Wyze Outdoor Power Adapter for V4 and Extreme Weather Cam Installation
When it comes to securing your home or monitoring outdoor spaces, having reliable power solutions for your Wyze cameras is essential. The
Wyze Outdoor Power Adapter is specifically designed to keep your Wyze Cam v4 and other compatible models powered safely and efficiently in all weather conditions. Whether you’re installing your camera in rain, snow, or shine, this adapter ensures continuous operation with its robust weather resistance and smart design.
Wyze Outdoor Power Adapter: Built for All Weather Conditions
Weather-Resistant Durability
The Wyze Outdoor Power Adapter boasts an
IP67 weather resistance rating, making it fully capable of withstanding harsh outdoor environments including heavy rain, snow, and dust. This means you can confidently install your Wyze Cam v4 or other compatible cameras outside without worrying about power interruptions caused by weather.
- Operating temperature: -22°F to 122°F (-30°C to 50°C)
- Input power: 100V-240V
- Output power: 5V 2A
- Cable length: 12.5 ft (3.8 m) total, with 3.9 ft AC cable and 8.5 ft DC cable
- Connector to camera: Micro USB
- Connector to wall plug: 2 pin flat, US style
Compatibility and Installation Notes
- Compatible with Wyze Cam v3, Wyze Cam v4, Pan v3, Battery Cam Pro, and more.
- For Wyze Cam v3 Pro and Pan v3, the adapter must be used alongside the L-shaped Micro USB Adapter.
- For Wyze Battery Cam Pro, the adapter requires the USB-C adapter.
- Not compatible with the OG Stack Kit.
- Comes with wire clips, screws, anchors, and a weatherproof L-shaped Micro-USB adapter for secure and neat installation.
Ready for rain, snow, or shine, the Wyze Outdoor Power Adapter is your go-to solution for powering outdoor Wyze cameras reliably.
Wyze Cam Pan v3: The Perfect Outdoor Camera Companion
Advanced Pan and Tilt Features
The
Wyze Cam Pan v3 is a versatile indoor/outdoor security camera featuring 360° horizontal pan and 180° vertical tilt, allowing you to cover wide areas with a single device. Its IP65 weather resistance rating means it can handle outdoor conditions when paired with the Wyze Outdoor Power Adapter.
- Video resolution: 1080p Full HD
- Field of view: 120°
- Night vision: 4 IR LEDs (850 nm)
- Audio: Built-in speaker and microphone with 2-way audio and noise & echo cancellation
- Connectivity: 2.4 GHz Wi-Fi (802.11 b/g/n)
- Storage: Supports up to 256 GB microSD card
- Rotation speed: Up to 110° per second
Installation and Power
- Requires the Wyze Outdoor Power Adapter for safe outdoor use.
- Comes in black or white matte finish.
- Compact size: 124mm (H) x 60mm (W) x 63mm (D), weighing 320g.
- Includes mounting kit for easy setup.
Wyze Cam Pan v3 powered outdoors through the Wyze Outdoor Power Adapter, ready for extreme weather.
Bird Feeder Plug-in Cam v4 Bundle: Outdoor Monitoring Made Easy
All-in-One Birdwatching and Security Solution
For nature lovers and bird watchers, the
Bird Feeder Plug-in Cam v4 Bundle combines the Wyze Bird Feeder, Wyze Cam v4, and the Wyze Outdoor Power Adapter. This bundle offers a seamless way to monitor feathered visitors while ensuring your camera stays powered outdoors.
Weather-resistant for all seasons
- Multiple mounting options: wall, tree, pole, cord, suction cup
- Macro Lens Adapter included for close-up birdwatching
- Compatible with Wyze Solar Panel for sustainable power
This bundle is perfect for anyone wanting to enjoy remote birdwatching with the reliability of Wyze’s outdoor power solutions.
L-Shaped Micro USB Adapter: Essential for Pan v3 and v3 Pro
The
Wyze L-Shaped Micro USB Adapter is a small but crucial accessory that enables the Wyze Outdoor Power Adapter to work with Wyze Cam Pan v3 and Cam v3 Pro models. Its weatherproof design ensures a secure connection that withstands outdoor conditions.
- Compatible with Wyze Outdoor Power Adapter v1 and other Micro USB cables
- Helps maintain a neat and protected cable connection for outdoor installations
Installation Tips for Extreme Weather Environments
- Use the included wire clips and screws to secure cables tightly against walls or eaves, preventing damage from wind or animals.
- Ensure the L-shaped adapter is properly connected to avoid strain on the cable and camera port.
- Position your camera and power adapter in sheltered locations when possible, such as under eaves or behind gutters, to extend their lifespan.
- Regularly inspect connections and cables for wear, especially after severe weather events.
With the right accessories and installation techniques, your Wyze Cam v4 or Pan v3 will deliver reliable performance year-round.
Summary
The
Wyze Outdoor Power Adapter is the essential accessory for powering your Wyze Cam v4 and other outdoor cameras in extreme weather. When paired with compatible cameras like the
Wyze Cam Pan v3 or bundled in the
Bird Feeder Plug-in Cam v4 Bundle, it offers a robust, weatherproof solution for continuous outdoor monitoring. Don’t forget the
L-Shaped Micro USB Adapter for Pan v3 compatibility and follow best installation practices to maximize durability and performance.
Enjoy clear two-way audio communication with Wyze Cam Pan v3 indoors or outdoors.
Experience peace of mind with Wyze’s outdoor power solutions designed for all seasons and weather conditions.
What is the Wyze Outdoor Power Adapter and what cameras is it compatible with?
The Wyze Outdoor Power Adapter is a weather-resistant power solution designed to keep your Wyze Cam v4 and other compatible models powered safely outdoors. It is compatible with Wyze Cam v3, Wyze Cam v4, Pan v3, Battery Cam Pro, and more. For Wyze Cam v3 Pro and Pan v3, it must be used with the L-shaped Micro USB Adapter, and for Wyze Battery Cam Pro, a USB-C adapter is required. It is not compatible with the OG Stack Kit.Is the Wyze Outdoor Power Adapter weatherproof?
Yes, the Wyze Outdoor Power Adapter has an IP67 weather resistance rating, making it fully capable of withstanding harsh outdoor environments, including heavy rain, snow, and dust. It operates in temperatures from -22°F to 122°F (-30°C to 50°C).What are the technical specifications of the Wyze Outdoor Power Adapter?
The Wyze Outdoor Power Adapter features an input power of 100V-240V, output power of 5V 2A, and a total cable length of 12.5 ft (3.8 m) with a 3.9 ft AC cable and 8.5 ft DC cable. It uses a Micro USB connector for the camera and a 2-pin flat, US-style connector for the wall plug.What accessories are included with the Wyze Outdoor Power Adapter?
The Wyze Outdoor Power Adapter comes with wire clips, screws, anchors, and a weatherproof L-shaped Micro-USB adapter to ensure a secure and neat installation.Why do I need the L-Shaped Micro USB Adapter for my Wyze Cam Pan v3 or v3 Pro?
The L-Shaped Micro USB Adapter is essential for connecting the Wyze Outdoor Power Adapter to Wyze Cam Pan v3 and Cam v3 Pro models. Its weatherproof design ensures a secure and protected connection for outdoor installations.Can I use the Wyze Outdoor Power Adapter with the Wyze Bird Feeder Plug-in Cam v4 Bundle?
Yes, the Wyze Bird Feeder Plug-in Cam v4 Bundle includes the Wyze Outdoor Power Adapter, ensuring your Wyze Cam v4 stays powered outdoors for reliable birdwatching and security monitoring in all weather conditions.What are the installation tips for using Wyze cameras and power adapters in extreme weather?
For best results, use the included wire clips and screws to secure cables, ensure the L-shaped adapter is properly connected, and position your camera and power adapter in sheltered locations when possible. Regularly inspect connections and cables for wear, especially after severe weather events.What are the key features of the Wyze Cam Pan v3 for outdoor use?
The Wyze Cam Pan v3 offers 360° horizontal pan, 180° vertical tilt, 1080p Full HD video, 120° field of view, night vision, two-way audio, and IP65 weather resistance. For safe outdoor use, it requires the Wyze Outdoor Power Adapter and the L-shaped Micro USB Adapter.Can the Wyze Outdoor Power Adapter be used with a solar panel?
Yes, the Wyze Bird Feeder Plug-in Cam v4 Bundle is compatible with the Wyze Solar Panel, offering a sustainable power option for your outdoor camera setup.How do I ensure a secure and weatherproof installation of my Wyze camera outdoors?
To ensure a secure and weatherproof installation, use the provided mounting kit, wire clips, and L-shaped Micro USB Adapter. Place the camera and power adapter in sheltered areas when possible, and regularly check all connections for durability.
