Long-Lasting Outdoor Power for Wyze Cameras in Extreme Weather
Long Lasting Outdoor Power Source for Wyze Cameras in Extreme Weather
When it comes to securing your home or monitoring your outdoor spaces with Wyze cameras, having a reliable and weather-resistant power source is essential. The Wyze Outdoor Power Adapter is specifically designed to keep your Wyze cameras powered through rain, snow, and extreme temperatures, ensuring continuous surveillance without interruption.
Wyze Outdoor Power Adapter: Durable Power for All Weather Conditions
Weather-Resistant and Reliable Power Supply
The Wyze Outdoor Power Adapter is built to withstand the harshest outdoor environments with an IP67 weather resistance rating, making it impervious to dust and water immersion. Whether it's pouring rain, heavy snow, or scorching heat, this adapter keeps your Wyze cameras running smoothly.
  • Operating Temperature: -22°F to 122°F (-30°C to 50°C)
  • Cable Length: 12.5 ft (3.8 m) for flexible installation
  • Output Power: 5V 2A, ensuring stable power delivery
  • Compatibility: Works with Wyze Cam v3, v4, Pan v3, and Battery Cam Pro (with appropriate adapters)
  • Included Accessories: Wire clips, screws, weatherproof L-shaped Micro-USB adapter for secure and neat setup
Note: For Wyze Cam v3 Pro and Pan v3, both the Outdoor Power Adapter and L-shaped MicroUSB Adapter are required. Battery Cam Pro requires the USB-C adapter as well.
Certified Safety and Warranty
The adapter is FCC and UL certified, providing peace of mind with a 1-year warranty. Its compact size (78.7 mm x 62.5 mm x 29.4 mm) and lightweight design (235 g) make it easy to install without bulky hardware.
Wyze Cam Pan v3: Seamless Outdoor Surveillance with Power Adapter
Advanced Outdoor Camera Features
The Wyze Cam Pan v3 is a versatile indoor/outdoor security camera featuring 360° horizontal pan and 180° vertical tilt, allowing you to cover every angle of your property. It boasts a durable polycarbonate body with IP65 weather resistance, perfect for outdoor use when paired with the Wyze Outdoor Power Adapter.
  • Video Resolution: Full HD 1080p with H.264 encoding
  • Night Vision: 4 IR LEDs for clear images in low light
  • Audio: Built-in speaker and microphone with 2-way audio and noise cancellation
  • Field of View: 120° with 8x digital zoom
  • Connectivity: 2.4 GHz Wi-Fi compatible with Alexa, Google Assistant, and IFTTT integrations
  • Operating Temperature: -20°C to 50°C (-4°F to 122°F)
This camera requires the Wyze Outdoor Power Adapter for safe and continuous outdoor operation.
Bundles for Convenience
  • Wyze Cam Pan v3 + 30-Day Cam Plus Bundle: Includes the camera, power adapter, mounting kit, and quick start guide.
  • Pan v3 Security Bundle: Comes with two cameras, two power adapters, mounting kits, and 32GB microSD cards for extended local storage.
Wyze Cam Pan v3 in Snowy Outdoor Setting
Bird Feeder Plug-in Cam v4 Bundle: Power and Nature Monitoring Combined
For bird enthusiasts and outdoor watchers, the Bird Feeder Plug-in Cam v4 Bundle offers a unique combination of Wyze Cam v4, Wyze Bird Feeder, and the Wyze Outdoor Power Adapter. This bundle is designed for all-season use with weather-resistant features and multiple mounting options including wall, tree, pole, and suction cup.
  • Compatible Cameras: Battery Cam Pro, Cam v3, Cam v4, Cam Outdoor v1 & v2
  • Features: Macro lens adapter included, compatible with Wyze Solar Panel for sustainable power
  • Installation: Easy and flexible mounting options for optimal birdwatching angles
This bundle ensures your Wyze Cam v4 stays powered outdoors reliably, even in extreme weather.
Why Choose Wyze Outdoor Power Solutions?
  • Long-lasting and weatherproof: IP67 rating ensures protection against dust and water.
  • Versatile compatibility: Supports multiple Wyze camera models with necessary adapters.
  • Easy installation: Comes with mounting hardware and wire clips for neat setup.
  • Stable power output: Keeps your cameras running 24/7 without interruption.
  • Certified and safe: FCC and UL certifications with a 1-year warranty.
Protect your investment and keep your Wyze cameras powered no matter the weather with the Wyze Outdoor Power Adapter and compatible bundles.
Two-Way Audio Feature of Wyze Cam Pan v3
Summary of Key Products for Outdoor Power and Surveillance
Product NameKey FeaturesWeather ResistanceCompatibility
Wyze Outdoor Power AdapterIP67, 12.5 ft cable, 5V 2A output, FCC/ULIP67Wyze Cam v3, v4, Pan v3, Battery Cam Pro
Wyze Cam Pan v3360° pan, 1080p, 2-way audio, IP65IP65Requires Outdoor Power Adapter
Bird Feeder Plug-in Cam v4 BundleIncludes Cam v4, Bird Feeder, Outdoor Power AdapterWeather-resistantWyze Cam v4, Battery Cam Pro, Cam Outdoor
Conclusion
For those seeking a long-lasting outdoor power source for Wyze cameras in extreme weather, the Wyze Outdoor Power Adapter is the ultimate solution. Paired with Wyze’s weather-resistant cameras like the Pan v3 or the Cam v4 in the Bird Feeder Bundle, you get reliable, continuous power and high-quality surveillance no matter the conditions. Invest in Wyze’s outdoor power solutions to ensure your cameras stay active and your property stays protected through every season.
FeatureWyze Outdoor Power AdapterWyze Cam Pan v3Wyze Cam Pan v3 + 30-Day Cam Plus BundlePan v3 Security Bundle
TypeAccessoryCameraCamera BundleCamera Bundle
Weather ResistanceIP67IP65IP65IP65
CompatibilityWyze Cam v4, OG series, Cam Pan v3, Cam v3 Pro (with L-shaped adapter), Battery Cam Pro (with USB-C adapter)Indoor/Outdoor cameraIndoor/Outdoor cameraIndoor/Outdoor camera
Pan & TiltN/A360° pan, 180° tilt360° pan, 180° tilt360° pan, 180° tilt
Video ResolutionN/A1920 x 1080 (1080p)1920 x 1080 (1080p)1920 x 1080 (1080p)
Night VisionN/AColor Night Vision (4 IR LEDs, 850 nm)Color Night Vision (4 IR LEDs, 850 nm)Color Night Vision (4 IR LEDs, 850 nm)
AudioN/ABuilt-in speaker and microphone, 2-way audioBuilt-in speaker and microphone, 2-way audioBuilt-in speaker and microphone, 2-way audio
Motion TrackingN/AAutomatic motion trackingAutomatic motion trackingAutomatic motion tracking
Power Adapter IncludedYesYesYesYes
Additional FeaturesIP67 weather resistant, required for outdoor use with certain camerasPrivacy Mode, Custom detection zones, Smoke & CO alertsIncludes 30-Day Cam Plus subscription (free trial)Includes 2x Wyze Cam Pan v3, 2x 32GB microSD cards, and other accessories
Price$14.99 - $19.99 (varies by variant)$39.98 (1 pack)$39.98 (camera) + 30-Day Cam Plus included$82.99
WarrantyNot specified1-Year1-Year1-Year
Included ItemsOutdoor Power Adapter and adapters depending on variant1x Wyze Cam Pan v3, 1x 6' micro USB Cable, Power Adapter, Mounting Kit, Quick Start GuideSame as Wyze Cam Pan v32x Wyze Cam Pan v3, 2x 6' micro USB Cable, 2x Power Adapter, 2x Mounting Kit, 2x 32GB MicroSD Cards, Quick Start Guide
ConnectivityN/A802.11 b/g/n 2.4GHz Wi-Fi802.11 b/g/n 2.4GHz Wi-Fi802.11 b/g/n 2.4GHz Wi-Fi
What is the Wyze Outdoor Power Adapter and how does it benefit outdoor Wyze cameras?The Wyze Outdoor Power Adapter is a weather-resistant power supply designed specifically for Wyze cameras. With an IP67 rating, it protects against dust and water immersion, ensuring your cameras remain powered in rain, snow, and extreme temperatures. This adapter provides stable 5V 2A output and comes with a 12.5 ft cable for flexible installation, making it ideal for continuous outdoor surveillance.
Which Wyze cameras are compatible with the Wyze Outdoor Power Adapter?The Wyze Outdoor Power Adapter is compatible with Wyze Cam v3, v4, Pan v3, and Battery Cam Pro (with the appropriate adapters). For Wyze Cam v3 Pro and Pan v3, both the Outdoor Power Adapter and the L-shaped MicroUSB Adapter are required. The Battery Cam Pro requires the USB-C adapter.
Is the Wyze Outdoor Power Adapter safe and certified for outdoor use?Yes, the Wyze Outdoor Power Adapter is FCC and UL certified, ensuring safety and reliability. It also comes with a 1-year warranty for added peace of mind.
What are the weather resistance and operating temperature specifications of the Wyze Outdoor Power Adapter?The Wyze Outdoor Power Adapter has an IP67 weather resistance rating, making it dust-tight and protected against water immersion. It operates in temperatures ranging from -22°F to 122°F (-30°C to 50°C), making it suitable for extreme weather conditions.
What accessories are included with the Wyze Outdoor Power Adapter?The Wyze Outdoor Power Adapter comes with wire clips, screws, and a weatherproof L-shaped Micro-USB adapter for a secure and neat installation.
Why is the Wyze Outdoor Power Adapter necessary for the Wyze Cam Pan v3?The Wyze Cam Pan v3 is designed for both indoor and outdoor use, but for safe and continuous outdoor operation, it requires the Wyze Outdoor Power Adapter. This ensures the camera remains powered and protected from the elements.
What features does the Wyze Cam Pan v3 offer for outdoor surveillance?The Wyze Cam Pan v3 features 360° horizontal pan, 180° vertical tilt, Full HD 1080p video, night vision with 4 IR LEDs, two-way audio with noise cancellation, and a 120° field of view with 8x digital zoom. It is IP65 weather-resistant and operates in temperatures from -4°F to 122°F (-20°C to 50°C).
What is included in the Wyze Cam Pan v3 and Bird Feeder Plug-in Cam v4 bundles?The Wyze Cam Pan v3 bundle includes the camera, power adapter, mounting kit, and a quick start guide. The Pan v3 Security Bundle comes with two cameras, two power adapters, mounting kits, and 32GB microSD cards. The Bird Feeder Plug-in Cam v4 Bundle includes the Wyze Cam v4, Wyze Bird Feeder, Wyze Outdoor Power Adapter, macro lens adapter, and offers multiple mounting options.
Can the Wyze Outdoor Power Adapter be used with the Wyze Bird Feeder Plug-in Cam v4 Bundle?Yes, the Wyze Outdoor Power Adapter is included in the Bird Feeder Plug-in Cam v4 Bundle, providing reliable, weather-resistant power for year-round birdwatching and outdoor monitoring.
What makes Wyze outdoor power solutions ideal for extreme weather conditions?Wyze outdoor power solutions, such as the Wyze Outdoor Power Adapter, are designed with IP67 weather resistance, stable power output, and compatibility with multiple Wyze camera models. They ensure your cameras remain powered and operational in extreme weather, protecting your property with continuous surveillance.
How easy is it to install the Wyze Outdoor Power Adapter?The Wyze Outdoor Power Adapter is easy to install, featuring a 12.5 ft cable for flexible placement and included mounting hardware and wire clips for a neat and secure setup.
Does the Wyze Outdoor Power Adapter support continuous 24/7 camera operation?Yes, the Wyze Outdoor Power Adapter provides stable and reliable power, allowing your Wyze cameras to operate continuously 24/7 without interruption, regardless of outdoor weather conditions.
What are the installation requirements for the Wyze Outdoor Power Adapter?Can the Wyze Outdoor Power Adapter be used with other Wyze camera models?What is the warranty period for the Wyze Outdoor Power Adapter?
