Extend Your Wyze Cam Setup with the 20ft USB Extension Cable
If you're looking to install your Wyze Cam near ceiling beams or in hard-to-reach places, the
Wyze Cam USB Extension Cable - 20ft is the perfect accessory to give you the freedom and flexibility you need. This 20-foot cable extends the reach of your Wyze Cam, allowing you to position your camera exactly where you want it without worrying about power outlet proximity.
Key Features of the Wyze Cam USB Extension Cable - 20ft
- Compatibility: Works seamlessly with Wyze Cam v2, v3, v4, Wyze Cam v3 Pro, Wyze Cam Pan v2/v3, Wyze Cam OG Standard, and Wyze Cam OG Telephoto.
- Length: A generous 20 feet of extension cable to cover long distances, ideal for mounting near ceiling beams or other elevated spots.
- Ease of Use: Simple plug-and-play design that extends your camera’s USB power cable without any complicated setup.
- Durability: Designed to maintain stable power delivery over the extended length, ensuring your Wyze Cam stays powered continuously.
Say goodbye to short cables and enjoy the freedom of a 20ft cable to place your Wyze Cam exactly where you need it.
Enhance Your Security with Wyze Cam v4 Outdoor Bundle
For those who want to combine extended cable reach with top-tier camera performance, the
Wyze Cam v4 Outdoor Bundle is an excellent choice. This bundle includes the Wyze Cam v4, which offers crystal-clear 2.5K QHD resolution and enhanced color night vision, perfect for outdoor monitoring near ceiling beams or other elevated areas.
Why Choose Wyze Cam v4 Outdoor Bundle?
- Superior Image Quality: Capture stunning 2.5K Quad HD video with vibrant colors and wide dynamic range.
- Enhanced Color Night Vision: See more details at night with color night vision that outperforms traditional infrared.
- Motion-Activated Spotlight: Automatically lights up when motion is detected, deterring unwanted visitors.
- Wi-Fi 6 Support: Enjoy a stronger, more reliable connection even at greater distances.
- 24/7 Local Recording: Continuous recording with a built-in microSD card slot for complete coverage.
- Smart Alerts: Receive notifications for motion, sound, smoke, and CO alarms.
- Outdoor Ready: Weather-resistant design paired with the Wyze Outdoor Power Adapter (included in the bundle) for reliable outdoor use.
This bundle is perfect for mounting near ceiling beams outdoors, where you can use the 20ft USB extension cable to power the camera conveniently.
Alt text: Wyze Cam v4 mounted near ceiling beams outdoors with extended cable
Whole Home Security Starter Kit: Comprehensive Protection with Flexibility
If you want a complete security solution that includes the Wyze Cam v4 and the convenience of extended cable options, the
Whole Home Security Starter Kit is a great pick. This kit bundles the Wyze Cam v4 with other essential security devices, providing a robust system for your home.
Starter Kit Highlights:
- Includes 1x Wyze Cam v4, perfect for indoor or outdoor use.
- Compatible with USB extension cables like the 20ft Wyze Cam USB Extension Cable for flexible installation.
- Available in multiple colors (White, Grey, Black) to match your home décor.
- Ideal for mounting near ceiling beams or other strategic locations to maximize coverage.
Why Use a 20ft USB Extension Cable with Your Wyze Cam?
Mounting your Wyze Cam near ceiling beams or in elevated locations often means power outlets are out of reach. The 20ft USB extension cable solves this problem by:
- Allowing you to place your camera in the optimal position for the best field of view.
- Keeping your installation neat and organized without unsightly power adapters dangling.
- Ensuring continuous power supply without interruption, critical for 24/7 monitoring.
Summary
For anyone searching for a **20 ft USB extension
What Wyze Cam models are compatible with the 20ft USB Extension Cable?
The 20ft Wyze Cam USB Extension Cable is compatible with Wyze Cam v2, v3, v4, Wyze Cam v3 Pro, Wyze Cam Pan v2/v3, Wyze Cam OG Standard, and Wyze Cam OG Telephoto.How long is the Wyze Cam USB Extension Cable?
The Wyze Cam USB Extension Cable is 20 feet long, making it ideal for mounting your camera near ceiling beams or in hard-to-reach places.Is the Wyze Cam USB Extension Cable easy to install?
Yes, the Wyze Cam USB Extension Cable features a simple plug-and-play design, allowing you to easily extend your camera’s USB power cable without any complicated setup.Does the 20ft USB extension cable provide stable power to my Wyze Cam?
Yes, the 20ft USB extension cable is designed to maintain stable power delivery over the extended length, ensuring your Wyze Cam stays powered continuously.Can I use the 20ft USB extension cable for outdoor Wyze Cam installations?
Yes, the 20ft USB extension cable is perfect for outdoor installations, especially when paired with weather-resistant Wyze Cam models and the Wyze Outdoor Power Adapter.What are the benefits of using a 20ft USB extension cable with my Wyze Cam?
Using a 20ft USB extension cable allows you to place your Wyze Cam in the optimal position for the best field of view, keeps your installation neat and organized, and ensures a continuous power supply for 24/7 monitoring.What is included in the Wyze Cam v4 Outdoor Bundle?
The Wyze Cam v4 Outdoor Bundle includes the Wyze Cam v4 with 2.5K QHD resolution, enhanced color night vision, motion-activated spotlight, Wi-Fi 6 support, 24/7 local recording, smart alerts, and a weather-resistant design with the Wyze Outdoor Power Adapter.Does the Wyze Cam v4 support color night vision?
Yes, the Wyze Cam v4 features enhanced color night vision, allowing you to see more details at night compared to traditional infrared cameras.What is included in the Whole Home Security Starter Kit?
The Whole Home Security Starter Kit includes one Wyze Cam v4 and other essential security devices, offering a comprehensive security solution for your home. It is compatible with the 20ft Wyze Cam USB Extension Cable for flexible installation.Are there color options available for the Wyze Cam v4 in the Starter Kit?
Yes, the Wyze Cam v4 in the Whole Home Security Starter Kit is available in White, Grey, and Black to match your home décor.
