Refurbished Wyze Security Cameras with 3x Telephoto Lens for Indoor & Outdoor Use
When it comes to securing your home or business, having a reliable security camera that works both indoors and outdoors is essential. If you're searching for a
refurbished Wyze security camera with a 3x telephoto lens, you want a device that offers crystal-clear video, versatile installation options, and advanced features to keep your property safe around the clock.
Wyze offers several excellent options that fit this description, including cameras with telephoto lenses and outdoor-ready designs. Below, we explore the best Wyze products tailored for indoor and outdoor security, highlighting their specs and unique benefits.
Wyze Cam OG Bundle: Affordable 3x Telephoto Lens Camera for Indoor & Outdoor Use
Key Features:
- 3x Telephoto Lens: Zoom in on important details with a narrow 27° diagonal field of view, perfect for focused surveillance.
- 1080p Full HD Video: Crisp 1920 x 1080 resolution ensures clear images day and night.
- Indoor and Outdoor Rated (IP65): Weather-resistant design lets you install it inside or outside without worry.
- Built-in Spotlight: 5000K, 40 lumens spotlight enhances night vision and deters intruders.
- Fast Notifications & 2-Way Audio: Get alerts 3x faster and communicate through the built-in speaker and microphone with noise and echo cancellation.
- Local Storage Support: Compatible with up to 256 GB microSD cards for continuous recording.
- Compact & Lightweight: Only 4.1 oz and 1.89 inches cube size, easy to place anywhere.
This camera is ideal for users who want a budget-friendly, versatile security solution with telephoto zoom capabilities for detailed monitoring.
Wyze Cam v4 Outdoor Bundle: Advanced Outdoor Security with Enhanced Night Vision
Key Features:
- 2.5K QHD Resolution: Ultra-clear video quality with wide dynamic range (WDR) for balanced lighting.
- Enhanced Color Night Vision: See vivid colors even in low light conditions.
- Motion-Activated Spotlight: Automatically lights up when motion is detected to deter unwanted visitors.
- 24/7 Local Recording: Continuous recording with included 128GB microSD card.
- Wi-Fi 6 Support: Faster, more reliable wireless connectivity.
- Smart Assistant Compatibility: Works seamlessly with Alexa and Google Assistant.
- Outdoor Ready: Designed specifically for outdoor use with weatherproof housing.
- Additional Sensors: Smoke and CO alerts integrated for comprehensive home safety.
This bundle is perfect for those who want a high-resolution, feature-rich outdoor camera with smart home integration and reliable night vision.
Wyze Cam Floodlight v2 providing security and illumination outdoors
Wyze Cam Floodlight v2: Powerful Outdoor Security with 2800 Lumens LED Lighting
Key Features:
- 2800 Lumens Brightness: Two dimmable LED light panels flood your outdoor area with bright, clear light.
- 2K Video with Color Night Vision: High-quality video capture day and night.
- 160° Wide-Angle View: Covers a broad area for maximum surveillance.
- AI-Powered Light Control: Automatically adjusts lighting based on motion and ambient light.
- Two-Way Audio & Siren: Built-in speaker and microphone plus a 105dB siren for active deterrence.
- Dusk-to-Dawn Automation: Lights turn on and off automatically based on natural light.
- Weather Resistant (IP65): Built to withstand harsh outdoor conditions.
- Smart Home Integration: Compatible with Alexa, Google Assistant, and IFTTT.
This floodlight camera is ideal for users who want to combine powerful lighting with security monitoring, perfect for driveways, garages, and front porches.
Why Choose Refurbished Wyze Security Cameras?
Refurbished Wyze cameras offer the same trusted features and performance as new models but at a more affordable price point. They undergo rigorous testing to ensure quality and reliability, making them a smart choice for budget-conscious buyers who don’t want to compromise on security.
Wyze’s lineup with telephoto lenses and outdoor capabilities ensures you get detailed, reliable surveillance whether inside your home or monitoring your property’s exterior.
Summary of Recommended Wyze Security Cameras with 3x Telephoto Lens
Product Name | Telephoto Lens | Resolution | Indoor/Outdoor | Night Vision Type | Special Features | Price Range |
Wyze Cam OG Bundle | Yes (3x) | 1080p | Indoor & Outdoor (IP65) | IR Night Vision (4 IR LEDs) | Built-in spotlight, 8x digital zoom | $74.99 |
Wyze Cam v4 Outdoor Bundle | No | 2.5K QHD | Outdoor | Enhanced Color Night Vision | Motion spotlight, Wi-Fi 6, 24/7 recording | $69.99 |
Wyze Cam Floodlight v2 | No | 2K | Outdoor | Color Night Vision | 2800 lumens floodlight, AI light control | $89.98 |
Conclusion
For those specifically seeking a
refurbished Wyze security camera with a 3x telephoto lens suitable for both indoor and outdoor use, the
Wyze Cam OG Bundle stands out as the best choice. It combines affordability, telephoto zoom, and weather resistance in a compact design.
If you want enhanced outdoor security with superior video quality and lighting, consider the
Wyze Cam v4 Outdoor Bundle or the
Wyze Cam Floodlight v2 for powerful illumination and smart features.
Investing in these Wyze cameras ensures you get reliable, high-quality surveillance that keeps your home safe day and night.
Control your Wyze Cam Floodlight v2 easily from your smartphone
What are the benefits of choosing a refurbished Wyze security camera?
Refurbished Wyze security cameras offer the same trusted features and performance as new models but at a more affordable price. Each refurbished camera undergoes rigorous testing to ensure quality and reliability, making them a smart choice for budget-conscious buyers who don’t want to compromise on security.Which Wyze security camera has a 3x telephoto lens for indoor and outdoor use?
The Wyze Cam OG Bundle features a 3x telephoto lens, making it ideal for both indoor and outdoor use. It offers a narrow 27° diagonal field of view for focused surveillance, 1080p Full HD video, weather-resistant IP65 rating, and a built-in spotlight for enhanced night vision.Is the Wyze Cam OG Bundle suitable for outdoor installation?
Yes, the Wyze Cam OG Bundle is rated IP65 for weather resistance, making it suitable for both indoor and outdoor installation. Its compact and lightweight design allows for versatile placement around your property.What are the key features of the Wyze Cam OG Bundle?
The Wyze Cam OG Bundle includes a 3x telephoto lens, 1080p Full HD video, IP65 weather resistance, a built-in 5000K spotlight, fast notifications, two-way audio with noise and echo cancellation, support for up to 256GB microSD cards, and a compact design.Does the Wyze Cam OG Bundle support local video storage?
Yes, the Wyze Cam OG Bundle supports local storage with microSD cards up to 256GB, allowing for continuous video recording and playback without a subscription.What is the difference between the Wyze Cam OG Bundle and the Wyze Cam v4 Outdoor Bundle?
The Wyze Cam OG Bundle features a 3x telephoto lens and is suitable for both indoor and outdoor use, while the Wyze Cam v4 Outdoor Bundle offers 2.5K QHD resolution, enhanced color night vision, motion-activated spotlight, Wi-Fi 6 support, and is designed specifically for outdoor use. The v4 does not have a telephoto lens.What makes the Wyze Cam Floodlight v2 a good choice for outdoor security?
The Wyze Cam Floodlight v2 combines powerful 2800 lumens LED lighting with 2K video resolution, color night vision, a 160° wide-angle view, AI-powered light control, two-way audio, a 105dB siren, dusk-to-dawn automation, and weather-resistant IP65 housing. It is ideal for illuminating and monitoring large outdoor areas like driveways and porches.Are Wyze security cameras compatible with smart home assistants?
Yes, Wyze security cameras such as the Wyze Cam v4 Outdoor Bundle and Wyze Cam Floodlight v2 are compatible with Alexa, Google Assistant, and IFTTT, allowing for seamless smart home integration and voice control.Which Wyze camera is best for detailed monitoring with telephoto zoom?
The Wyze Cam OG Bundle is the best choice for detailed monitoring with its 3x telephoto lens, providing focused surveillance and clear video both indoors and outdoors.Do Wyze security cameras offer night vision capabilities?
Yes, Wyze security cameras offer various night vision features. The Wyze Cam OG Bundle has IR night vision with a built-in spotlight, the Wyze Cam v4 Outdoor Bundle features enhanced color night vision, and the Wyze Cam Floodlight v2 provides 2K video with color night vision and powerful LED lighting for clear nighttime footage.
