20ft Wyze Cam USB Extension Cable for Wide Backyard Coverage
Extend Your Wyze Cam Coverage with 20ft USB Extension Cable
If you want to cover a wide backyard with your Wyze Cam, having extra cable length is essential. The Wyze Cam USB extension cable 20ft is the perfect solution to extend your camera’s reach without compromising power or connectivity. This allows you to position your Wyze Cam v4 or outdoor bundles exactly where you need them for optimal security coverage.
Wyze Cam v4: Superior Clarity and Flexible Placement
Crystal Clear 2.5K QHD Resolution
Wyze Cam v4 delivers stunning 2.5K Quad High Definition video, capturing every detail in your backyard with exceptional clarity. Whether it’s day or night, the camera’s enhanced color night vision ensures vibrant, true-to-life footage even in low-light conditions.
Weather-Resistant for Outdoor Use
Rated IP65 for weather resistance, Wyze Cam v4 can withstand rain, wind, and dust, making it ideal for outdoor backyard monitoring. With the 20ft USB extension cable, you can easily place the camera far from power outlets, covering wider areas without hassle.
Smart Features for Enhanced Security
  • Auto-zoom with AI Smart Focus tracks important activity while keeping the bigger picture in view.
  • Motion and sound detection send instant alerts to your phone.
  • Two-way talk with advanced audio coding lets you communicate clearly through the camera.
  • Motion-activated spotlight and 99 dB siren deter intruders effectively.
Easy Setup and Mounting
The screw-free magnetic mount and Bluetooth® setup make installation quick and tool-free. The extended cable length means you can mount the camera in the perfect spot without worrying about proximity to power sources. Backyard security with Wyze Cam Alt text: Wyze Cam monitoring a wide backyard with extended cable
Wyze Cam v4 Outdoor Bundle: Complete Outdoor Security Solution
What’s Included
  • Wyze Cam v4 with 2.5K QHD resolution and enhanced color night vision
  • Wyze Outdoor Power Adapter for reliable wired power
  • 128GB Wyze MicroSD Card for 24/7 local recording
Features Tailored for Outdoor Use
  • Wi-Fi 6 support ensures a stronger, more reliable connection even at greater distances, perfect for large backyards.
  • Motion detection zones allow you to customize alerts for specific areas, reducing false alarms.
  • Smoke and CO alerts add an extra layer of safety by notifying you immediately of potential hazards.
  • Wide Dynamic Range (WDR) delivers vibrant colors and balanced lighting in all conditions.
Extended Cable Compatibility
The 20ft USB extension cable complements this bundle perfectly, enabling you to position the camera far from power outlets while maintaining continuous power and recording.
Whole Home Security Starter Kit: Versatile and Ready to Use
What’s Inside
  • 1x Wyze Cam v4 (available in White, Grey, or Black)
  • 1x Wyze Video Doorbell v2 for front door monitoring
  • 1x Wyze Home Monitoring Starter Kit
Why Choose This Kit?
This starter kit is designed for comprehensive home security, including outdoor coverage with the Wyze Cam v4. The extended USB cable option allows you to place the camera in hard-to-reach backyard locations, ensuring no blind spots.
Key Benefits
  • Easy integration with other Wyze devices for a seamless security system
  • Color night vision and motion detection for reliable monitoring day and night
  • Flexible mounting options with magnetic base and extended cable support
Pro Tip: Using a 20ft USB extension cable with your Wyze Cam v4 or Outdoor Bundle is a smart way to maximize your backyard coverage without compromising on power or video quality. It gives you the freedom to install your camera exactly where it’s needed most.
Summary
For wide backyard coverage, the Wyze Cam v4 and Wyze Cam v4 Outdoor Bundle are your best choices, offering high-resolution video, weather resistance, and smart features. Pairing these with a 20ft USB extension cable ensures you can extend your camera’s reach effortlessly, covering every corner of your property with confidence.
FeatureWyze Cam v4Wyze Cam v4 Outdoor BundleWhole Home Security Starter Kit
Price$100.00$69.99$155.95
Included ItemsWyze Cam v4Wyze Cam v4, Wyze Outdoor Power Adapter, 128GB MicroSD CardWyze Cam v4, Wyze Video Doorbell v2, Wyze Home Monitoring Starter Kit
Resolution2.5K QHD (2560x1440)2.5K QHD (2560x1440)2.5K QHD (2560x1440)
Color Night VisionYesYesYes
Night Vision TypeEnhanced Color Night VisionEnhanced Color Night VisionEnhanced Color Night Vision
Motion-Activated SpotlightYesYesYes
SirenYesYesYes
AudioEnhanced Two-Way TalkEnhanced Two-Way TalkEnhanced Two-Way Talk
Weather ResistanceIP65IP65IP65
Wi-Fi Support2.4 GHz Wi-Fi, Wi-Fi 62.4 GHz Wi-Fi, Wi-Fi 62.4 GHz Wi-Fi, Wi-Fi 6
Local Storage SupportmicroSD card up to 512 GBmicroSD card (128GB included)microSD card up to 512 GB (assumed with Cam v4)
Cloud StorageAvailable with subscriptionAvailable with subscriptionAvailable with subscription
Smart Assistant CompatibilityAlexa, Google Assistant, IFTTTAlexa, Google AssistantAlexa, Google Assistant
Mounting OptionsStand, Wall, Ceiling, MagneticStand, Wall, Ceiling, MagneticWyze Cam v4 mounting options (assumed same as Cam v4)
Additional Devices IncludedNoneOutdoor Power Adapter, MicroSD CardVideo Doorbell v2, Home Monitoring Starter Kit
Use CaseIndoor/Outdoor (wired)Outdoor-ready bundleWhole home security solution
Warranty1 Year1 YearNot specified
What is the benefit of using a 20ft USB extension cable with Wyze Cam v4?A 20ft USB extension cable allows you to position your Wyze Cam v4 farther from power outlets, making it easier to cover wide backyards or hard-to-reach areas without compromising power or video quality.
Is the Wyze Cam v4 suitable for outdoor use?Yes, the Wyze Cam v4 is rated IP65 for weather resistance, making it ideal for outdoor use. It can withstand rain, wind, and dust, ensuring reliable performance in various weather conditions.
What video quality does the Wyze Cam v4 offer?The Wyze Cam v4 delivers 2.5K Quad High Definition (QHD) video, providing crystal clear footage with enhanced color night vision for vibrant, true-to-life images even in low-light conditions.
What smart security features are included with Wyze Cam v4?Wyze Cam v4 includes auto-zoom with AI Smart Focus, motion and sound detection with instant alerts, two-way talk with advanced audio coding, a motion-activated spotlight, and a 99 dB siren to deter intruders.
How easy is it to install the Wyze Cam v4?Installation is quick and tool-free thanks to the screw-free magnetic mount and Bluetooth® setup. The extended cable length also allows flexible placement without worrying about proximity to power sources.
What comes with the Wyze Cam v4 Outdoor Bundle?The Wyze Cam v4 Outdoor Bundle includes a Wyze Cam v4 with 2.5K QHD resolution, a Wyze Outdoor Power Adapter for reliable wired power, and a 128GB Wyze MicroSD Card for 24/7 local recording.
Does the Wyze Cam v4 Outdoor Bundle support Wi-Fi 6?Yes, the Wyze Cam v4 Outdoor Bundle supports Wi-Fi 6, ensuring a stronger and more reliable connection even at greater distances, which is perfect for large backyards.
Can I customize motion detection zones with Wyze Cam v4?Yes, Wyze Cam v4 allows you to set up motion detection zones, so you can receive alerts only for specific areas and reduce false alarms.
What is included in the Whole Home Security Starter Kit?The Whole Home Security Starter Kit includes one Wyze Cam v4 (available in White, Grey, or Black), one Wyze Video Doorbell v2, and one Wyze Home Monitoring Starter Kit for comprehensive home security.
How does the 20ft USB extension cable improve home security coverage?The 20ft USB extension cable enables you to install your Wyze Cam v4 in hard-to-reach or distant locations, such as wide backyards, ensuring there are no blind spots in your security coverage.
Is the Wyze Cam v4 compatible with other Wyze devices?Yes, the Wyze Cam v4 easily integrates with other Wyze devices, allowing you to build a seamless and comprehensive home security system.
Does the Wyze Cam v4 support local video recording?Yes, the Wyze Cam v4 supports local video recording with a MicroSD card, and the Outdoor Bundle includes a 128GB Wyze MicroSD Card for 24/7 recording.
Can you tell me more about the features of the Wyze Cam v4?Is the Wyze Cam v4 easy to install in outdoor locations?Are there any discounts or promotions currently available for Wyze products?
