Pan v3 Camera Bundle: Complete Setup with Adapter and MicroSD Card
If you're looking to enhance your home security with the versatile
Wyze Cam Pan v3, this bundle is designed to provide everything you need for a seamless installation and reliable operation. From powering your camera smartly to mounting it securely and expanding storage with a MicroSD card, this bundle covers all essentials.
Wyze Lamp Socket v2: Smart Power Adapter for Pan v3
Power Your Pan v3 Camera Without a Plug
The
Wyze Lamp Socket v2 is the perfect power solution for your Wyze Cam Pan v3. This innovative lamp socket allows you to power your camera directly from an existing outdoor light fixture, eliminating the need for additional power outlets or complicated wiring.
- Compatibility: Supports Wyze Cam v3, v3 Pro, v4, Cam OG, and Pan v3.
- Easy Installation: Screws in just like a regular light bulb, making setup quick and hassle-free.
- Smart Lighting Integration: Enables motion-activated lighting when paired with your camera.
- Compact & Durable: Made from polycarbonate and plastic, designed for damp locations (not fully waterproof).
- Power Specs: 120V~, 60Hz input with a max lamp power of 20W (use CFL or LED bulbs recommended).
Upgrade your outdoor lighting and camera power source simultaneously with this smart adapter.
Wyze Cam Mounting Kit: Secure and Flexible Installation
Mount Your Pan v3 Camera Anywhere with Confidence
The
Wyze Cam Mounting Kit is designed to provide a sturdy and flexible mounting solution for your Pan v3 camera. Whether you want to install it on a wall, ceiling, or other surfaces, this kit has you covered.
- Complete Kit: Includes a mounting bracket, adhesive tape, screws, and a 5-foot USB extension cable.
- Compatibility: Works with Wyze Cam v2, v3, and v3 Pro.
- Extended Reach: The longer USB cable allows for flexible placement without worrying about power outlet proximity.
- Easy Setup: Adhesive and screws provide multiple mounting options for different surfaces.
Ensure your Pan v3 camera is positioned perfectly for optimal coverage and security.
MicroSD Card: Expand Your Storage for Continuous Recording
While the bundle focuses on the Pan v3 camera and its essential accessories, adding a MicroSD card is crucial for local video storage. With a MicroSD card installed, your Pan v3 can record continuously or on motion detection, giving you peace of mind with saved footage accessible anytime.
- Recommended Capacity: 32GB to 128GB for ample storage.
- Supports Continuous and Event Recording: Store hours of video locally without relying solely on cloud storage.
- Easy to Install: Insert into the camera’s MicroSD slot for instant use.
Why Choose the Pan v3 Camera Bundle?
- Complete Power Solution: The Wyze Lamp Socket v2 powers your camera smartly without extra wiring.
- Secure Mounting: The mounting kit ensures your camera stays firmly in place.
- Expandable Storage: Add a MicroSD card for reliable local video recording.
- Smart Home Integration: Control and monitor your camera and lighting through the Wyze app.
- Weather-Resistant Setup: Designed for outdoor use with durable components.
Protect your home with a smart, easy-to-install Pan v3 camera bundle that includes everything you need for power, mounting, and storage.
Summary of Included Products
Wyze Lamp Socket v2
Power your Pan v3 camera via outdoor light fixture without extra plugs.
Secure mounting bracket, adhesive, screws, and USB extension cable for flexible installation.
MicroSD Card (recommended separately)
Expand your camera’s storage for continuous and event video recording.
Optimize your home security setup today with the Pan v3 camera bundle — smart power, secure mounting, and reliable storage all in one package.
What is included in the Pan v3 Camera Bundle?
The Pan v3 Camera Bundle includes the Wyze Cam Pan v3, Wyze Lamp Socket v2 for smart power, a Wyze Cam Mounting Kit for secure installation, and a recommended MicroSD card for expanded local storage.How does the Wyze Lamp Socket v2 power the Pan v3 camera?
The Wyze Lamp Socket v2 allows you to power your Pan v3 camera directly from an existing outdoor light fixture, eliminating the need for extra power outlets or complicated wiring. It simply screws in like a regular light bulb.Is the Wyze Lamp Socket v2 compatible with other Wyze cameras?
Yes, the Wyze Lamp Socket v2 is compatible with Wyze Cam v3, v3 Pro, v4, Cam OG, and Pan v3 models.Can I use the Pan v3 camera outdoors?
Yes, the Pan v3 camera and its accessories are designed for outdoor use. The Wyze Lamp Socket v2 is made from durable materials suitable for damp locations, and the mounting kit provides secure installation options for various surfaces.What mounting options are available with the Wyze Cam Mounting Kit?
The Wyze Cam Mounting Kit includes a mounting bracket, adhesive tape, screws, and a 5-foot USB extension cable, allowing you to mount your Pan v3 camera on walls, ceilings, or other surfaces with flexible placement.What size MicroSD card is recommended for the Pan v3 camera?
A MicroSD card with a capacity between 32GB and 128GB is recommended for the Pan v3 camera to ensure ample storage for continuous or event-based video recording.Does the Pan v3 camera support continuous recording?
Yes, with a MicroSD card installed, the Pan v3 camera supports both continuous and motion-triggered event recording, allowing you to store hours of video locally.Can I control the Pan v3 camera and lighting through the Wyze app?
Yes, the Pan v3 camera bundle supports smart home integration, allowing you to control and monitor your camera and lighting directly through the Wyze app.Is the Wyze Lamp Socket v2 fully waterproof?
The Wyze Lamp Socket v2 is designed for damp locations but is not fully waterproof. It is suitable for outdoor use in covered areas.What type of light bulbs can be used with the Wyze Lamp Socket v2?
The Wyze Lamp Socket v2 supports a maximum lamp power of 20W and is recommended for use with CFL or LED bulbs.
