Upgrade Your Outdated Peephole or Intercom with Wyze Doorbell Cameras
Replacing an old peephole or intercom system with a modern video doorbell camera can dramatically improve your home security and convenience. Wyze offers a range of upgraded doorbell cameras designed to provide crystal-clear video, smart alerts, and seamless integration with your smart home. Whether you want a wired or battery-powered solution, Wyze has you covered with advanced features that make monitoring your front door easier and smarter.
Wyze Video Doorbell v2: The Wired Upgrade with 2K Clarity
Crisp 2K Video and Wide Field of View
The Wyze Video Doorbell v2 delivers stunning 2K (2048 x 1536) resolution, providing you with clear, detailed video footage of your doorstep. Its wide 135° horizontal and 103° vertical field of view ensures you won’t miss any activity, covering a broad area around your door.
Essential Smart Features
- Two-way audio lets you communicate with visitors from anywhere.
- Real-time alerts notify you instantly when motion or a visitor is detected.
- Motion-activated voice deterrence warns off unwanted guests.
- Local microSD storage (up to 256GB) keeps your footage safe without monthly fees.
Durable and Weather-Resistant
Built with polycarbonate and resin materials, the doorbell is IP65 rated for weather resistance, making it reliable in all seasons. It operates in temperatures from -4°F to 122°F, perfect for most climates.
Easy Installation and Accessories
The doorbell comes with a chime controller and installation kit, including a wedge accessory to adjust the viewing angle for angled door frames or porches with stairs.
Upgrade your front porch with Wyze Video Doorbell v2 for clear, reliable security.
Wyze Duo Cam Battery Doorbell: Advanced Battery-Powered Dual Cameras
Dual Camera Views for Complete Coverage
The Wyze Duo Cam Doorbell features two cameras: a front-facing 2K camera for visitors and a bottom-facing 1080p camera to monitor packages or the doorstep floor. This dual perspective helps prevent package theft and gives you a comprehensive view of your entryway.
Flexible Power Options
- Battery-powered with a removable 6200 mAh lithium-ion battery for easy charging via USB-C.
- Can also be hardwired for continuous power if preferred.
Smart AI Detection and Alerts
- Real-time AI-powered person and package detection reduce false alerts.
- Motion-activated voice deterrence warns intruders with a 90 dB siren.
- Two-way audio for direct communication.
Robust Build and Connectivity
- IP65 weather resistance ensures durability outdoors.
- Dual-band Wi-Fi (2.4 GHz & 5 GHz) and Bluetooth 5.0 for reliable connectivity.
- Supports local microSD storage up to 256GB and cloud storage options.
Included Wyze Wi-Fi Chime
The Duo Cam package includes a Wyze Wi-Fi Chime for indoor alerts without complicated wiring.
Experience dual-camera security with the Wyze Duo Cam Battery Doorbell.
Wyze Video Doorbell Pro: Wireless or Wired with Ultra-Wide View
Ultra-Wide Viewing Angle and HD Quality
The Wyze Video Doorbell Pro offers a wider field of view than many competitors, capturing more of your porch area in crystal-clear HD resolution. It supports both wired and battery power, giving you installation flexibility.
Smart Detection and Security Features
- Person, package, vehicle, and pet detection with smart alerts.
- Motion-activated security light enhances nighttime visibility.
- Two-way audio with quick response capabilities.
- 20 unique chime tunes and adjustable sound levels.
Easy Installation and Smart Home Integration
- Install in just 30 seconds using screws or a screw-free adhesive plate.
- Works seamlessly with Alexa and Google Assistant for voice control.
- Includes a dual-band Wi-Fi extender chime for faster notifications.
Wyze Video Doorbell Pro combines convenience and advanced smart features.
Enhance Your Doorbell Setup with Wyze Universal Wi-Fi Chime
If you want to add a chime to your Wyze doorbell system without complicated wiring, the Wyze Universal Wi-Fi Chime is the perfect accessory. It plugs into any standard outlet and connects wirelessly to your Wyze cameras and doorbells.
Key Features
- Compatible with all Wyze Cams and doorbells.
- Offers 17 different chime tones to customize your alerts.
- Supports multiple devices for whole-home coverage.
- Easy plug-and-play installation.
This chime ensures you never miss a visitor or delivery, even if your phone is away.
Why Upgrade from Peephole or Intercom Systems?
Traditional peepholes and intercoms offer limited visibility and no remote access. Upgrading to a Wyze doorbell camera system provides:
- High-definition video you can view anytime on your smartphone.
- Two-way communication with visitors from anywhere.
- Smart alerts and AI detection to reduce false alarms.
- Integration with voice assistants and smart home devices.
- Weatherproof, durable designs for year-round security.
Make your home safer and smarter with Wyze’s advanced doorbell cameras and accessories.
Summary of Wyze Doorbell Camera Options
Product | Power Type | Video Resolution | Special Features | Included Accessories |
Wyze Video Doorbell v2 | Wired | 2K (2048x1536) | Local microSD storage, voice deterrence | Chime controller, wedge kit |
Wyze Duo Cam Battery Doorbell | Battery / Wired | Front 2K / Bottom 1080p | Dual cameras, AI detection, siren | Wi-Fi chime, removable battery |
Wyze Video Doorbell Pro | Battery / Wired | HD | Ultra-wide view, motion light, smart alerts | Dual-band Wi-Fi chime |
Wyze Universal Wi-Fi Chime | Accessory | N/A | 17 chime tones, easy plug-in | N/A |
Upgrade your home security today with Wyze’s smart, reliable doorbell cameras designed to replace outdated peepholes and intercoms.
What are the benefits of upgrading my peephole or intercom to a Wyze doorbell camera?
Upgrading to a Wyze doorbell camera provides high-definition video you can view on your smartphone, two-way communication with visitors from anywhere, smart alerts with AI detection to reduce false alarms, integration with voice assistants and smart home devices, and weatherproof, durable designs for year-round security.Which Wyze doorbell camera is best for wired installation?
The Wyze Video Doorbell v2 is ideal for wired installation. It offers crisp 2K video resolution, a wide field of view, two-way audio, real-time alerts, motion-activated voice deterrence, and local microSD storage. It also comes with a chime controller and installation kit.Does Wyze offer a battery-powered doorbell camera?
Yes, the Wyze Duo Cam Battery Doorbell is battery-powered with a removable 6200 mAh lithium-ion battery for easy charging via USB-C. It can also be hardwired for continuous power, offering flexible installation options.What is unique about the Wyze Duo Cam Battery Doorbell?
The Wyze Duo Cam Battery Doorbell features dual cameras: a front-facing 2K camera for visitors and a bottom-facing 1080p camera to monitor packages or the doorstep floor. This dual perspective helps prevent package theft and provides comprehensive entryway coverage.How does the Wyze Video Doorbell Pro enhance home security?
The Wyze Video Doorbell Pro offers an ultra-wide viewing angle in HD quality, person, package, vehicle, and pet detection with smart alerts, a motion-activated security light for nighttime visibility, two-way audio, and easy installation with both wired and battery power options.Can Wyze doorbell cameras be integrated with smart home systems?
Yes, Wyze doorbell cameras work seamlessly with Alexa and Google Assistant, allowing for voice control and integration with your smart home ecosystem.What storage options are available for Wyze doorbell cameras?
Wyze doorbell cameras support local microSD storage up to 256GB, allowing you to save footage without monthly fees. Some models also offer cloud storage options for added convenience.Are Wyze doorbell cameras weather-resistant?
Yes, Wyze doorbell cameras are built with weather-resistant materials and are IP65 rated, making them reliable for outdoor use in various climates and weather conditions.What is the Wyze Universal Wi-Fi Chime and how does it work?
The Wyze Universal Wi-Fi Chime is an accessory that plugs into any standard outlet and connects wirelessly to your Wyze cameras and doorbells. It offers 17 different chime tones, supports multiple devices for whole-home coverage, and features easy plug-and-play installation.How easy is it to install a Wyze doorbell camera?
Wyze doorbell cameras are designed for easy installation. The Wyze Video Doorbell Pro, for example, can be installed in just 30 seconds using screws or a screw-free adhesive plate. Installation kits and accessories are included with each model to simplify the process.What smart detection features do Wyze doorbell cameras offer?
Wyze doorbell cameras offer AI-powered person and package detection, motion-activated voice deterrence, and real-time alerts to help reduce false alarms and enhance your home security.Do Wyze doorbell cameras come with indoor chimes?
Yes, select Wyze doorbell cameras, such as the Wyze Duo Cam Battery Doorbell and Wyze Video Doorbell Pro, include a Wi-Fi chime or chime controller for indoor alerts without complicated wiring.
