Wyze Outdoor Power Adapter for Weather Resistant Camera Installation and Replacement
When it comes to installing or replacing power adapters for your Wyze outdoor cameras, the
Wyze Outdoor Power Adapter stands out as the perfect solution. Designed specifically to withstand harsh weather conditions, this adapter ensures your Wyze cameras stay powered reliably rain or shine.
Wyze Outdoor Power Adapter: Durable and Weather-Resistant Power Solution
Built for All Weather Conditions
The Wyze Outdoor Power Adapter is rated
IP67 weather-resistant, making it ideal for outdoor use in rain, snow, or extreme temperatures ranging from -30°C to 50°C (-22°F to 122°F). This robust protection guarantees your camera’s power supply remains uninterrupted regardless of the elements.
Compatibility and Versatility
- Compatible with popular Wyze cameras including Wyze Cam v3, Cam v4, Pan v3, and Battery Cam Pro.
- Note: Some cameras like Wyze Cam v3 Pro and Pan v3 require both the Outdoor Power Adapter and the L-shaped MicroUSB Adapter for proper installation. Battery Cam Pro also requires the USB-C adapter.
- Not compatible with the OG Stack Kit.
Convenient Cable Lengths and Design
- Total cable length of 12.5 ft (3.8 m) allows flexible placement of your camera.
- Compact dimensions (78.7 mm x 62.5 mm x 29.4 mm) and lightweight (235 g) design make installation easy and unobtrusive.
- Comes with wire clips, screws, anchors, and weatherproof L-shaped Micro-USB adapter for secure and neat setup.
Certified Safety and Warranty
- FCC and UL certified for safety and reliability.
- Backed by a 1-year warranty for peace of mind.
Ready for rain, snow, or shine, the Wyze Outdoor Power Adapter is your go-to accessory for powering Wyze outdoor cameras safely and efficiently.
Wyze Cam Pan v3: The Perfect Outdoor Camera Companion
360° Pan and 180° Tilt with Weather Resistance
The
Wyze Cam Pan v3 is a versatile indoor/outdoor security camera featuring a full 360° horizontal pan and 180° vertical tilt, allowing you to monitor wide areas with ease. It boasts an
IP65 weather resistance rating, making it suitable for outdoor use when paired with the Wyze Outdoor Power Adapter.
High-Quality Video and Audio
- Full HD 1080p video resolution with H.264 encoding.
- Night vision with 4 IR LEDs for clear images in low light.
- Built-in speaker and microphone enable 2-way audio with noise and echo cancellation.
- Push notifications keep you informed of activity in real-time.
Smart Features and Integration
- Compatible with Alexa, Google Assistant, and IFTTT for seamless smart home integration.
- Supports up to 256 GB microSD card for local storage.
- Connects via 2.4 GHz Wi-Fi for reliable streaming.
Compact and Stylish Design
- Matte finish with polycarbonate body and glass/plastic lens.
- Dimensions: 124mm (H) x 60mm (W) x 63mm (D), weighing just 320 g.
- Easy mounting with a 1/4" - 20 screw mount.
For optimal outdoor performance, the Pan v3 requires the Wyze Outdoor Power Adapter, ensuring your camera stays powered through all weather conditions.
Wyze Cam Pan v3 powered outdoors in winter weather
Bundles Featuring Wyze Outdoor Power Adapter
This bundle includes the
Wyze Bird Feeder,
Wyze Cam v4, and the
Wyze Outdoor Power Adapter — a perfect setup for birdwatching enthusiasts who want to monitor feathered visitors year-round. The adapter ensures your camera stays powered outdoors, while the bird feeder attracts a variety of birds with its vibrant design.
- Weather-resistant for all seasons.
- Multiple mounting options: wall, tree, pole, cord, suction cup.
- Compatible with Wyze Solar Panel for sustainable power.
Wyze Cam Pan v3 + 30-Day Cam Plus Bundle
Get the Wyze Cam Pan v3 bundled with a power adapter, mounting kit, and a 30-day Cam Plus subscription. This bundle offers a complete outdoor security solution with the convenience of continuous power and enhanced cloud features.
Pan v3 Security Bundle
Includes two Wyze Cam Pan v3 cameras, power adapters, mounting kits, and 32GB microSD cards. Ideal for comprehensive outdoor surveillance, this bundle ensures your cameras are always powered and ready to capture every angle.
Why Choose Wyze Outdoor Power Adapter?
- Reliable Weatherproofing: IP67 rating protects against dust and water ingress.
- Easy Installation: Comes with all necessary mounting hardware and adapters.
- Wide Compatibility: Supports multiple Wyze camera models for versatile use.
- Safe and Certified: FCC and UL certifications guarantee safety and quality.
- Long Cable Length: Flexible placement options for your outdoor cameras.
Ensure your Wyze outdoor cameras perform at their best with the Wyze Outdoor Power Adapter — the essential accessory for weather-resistant, reliable power.
Summary
For anyone looking to install or replace a power adapter for their Wyze outdoor cameras, the
Wyze Outdoor Power Adapter is the ideal choice. Its weather-resistant design, compatibility with multiple Wyze camera models, and included accessories make it a must-have for secure and reliable outdoor camera setups. Pair it with the Wyze Cam Pan v3 or other Wyze cameras to enjoy seamless, weatherproof surveillance all year round.
What is the Wyze Outdoor Power Adapter and what makes it weather-resistant?
The Wyze Outdoor Power Adapter is a power solution designed specifically for Wyze outdoor cameras. It features an IP67 weather-resistant rating, making it ideal for use in rain, snow, and extreme temperatures ranging from -30°C to 50°C (-22°F to 122°F). This ensures your camera remains powered reliably in all weather conditions.Which Wyze cameras are compatible with the Wyze Outdoor Power Adapter?
The Wyze Outdoor Power Adapter is compatible with Wyze Cam v3, Cam v4, Pan v3, and Battery Cam Pro. Please note that some models, such as Wyze Cam v3 Pro and Pan v3, require both the Outdoor Power Adapter and the L-shaped MicroUSB Adapter for proper installation. The Battery Cam Pro also requires the USB-C adapter. The adapter is not compatible with the OG Stack Kit.What is the cable length of the Wyze Outdoor Power Adapter?
The Wyze Outdoor Power Adapter comes with a total cable length of 12.5 feet (3.8 meters), allowing for flexible placement of your Wyze outdoor cameras.What accessories are included with the Wyze Outdoor Power Adapter?
The Wyze Outdoor Power Adapter includes wire clips, screws, anchors, and a weatherproof L-shaped Micro-USB adapter to ensure a secure and neat installation.Is the Wyze Outdoor Power Adapter certified for safety?
Yes, the Wyze Outdoor Power Adapter is FCC and UL certified, ensuring safety and reliability for your outdoor camera installations.Does the Wyze Outdoor Power Adapter come with a warranty?
Yes, the Wyze Outdoor Power Adapter is backed by a 1-year warranty for added peace of mind.Why do I need the Wyze Outdoor Power Adapter for the Wyze Cam Pan v3?
The Wyze Cam Pan v3 is designed for both indoor and outdoor use, but for optimal outdoor performance and weather resistance, it requires the Wyze Outdoor Power Adapter to ensure continuous and reliable power in all weather conditions.Are there any bundles that include the Wyze Outdoor Power Adapter?
Yes, several bundles feature the Wyze Outdoor Power Adapter, including the Bird Feeder Plug-in Cam v4 Bundle, Wyze Cam Pan v3 + 30-Day Cam Plus Bundle, and the Pan v3 Security Bundle. These bundles offer complete solutions for outdoor surveillance and birdwatching, ensuring your cameras stay powered year-round.Can the Wyze Outdoor Power Adapter be used with the Wyze Solar Panel?
Yes, the Wyze Outdoor Power Adapter is compatible with the Wyze Solar Panel, providing a sustainable power option for your outdoor cameras.What are the dimensions and weight of the Wyze Outdoor Power Adapter?
The Wyze Outdoor Power Adapter measures 78.7 mm x 62.5 mm x 29.4 mm and weighs 235 grams, making it compact and easy to install.What are the main benefits of using the Wyze Outdoor Power Adapter?
The main benefits include reliable weatherproofing (IP67 rating), easy installation with included hardware, wide compatibility with multiple Wyze camera models, certified safety (FCC and UL), and a long cable length for flexible camera placement.
