze floodlight cameras are designed for easy DIY installation. The Floodlight Pro, for example, can replace your existing floodlight in under 20 minutes without the need for an electrician.Do Wyze floodlight cameras have two-way audio and a siren?
Yes, both Wyze Cam Floodlight v2 and Floodlight Pro include two-way talk functionality and a 105dB siren to communicate with visitors or deter unwanted guests.Are there bundle options available for Wyze floodlight cameras?
Yes, Wyze offers bundles that combine the Floodlight Pro or Floodlight v2 with the Plug-In Mount, providing a complete and easy-to-install security lighting solution.
