Long Lasting Outdoor LED String Lights for Garden Events
Create the perfect ambiance for your garden events with smart, durable, and energy-efficient LED lighting solutions. Whether you're hosting an intimate dinner or a lively party, these Wyze connected home products offer long-lasting performance, easy control, and weather-resistant features to illuminate your outdoor space beautifully.
Outdoor Power Solutions for LED String Lights
Wyze Plug Outdoor: Reliable Power Rain or Shine
Power your outdoor LED string lights effortlessly with the
Wyze Plug Outdoor, designed specifically for outdoor use. This smart plug is weather-resistant with an IP64 rating, ensuring it withstands rain, dust, and varying temperatures from -4°F to 120°F. It supports up to 15A max output with overload protection, making it perfect for powering multiple string lights or other garden event decorations.
- Dual outlets for versatile device connections
- App control for scheduling and remote on/off
- Energy monitoring to track power usage
- Voice control compatible with Alexa
- WiFi range up to 300 feet for flexible placement
With the Wyze Plug Outdoor, you can automate your garden lighting to turn on at sunset or off after your event, all from your smartphone.
Enhance your garden events with smart outdoor power solutions
Bright and Customizable LED Bulbs for Outdoor Ambiance
Wyze Bulb White: Crisp, Dimmable White Light
For classic, bright white lighting, the
Wyze Bulb White offers a wide color temperature range from warm 2700K to cool 6500K, perfect for setting the mood at any garden event. These bulbs are dimmable and provide up to 800 lumens of brightness with a 230° beam angle, ensuring broad and even light coverage.
- Long lifespan of 25,000 hours for lasting use
- Suitable for damp locations, ideal for covered outdoor areas
- Smart control via Wyze app with scheduling and automation
- Voice assistant compatibility with Alexa and Google Assistant
- Energy efficient at just 9.5 watts per bulb
Whether you want soft, warm lighting for a cozy evening or bright white light for a lively gathering, these bulbs adapt to your needs.
Wyze Bulb Color BR30: Vibrant Color-Changing Lighting
Add a splash of color to your garden events with the
Wyze Bulb Color BR30. This smart bulb fits standard recessed fixtures and offers 16 million colors to create dynamic lighting scenes. From romantic reds to festive blues and greens, customize your outdoor space with ease.
- Dimmable and color-changing for full mood control
- Wide lumen range from 30 to 950 lumens for versatile brightness
- Smart features including sleep routines, vacation mode, and music sync
Durable with 25,000 hours life expectancy
Works with Alexa, Google Assistant, and Bluetooth
Perfect for garden parties, weddings, or holiday celebrations, these bulbs bring your outdoor lighting to life with vibrant hues.
Create vibrant outdoor lighting with color-changing bulbs
Smart Control for Seamless Outdoor Lighting Experience
Wyze Switch: Turn Your Outdoor Lights Smart
Transform your existing outdoor string lights into smart lights with the
Wyze Switch. This connected home switch allows you to control your garden lighting from anywhere using the Wyze app. Set timers, schedules, or multi-tap actions to automate your lighting perfectly for any event.
- Remote control from anywhere via smartphone
- Multi-tap customization for different lighting scenes
- Integrates with other Wyze devices for a connected smart home
- Power loss recovery ensures your settings stay intact
- Available in 1-pack or 3-pack for multiple lighting zones
With the Wyze Switch, managing your outdoor LED string lights becomes effortless, enhancing your garden event experience.
Smart control for your outdoor lighting setup
Why Choose Wyze for Your Outdoor LED String Lights?
Wyze offers a comprehensive ecosystem of connected home products designed to make your outdoor lighting smart, reliable, and easy to manage. From weatherproof plugs to customizable bulbs and smart switches, Wyze ensures your garden events shine bright with minimal effort.
- Durability: Weather-resistant plugs and bulbs suitable for outdoor or damp locations
- Longevity: LED bulbs with up to 25,000 hours of life expectancy
- Smart Automation: Control lighting schedules, scenes, and energy usage remotely
- Voice Control: Compatible with Alexa and Google Assistant for hands-free operation
- Energy Efficiency: Low wattage bulbs and smart plugs help save power
Elevate your garden events with Wyze’s long-lasting outdoor LED lighting solutions that combine style, technology, and convenience.
Summary of Featured Products
Product | Key Features | Outdoor Suitability |
Wyze Plug Outdoor | Weatherproof, dual outlets, app & voice control | Yes, IP64 rated |
Wyze Bulb White | Dimmable, bright white light, damp location compatible | Suitable for covered outdoor |
Wyze Bulb Color BR30 | Color-changing, dimmable, 16 million colors | Suitable for damp locations |
Wyze Switch | Smart switch, remote control, multi-tap actions | Indoor/outdoor switch control |
Illuminate your garden events with Wyze’s smart, long-lasting LED lighting solutions and enjoy effortless control and stunning ambiance all night long.
What makes Wyze outdoor LED string lights ideal for garden events?
Wyze outdoor LED string lights are perfect for garden events because they offer smart, durable, and energy-efficient lighting solutions. With weather-resistant features, long-lasting performance, and easy app or voice control, you can create the perfect ambiance for any outdoor gathering.How does the Wyze Plug Outdoor enhance outdoor lighting setups?
The Wyze Plug Outdoor is designed for reliable outdoor power, featuring an IP64 weather-resistant rating, dual outlets, and support for up to 15A max output. It allows you to control your outdoor LED string lights remotely via the Wyze app, schedule on/off times, monitor energy usage, and use voice commands with Alexa.Are Wyze LED bulbs suitable for outdoor use?
Yes, Wyze Bulb White and Wyze Bulb Color BR30 are suitable for outdoor use in covered or damp locations. They are designed to withstand outdoor conditions, making them ideal for patios, porches, and garden event lighting.What are the benefits of using Wyze Bulb White for outdoor lighting?
Wyze Bulb White offers a wide color temperature range (2700K to 6500K), is dimmable, and provides up to 800 lumens of brightness. With a long lifespan of 25,000 hours, energy efficiency, and compatibility with smart controls and voice assistants, it’s perfect for creating the right mood at any garden event.How can I add color to my outdoor lighting with Wyze products?
The Wyze Bulb Color BR30 allows you to choose from 16 million colors and adjust brightness from 30 to 950 lumens. It’s perfect for adding vibrant, customizable lighting to garden parties, weddings, or holiday celebrations, and can be controlled via the Wyze app or voice assistants.Can I control my outdoor LED string lights remotely?
Yes, with Wyze smart products like the Wyze Plug Outdoor, Wyze Bulbs, and Wyze Switch, you can control your outdoor LED string lights remotely using the Wyze app. You can set schedules, automate lighting, and even use voice commands with Alexa or Google Assistant.What is the Wyze Switch and how does it work for outdoor lighting?
The Wyze Switch is a smart light switch that lets you control your outdoor string lights from anywhere using the Wyze app. It supports multi-tap customization for different lighting scenes, integrates with other Wyze devices, and retains your settings even after power loss.Are Wyze outdoor lighting solutions energy efficient?
Yes, Wyze outdoor lighting solutions are designed for energy efficiency. The LED bulbs use low wattage (as little as 9.5 watts per bulb), and the Wyze Plug Outdoor includes energy monitoring to help you track and manage power usage.Do Wyze outdoor lighting products work with voice assistants?
Absolutely. Wyze outdoor lighting products, including the Wyze Plug Outdoor and Wyze Bulbs, are compatible with Alexa and Google Assistant, allowing for convenient hands-free control of your garden lighting.How durable are Wyze outdoor lighting products?
Wyze outdoor lighting products are built for durability, with weather-resistant plugs (IP64 rated) and bulbs suitable for damp or covered outdoor locations. The LED bulbs have a long lifespan of up to 25,000 hours, ensuring reliable performance for years.
