Buy Wyze Cam v3 Pro: Smart Focus Motion Detection & Bundles
Wyze Cam v3 Pro: Smart Focus Motion Detection and Purchase Guide
If you're looking to purchase the Wyze Cam v3 Pro with advanced smart focus motion detection, this page highlights the best options and accessories to maximize your smart home security experience. The Wyze Cam v3 Pro is designed to deliver precise motion tracking, clear video quality, and seamless integration with smart home systems.
Ultimate Security Bundle Featuring Wyze Cam v3 Pro
All-in-One Smart Home Security Solution
The Ultimate Security Bundle (13-piece) is the perfect package for anyone wanting comprehensive protection inside and outside their home. This bundle includes:
  • Wyze Cam Duo Doorbell: Dual cameras for full head-to-toe and front porch visibility with two-way audio and smart alerts.
  • Wyze Lock Bolt: Keyless entry with fingerprint reader and illuminated keypad.
  • 2× Wyze Cam Pan v3: Pan-and-tilt cameras with motion tracking and color night vision.
  • 2× Wyze Cam v4: Indoor/outdoor cameras with enhanced clarity and smart motion detection.
  • 2× Wyze Battery Cam Pro: Wire-free cameras with advanced AI detection and color night vision.
  • Wyze Sense Hub: Central hub connecting all sensors for instant alerts.
  • Motion Sensor & Entry Sensors: Detects motion and open doors/windows for proactive security.
This bundle includes Wyze Cam Pan v3 cameras that complement the Wyze Cam v3 Pro’s smart focus motion detection by providing pan-and-tilt capabilities with motion tracking, ensuring no movement goes unnoticed.
The Ultimate Security Bundle offers unmatched peace of mind by combining intelligent cameras, advanced entry protection, and seamless connectivity through the Wyze app.
Powering Your Wyze Cam v3 Pro: Smart and Convenient Accessories
Wyze Lamp Socket v2
Make your exterior lighting smarter and more convenient with the Wyze Lamp Socket v2. This accessory powers your Wyze Cam v3 Pro (as well as Wyze Cam v3, v4, and others) without needing a traditional power outlet. It fits standard E26 sockets and supports 120V power input.
  • Compatible with Wyze Cam v3 Pro and other Wyze cameras.
  • Easy installation in existing lamp sockets.
  • Supports 2.4GHz Wi-Fi and Bluetooth connectivity.
  • Ideal for damp locations (not fully weatherproof).
This lamp socket is perfect for outdoor setups where power outlets are limited, enabling your Wyze Cam v3 Pro to stay powered continuously for reliable motion detection.
Wyze Outdoor Power Adapter
For outdoor use, the Wyze Outdoor Power Adapter is essential. It is IP67 weather-resistant, ensuring your Wyze Cam v3 Pro stays powered rain or shine. This adapter comes with a weatherproof L-shaped Micro USB adapter, making it perfect for outdoor installations.
  • Designed specifically for Wyze Cam v3 Pro and Pan v3.
  • Includes wire clips and screws for secure mounting.
  • Supports operating temperatures from -22°F to 122°F.
  • Provides a stable 5V/2A power output.
Using this adapter guarantees your Wyze Cam v3 Pro remains operational in all weather conditions, maintaining smart focus motion detection without interruption.
Mounting and Cable Solutions for Optimal Placement
Wyze Cam Mounting Kit
To get the best angle and coverage for your Wyze Cam v3 Pro, the Wyze Cam Mounting Kit is a must-have accessory. It includes:
  • Wall plate for secure mounting.
  • Adhesive tape for easy installation.
  • 5-foot USB extension cable for flexible placement.
  • Screws for added stability.
This kit ensures your camera is positioned perfectly to maximize the smart focus motion detection capabilities of the Wyze Cam v3 Pro.
Wyze Cam USB Extension Cable - 20ft
If you need even more flexibility, the 20ft USB Extension Cable allows you to place your Wyze Cam v3 Pro far from power sources without compromising connectivity or power.
  • Weather-resistant cable rated IP67.
  • Durable and long enough for versatile installation options.
Why Choose Wyze Cam v3 Pro for Smart Focus Motion Detection?
  • Advanced AI Motion Detection: Precisely tracks and focuses on moving objects, reducing false alerts.
  • Color Night Vision: See clear, colorful video even in low light.
  • Two-Way Audio: Communicate through the camera remotely.
  • Weather-Resistant Design: Suitable for indoor and outdoor use.
  • Seamless App Integration: Control and monitor your camera from anywhere.
Smart Home Security Setup
Enhance your home security with Wyze Cam v3 Pro and its smart focus motion detection, supported by a range of accessories designed for convenience and durability.
Summary of Recommended Products for Wyze Cam v3 Pro
Product NameKey FeaturesPrice (USD)
Ultimate Security BundleComplete security system with multiple cameras and sensors499.99
Wyze Lamp Socket v2Powers Wyze Cam v3 Pro via lamp socket16.98
Wyze Outdoor Power AdapterWeatherproof power adapter for outdoor use19.99 (bundle)
Wyze Cam Mounting KitMounting bracket, adhesive, and USB cable5.99
Wyze Cam USB Extension Cable20ft weather-resistant USB extension cable7.99
Investing in the Wyze Cam v3 Pro along with these accessories ensures you get the most out of smart focus motion detection technology, providing reliable, clear, and intelligent home security.
Feature / ProductUltimate Security Bundle (13-piece)Wyze Lamp Socket v2Wyze Cam Mounting KitWyze Outdoor Power Adapter
TypeSmart Home Security SystemAccessoriesAccessoriesAccessories
Price$499.99$16.98$5.99$14.99 - $19.99 (varies by style)
DescriptionComplete security system with cameras, lock, sensors, and hub for full property protectionPowers Wyze Cam v3/v3 Pro/v4, Cam OG, Pan v3 without power outletMounting bracket, adhesive, and longer Micro USB cable for Wyze Cam v2, v3, v3 ProWeather-resistant power adapter for outdoor use with Wyze cameras
Included ItemsWyze Cam Duo Doorbell, Wyze Lock Bolt, 2× Wyze Cam Pan v3, 2× Wyze Cam v4, 2× Wyze Battery Cam Pro, Wyze Sense Hub, 1× Motion Sensor, 3× Entry SensorsN/AWall Plate, USB Extension Cable (5 ft), Adhesive Tape, Screw SetWyze Outdoor Power Adapter, Wire Clips, Screws, Screw Anchors, L-shaped Adapter, Weatherproof L-shaped Micro-USB Adapter
CompatibilityWorks with Wyze app and devices included in bundleWyze Cam v3, v3 Pro, v4, Cam OG, Pan v3Wyze Cam v2, v3, v3 ProWyze Cam v3, v4, Pan v3, Battery Cam Pro, OG series
Power InputN/A120V~, 60HzN/A100V-240V
Weather ResistanceN/ANot weatherproof, suitable for damp locationsN/AIP67 weather resistant
ConnectivityIntegrated via Wyze Sense Hub and Wyze app802.11 b/g/n 2.4GHz, BluetoothN/AN/A
Key FeaturesDual cameras, fingerprint lock, pan-tilt cameras, AI detection, motion sensors, two-way audio, smart alertsPowers cameras without outlet, compatible with multiple Wyze camsEasy mounting solution with adhesive and screwsOutdoor rated power adapter with included adapters for various Wyze cameras
DimensionsN/A56.5mm x 56.5mm x 65mmN/A78.7 mm x 62.5 mm x 29.4 mm
WeightN/A80 gN/A235 g
WarrantyN/A1 YearN/A1 Year
What is the Wyze Cam v3 Pro and what are its main features?The Wyze Cam v3 Pro is a smart home security camera designed for advanced smart focus motion detection. Its main features include precise AI-powered motion tracking, color night vision, two-way audio, weather-resistant design for indoor and outdoor use, and seamless integration with the Wyze app for remote monitoring and control.
What is included in the Ultimate Security Bundle featuring Wyze Cam v3 Pro?The Ultimate Security Bundle (13-piece) includes a Wyze Cam Duo Doorbell, Wyze Lock Bolt, 2 Wyze Cam Pan v3 cameras, 2 Wyze Cam v4 cameras, 2 Wyze Battery Cam Pro cameras, Wyze Sense Hub, motion and entry sensors, and accessories for comprehensive home security. This bundle provides full coverage inside and outside your home, combining intelligent cameras and advanced entry protection.
How does the Wyze Cam v3 Pro’s smart focus motion detection work?Wyze Cam v3 Pro uses advanced AI motion detection to precisely track and focus on moving objects, reducing false alerts and ensuring you are notified only of important activity. This technology helps enhance your home security by providing accurate and reliable motion alerts.
What accessories are recommended for powering the Wyze Cam v3 Pro outdoors?For outdoor power, the Wyze Outdoor Power Adapter is recommended. It is IP67 weather-resistant, supports temperatures from -22°F to 122°F, and comes with a weatherproof L-shaped Micro USB adapter, wire clips, and screws for secure mounting. This ensures your Wyze Cam v3 Pro remains powered and operational in all weather conditions.
Can I power the Wyze Cam v3 Pro using a lamp socket?Yes, the Wyze Lamp Socket v2 allows you to power the Wyze Cam v3 Pro (and other Wyze cameras) using a standard E26 lamp socket. It supports 120V input, is easy to install, and is ideal for locations where traditional power outlets are not available.
What mounting options are available for the Wyze Cam v3 Pro?The Wyze Cam Mounting Kit is available for optimal placement of your Wyze Cam v3 Pro. It includes a wall plate, adhesive tape, a 5-foot USB extension cable, and screws for secure and flexible installation, ensuring the best angle for motion detection.
Is there a way to extend the power cable for the Wyze Cam v3 Pro?Yes, the Wyze Cam USB Extension Cable (20ft) is a weather-resistant cable that allows you to place your Wyze Cam v3 Pro farther from power sources without losing connectivity or power. It is durable and suitable for both indoor and outdoor installations.
What are the benefits of using the Wyze Cam v3 Pro for home security?The Wyze Cam v3 Pro offers advanced AI motion detection, color night vision, two-way audio, weather-resistant design, and seamless app integration. These features provide reliable, clear, and intelligent home security, making it an excellent choice for protecting your property.
Are the accessories compatible with other Wyze cameras?Yes, many accessories such as the Wyze Lamp Socket v2 and the Wyze Cam USB Extension Cable are compatible with other Wyze cameras, including Wyze Cam v3, v4, and Pan v3, offering flexibility for your smart home setup.
How can I purchase the Wyze Cam v3 Pro and its recommended accessories?You can purchase the Wyze Cam v3 Pro and its recommended accessories, such as the Ultimate Security Bundle, Wyze Lamp Socket v2, Wyze Outdoor Power Adapter, Wyze Cam Mounting Kit, and Wyze Cam USB Extension Cable, through the official Wyze website or authorized retailers.
Can you tell me more about the features of the Wyze Cam v3 Pro?What accessories do you recommend for the Wyze Cam v3 Pro?Are there any discounts or promotions available for the Wyze Cam v3 Pro?
