Wyze Video Doorbell v2 vs Original: Key Differences Explained
When choosing a smart video doorbell, understanding the differences between the
Wyze Video Doorbell v2 and the
Original Wyze Video Doorbell (Wired) is essential. Both offer reliable home security features, but the v2 model brings significant upgrades that enhance video quality, storage options, and overall functionality.
Wyze Video Doorbell v2: Advanced Features for Superior Security
Crystal-Clear 2K Video Resolution
The Wyze Video Doorbell v2 delivers stunning
2K (2048 x 1536) video resolution, providing sharper and more detailed footage compared to the original's 1080p full HD. This means you can clearly see faces, packages, and other important details on your porch.
Local MicroSD Storage for 24/7 Recording
Unlike the original model, the v2 includes a built-in microSD card slot that supports continuous local recording. This feature allows you to review footage anytime without relying solely on cloud storage, giving you peace of mind and more control over your video data.
Motion-Activated Voice Deterrence
The v2 introduces a smart
motion-activated voice deterrence feature that plays automated voice prompts to warn visitors they are being recorded. This proactive security measure helps deter unwanted activity before it happens (requires Cam Plus subscription).
Enhanced Field of View and Pre-Roll Recording
With a wider field of view and the ability to capture
3-6 seconds of pre-roll video before motion events, the v2 ensures you don’t miss any critical moments around your doorstep.
Compatibility with Existing Chimes
The v2 comes with a
chime controller that allows it to work seamlessly with your home’s existing mechanical chime, preserving the traditional doorbell sound while upgrading to smart functionality.
Weatherproof and Night Vision
Rated
IP65 weather-resistant, the v2 withstands harsh weather conditions. It also features an award-winning starlight sensor for
color night vision, delivering clear video even in low-light environments.
Smart Home Integration
Works effortlessly with
Amazon Alexa and
Google Home, enabling voice commands and live feed viewing on compatible smart devices.
Original Wyze Video Doorbell (Wired): Reliable and Compact
1080p Full HD Video Quality
The original Wyze Video Doorbell offers solid
1080p full HD video with a 4:3 aspect ratio, providing clear head-to-toe coverage of your porch area.
Two-Way Audio with Noise Cancellation
Equipped with a built-in speaker and microphone, it supports two-way talk with noise and echo cancellation, allowing you to communicate clearly with visitors.
Motion Detection and Night Vision
The original model includes motion detection and infrared night vision with 6 IR LEDs, ensuring you can monitor activity day and night.
Limited Local Storage
Unlike the v2, the original doorbell does not support local microSD storage for continuous recording, relying primarily on cloud storage options.
Chime Compatibility
The original Wyze Video Doorbell requires bypassing the existing mechanical chime, meaning your traditional doorbell sound will not work after installation.
Weather Resistance and Smart Features
Also rated
IP65 weatherproof, it supports Alexa and Google Assistant integration for smart home compatibility.
Side-by-Side Comparison Summary
Feature | Wyze Video Doorbell v2 | Original Wyze Video Doorbell (Wired) |
Video Resolution | 2K (2048 x 1536) | 1080p Full HD |
Local Storage | Yes, microSD slot for 24/7 recording | No local storage, cloud only |
Motion-Activated Voice Deterrence | Yes (with Cam Plus subscription) | No |
Field of View | Wider with pre-roll recording | Standard 120° vertical x 88° horizontal |
Chime Compatibility | Works with existing chime (chime controller included) | Existing chime disabled after install |
Night Vision | Color night vision with starlight sensor | Infrared night vision |
Smart Home Integration | Alexa, Google Home | Alexa, Google Home |
Weather Resistance | IP65 | IP65 |
Which Wyze Video Doorbell Should You Choose?
If you want the latest in video clarity, local storage, and advanced security features like voice deterrence, the
Wyze Video Doorbell v2 is the clear winner. It’s perfect for homeowners who want detailed monitoring and seamless integration with existing doorbell chimes.
The
Original Wyze Video Doorbell remains a solid choice for those seeking a budget-friendly wired doorbell with reliable 1080p video and basic smart features, but without local recording or advanced deterrence.
Enhance Your Wyze Video Doorbell v2 Experience
For porches with angled door frames or stairs, the
Wedge Kit accessory helps you adjust the doorbell’s viewing angle to eliminate blind spots and maximize coverage. Made from durable, weather-resistant plastic, it’s designed specifically for the v2 model to ensure perfect porch security.
Alt text: Wyze Video Doorbell v2 with Wedge Kit installed on angled porch
"Answer your door from anywhere with Wyze Video Doorbell v2’s clearest 2K video and local storage, or choose the original for dependable 1080p HD monitoring."
Conclusion
Upgrading from the original Wyze Video Doorbell to the v2 means gaining sharper video, continuous local recording, and smarter security features that help protect your home better. Whether you prioritize video quality, storage options, or chime compatibility, Wyze offers a smart doorbell solution tailored to your needs.
What are the main differences between Wyze Video Doorbell v2 and the Original Wyze Video Doorbell?
The Wyze Video Doorbell v2 offers 2K video resolution, local microSD storage for 24/7 recording, motion-activated voice deterrence, a wider field of view with pre-roll recording, compatibility with existing chimes, and color night vision. The original Wyze Video Doorbell provides 1080p HD video, cloud-only storage, standard motion detection, infrared night vision, and requires bypassing your existing chime.Does Wyze Video Doorbell v2 support local storage?
Yes, the Wyze Video Doorbell v2 features a built-in microSD card slot that allows for continuous local recording, so you can review footage anytime without relying solely on cloud storage.Can I use my existing mechanical chime with Wyze Video Doorbell v2?
Yes, the Wyze Video Doorbell v2 comes with a chime controller that enables compatibility with your home’s existing mechanical chime, preserving the traditional doorbell sound.What video resolution does Wyze Video Doorbell v2 offer compared to the original?
Wyze Video Doorbell v2 delivers 2K (2048 x 1536) video resolution for sharper and more detailed footage, while the original Wyze Video Doorbell provides 1080p full HD video.Does the Wyze Video Doorbell v2 have color night vision?
Yes, the Wyze Video Doorbell v2 features a starlight sensor for color night vision, providing clear video even in low-light conditions. The original model uses infrared night vision.Is the Wyze Video Doorbell v2 weatherproof?
Yes, both the Wyze Video Doorbell v2 and the original model are rated IP65 weather-resistant, making them suitable for outdoor use in various weather conditions.What is motion-activated voice deterrence on Wyze Video Doorbell v2?
Motion-activated voice deterrence is a feature on the Wyze Video Doorbell v2 that plays automated voice prompts to alert visitors they are being recorded, helping to deter unwanted activity. This feature requires a Cam Plus subscription.Does the original Wyze Video Doorbell support local microSD storage?
No, the original Wyze Video Doorbell does not support local microSD storage and relies primarily on cloud storage for video recordings.Can I integrate Wyze Video Doorbells with Alexa or Google Home?
Yes, both the Wyze Video Doorbell v2 and the original model are compatible with Amazon Alexa and Google Home, allowing for voice commands and live feed viewing on supported devices.What is the Wyze Video Doorbell v2 Wedge Kit and how does it help?
The Wyze Video Doorbell v2 Wedge Kit is an accessory designed to adjust the doorbell’s viewing angle, especially for porches with angled door frames or stairs. It helps eliminate blind spots and maximize coverage, ensuring optimal security.Which Wyze Video Doorbell is best for advanced security and video quality?
The Wyze Video Doorbell v2 is the best choice for advanced security and video quality, offering 2K resolution, local storage, motion-activated voice deterrence, and enhanced night vision.Does the original Wyze Video Doorbell work with my existing chime?
No, installing the original Wyze Video Doorbell requires bypassing your existing mechanical chime, so your traditional doorbell sound will not work after installation.
