Wyze Formaldehyde Filter Subscription for Eliminating Chemicals and Odor
When it comes to breathing clean, fresh air in your home, eliminating harmful chemicals like formaldehyde and unpleasant odors is essential. Wyze offers a comprehensive solution with its
Wyze Air Purifier,
Wyze Air Filter, and the convenient
Wyze Air Filter Subscription service. These products work together to ensure your indoor air is purified, safe, and odor-free, especially targeting chemical pollutants such as formaldehyde.
Wyze Air Purifier: Advanced Air Cleaning for Your Home
The
Wyze Air Purifier is designed to clear the air efficiently and quietly, making it a perfect addition to any living space. It comes with premium filters, including the Formaldehyde Filter (Premium), which is specifically engineered to target and remove formaldehyde and other harmful gases.
Key Features:
- High CADR Performance: The Formaldehyde Filter variant delivers a Clean Air Delivery Rate (CADR) of 317 m³/h (186 CFM), effectively purifying air in spaces of 450-550 ft².
- Multi-stage Filtration: Equipped with a pre-filter, True HEPA 12 filter, MnO2, and activated carbon to capture particles, gases, and odors.
- Quiet Operation: Operates at whisper-quiet noise levels starting below 21 dBA, ensuring minimal disruption.
- Smart Controls: Compatible with Google Home and Alexa for voice control and app-based air quality monitoring.
- Laser Particle Sensor: Detects particles as small as 0.3 microns with air quality measured 100 times per second.
- Filter Life: Each filter lasts approximately 6 months, ensuring long-term air quality maintenance.
"A luxury air purifier without a luxury price tag."
Keep your air purifier performing at its best with easy filter changes.
Wyze Air Filter: Custom Filters Tailored to Your Air Quality Needs
The
Wyze Air Filter offers customizable filter options to address specific air quality concerns, including the Formaldehyde Filter (Premium) designed to eliminate formaldehyde and other volatile organic compounds (VOCs).
Filter Variants:
- Allergen Filter (Standard): HEPA 13 filter for allergens and dust.
- Formaldehyde Filter (Premium): HEPA 12 + MnO2 + Activated Carbon, with a TVOC removal efficiency of 98.9%.
- Wildfire Filter (Special Use): Designed for smoke and wildfire-related pollutants.
Specifications:
- Dimensions: 8.1" x 8.1" x 11.3" (205 mm x 205 mm x 286 mm)
- Weight: Approximately 1.7 lb (0.77 kg) for the Formaldehyde Filter
- Formaldehyde CADR: 178 m³/h
- Service Life: 5 to 12 months depending on usage
- Pre-filter Included: Yes, to capture larger particles and extend filter life
This filter is perfect for those living in newly built homes, near industrial areas, or anyone concerned about chemical pollutants and odors in their indoor environment.
Wyze Air Filter Subscription: Hassle-Free Replacement Filters Delivered
Maintaining optimal air quality requires timely filter replacements. The
Wyze Air Filter Subscription service ensures you never run out of fresh filters by delivering replacement filters directly to your door.
Subscription Benefits:
- Filter Types Available: Allergen, Formaldehyde, and Wildfire filters.
- Convenient Delivery: Scheduled shipments based on your filter’s lifespan (typically 5-12 months).
- Consistent Air Quality: Keep your Wyze Air Purifier performing at peak efficiency without interruption.
- Filter Composition: Includes pre-filter, True HEPA 12, MnO2, and activated carbon for the Formaldehyde Filter variant.
This subscription service is ideal for busy households who want to maintain clean air effortlessly and continuously.
Why Choose Wyze for Formaldehyde and Odor Elimination?
"You don’t drink the same drink or eat the same food as everyone else. Why should you breathe the same air?"
Wyze’s approach to air purification is customizable and smart, allowing you to tailor your air quality solutions to your unique environment. The Formaldehyde Filter is specifically designed to combat chemical pollutants and odors, providing peace of mind for your family’s health.
- High Efficiency: Removes up to 98.9% of total volatile organic compounds (TVOCs), including formaldehyde.
- Smart Home Integration: Control and monitor air quality from your smartphone or voice assistant.
- Long-lasting Filters: Designed for durability and sustained performance.
- Affordable and Accessible: Premium air purification without breaking the bank.
Breathe easy with Wyze’s smart air purification solutions.
Summary of Wyze Formaldehyde Filter Products
Product | Filter Type | Price (USD) | CADR (Formaldehyde) | Filter Life | Key Features |
Wyze Air Purifier | Formaldehyde Filter | $174.99 | 317 m³/h (186 CFM) | 6 months | Smart controls, laser sensor, quiet |
Wyze Air Filter | Formaldehyde Filter | $40.99 | 178 m³/h | 5-12 months | HEPA 12 + MnO2 + Activated Carbon |
Wyze Air Filter Subscription | Formaldehyde Filter | $40.99 | Same as filter | Auto replacement | Convenient scheduled delivery |
Experience cleaner, safer air with Wyze’s formaldehyde filter and subscription service — the smart choice for eliminating chemicals and odors from your home environment.
What is the Wyze Formaldehyde Filter Subscription?
The Wyze Formaldehyde Filter Subscription is a convenient service that delivers replacement formaldehyde filters for your Wyze Air Purifier directly to your door on a scheduled basis. This ensures you always have a fresh filter to maintain optimal air quality and eliminate harmful chemicals and odors in your home.How does the Wyze Air Purifier remove formaldehyde and odors?
The Wyze Air Purifier uses a multi-stage filtration system, including a pre-filter, True HEPA 12 filter, MnO2, and activated carbon. The Formaldehyde Filter (Premium) is specifically engineered to target and remove formaldehyde, volatile organic compounds (VOCs), and unpleasant odors, providing clean and safe indoor air.What are the benefits of the Wyze Air Filter Subscription service?
The Wyze Air Filter Subscription service offers hassle-free, scheduled delivery of replacement filters, ensuring your air purifier always operates at peak efficiency. It helps maintain consistent air quality, eliminates the need to remember filter replacement dates, and supports a healthier home environment.How often should I replace my Wyze Formaldehyde Filter?
Wyze recommends replacing the Formaldehyde Filter every 5 to 12 months, depending on usage and air quality conditions. The subscription service can be tailored to your specific needs, so you receive new filters at the right time.What makes the Wyze Formaldehyde Filter effective against chemical pollutants?
The Wyze Formaldehyde Filter combines HEPA 12 filtration, MnO2, and activated carbon to capture and neutralize up to 98.9% of total volatile organic compounds (TVOCs), including formaldehyde and other harmful gases, making it highly effective for chemical pollutant removal.Is the Wyze Air Purifier suitable for large rooms?
Yes, the Wyze Air Purifier with the Formaldehyde Filter delivers a Clean Air Delivery Rate (CADR) of 317 m³/h (186 CFM), effectively purifying air in spaces ranging from 450 to 550 square feet.Can I control the Wyze Air Purifier with my smartphone or voice assistant?
Absolutely. The Wyze Air Purifier is compatible with Google Home and Alexa, allowing you to control and monitor your air quality using your smartphone or voice commands for added convenience.What types of filters are available for the Wyze Air Purifier?
Wyze offers several filter options for its air purifier, including the Allergen Filter (Standard), Formaldehyde Filter (Premium), and Wildfire Filter (Special Use). Each filter is designed to address specific air quality concerns.Who should use the Wyze Formaldehyde Filter?
The Wyze Formaldehyde Filter is ideal for individuals living in newly built homes, near industrial areas, or anyone concerned about chemical pollutants and odors in their indoor environment.How quiet is the Wyze Air Purifier during operation?
The Wyze Air Purifier operates at whisper-quiet noise levels starting below 21 dBA, making it suitable for bedrooms, living rooms, and other quiet spaces.
