Universal Durable Metal Ceiling Mount for Wyze Battery Cam Pro Installation
When it comes to installing your Wyze Battery Cam Pro on a ceiling, having a reliable, durable, and universal metal mount is essential. The Wyze Universal Mount (Long) is specifically designed to provide a sturdy and flexible mounting solution, especially for ceiling installations. This mount features a longer stem that allows you to position your camera optimally, ensuring the best field of view and security coverage.
Wyze Battery Cam Pro: The Ultimate Wire-Free Security Camera
Key Features and Benefits
- 2.5K HDR Video Resolution: Capture crystal-clear footage with high dynamic range, ensuring balanced images with richer colors both day and night.
- Wire-Free and No Hub Required: Enjoy the freedom of wireless installation without the need for complicated wiring or hubs.
- Integrated Spotlight & Siren: The camera includes a 150-lumen motion-activated LED spotlight and a siren to deter intruders effectively.
- Radar + PIR Motion Detection: Dual sensors provide earlier and more precise motion detection, reducing false alarms.
- Removable, Rechargeable Battery Packs: Easily swap batteries without taking down the camera, minimizing downtime.
- IP65 Weatherproof: Built to withstand rain, dust, and extreme weather conditions.
- Dual-Band WiFi Support: Connects seamlessly to both 2.4 GHz and 5 GHz networks for faster and more reliable streaming.
- Local Recording: Supports microSD cards for local storage of motion events without subscription fees.
Flexible Mounting with Wyze Universal Mount
For ceiling installations, the Wyze Universal Mount (Long) is a must-have accessory. Its durable metal construction and extended stem provide the perfect solution to mount your Wyze Battery Cam Pro securely on ceilings or under eaves. This mount ensures your camera stays firmly in place while offering flexible angles for optimal surveillance.
Wyze Battery Cam Pro + Solar Panel: Continuous Power for Extended Security
Why Choose the Solar Panel Bundle?
- Extended Battery Life: The included solar panel converts sunlight into power, allowing your camera to stay operational longer without manual recharging.
- Weather-Resistant Design: Both the camera and solar panel are IP65 rated, ensuring durability in all weather conditions.
- Easy Installation: No electrician needed; simply mount the camera with the universal mount and connect the solar panel.
- All Features of Wyze Battery Cam Pro: Enjoy 2.5K HDR video, integrated spotlight, radar + PIR motion detection, and more.
This bundle is perfect for those who want hassle-free, continuous monitoring without worrying about battery life interruptions.
Essential Accessories for Optimal Performance
Wyze Removable Battery Pack
- High Capacity: 6200mAh rechargeable lithium-ion battery lasts up to 6 months on a single charge.
- Convenient USB-C Charging: Fast and easy charging with a built-in USB-C port.
- Compact and Lightweight: Measures 2.9 x 1.6 x 0.9 inches and weighs just 3.9 oz, making it easy to swap batteries quickly.
Wyze Battery Charging Dock
- Charge Two Batteries Simultaneously: Keep your spare batteries ready with this dual charging dock.
- Compact Design: Small footprint with included power adapter and USB-A to USB-C cable.
- Fast Charging: Fully charges batteries in approximately 8.5 hours.
Why Choose Wyze for Your Ceiling Mount Security Needs?
"Wyze Battery Cam Pro combined with the Universal Mount offers a seamless, durable, and flexible solution for ceiling installations, ensuring your home or business is protected with professional-grade security."
With the Wyze Battery Cam Pro and its accessories, you get a complete ecosystem designed for easy installation, reliable performance, and extended power options. Whether you choose the standalone camera, the solar panel bundle, or add essential accessories like extra batteries and charging docks, Wyze provides everything you need for a universal durable metal ceiling mount installation.
Summary of Products for Ceiling Mount Installation
- Wyze Battery Cam Pro: Wire-free, 2.5K HDR, spotlight, radar + PIR, removable battery, IP65 weatherproof.
- Wyze Battery Cam Pro + Solar Panel: Includes solar panel for continuous power, all features of Battery Cam Pro.
- Wyze Universal Mount (Long): Durable metal mount with longer stem, ideal for ceiling or eave mounting.
- Wyze Removable Battery Pack: High-capacity rechargeable battery for extended use.
- Wyze Battery Charging Dock: Dual battery charger for convenient power management.
Optimize your Wyze Battery Cam Pro installation with the universal durable metal ceiling mount and accessories to ensure maximum security, flexibility, and convenience.
# Product Tags and Highlights
What is the Wyze Universal Mount (Long) and why is it ideal for ceiling installations?
The Wyze Universal Mount (Long) is a durable metal mount specifically designed for ceiling or eave installations of the Wyze Battery Cam Pro. Its longer stem allows for flexible positioning, ensuring optimal camera angles and a secure fit for enhanced security coverage.Can the Wyze Battery Cam Pro be installed wire-free on the ceiling?
Yes, the Wyze Battery Cam Pro is a wire-free security camera that can be easily installed on the ceiling using the Wyze Universal Mount (Long), without the need for complicated wiring or a hub.What are the key features of the Wyze Battery Cam Pro?
The Wyze Battery Cam Pro offers 2.5K HDR video resolution, wire-free installation, integrated 150-lumen spotlight and siren, radar + PIR motion detection, removable rechargeable battery packs, IP65 weatherproof rating, dual-band WiFi support, and local microSD card recording.How does the Wyze Battery Cam Pro + Solar Panel bundle provide continuous power?
The Wyze Battery Cam Pro + Solar Panel bundle includes a weather-resistant solar panel that converts sunlight into power, allowing the camera to operate continuously without frequent manual recharging. Both the camera and solar panel are IP65 rated for durability.What accessories are recommended for optimal Wyze Battery Cam Pro performance?
Recommended accessories include the Wyze Universal Mount (Long) for secure ceiling installation, Wyze Removable Battery Pack for extended use, and the Wyze Battery Charging Dock for charging two batteries simultaneously.How long does the Wyze Removable Battery Pack last and how is it charged?
The Wyze Removable Battery Pack has a high capacity of 6200mAh and can last up to 6 months on a single charge. It features convenient USB-C charging for fast and easy power replenishment.Is the Wyze Battery Cam Pro weatherproof for outdoor ceiling mounting?
Yes, the Wyze Battery Cam Pro is IP65 weatherproof, making it suitable for both indoor and outdoor ceiling or eave mounting, and capable of withstanding rain, dust, and extreme weather conditions.What motion detection technology does the Wyze Battery Cam Pro use?
The Wyze Battery Cam Pro uses dual motion detection technology, combining radar and PIR (Passive Infrared) sensors for earlier and more accurate motion detection, reducing false alarms.Can I record video locally on the Wyze Battery Cam Pro without a subscription?
Yes, the Wyze Battery Cam Pro supports local recording via microSD cards, allowing you to store motion events without any subscription fees.Why should I choose Wyze for my ceiling mount security camera needs?
Wyze offers a complete ecosystem for ceiling mount security, including the durable Universal Mount (Long), high-performance Battery Cam Pro, solar panel for continuous power, and essential accessories, ensuring easy installation, reliable performance, and maximum flexibility.
