Buy Activated Carbon Air Filter Replacements for Odor Removal
Buy Air Filter Replacement with Activated Carbon for Odor Removal
If you're looking to improve your indoor air quality and effectively remove odors, activated carbon air filters are your best solution. Activated carbon filters are specially designed to trap and neutralize odors, volatile organic compounds (VOCs), and harmful gases, making your living space fresher and healthier. Below, we highlight the top Wyze products featuring activated carbon filters that excel in odor removal and air purification.
Wyze Air Filter Replacement Options with Activated Carbon
Customized Filters for Every Need
Wyze offers a range of replacement air filters designed to fit the Wyze Air Purifier, each equipped with activated carbon to tackle odors and harmful gases effectively. Filter Types Available:
  • Allergen Filter (Standard): Combines a pre-filter, True HEPA 13, and activated carbon to capture allergens and odors.
  • Formaldehyde Filter (Premium): Features a pre-filter, True HEPA 12, manganese dioxide (MnO2), and activated carbon for enhanced removal of formaldehyde and VOCs.
  • Wildfire Filter (Special Use): Includes a pre-filter, True HEPA 12, and activated carbon, ideal for filtering smoke and wildfire-related pollutants.
Key Specifications
  • Dimensions: 8.1" x 8.1" x 11.3" (205 mm x 205 mm x 286 mm)
  • Weight: Ranges from 1.5 lb to 1.9 lb depending on filter type
  • TVOC Removal Efficiency: Up to 98.9% for formaldehyde filter
  • Service Life: 4 to 12 months depending on filter type and usage
  • Particulate Matter CADR: Up to 362 m³/h (214 CFM)
These replacement filters ensure your Wyze Air Purifier continues to deliver clean, odor-free air tailored to your environment.
"You don't drink the same drink or eat the same food as everyone else. Why should you breathe the same air?" – Wyze
Man replacing air filter in purifier Keep your air fresh with easy filter replacements
Wyze Air Purifier with Activated Carbon Filter
Premium Air Purification with Smart Features
The Wyze Air Purifier is a powerful connected home device that comes pre-installed with activated carbon filters designed for odor removal and air quality improvement.
  • Filter Variants: Allergen, Formaldehyde, and Wildfire filters, all containing activated carbon
  • CADR (Clean Air Delivery Rate): Up to 350 m³/h (206 CFM) for allergens
  • Noise Level: Whisper-quiet operation at 21 decibels on the lowest setting
  • Effective Area Coverage: 450-550 square feet, perfect for medium to large rooms
  • Smart Controls: Compatible with Google Home and Alexa, with real-time air quality alerts and laser particle detection (0.3 microns accuracy)
  • Filter Life: Approximately 6 months per filter
Why Choose Wyze Air Purifier?
  • Removes odors, allergens, viruses, bacteria, and harmful gases with 99% efficiency
  • Activated carbon layer traps odors and VOCs effectively
  • Sleek gray design fits seamlessly into any home environment
  • Energy-efficient with low power consumption (3.5 to 45W)
This purifier is ideal for anyone seeking a smart, effective solution to maintain fresh, clean air and eliminate unwanted odors. Lifestyle image of air purifier in modern living room Breathe easy with Wyze Air Purifier
Wyze Air Filter Subscription – Hassle-Free Replacement
Convenient Filter Delivery Service
Never worry about running out of activated carbon filters with the Wyze Air Filter Subscription. This service delivers replacement filters directly to your door, ensuring your air purifier always performs at its best.
  • Filter Options: Allergen, Formaldehyde, Wildfire
  • Filter Composition: Includes pre-filter, True HEPA, and activated carbon layers
  • Pricing: Affordable monthly plans starting at $37.99
Subscribing guarantees you maintain optimal odor removal and air purification without the hassle of remembering to reorder.
Why Activated Carbon Filters Are Essential for Odor Removal
Activated carbon is a highly porous material that adsorbs gases and odors at a molecular level. This makes it especially effective against:
  • Pet odors
  • Cooking smells
  • Smoke and wildfire pollutants
  • Chemical fumes like formaldehyde and VOCs
When combined with HEPA filtration, activated carbon filters provide comprehensive air cleaning, improving both air quality and comfort in your home.
Summary
For effective odor removal and superior air purification, Wyze offers:
  • Wyze Air Filter Replacement with activated carbon for tailored filtration needs
  • Wyze Air Purifier equipped with premium activated carbon filters and smart features
  • Wyze Air Filter Subscription for convenient, timely filter replacements
Invest in these products to breathe fresher, cleaner air and enjoy a healthier living environment.
FeatureWyze Air FilterWyze Air Filter SubscriptionWyze Air Purifier
Product TypeConnected Home - Air Filter AccessoriesHardware Subscription - Replacement FiltersConnected Home - Air Purifier Device
PurposeCustom air filters for Wyze Air PurifierReplacement filters for Wyze Air PurifierAir purifier device with pre-installed filter
Filter VariantsAllergen Filter (Standard) - $37.99Allergen Filter - $37.99Allergen Filter (Standard) - $169.99
Formaldehyde Filter (Premium) - $63.99Formaldehyde Filter - $63.99Formaldehyde Filter (Premium) - $174.99
Wildfire Filter (Special Use) - $40.99Wildfire Filter - $40.99Wildfire Filter (Special Use) - $194.99
Filter CompositionAllergen: Pre-Filter + HEPA 13 + Granulated CarbonSame as Wyze Air FilterSame as Wyze Air Filter
Formaldehyde: Pre-Filter + True HEPA 12 + Granulated Carbon with Activated Manganese
Wildfire: Pre-Filter + True HEPA 12 + Chemically Modified Granulated Carbon
Filter LifeNot specified (sold individually)Not specified (subscription replacement)6 months
Price$37.99 - $63.99 depending on filter type$37.99 - $63.99 depending on filter type$169.99 - $194.99 depending on filter type
Purchase TypeOne-time purchaseSubscription (auto replacement)One-time purchase
AvailabilityCurrently sold out/unavailableCurrently sold out/unavailableIn stock
Return Policy30-day hassle-free returns30-day hassle-free returns30-day hassle-free returns
Additional FeaturesCustomize air filtration to specific needsConvenient filter replacement service350 CADR, whisper-quiet, smart controls, AQ alerts, laser particle detection
DimensionsN/A (filters only)N/A (filters only)9.5 in x 9.4 in x 18.5 in (243 mm x 240 mm x 472 mm)
WeightN/AN/A8.75 - 9.32 lb depending on filter
Operating ConditionsN/AN/A14°F - 104°F / -10°C - 40°C; <85% humidity
Smart Home CompatibilityN/AN/AGoogle Home, Alexa
Noise LevelN/AN/A21 dBA (lowest setting) to 52.1 dBA (highest)
Effective AreaN/AN/A450-550 ft²
What are the benefits of using activated carbon air filters for odor removal?Activated carbon air filters are highly effective at trapping and neutralizing odors, volatile organic compounds (VOCs), and harmful gases. This makes them ideal for removing pet odors, cooking smells, smoke, and chemical fumes, resulting in fresher and healthier indoor air.
Which Wyze air filter replacement options include activated carbon?Wyze offers several replacement air filters for the Wyze Air Purifier, all equipped with activated carbon. The available options are the Allergen Filter (Standard), Formaldehyde Filter (Premium), and Wildfire Filter (Special Use), each designed to target specific air quality concerns while effectively removing odors.
How often should I replace my Wyze air filter with activated carbon?The service life of Wyze air filters with activated carbon ranges from 4 to 12 months, depending on the filter type and usage. Regular replacement ensures optimal odor removal and air purification performance.
What is the Clean Air Delivery Rate (CADR) of Wyze air purifiers and filters?Wyze air purifiers offer a Clean Air Delivery Rate (CADR) of up to 350 m³/h (206 CFM) for allergens, while replacement filters can reach up to 362 m³/h (214 CFM) for particulate matter, ensuring efficient air cleaning for medium to large rooms.
What room size can the Wyze Air Purifier with activated carbon filter cover?The Wyze Air Purifier with activated carbon filter is designed to effectively purify air in rooms ranging from 450 to 550 square feet, making it suitable for medium to large living spaces.
What smart features does the Wyze Air Purifier offer?The Wyze Air Purifier includes smart controls compatible with Google Home and Alexa, real-time air quality alerts, and laser particle detection with 0.3-micron accuracy, providing a connected and convenient air purification experience.
How does the Wyze Air Filter Subscription work?The Wyze Air Filter Subscription is a convenient service that delivers replacement filters directly to your door at regular intervals. You can choose from Allergen, Formaldehyde, or Wildfire filter options, ensuring your air purifier always operates at peak performance without the hassle of manual reordering.
What makes activated carbon filters essential for air purification?Activated carbon filters are essential because their highly porous structure adsorbs gases and odors at a molecular level. When combined with HEPA filtration, they provide comprehensive air cleaning by removing both airborne particles and unwanted smells, improving overall indoor air quality.
Are Wyze air filters energy efficient and quiet?Yes, Wyze air purifiers are energy efficient, with power consumption ranging from 3.5 to 45W. They also operate quietly, with noise levels as low as 21 decibels on the lowest setting, making them suitable for use in bedrooms and living areas.
What types of pollutants do Wyze activated carbon filters remove?Wyze activated carbon filters are effective at removing a wide range of pollutants, including pet odors, cooking smells, smoke, wildfire pollutants, chemical fumes like formaldehyde, and volatile organic compounds (VOCs).
What are the different types of Wyze air filters available for odor removal?How does the Wyze Air Purifier compare to other air purifiers on the market?Can I customize my air filter subscription based on my needs?
