Wyze Cameras and Smart Home Devices Overview
Discover the power of Wyze smart home technology with a range of innovative cameras and connected devices designed to enhance your home security and automation. Whether you want crystal-clear video surveillance, smart lighting control, or seamless integration with your smart home ecosystem, Wyze offers reliable, feature-packed products that fit your lifestyle and budget.
Wyze Cam v4 – Advanced 2.5K QHD Security Camera
Wyze Cam v4 is a top-tier security camera that delivers unmatched clarity and smart features for both indoor and outdoor use.
Key Features:
- Video Quality: Stunning 2.5K QHD (2560x1440) resolution with 8x digital zoom for detailed monitoring.
- Night Vision: Enhanced color night vision with 4 IR LEDs and 2 white spotlight LEDs (72 lumens) to illuminate dark areas.
- Field of View: Wide-angle coverage with 115.8° diagonal, 98.5° horizontal, and 53.1° vertical fields of view.
- Durability: Weather-resistant IP65 rating, operating in temperatures from -4°F to 122°F.
- Connectivity: Supports Wi-Fi 6 and Bluetooth 5.2 for fast, reliable connections.
- Audio: 99dB waterproof speaker, two-way talk with noise and echo cancellation, plus a built-in siren for alerts.
- Storage: Local microSD card support up to 512GB and optional cloud storage with subscription.
- Mounting Options: Versatile installation with stand, wall, ceiling, or magnetic mounts.
- Smart Integrations: Compatible with Alexa, Google Assistant, and IFTTT for voice control and automation.
Wyze Cam v4 is perfect for homeowners seeking a high-resolution, weatherproof camera with advanced night vision and smart home compatibility.
Wyze Cam v4 providing reliable home security day and night
Wyze Video Doorbell v2 – Clear 2K Wired Doorbell Camera
Upgrade your front door security with the Wyze Video Doorbell v2, offering crisp 2K video and essential smart features.
Highlights:
- Resolution: 2K (2048 x 1536) video with 20 FPS daytime and 15 FPS nighttime frame rates.
- Field of View: Ultra-wide 166.8° diagonal, 135° horizontal, and 103° vertical for comprehensive coverage.
- Night Vision: 6 IR LEDs (940 nm) for clear black-and-white night footage.
- Audio: Two-way communication with ECM microphone and 8Ω 1W speaker.
- Power: Requires 16V-24V AC wiring, suitable for most wired doorbell systems.
- Storage: Local microSD card support up to 256GB and cloud storage options.
- Weatherproof: IP65 rating ensures durability in harsh weather conditions.
- Smart Home Integration: Works with Alexa, Google Assistant, and IFTTT.
- Included Accessories: Comes with chime controller, wall plate, wedge for angled installation, and wiring kit.
This doorbell camera is ideal for anyone wanting detailed video, real-time alerts, and two-way talk to answer the door from anywhere.
Wyze Cam Floodlight v2 – Bright Outdoor Security with 2K Video
Illuminate and secure your outdoor spaces with the Wyze Cam Floodlight v2, combining powerful lighting and smart camera technology.
Features:
- Lighting: Two dimmable LED panels delivering 2800 lumens at 5000K color temperature.
- Video: 2K (2304 x 1296) resolution with 160° diagonal field of view.
- Color Night Vision: See full-color video even in low light conditions.
- Audio: Built-in microphone and speaker for two-way talk, plus a 105dB siren for deterrence.
- Automation: AI-powered light control and dusk-to-dawn automation for energy efficiency.
- Storage: Supports up to 256GB microSD card for continuous local recording.
- Connectivity: 2.4 GHz Wi-Fi compatible with Alexa, Google Assistant, and IFTTT.
- Weather Resistance: IP65 rated for reliable outdoor use in temperatures from -4°F to 140°F.
- Mounting: Wall or ceiling mount options for flexible installation.
Perfect for driveways, garages, and backyards, this floodlight camera offers bright illumination and smart security in one device.
Wyze Cam Floodlight v2 lighting up your outdoor security
Wyze Switch – Smart Light Control for Your Home
Transform your traditional lighting into smart lighting with the Wyze Switch, enabling remote control and automation.
Benefits:
- Smart Control: Turn lights on/off from anywhere using the Wyze app.
- Multi-Tap Actions: Customize single, double, and triple tap actions to control other Wyze devices like cameras, locks, and vacuums.
- Automation: Set timers, schedules, and vacation modes to simulate occupancy.
- Power Loss Recovery: Automatically restores settings after power outages.
- Integration: Works seamlessly with Alexa, Google Assistant, and the Wyze ecosystem.
- Available Packs: Choose from 1-pack or 3-pack options to outfit multiple rooms.
Ideal for upgrading your home lighting system with smart convenience and energy savings.
Wyze Switch in a modern kitchen setting with voice assistant control
Wyze Plug – Smart Plug for Effortless Device Automation
Make your everyday devices smart with the Wyze Plug, offering easy app control and voice assistant compatibility.
Features:
- Remote Control: Turn devices on/off from anywhere via the Wyze app.
- Scheduling: Set timers and schedules to automate your appliances.
- Voice Control: Compatible with Alexa, Google Assistant, and IFTTT.
- Compact Design: Fits into any standard outlet without blocking adjacent sockets.
- Indoor Use: Designed for indoor environments with operating temperatures from -4°F to 104°F.
- Available Packs: Sold in 2-pack or 4-pack bundles for multiple devices.
Perfect for controlling lamps, fans, coffee makers, and more, the Wyze Plug brings smart convenience to your home.
Wyze smart home products combine cutting-edge technology with user-friendly design to keep your home safe, connected, and efficient. From high-resolution cameras to smart switches and plugs, Wyze offers affordable solutions that integrate seamlessly into your lifestyle.
Summary of Featured Wyze Products
Product | Key Specs | Price Range |
Wyze Cam v4 | 2.5K QHD, color night vision, IP65 | $100.00 |
Wyze Video Doorbell v2 | 2K video, wide FOV, two-way audio | $44.98 |
Wyze Cam Floodlight v2 | 2800 lumens, 2K video, color night vision | $89.98 |
Wyze Switch | Smart light control, multi-tap actions | $14.99 - $41.98 |
Wyze Plug | Smart plug, scheduling, voice control | $24.98 - $39.98 |
Enhance your home security and automation with Wyze’s trusted smart devices today.
What is the video quality of the Wyze Cam v4 security camera?
The Wyze Cam v4 offers stunning 2.5K QHD (2560x1440) resolution with 8x digital zoom, providing crystal-clear video surveillance for both indoor and outdoor use.Does the Wyze Cam v4 work outdoors and in harsh weather?
Yes, the Wyze Cam v4 is weather-resistant with an IP65 rating and operates in temperatures from -4°F to 122°F, making it suitable for both indoor and outdoor environments.What smart home systems are Wyze cameras compatible with?
Wyze cameras, including the Cam v4, Video Doorbell v2, and Cam Floodlight v2, are compatible with Alexa, Google Assistant, and IFTTT for seamless smart home integration and voice control.How does the Wyze Video Doorbell v2 enhance front door security?
The Wyze Video Doorbell v2 provides clear 2K video, ultra-wide field of view, night vision, two-way audio, and real-time alerts, allowing you to monitor and communicate with visitors from anywhere.Can Wyze cameras record video locally without a subscription?
Yes, Wyze cameras support local storage via microSD cards (up to 512GB for Cam v4 and up to 256GB for Video Doorbell v2 and Cam Floodlight v2), allowing continuous recording without a subscription. Cloud storage is also available as an option.What are the lighting features of the Wyze Cam Floodlight v2?
The Wyze Cam Floodlight v2 features two dimmable LED panels delivering 2800 lumens at 5000K color temperature, providing bright illumination for outdoor security.Does the Wyze Cam Floodlight v2 offer color night vision?
Yes, the Wyze Cam Floodlight v2 is equipped with color night vision, allowing you to see full-color video even in low-light conditions.How can I control my home lighting with Wyze Switch?
The Wyze Switch allows you to control your lights remotely via the Wyze app, set timers and schedules, and customize multi-tap actions to control other Wyze devices. It also works with Alexa and Google Assistant for voice control.What devices can I automate with the Wyze Plug?
The Wyze Plug can automate a variety of indoor devices such as lamps, fans, and coffee makers. It offers remote control, scheduling, and voice assistant compatibility for effortless device automation.Are Wyze smart home devices easy to install and use?
Yes, Wyze smart home devices are designed for user-friendly installation and operation, with versatile mounting options, intuitive app controls, and seamless integration with popular smart home platforms.What is the price range for Wyze smart home products?
Wyze smart home products are affordably priced, with the Wyze Cam v4 at $100.00, Video Doorbell v2 at $44.98, Cam Floodlight v2 at $89.98, Switch from $14.99 to $41.98, and Plug from $24.98 to $39.98.
