Wyze Cam Pan v3 Starter Pack with MicroSD Card & Accessories
Wyze Cam Pan v3 Camera Starter Pack with Micro SD Card
Looking for a versatile, weatherproof security camera starter pack? The Wyze Cam Pan v3 combined with a compatible microSD card and essential power accessories offers an unbeatable solution for both indoor and outdoor surveillance. This starter pack is perfect for homeowners, pet owners, and anyone wanting comprehensive 360° coverage with local storage options.
Wyze Cam Pan v3: The Ultimate Pan & Tilt Security Camera
360° Pan and 180° Tilt for Full Coverage
The Wyze Cam Pan v3 is a redesigned security camera that offers a full 360° horizontal pan and an impressive 180° vertical tilt. This means it can look straight up and down, covering every corner of your room or outdoor space without blind spots.
Weather-Resistant for Outdoor Use
Rated IP65 weather resistant, the Pan v3 is built to withstand rain, snow, and dust, making it ideal for outdoor monitoring. (Note: For outdoor use, the camera requires the Wyze Outdoor Power Adapter and L-shaped Micro USB Adapter sold separately.)
Whether it’s a snowy winter day or a rainy afternoon, the Pan v3 keeps an eye on your property without missing a beat.
Wyze Cam Pan v3 in snowy outdoor setting Wyze Cam Pan v3 weatherproof outdoor security
Advanced Motion Tracking & Notifications
The camera automatically detects motion and quietly tracks moving objects with its upgraded motor, ensuring you never miss important activity. It sends instant alerts to your phone for motion or sound detection, including smart notifications for pets, packages, or people with a Cam Plus subscription.
Color Night Vision & Privacy Mode
Equipped with a Starlight Sensor, the Pan v3 delivers vibrant color night vision, so you get clear, detailed footage even in low light. When you want privacy, simply enable Privacy Mode in the app, and the camera will point its lens downward, turning off its field of view.
Two-Way Audio for Real-Time Communication
Speak and listen through the camera using the Wyze app. Whether it’s greeting visitors or calming pets, the two-way audio feature keeps you connected wherever you are.
Essential Accessories for Outdoor Use
To safely power your Wyze Cam Pan v3 outdoors, the Wyze Outdoor Power Adapter is a must-have. It is IP67 rated for weather resistance and comes with wire clips, screws, and a weatherproof L-shaped Micro USB adapter to ensure a secure and durable installation.
  • Cable length: 12.5 ft for flexible placement
  • Operating temperature: -30°C to 50°C (-22°F to 122°F)
  • Compatible with Wyze Cam Pan v3 and other Wyze cameras
Wyze L-Shaped Micro USB Adapter
This adapter works with the Outdoor Power Adapter to connect seamlessly to the Pan v3 camera, allowing for neat and weatherproof cable management.
MicroSD Cards for Local Storage
Wyze offers microSD cards in various sizes (32GB, 128GB, 256GB) that are fully compatible with the Pan v3 camera. Using a microSD card allows you to store continuous video locally without relying solely on cloud storage, giving you more control and privacy over your footage.
Why Choose the Wyze Cam Pan v3 Starter Pack?
  • All-in-One Security Solution: Includes a high-performance pan & tilt camera, power adapter, and local storage options.
  • Indoor & Outdoor Versatility: Weatherproof design with flexible mounting and power solutions.
  • Smart Features: Motion tracking, color night vision, two-way audio, and privacy mode.
  • Expandable Storage: Supports microSD cards up to 256GB for continuous recording.
  • Affordable & Reliable: Award-winning camera technology at a competitive price point.
Two-way audio feature with pet interaction Stay connected with two-way audio
Summary of Included Products in the Starter Pack
ProductKey FeaturesPrice Range
Wyze Cam Pan v3360° pan, 180° tilt, IP65 weather resistant, color night vision, two-way audioFrom $39.98 (1 pack)
Wyze Outdoor Power AdapterIP67 weatherproof, 12.5 ft cable, includes L-shaped Micro USB adapterFrom $14.99
Wyze L-Shaped Micro USB AdapterWeatherproof adapter for outdoor power setup$5.99
Wyze MicroSD CardLocal storage, 32GB to 256GB optionsFrom $8.99
Enhance Your Home Security Today
The Wyze Cam Pan v3 starter pack with microSD card and outdoor power accessories is the perfect choice for anyone looking to upgrade their home or business security with a reliable, feature-rich camera system. Enjoy peace of mind with smart notifications, full coverage, and weatherproof durability.
FeatureWyze Cam Pan v3Wyze Outdoor Power AdapterWyze L-Shaped Micro USB Adapter
TypeCameraAccessoryReplacement Part
DescriptionIndoor/outdoor 360° pan, 180° tilt security camera, IP65 weather resistant. Requires Outdoor Power Adapter for safe outdoor use.IP67 weather-resistant power adapter for outdoor use. Required with Pan v3 for outdoor use.Adapter to enable Outdoor Power Adapter or Micro USB cable to work with Pan v3 or Cam v3 Pro.
Weather ResistanceIP65IP67Not specified
CompatibilityN/AWyze Cam v3, Wyze Cam v4, Pan v3, Battery Cam ProWyze Cam Pan v3, Wyze Cam v3 Pro, Wyze Outdoor Adapter v1
Power Input110-240V (AC/DC)100-240VN/A
Power Output5V/2000mA5V/2AN/A
Connector to Camera1 micro USBMicro USBMicro USB
Cable Length6" (1.8 m) power cableTotal 12.5 ft (3.8 m): AC cable 3.9 ft (1.2 m), DC cable 8.5 ft (2.6 m)N/A
Dimensions124mm (H) x 60mm (W) x 63mm (D)78.7 mm x 62.5 mm x 29.4 mmNot specified
Weight11.29 oz (320 g)235 gNot specified
CertificationsFCC, IC, UL, TSCA, IP65FCC, ULNot specified
Warranty1-Year1-YearNot specified
Additional Features360° horizontal pan, 180° vertical tilt, 1080p video, 2-way audio, night vision, push notificationsIncludes wire clips, screws, weatherproof L-shaped Micro USB adapterEnables use of Outdoor Power Adapter with Pan v3 or Cam v3 Pro
What is included in the Wyze Cam Pan v3 Camera Starter Pack?The Wyze Cam Pan v3 Camera Starter Pack includes the Wyze Cam Pan v3 security camera, a compatible microSD card (available in 32GB, 128GB, or 256GB), and essential power accessories such as the Wyze Outdoor Power Adapter and L-shaped Micro USB Adapter for outdoor installation.
Is the Wyze Cam Pan v3 suitable for outdoor use?Yes, the Wyze Cam Pan v3 is IP65 weather resistant, making it suitable for both indoor and outdoor use. For outdoor installation, it requires the Wyze Outdoor Power Adapter and L-shaped Micro USB Adapter, which are included in the starter pack.
What are the pan and tilt capabilities of the Wyze Cam Pan v3?The Wyze Cam Pan v3 offers a full 360° horizontal pan and 180° vertical tilt, allowing it to cover every corner of your room or outdoor area without blind spots.
Does the Wyze Cam Pan v3 support local video storage?Yes, the Wyze Cam Pan v3 supports local video storage via microSD cards. You can use microSD cards up to 256GB to store continuous video footage without relying solely on cloud storage.
What smart features does the Wyze Cam Pan v3 offer?The Wyze Cam Pan v3 features advanced motion tracking, instant motion and sound notifications, color night vision with a Starlight Sensor, two-way audio for real-time communication, and a privacy mode that turns off the camera’s field of view.
How does the Wyze Cam Pan v3 handle night vision?The Wyze Cam Pan v3 is equipped with a Starlight Sensor that provides vibrant color night vision, ensuring clear and detailed footage even in low-light conditions.
What is the Wyze Outdoor Power Adapter and why is it important?The Wyze Outdoor Power Adapter is an IP67 weatherproof power solution designed for outdoor use with the Wyze Cam Pan v3. It includes a 12.5 ft cable, wire clips, screws, and a weatherproof L-shaped Micro USB adapter for secure and flexible installation.
Can I communicate through the Wyze Cam Pan v3?Yes, the Wyze Cam Pan v3 features two-way audio, allowing you to speak and listen through the camera using the Wyze app. This is useful for greeting visitors or interacting with pets remotely.
What microSD card sizes are compatible with the Wyze Cam Pan v3?The Wyze Cam Pan v3 is compatible with Wyze microSD cards in 32GB, 128GB, and 256GB sizes, providing flexible options for local video storage.
What makes the Wyze Cam Pan v3 Starter Pack a good choice for home security?The Wyze Cam Pan v3 Starter Pack offers an all-in-one security solution with a high-performance pan and tilt camera, weatherproof power accessories, expandable local storage, and smart features like motion tracking, color night vision, and two-way audio—all at an affordable price.
What are the key features of the Wyze Cam Pan v3 camera?Can you tell me more about the microSD card options available for the Wyze Cam Pan v3?Are there any ongoing promotions or discounts for the Wyze Cam Pan v3 starter pack?
