Wyze Lock Bolt Compatibility: Fits Most Doors & Smart Features
Wyze Lock Bolt Compatibility and Features
If you're searching for a reliable, secure, and easy-to-install smart lock solution, the Wyze Lock Bolt is an excellent choice. Designed to replace your existing deadbolt, this Bluetooth-enabled smart lock offers seamless compatibility with most exterior doors, making it a versatile option for upgrading your home security.
Compatible Door Types and Installation
The Wyze Lock Bolt is engineered to fit almost all standard exterior doors, replacing your current deadbolt in about 20 minutes. Whether your door is wood, metal, or composite, the lock’s design ensures a snug and secure fit without requiring complex modifications.
  • Easy Installation: No professional help needed; install it yourself quickly.
  • Deadbolt Replacement: Directly replaces your existing deadbolt mechanism.
  • Compatible with Standard Doors: Works with most exterior door types and sizes.
"Replaces your existing deadbolt in just 20 minutes."
Smart Features and Security Compatibility
Wyze Lock Bolt operates via Bluetooth, connecting locally to your smartphone through the Wyze app. This means it does not rely on cloud connectivity for unlocking or locking, enhancing privacy and security.
  • Fingerprint Reader: Ultra-fast fingerprint sensor for keyless entry.
  • Backlit Keypad: Luxurious, weatherproof keypad with anti-peep technology.
  • Auto-Lock Feature: Automatically locks after a set delay to prevent accidental unlocking.
  • Local Bluetooth Connection: Ensures your data stays private without cloud dependency.
  • Hardware Encryption: Protects your fingerprint and passcode data.
  • Two-Factor Authentication: Adds an extra layer of security via the Wyze app.
Battery and Power Compatibility
The Wyze Lock Bolt runs on 4 AA batteries, providing up to 12 months of battery life under typical usage. It also features a USB-C port for emergency charging if the batteries run out while you’re away.
  • Long Battery Life: Up to 12 months on 4 AA batteries.
  • Emergency USB-C Charging: Temporary power to unlock if batteries die.
  • Battery Indicator: Alerts you when battery replacement is needed.
Replacement Parts for Wyze Lock Bolt
To maintain your Wyze Lock Bolt in optimal condition, Wyze offers compatible replacement parts designed specifically for this model:
  • Wyze Lock Bolt Screws: Replacement screws to secure the lock assembly.
  • Wyze Lock Bolt Interior Assembly Metal Plate: Anchors the interior assembly firmly to your door.
  • Wyze Lock Bolt Interior Assembly Battery Cover: Replacement cover for the battery compartment.
These parts ensure your lock remains secure and functional without needing a full replacement.
Enhance Your Security with Wyze Bundles Featuring Lock Bolt
For a comprehensive home security upgrade, consider Wyze’s curated bundles that include the Lock Bolt along with other smart devices.
Essential Security Bundle
This all-in-one package combines the Wyze Lock Bolt with multiple security devices to protect your home from every angle:
  • Wyze Video Doorbell v2: Crisp 1080p HD video and two-way audio.
  • Wyze Cam Pan v3: Pan-and-tilt camera with 360° horizontal and 180° vertical coverage.
  • Two Wyze Cam OG: Plug-in cameras with motion-activated spotlights and color night vision.
  • Wyze Lock Bolt: Fast fingerprint sensor and backlit keypad for secure access.
This bundle offers seamless integration and centralized control through the Wyze app, making it easier to monitor and secure your home.
Designed specifically for front porch security, this bundle pairs the Wyze Lock Bolt with video doorbells and cameras:
  • Wyze Video Doorbell and Chime: View your front porch in 1080p HD with two-way audio.
  • Wyze Lock Bolt: Lock and unlock remotely, view lock history.
  • Works with Alexa and Google Assistant: Voice control compatibility.
This bundle is perfect for those wanting to secure their entryway with smart devices that work together effortlessly.
Why Choose Wyze Lock Bolt for Your Home?
  • Compatibility: Fits most exterior doors and replaces existing deadbolts.
  • Security: Advanced fingerprint sensor, encrypted data, and anti-peep keypad.
  • Convenience: Auto-lock, emergency USB-C charging, and app control.
  • Durability: Weatherproof with IPX5 rating and pick-proof design.
  • Customization: Store up to 20 access codes and 50 fingerprints.
Experience the perfect blend of security, convenience, and style with Wyze Lock Bolt.
Wyze Lock Bolt Lifestyle Secure your front door with Wyze Lock Bolt’s smart fingerprint access. Wyze Lock Bolt App Control Control your Wyze Lock Bolt easily from your smartphone app. Wyze Lock Bolt Installation Simple installation replaces your existing deadbolt in minutes.
Summary of Wyze Lock Bolt Compatibility
The Wyze Lock Bolt is compatible with nearly all exterior doors, replacing your deadbolt with a smart, secure, and convenient locking system. Its Bluetooth connectivity, fingerprint sensor, and app control make it a modern upgrade for any home. Replacement parts like screws, metal plates, and battery covers are readily available to keep your lock functioning perfectly. For enhanced security, consider pairing it with Wyze’s security bundles that include cameras and video doorbells. Upgrade your home security today with Wyze Lock Bolt — the smart lock designed for compatibility, convenience, and peace of mind.
ProductTypePrice (USD)Key FeaturesIncluded Items / ComponentsCompatibility / Notes
Wyze Lock BoltConnected Home79.98Bluetooth smart lock, ultra-fast fingerprint reader, backlit keypad, auto-lock, pick-proof, weatherproof (IPX5), up to 12 months battery life, local Bluetooth connection, hardware encryption, 2FASmart lock with backlit keypad and fingerprint sensorReplaces existing deadbolt, installs in ~20 minutes, compatible with most exterior doors
Wyze Lock Bolt ScrewsReplacement Parts2.99Replacement set of screwsScrews for Wyze Lock BoltFor Wyze Lock Bolt
Wyze Lock Bolt Interior Assembly Metal PlateReplacement Parts4.99Metal plate to anchor the interior assembly to the doorMetal plateFor Wyze Lock Bolt interior assembly
Wyze Lock Bolt Interior Assembly Battery CoverReplacement Parts9.99Replacement interior battery coverBattery coverCompatible with Wyze Lock Bolt
Essential Security BundleBundle199.99Comprehensive home protection package including smart lock, video doorbell, pan camera, and 2 indoor/outdoor camsWyze Video Doorbell v2, Wyze Lock Bolt, Wyze Cam Pan v3, 2× Wyze Cam OGAll devices compatible with Wyze app
The Front Porch Security BundleCameras Bundle123.99–173.97Front porch security with video doorbell, chime, and smart lock; remote lock/unlock, lock history, Alexa/Google supportVariants include Wyze Lock or Wyze Lock Bolt with Wyze Video Doorbell and Chime, Wyze Cam V3Works with Alexa and Google Assistant
What types of doors are compatible with the Wyze Lock Bolt?The Wyze Lock Bolt is designed to fit almost all standard exterior doors, including wood, metal, and composite doors. It directly replaces your existing deadbolt without requiring complex modifications.
How easy is it to install the Wyze Lock Bolt?The Wyze Lock Bolt is easy to install and can be set up in about 20 minutes without professional help. It is engineered for DIY installation, replacing your current deadbolt mechanism.
What smart features does the Wyze Lock Bolt offer?The Wyze Lock Bolt features an ultra-fast fingerprint reader for keyless entry, a weatherproof backlit keypad with anti-peep technology, auto-lock functionality, local Bluetooth connection for privacy, hardware encryption, and two-factor authentication via the Wyze app.
Does the Wyze Lock Bolt require Wi-Fi or cloud connectivity?No, the Wyze Lock Bolt operates via Bluetooth and connects locally to your smartphone through the Wyze app. It does not rely on cloud connectivity for locking or unlocking, ensuring enhanced privacy and security.
How long does the Wyze Lock Bolt battery last and what happens if it runs out?The Wyze Lock Bolt runs on 4 AA batteries, providing up to 12 months of battery life under typical usage. If the batteries run out, you can use the emergency USB-C port for temporary power to unlock the door. The lock also features a battery indicator to alert you when replacement is needed.
Are replacement parts available for the Wyze Lock Bolt?Yes, Wyze offers compatible replacement parts for the Lock Bolt, including screws, the interior assembly metal plate, and the battery cover. These parts help maintain your lock’s security and functionality without needing a full replacement.
What security features does the Wyze Lock Bolt provide?The Wyze Lock Bolt offers advanced security features such as a fast fingerprint sensor, encrypted data storage, anti-peep keypad, two-factor authentication, and a pick-proof, weatherproof design with an IPX5 rating.
Can I control the Wyze Lock Bolt remotely or with voice assistants?The Wyze Lock Bolt can be controlled locally via Bluetooth through the Wyze app. When purchased as part of certain Wyze security bundles, it can also integrate with Alexa and Google Assistant for voice control.
What is included in Wyze security bundles featuring the Lock Bolt?Wyze security bundles may include the Lock Bolt, Wyze Video Doorbell v2, Wyze Cam Pan v3, Wyze Cam OG, and other smart devices. These bundles offer centralized control and seamless integration through the Wyze app for comprehensive home security.
How many access codes and fingerprints can the Wyze Lock Bolt store?The Wyze Lock Bolt can store up to 20 access codes and 50 fingerprints, allowing multiple users to have secure and convenient access to your home.
What types of doors can the Wyze Lock Bolt be installed on?How long does it take to install the Wyze Lock Bolt?Do you have any ongoing sales or discounts for the Wyze Lock Bolt?
