20ft Wyze Cam USB Extension Cable for Baby Monitor Setup
Power Extension Solutions for Wyze Cam as a Baby Monitor
When using your Wyze Cam as a baby monitor down the hall, having the right power extension is essential to ensure continuous monitoring without interruptions. The Wyze Cam USB Extension Cable - 20ft is the perfect accessory to extend your camera’s reach, allowing you to place the camera exactly where you need it for optimal baby monitoring.
Wyze Cam USB Extension Cable - 20ft: Extend Your Monitoring Range
Key Features:
  • Length: 20 feet of USB extension cable to overcome short cable limitations.
  • Compatibility: Works seamlessly with Wyze Cam v2, v3, v4, Wyze Cam v3 Pro, Wyze Cam Pan v2/v3, and original Wyze Cam models.
  • Convenience: Enables you to position your Wyze Cam down the hall or in any hard-to-reach spot without worrying about power outlet proximity.
  • Affordable: Priced at $7.99, it’s a cost-effective solution to extend your camera’s power supply.
Say goodbye to the hassle of relocating power outlets or using unreliable extension cords. This cable ensures your Wyze Cam stays powered continuously, making it ideal for baby monitoring where uninterrupted video feed is critical.
Why Choose Wyze Cam v4 for Baby Monitoring?
While the USB extension cable is a vital accessory, pairing it with a high-quality camera like the Wyze Cam v4 Outdoor Bundle enhances your baby monitoring experience.
Wyze Cam v4 Highlights:
  • Crystal-clear 2.5K QHD Resolution: Capture every detail with stunning clarity.
  • Enhanced Color Night Vision: See your baby clearly even in low light or at night.
  • Motion-Activated Spotlight: Adds extra visibility and security.
  • 24/7 Local Recording: Continuous monitoring with local storage options.
  • Wi-Fi 6 Support: Stronger, more reliable connection even at longer distances.
  • Smart Alerts: Motion and sound detection notify you instantly on your phone.
  • Compatibility: Works with Alexa and Google Assistant for hands-free control.
The Wyze Cam v4’s advanced features make it an excellent choice for parents who want peace of mind while monitoring their baby from another room.
Mother monitoring baby with Wyze Cam Keep a watchful eye on your baby with Wyze Cam and extended power options.
Setting Up Your Wyze Cam Baby Monitor Down the Hall
1. Connect the Wyze Cam to the USB Extension Cable: Plug the camera’s USB power cable into the 20ft extension cable. 2. Position the Camera: Place the camera in the baby’s room or hallway where it has a clear view. 3. Plug into Power Outlet: Use the extension cable to reach a distant power outlet without moving furniture or using unsafe power strips. 4. Configure the Camera: Use the Wyze app to set up motion zones, sound alerts, and night vision settings tailored for baby monitoring. This setup ensures your Wyze Cam remains powered and connected, providing reliable video and audio monitoring.
Summary
For parents looking to use Wyze Cam as a baby monitor down the hall, the Wyze Cam USB Extension Cable - 20ft is an essential accessory that offers flexibility and peace of mind. Pair it with the Wyze Cam v4 Outdoor Bundle for superior video quality, night vision, and smart alerts, ensuring you never miss a moment.
FeatureWyze Cam USB Extension Cable - 20ftWyze Cam v4 Outdoor Bundle
Product TypeAccessorySecurity Camera Bundle
Price$7.99$69.99
CompatibilityWyze Cam v2/v3/v4, v3 Pro, Pan v2/v3, OG Standard, OG TelephotoWyze Cam v4 (Black, Grey, White)
Cable Length20 ft6 ft (micro USB to USB-A cable included)
PurposeExtends USB cable length for Wyze camerasOutdoor security camera with accessories
Included Items20ft USB extension cable1x Wyze Cam v4, 1x Wyze Outdoor Power Adapter, 1x Wyze MicroSD Card 128GB
Video ResolutionN/A2.5K QHD (2560x1440)
Night VisionN/AEnhanced Color Night Vision with motion-activated spotlight
Power AdapterN/AWyze Outdoor Power Adapter included
Local StorageN/AmicroSD card 128GB included
Wi-Fi SupportN/AWi-Fi 6 support
Alexa & Google Assistant CompatibleN/AYes
Weather ResistanceN/AIP65
Return Policy30-day hassle-free returns30-day hassle-free returns
What is the best way to power my Wyze Cam when using it as a baby monitor down the hall?The Wyze Cam USB Extension Cable - 20ft is the ideal solution for powering your Wyze Cam as a baby monitor down the hall. It allows you to extend your camera’s reach to any location, ensuring continuous monitoring without interruptions.
Which Wyze Cam models are compatible with the 20ft USB Extension Cable?The 20ft USB Extension Cable is compatible with Wyze Cam v2, v3, v4, Wyze Cam v3 Pro, Wyze Cam Pan v2/v3, and the original Wyze Cam models.
How long is the Wyze Cam USB Extension Cable and what are its benefits?The Wyze Cam USB Extension Cable is 20 feet long, allowing you to place your camera in hard-to-reach spots or down the hall from a power outlet. This ensures your camera stays powered for uninterrupted baby monitoring.
Is the Wyze Cam USB Extension Cable a cost-effective solution?Yes, the Wyze Cam USB Extension Cable is affordably priced at $7.99, making it a budget-friendly way to extend your camera’s power supply without the need for additional outlets or unreliable extension cords.
Why is the Wyze Cam v4 recommended for baby monitoring?The Wyze Cam v4 is recommended for baby monitoring because it offers 2.5K QHD resolution, enhanced color night vision, motion-activated spotlight, 24/7 local recording, Wi-Fi 6 support, and smart alerts. These features provide clear, reliable, and secure monitoring for your baby.
Can I use the Wyze Cam v4 with smart home assistants?Yes, the Wyze Cam v4 is compatible with Alexa and Google Assistant, allowing for hands-free control and integration with your smart home setup.
How do I set up my Wyze Cam as a baby monitor using the USB extension cable?To set up your Wyze Cam as a baby monitor, connect the camera’s USB power cable to the 20ft extension cable, position the camera in the desired location, plug the extension cable into a power outlet, and configure the camera settings in the Wyze app for motion zones, sound alerts, and night vision.
What are the advantages of using a USB extension cable over a standard power strip for Wyze Cam?Using the Wyze Cam USB Extension Cable is safer and more reliable than standard power strips or extension cords. It ensures a stable power connection, reduces the risk of tripping hazards, and allows you to position your camera exactly where you need it for optimal baby monitoring.
Can you explain how to set up the Wyze Cam with the USB extension cable for baby monitoring?What are the key features of the Wyze Cam v4 that make it suitable for baby monitoring?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Cam or accessories?
