Wyze Outdoor Weatherproof Power Adapter for Secure Cam Install
Wyze Outdoor Weatherproof Power Adapter for Camera Installation
When it comes to setting up your Wyze cameras outdoors, having a reliable and weatherproof power source is essential. The Wyze Outdoor Power Adapter is specifically designed to keep your cameras powered safely and efficiently, no matter the weather conditions. Whether rain, snow, or shine, this adapter ensures your Wyze cameras stay connected and operational.
Why Choose the Wyze Outdoor Power Adapter?
Durable Weather-Resistant Design
The Wyze Outdoor Power Adapter boasts an IP67 weather resistance rating, making it fully capable of withstanding harsh outdoor environments. This means it is dust-tight and can handle immersion in water up to 1 meter deep for 30 minutes, ensuring your camera installation remains safe and functional through storms, snowfalls, or intense sun exposure.
Ready for rain, snow, or shine — this adapter is built to last outdoors.
Compatibility with Multiple Wyze Cameras
This power adapter is compatible with a variety of Wyze camera models, including: Wyze Cam v4
  • Wyze Cam v3 Pro (requires L-shaped Micro USB Adapter)
  • Wyze Cam Pan v3 (requires L-shaped Micro USB Adapter)
  • Wyze Battery Cam Pro (requires USB-C adapter)
Wyze Cam OG series Note that the adapters will not work with the OG Stack Kit.
Multiple Variant Options for Your Setup
The Wyze Outdoor Power Adapter comes in several variants to suit your camera and connection needs:
  • Outdoor Adapter + L-shaped Adapter + USB-C Adapter ($19.99) — Works with Cam v3/v3 Pro/v4, OG series, Pan v3, and Battery Cam Pro.
  • Outdoor Adapter + L-shaped Adapter ($14.99) — Compatible with Cam v3/v3 Pro and Cam Pan v3.
  • L-shaped Micro USB Adapter only ($5.99) — For Cam Pan v3 and Cam v3 Pro when used with Outdoor Power Adapter v1.
This flexibility allows you to customize your power solution depending on your camera model and installation requirements.
Installation and Usage Tips
  • Ensure you pair the Outdoor Power Adapter with the correct L-shaped or USB-C adapter for your specific Wyze camera model.
  • The adapter is designed for outdoor use, so it can be safely installed in exposed locations without worry.
  • Ideal for permanent outdoor camera installations where reliable power is critical.
Enhance Your Outdoor Camera Setup
Pairing the Wyze Outdoor Power Adapter with compatible Wyze cameras like the Wyze Cam v4 or Wyze Cam Pan v3 ensures continuous power and uninterrupted surveillance. This combination is perfect for monitoring your home’s exterior, driveway, garden, or any outdoor space. Outdoor Wyze Camera Installation Alt text: Wyze camera installed outdoors powered by weatherproof adapter
Summary
The Wyze Outdoor Power Adapter is the ultimate accessory for anyone looking to install Wyze cameras outdoors with confidence. Its robust weatherproof design, broad compatibility, and multiple adapter options make it a must-have for secure and reliable outdoor camera power.
FeatureWyze Outdoor Power Adapter (Only)Outdoor Adapter + L-shaped AdapterOutdoor Adapter + L-shaped Adapter + USB-C Adapter
CompatibilityWyze Cam v4, OG seriesCam v3, Cam v3 Pro, Cam Pan v3Cam v3, Cam v3 Pro, Cam Pan v3, Battery Cam Pro
Required forPowering Wyze Cam v4 or OG seriesRequired with L-shaped adapter for Cam v3/v3 Pro and Pan v3Required with L-shaped and USB-C adapters for Cam v3/v3 Pro, Pan v3, Battery Cam Pro
Weather ResistanceIP67IP67IP67
Price$13.99 (sold out)$14.99 (sold out)$19.99
NotesSold outSold outIn stock
Use CaseOutdoor power for Wyze Cam v4 or OG seriesOutdoor power for Cam v3/v3 Pro and Pan v3Outdoor power for Cam v3/v3 Pro, Pan v3, and Battery Cam Pro
Adapter Types IncludedOutdoor Power Adapter onlyOutdoor Power Adapter + L-shaped Micro USB AdapterOutdoor Power Adapter + L-shaped Micro USB Adapter + USB-C Adapter
Compatibility with OG Stack KitNot compatibleNot compatibleNot compatible
What is the Wyze Outdoor Weatherproof Power Adapter?The Wyze Outdoor Weatherproof Power Adapter is a specially designed power source for Wyze cameras, providing safe and efficient power for outdoor installations. It features a weather-resistant design to ensure your cameras remain operational in rain, snow, or sunshine.
Is the Wyze Outdoor Power Adapter weatherproof?Yes, the Wyze Outdoor Power Adapter has an IP67 weather resistance rating, making it dust-tight and capable of withstanding immersion in water up to 1 meter deep for 30 minutes. This ensures reliable performance in harsh outdoor conditions.
Which Wyze cameras are compatible with the Outdoor Power Adapter?The Wyze Outdoor Power Adapter is compatible with several Wyze camera models, including Wyze Cam v4, Wyze Cam v3 Pro (with L-shaped Micro USB Adapter), Wyze Cam Pan v3 (with L-shaped Micro USB Adapter), Wyze Battery Cam Pro (with USB-C adapter), and the Wyze Cam OG series. It is not compatible with the OG Stack Kit.
What adapter variants are available for the Wyze Outdoor Power Adapter?There are multiple variants available: 1) Outdoor Adapter + L-shaped Adapter + USB-C Adapter ($19.99) for Cam v3/v3 Pro/v4, OG series, Pan v3, and Battery Cam Pro; 2) Outdoor Adapter + L-shaped Adapter ($14.99) for Cam v3/v3 Pro and Cam Pan v3; 3) L-shaped Micro USB Adapter only ($5.99) for Cam Pan v3 and Cam v3 Pro when used with Outdoor Power Adapter v1.
Can I use the Wyze Outdoor Power Adapter with the OG Stack Kit?No, the Wyze Outdoor Power Adapter is not compatible with the OG Stack Kit.
How do I install the Wyze Outdoor Power Adapter for my camera?To install the Wyze Outdoor Power Adapter, pair it with the correct L-shaped or USB-C adapter for your specific Wyze camera model. The adapter is designed for outdoor use and can be safely installed in exposed locations for permanent camera setups.
Why should I use a weatherproof power adapter for my outdoor Wyze camera?Using a weatherproof power adapter like the Wyze Outdoor Power Adapter ensures your camera receives continuous, reliable power regardless of weather conditions. This is essential for uninterrupted surveillance and the long-term safety of your outdoor camera installation.
Where can I use the Wyze Outdoor Power Adapter?The Wyze Outdoor Power Adapter is ideal for outdoor camera installations such as monitoring your home’s exterior, driveway, garden, or any outdoor space where reliable power is needed.
What are the installation tips for the Wyze Outdoor Power Adapter?Can you tell me more about the compatibility of the Wyze Outdoor Power Adapter with different camera models?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Outdoor Power Adapter?
