Wireless Integration for Wired Doorbell Cameras & Smart Homes
Wireless Integration for Wired Doorbell Cameras with Smart Home Support
Integrating a wired doorbell camera into your smart home ecosystem while enabling wireless convenience is now easier than ever. Whether you want to upgrade your existing wired doorbell or install a new smart video doorbell with seamless wireless connectivity and smart home compatibility, Wyze offers a range of solutions tailored to your needs. Explore the best wired doorbell cameras with wireless integration capabilities and smart home support, designed to enhance your home security and convenience.
Wyze Video Doorbell v2: The Ultimate Wired Doorbell with Wireless Smart Features
Experience the clearest and most capable wired video doorbell with Wyze Video Doorbell v2. This device combines the reliability of a wired connection with wireless smart home integration, giving you the best of both worlds.
Key Features:
  • 2K Video Resolution: Capture every detail with 2048 x 1536 pixels, providing crystal-clear video day and night.
  • Local and Cloud Storage: Supports microSD cards up to 256GB for local storage plus optional cloud storage with Wyze Security Plan.
  • Two-Way Audio & Voice Deterrence: Communicate with visitors or deter unwanted guests with motion-activated voice alerts.
  • Wide Field of View: 135° horizontal and 103° vertical coverage ensures you see everything happening on your porch.
  • Smart Home Integration: Works seamlessly with Alexa, Google Assistant, and IFTTT for voice control and automation.
  • Weather Resistant: IP65 rating ensures durability in all weather conditions.
  • Power Requirements: Uses existing 16V-24V AC wired power, ensuring continuous operation without battery worries.
Included Accessories:
  • Wyze Chime Controller for wireless chime alerts inside your home.
  • Wall plate, wedge for angled mounting, wire caps, and installation kit for easy setup.
The Wyze Video Doorbell v2 is perfect for those who want a wired doorbell camera with wireless smart home integration, combining high-quality video and reliable power.
Smart Home Front Porch with Wyze Doorbell Enhance your front porch security with Wyze Video Doorbell v2
The Front Porch Security Bundle: Complete Wireless Integration for Wired Doorbell Cameras
For a comprehensive smart home security solution, the Front Porch Security Bundle combines the Wyze Video Doorbell with Wyze Lock and Chime, offering wireless control and monitoring of your wired doorbell camera and smart lock.
Bundle Highlights:
  • 1080p HD Video Doorbell: View your front porch clearly with two-way audio and motion detection.
  • Remote Lock Control: Lock or unlock your door remotely via the Wyze app, with full lock history tracking.
  • Wireless Chime Included: Hear doorbell alerts anywhere in your home with a wireless chime.
  • Smart Home Compatibility: Works with Alexa and Google Assistant for voice commands and automation.
  • Secure Data: End-to-end encryption and AES 128-bit encryption protect your video and lock data.
  • Easy Installation: Uses existing wired power for the doorbell, with wireless communication for lock and chime.
What’s in the Box:
  • Wyze Lock and Gateway for Bluetooth and Zigbee communication.
  • Wyze Video Doorbell and Chime.
  • Mounting hardware, wire caps, extension wires, and quick start guides.
This bundle is ideal for homeowners seeking a fully integrated smart home entry system that bridges wired doorbell reliability with wireless smart control.
Wyze Video Doorbell Pro: Hybrid Wired and Wireless Doorbell Camera
The Wyze Video Doorbell Pro offers the flexibility of both wired and wireless power options, making it a versatile choice for smart home enthusiasts who want easy installation and advanced features.
Standout Features:
  • Battery-Powered or Hardwired: Choose wired power or battery operation for up to 30 seconds install time.
  • Ultra-Wide Viewing Angle: Wider field of view than standard doorbells to cover more area.
  • Smart Detection Alerts: Person, package, vehicle, and pet detection with Cam Plus subscription.
  • Motion-Activated Security Light: Enhances night-time visibility and deters intruders.
  • Two-Way Audio: Clear communication with visitors and quick responses.
  • Customizable Chime: 20 unique tunes and 8 sound levels for personalized alerts.
  • Smart Home Integration: Compatible with Alexa and Google Assistant for voice control.
  • Unlock Integration: Works with Wyze Lock Bolt for seamless door security.
The Wyze Video Doorbell Pro is perfect for those who want the convenience of wireless installation without sacrificing wired power reliability, plus advanced smart home features.
Smart Home Voice Assistants with Doorbell Control your doorbell with Alexa and Google Assistant
Additional Accessories for Perfect Wireless Integration
Optimize your wired doorbell camera’s viewing angle with the Wyze Video Doorbell v2 Wedge Kit. This accessory is designed for angled door frames or porches with stairs, eliminating blind spots and enhancing coverage.
  • Includes horizontal and vertical brackets for flexible mounting.
  • Weather-resistant and easy to install.
  • Compatible exclusively with Wyze Video Doorbell v2.
Perfect for customizing your wired doorbell camera setup to maximize security coverage.
Why Choose Wyze for Wireless Integration of Wired Doorbell Cameras?
Wyze offers a unique blend of wired doorbell cameras with wireless smart home integration, ensuring:
  • Reliable Wired Power: No need to worry about battery life or charging.
  • Wireless Smart Features: Control and monitor your doorbell remotely via Wi-Fi and smart assistants.
  • Seamless Smart Home Compatibility: Works with Alexa, Google Assistant, and IFTTT for automation.
  • Affordable and Easy Installation: Designed for DIY installation with comprehensive kits and accessories.
  • Robust Security: End-to-end encryption and local storage options keep your data safe.
Upgrade your home security with Wyze’s wired doorbell cameras that integrate wirelessly into your smart home ecosystem.
Summary of Products for Wireless Integration with Wired Doorbell Cameras
Product NamePower TypeVideo ResolutionSmart Home SupportSpecial Features
Wyze Video Doorbell v2Wired (16V-24V AC)2K (2048x1536)Alexa, Google Assistant, IFTTTLocal microSD storage, voice deterrence
The Front Porch Security BundleWired + Wireless Lock1080p HDAlexa, Google AssistantRemote lock control, wireless chime
Wyze Video Doorbell ProWired or BatteryHDAlexa, Google AssistantUltra-wide view, motion-activated light
Wyze Video Doorbell v2 Wedge KitAccessoryN/AN/AAdjustable mounting angle
Enhance your wired doorbell camera with wireless smart home integration today and enjoy the convenience, security, and peace of mind that Wyze products deliver.
FeatureWyze Video Doorbell v2The Front Porch Security BundleWyze Video Doorbell ProWyze Video Doorbell (Wired)
Video Resolution2K (2304 x 1296)1080p HD (Doorbell and Chime)HD (exact resolution not specified, wider view)1080p Full HD (2048 x 1536 sensor)
Video Quality2K, Color Night Vision1080p HDCrystal-clear HD1080p Full HD
Field of ViewHead-to-toe view (exact degrees not specified)Not specifiedUltra-wide viewing angle120° Vertical x 88° Horizontal
PowerWiredIncludes Wyze Lock (battery) + Video Doorbell (wired)Wired or BatteryWired
Local StoragemicroSD card slot (continuous local recording)Not specifiedNot specifiedNot specified
Cloud Storage14-day free, Cam Plus subscription availableCam Plus subscription availableCam Plus subscription availableCam Plus subscription available
Two-way AudioYesYesYesYes
Motion DetectionYes, with motion-activated voice deterrenceYesYes, with smart detection alertsYes
Pre-roll Motion Recording3-6 secondsNot specifiedNot specifiedNot specified
Chime CompatibilityWorks with existing chime, chime controller includedIncludes Wyze Video Doorbell and ChimeChime includedExisting chime will not work after installation
Weather ResistanceIP65Not specifiedNot specifiedIP65
Integration with Smart AssistantsAlexa, Google HomeNot specifiedAlexa, Google AssistantAlexa, Google Assistant, IFTTT
Additional FeaturesMotion-activated voice deterrence, quick responses, custom detection zones, 30° corner kit includedIncludes Wyze Lock for remote lock/unlock and lock historyMotion-activated security light, 20 chime tunes, quick responses5 modern, 4 classic, 3 animal, 6 automation, 1 intruder alarm sounds
InstallationWired, includes wedge for angle adjustmentBundle includes multiple devicesWired or wireless, install in 30 secondsWired, includes mounting accessories
Price$44.98$123.99 - $173.97 (varies by variant)$99.98$29.99 - $34.99
What is wireless integration for wired doorbell cameras?Wireless integration for wired doorbell cameras allows you to connect your traditional wired doorbell to your smart home ecosystem. This enables features like remote monitoring, voice control, and automation through Wi-Fi and smart assistants, while maintaining the reliability of wired power.
Which Wyze doorbell camera offers both wired reliability and wireless smart home features?The Wyze Video Doorbell v2 combines the reliability of a wired connection with wireless smart home integration. It supports 2K video resolution, local and cloud storage, two-way audio, and works seamlessly with Alexa, Google Assistant, and IFTTT.
Can I control my Wyze wired doorbell camera with Alexa or Google Assistant?Yes, Wyze wired doorbell cameras, including the Video Doorbell v2 and Video Doorbell Pro, are compatible with Alexa and Google Assistant. This allows you to use voice commands and integrate your doorbell into your smart home routines.
What is included in the Wyze Front Porch Security Bundle?The Wyze Front Porch Security Bundle includes a Wyze Video Doorbell, Wyze Lock and Gateway, a wireless chime, mounting hardware, wire caps, extension wires, and quick start guides. This bundle provides a complete smart home entry system with both wired and wireless integration.
Does the Wyze Video Doorbell Pro support both wired and wireless installation?Yes, the Wyze Video Doorbell Pro offers hybrid installation options. You can power it using your existing doorbell wiring or use the built-in battery for a completely wireless setup, making installation flexible and convenient.
What are the storage options for Wyze wired doorbell cameras?Wyze wired doorbell cameras support both local and cloud storage. You can use a microSD card (up to 256GB) for local storage or subscribe to the Wyze Security Plan for cloud storage and advanced features like smart detection alerts.
How does the Wyze Video Doorbell v2 Wedge Kit improve camera coverage?The Wyze Video Doorbell v2 Wedge Kit allows you to adjust the mounting angle of your doorbell camera, making it ideal for angled door frames or porches with stairs. This helps eliminate blind spots and enhances your front porch security coverage.
Are Wyze doorbell cameras weather resistant?Yes, Wyze doorbell cameras such as the Video Doorbell v2 are IP65 rated, ensuring they are weather resistant and durable in all weather conditions.
What smart home platforms are compatible with Wyze wired doorbell cameras?Wyze wired doorbell cameras are compatible with major smart home platforms including Alexa, Google Assistant, and IFTTT, allowing for voice control and automation.
Is installation of Wyze wired doorbell cameras easy for DIY homeowners?Yes, Wyze doorbell cameras are designed for easy DIY installation. They come with comprehensive kits and accessories, including mounting hardware, wire caps, and quick start guides to simplify the setup process.
How does Wyze ensure the security of my video and lock data?Wyze uses end-to-end encryption and AES 128-bit encryption to protect your video and lock data, ensuring your smart home security system is safe and secure.
Can I receive doorbell alerts wirelessly inside my home?Yes, Wyze doorbell cameras come with a wireless chime controller, allowing you to hear doorbell alerts anywhere in your home without additional wiring.
What are the power requirements for Wyze Video Doorbell v2?The Wyze Video Doorbell v2 requires an existing 16V-24V AC wired power source, ensuring continuous operation without the need for battery charging.
What advanced features does the Wyze Video Doorbell Pro offer?The Wyze Video Doorbell Pro features ultra-wide viewing angles, motion-activated security light, person/package/vehicle/pet detection (with Cam Plus), two-way audio, customizable chimes, and integration with Wyze Lock Bolt for enhanced security.
What are the key features of the Wyze Video Doorbell v2?Can you tell me more about the Front Porch Security Bundle?Do you have any deals, ongoing sales, discounts, or promotions?
