Extend Your Wyze Cam Setup with the 20ft USB Extension Cable
If you're looking to avoid drilling extra holes and want more flexibility in placing your Wyze Cam, the
Wyze Cam USB Extension Cable - 20ft is the perfect accessory. This cable extends your camera's reach by an additional 20 feet, allowing you to position your Wyze Cam exactly where you need it without the hassle of rewiring or damaging your walls.
Why Choose the Wyze Cam USB Extension Cable - 20ft?
- Compatibility: Works seamlessly with Wyze Cam v2, v3, v4, Wyze Cam v3 Pro, Wyze Cam Pan v2/v3, Wyze Cam OG Standard, and Wyze Cam OG Telephoto.
- Length: A generous 20-foot length gives you the freedom to place your camera far from power outlets.
- Easy Installation: Simply plug in to extend your existing USB cable—no tools or drilling required.
- Affordable: Priced at just $7.99, it’s a cost-effective solution to enhance your home security setup.
Say goodbye to short cables and enjoy the freedom of flexible camera placement with this reliable extension.
Enhance Your Home Security with Wyze Cam v4
Pair your extended USB cable with the
Wyze Cam v4 for a powerful security solution. This camera offers advanced features that make it a top choice for indoor and outdoor surveillance.
Wyze Cam v4 Key Features:
- Video Quality: Crisp 2.5K QHD (2560x1440) resolution with 8x digital zoom.
- Night Vision: Equipped with 4 IR LEDs and 2 white spotlight LEDs for color night vision.
- Field of View: Wide 115.8° diagonal field of view to cover more area.
- Weather Resistance: Rated IP65, suitable for outdoor use.
- Connectivity: Supports 2.4 GHz Wi-Fi and Wi-Fi 6 for stable streaming.
- Smart Features: Two-way talk, built-in siren, noise and echo cancellation.
- Mounting Options: Versatile mounting including stand, wall, ceiling, and magnetic adhesive mounts.
- Power: Comes with a 6-foot flat micro USB to USB-A cable, which can be extended using the 20ft USB extension cable.
This camera is perfect for users who want a high-quality, flexible security camera setup without complicated wiring.
Complete Your Security Setup with Wyze Bundles
For those looking to build a comprehensive home security system, consider the
Whole Home Security Starter Kit or the
Whole Home Security Enhanced Kit. Both kits include the Wyze Cam v4 and other smart security devices, offering a complete solution.
Whole Home Security Starter Kit Includes:
- Wyze Cam v4 (available in White, Grey, or Black)
- Wyze Video Doorbell v2
- Wyze Home Monitoring Starter Kit
Whole Home Security Enhanced Kit Includes:
- Wyze Cam v4 (multiple color options)
- Wyze Cam Floodlight v2 (White or Black)
These bundles provide everything you need for robust home protection, and the 20ft USB extension cable can help you position your cameras optimally without extra drilling.
Practical Benefits of Using the 20ft USB Extension Cable
- Avoid Drilling: Extend your camera’s power cable without damaging walls or door frames.
- Flexible Placement: Position your Wyze Cam in the best spot for coverage, even if power outlets are far away.
- Neat Installation: Keep cables tidy and out of sight by routing them along walls or ceilings.
- Cost-Effective Upgrade: At under $8, it’s an inexpensive way to enhance your existing Wyze Cam setup.
Alt text: Homeowner installing Wyze Cam with USB extension cable for flexible placement
Summary
The
Wyze Cam USB Extension Cable - 20ft is an essential accessory for anyone wanting to extend their Wyze Cam’s reach without the hassle of drilling extra holes. Compatible with a wide range of Wyze cameras, it offers flexibility, ease of installation, and affordability. Pair it with the
Wyze Cam v4 or one of the comprehensive Wyze security kits to create a smart, adaptable home security system tailored to your needs.
What is the Wyze Cam USB Extension Cable - 20ft used for?
The Wyze Cam USB Extension Cable - 20ft is designed to extend the reach of your Wyze Cam by an additional 20 feet, allowing you to place your camera farther from power outlets without the need for drilling or rewiring.Which Wyze Cam models are compatible with the 20ft USB Extension Cable?
The 20ft USB Extension Cable is compatible with Wyze Cam v2, v3, v4, Wyze Cam v3 Pro, Wyze Cam Pan v2/v3, Wyze Cam OG Standard, and Wyze Cam OG Telephoto.How do I install the Wyze Cam USB Extension Cable?
Installation is simple—just plug the extension cable into your existing Wyze Cam USB cable. No tools, drilling, or complicated setup is required.Can I use the 20ft USB Extension Cable outdoors with my Wyze Cam v4?
Yes, the Wyze Cam v4 is rated IP65 for weather resistance, making it suitable for outdoor use. The 20ft USB Extension Cable allows you to position your camera outdoors even if the nearest power outlet is far away.What are the benefits of using a 20ft USB extension cable with my Wyze Cam?
Using a 20ft USB extension cable gives you flexible camera placement, helps avoid drilling holes, keeps cables tidy, and is a cost-effective way to enhance your home security setup.How much does the Wyze Cam USB Extension Cable - 20ft cost?
The Wyze Cam USB Extension Cable - 20ft is affordably priced at just $7.99.What features does the Wyze Cam v4 offer for home security?
The Wyze Cam v4 features 2.5K QHD video resolution, 8x digital zoom, color night vision with IR and spotlight LEDs, a 115.8° field of view, IP65 weather resistance, two-way talk, built-in siren, noise and echo cancellation, and versatile mounting options.Can I use the 20ft USB extension cable with Wyze security bundles?
Yes, the 20ft USB extension cable can be used with Wyze security bundles, such as the Whole Home Security Starter Kit and Enhanced Kit, to help you position your cameras optimally without extra drilling.What is included in the Wyze Whole Home Security Starter Kit?
The Whole Home Security Starter Kit includes a Wyze Cam v4 (available in White, Grey, or Black), Wyze Video Doorbell v2, and the Wyze Home Monitoring Starter Kit.What is included in the Wyze Whole Home Security Enhanced Kit?
The Whole Home Security Enhanced Kit includes a Wyze Cam v4 (multiple color options) and a Wyze Cam Floodlight v2 (available in White or Black).
