Understanding Power Sources in Wyze Products
When choosing Wyze smart home devices, understanding their power sources is essential for seamless installation and optimal performance. Wyze offers a variety of products powered by different methods including wired power adapters, batteries, and AC plugs. This guide highlights the power source differences across popular Wyze products to help you pick the right device for your smart home setup.
Wyze Plug: Convenient AC-Powered Smart Plugs
Power Source and Specs
- Input: 100-120 VAC, 60Hz (standard household power)
- Output: 15A Max
- Usage: Indoor use only
- Connectivity: 2.4GHz WiFi for smart control
- Compatibility: Works with Android 5.0+ and iOS 9.0+
- Certifications: ETL certified for safety
- Warranty: 1 Year
Wyze Plug is designed to convert your regular outlets into smart plugs powered directly by your home’s AC power. This means no batteries to worry about and continuous power supply for your devices. Ideal for lamps, fans, coffee makers, and other appliances, the Wyze Plug offers reliable, always-on smart control.
The Wyze Plug’s wired power source ensures uninterrupted operation, perfect for devices that need constant power without the hassle of recharging or replacing batteries.
Wyze Plug controlling home appliances with ease
Wyze Cam v4: Wired Security with Flexible Power Adapter
- Power Adapter Input: 110-240 V (AC/DC)
- Power Adapter Output: Indoor 5V/1A
- Cable: 6-foot flat micro USB to USB-A cable
- Operating Temperature: -4ºF to 122ºF (-20ºC to 50ºC)
- Weather Resistance: IP65 rated for outdoor use
- Connectivity: Supports Wi-Fi 6 and 2.4 GHz Wi-Fi
- Storage: Local microSD card up to 512 GB + optional cloud storage
Wyze Cam v4 uses a wired power adapter that plugs into standard AC outlets, converting to a low-voltage 5V DC supply via USB. This ensures continuous power for 24/7 monitoring without battery concerns. The included 6-foot cable offers flexible placement near power sources.
Wired power for Wyze Cam v4 guarantees uninterrupted security coverage with enhanced night vision and spotlight features.
Wyze Cam v4 providing reliable outdoor security
Wyze Cam Pan v3: Wired with Optional Outdoor Power Adapter
- Power Adapter Input: 110-240V (AC/DC)
- Power Adapter Output: 5V/2000mA
- Power Cable Length: 6 inches (1.8 meters)
- Connectivity: 2.4 GHz Wi-Fi (no 5 GHz support)
- Weather Resistance: IP65 rated for outdoor use (with optional outdoor power adapter)
Wyze Cam Pan v3 is powered by a wired AC adapter converting to 5V DC, similar to Wyze Cam v4 but with a higher current output to support pan and tilt motors. For outdoor use, it requires a separate Wyze Outdoor Power Adapter to ensure weatherproof power delivery.
The wired power source supports continuous operation and motorized movement, making it ideal for dynamic home surveillance.
Wyze Video Doorbell v2: Requires Wired AC Power
- Power: 16V-24V AC, ≥10VA (typical doorbell wiring)
- Storage: Local microSD up to 256GB + cloud option
Wyze Video Doorbell v2 is a wired device designed to replace traditional doorbells and uses existing doorbell wiring for power. It requires a 16-24V AC power supply, typical in most homes, ensuring it stays powered without batteries.
Wired power ensures the doorbell is always ready to capture visitors with 2K video and real-time alerts.
Wyze Lock Bolt: Battery-Powered Smart Lock
- Power Source: 4x AA Batteries (included)
- Battery Life: 10-12 months typical usage
- Communication: Bluetooth 5.0 with 16 ft range
- Weather Resistance: IPX5 rated
- Operating Temperature: -13ºF to 122ºF
Unlike other Wyze devices that rely on wired power, the Wyze Lock Bolt is battery-powered for easy installation without wiring. The lock uses four AA batteries, providing up to a year of operation before replacement is needed. This makes it ideal for door locks where wiring is impractical.
Battery power offers flexibility and convenience for smart lock installation with ultra-fast fingerprint access.
Wyze Lock Bolt providing secure, keyless entry
Summary of Wyze Product Power Sources
Product | Power Source | Notes |
Wyze Plug | Wired AC (100-120 VAC) | Indoor use, always powered |
Wyze Cam v4 | Wired AC adapter (5V DC) | 6-foot USB cable, outdoor rated |
Wyze Cam Pan v3 | Wired AC adapter (5V DC) | Requires outdoor adapter for outside |
Wyze Video Doorbell v2 | Wired AC (16-24V AC) | Uses existing doorbell wiring |
Wyze Lock Bolt | Battery (4x AA) | Up to 12 months battery life |
Choosing the right Wyze product depends on your power availability and installation preferences. Wired devices offer continuous power and are ideal for fixed locations, while battery-powered options like the Wyze Lock Bolt provide installation flexibility without wiring.
Understanding these power source differences helps you plan your smart home setup efficiently, ensuring your Wyze devices stay powered and connected for optimal performance.
What power source does the Wyze Plug use?
The Wyze Plug is powered directly by your home's AC power (100-120 VAC, 60Hz). It does not require batteries and is designed for indoor use, providing continuous power for your connected devices.Is the Wyze Plug suitable for outdoor use?
No, the Wyze Plug is intended for indoor use only and should not be used outdoors.How is the Wyze Cam v4 powered?
The Wyze Cam v4 uses a wired power adapter that plugs into a standard AC outlet and converts to a 5V/1A DC supply via a 6-foot micro USB to USB-A cable. This ensures continuous, reliable power for 24/7 security monitoring.Can the Wyze Cam v4 be used outdoors?
Yes, the Wyze Cam v4 is IP65 rated for outdoor use and can operate in temperatures from -4ºF to 122ºF (-20ºC to 50ºC).What type of power adapter does the Wyze Cam Pan v3 require?
The Wyze Cam Pan v3 uses a wired AC adapter that converts to 5V/2000mA DC. For outdoor installation, a separate Wyze Outdoor Power Adapter is required to ensure weatherproof power delivery.Is the Wyze Cam Pan v3 weatherproof out of the box?
The Wyze Cam Pan v3 is IP65 rated for outdoor use only when paired with the optional Wyze Outdoor Power Adapter. Without this adapter, it is intended for indoor use.How is the Wyze Video Doorbell v2 powered?
The Wyze Video Doorbell v2 is powered by existing doorbell wiring, requiring a 16V-24V AC power supply (≥10VA). This ensures the doorbell is always powered without the need for batteries.Does the Wyze Video Doorbell v2 require batteries?
No, the Wyze Video Doorbell v2 does not use batteries. It relies on wired AC power from your home's existing doorbell wiring.What powers the Wyze Lock Bolt?
The Wyze Lock Bolt is powered by four AA batteries, which are included with the device. Typical battery life is 10-12 months, depending on usage.How long do the batteries last in the Wyze Lock Bolt?
The Wyze Lock Bolt's four AA batteries typically last between 10 to 12 months with normal usage.Which Wyze products are battery-powered?
Among the products listed, only the Wyze Lock Bolt is battery-powered, using four AA batteries for up to 12 months of operation.Which Wyze devices require wired power?
The Wyze Plug, Wyze Cam v4, Wyze Cam Pan v3, and Wyze Video Doorbell v2 all require wired power sources for continuous operation.How do I choose the right Wyze product based on power source?
Choose a wired Wyze device if you want continuous, always-on operation and have access to power outlets or doorbell wiring. Opt for the battery-powered Wyze Lock Bolt if you need installation flexibility without wiring.
