Best 2K Video Doorbells with AI Detection for Porch Security
2K Resolution Video Doorbells with AI Detection for Porch Security
Enhance your home security with the latest 2K resolution video doorbells equipped with AI detection technology. These smart devices not only provide crystal-clear video of your porch but also intelligently detect people, packages, and vehicles to keep you informed and secure. Whether you want wired or battery-powered options, these video doorbells offer seamless integration with your smart home ecosystem and advanced features to protect your front porch.
Wyze Video Doorbell v2: Wired 2K Video Doorbell with AI Detection
Experience the clearest wired video doorbell from Wyze with the Wyze Video Doorbell v2. This model delivers stunning 2K resolution video, capturing every detail from head to toe on your porch. Its wired setup ensures continuous power and supports 24/7 local recording via an onboard microSD card slot, so you never miss a moment before or after the doorbell rings.
Key Features:
  • 2K Video Quality: Crystal-clear footage with a wide 130° field of view to cover your entire porch.
  • Local MicroSD Storage: Continuous 24/7 recording without relying solely on cloud storage.
  • Two-Way Audio: Speak directly to visitors from anywhere using the Wyze app.
  • Motion-Activated Voice Deterrence: Automatically warns visitors they are being recorded (requires Cam Plus subscription).
  • Pre-Roll Motion Recording: Captures 3-6 seconds before motion events for full context.
  • Weatherproof (IP65): Durable in all weather conditions, rain or shine.
  • Works with Alexa and Google Home: View live feeds and receive smart alerts on your voice assistant devices.
  • Included 30° Corner Kit: Adjust the mounting angle for optimal porch coverage.
"Answer your door from anywhere with our clearest and most capable wired video doorbell yet."
Wyze Video Doorbell v2 lifestyle Wyze Video Doorbell v2 installed on a front porch, showcasing smart home security.
Wyze Duo Cam Battery Doorbell: Advanced Dual-Camera Battery-Powered Doorbell
For those seeking a wireless solution with enhanced coverage, the Wyze Duo Cam Battery Doorbell offers dual camera views with 2K resolution on the front camera and 1080p on the bottom camera. This allows you to monitor both visitors and packages simultaneously with real-time AI detections and alerts.
Highlights:
  • Dual 2K + 1080p Cameras: Front camera captures 2K video with a 132° horizontal field of view; bottom camera covers packages with 1080p.
  • Battery Powered: Includes a removable 6200mAh rechargeable battery pack for up to 6 months of use.
  • AI Detection & Alerts: Person, package, and vehicle detection with instant notifications.
  • Two-Way Audio & Voice Deterrence: Communicate with visitors and deter unwanted activity.
  • Local and Cloud Storage: Supports microSD cards for local recording and cloud backup.
  • Weather Resistant (IP65): Built to withstand harsh outdoor conditions.
  • Includes Wyze Wi-Fi Chime: Hear alerts inside your home without relying on your existing chime.
"Wyze Duo Cam Doorbell is our most advanced battery-powered video doorbell yet."
Wyze Duo Cam Doorbell lifestyle Wyze Duo Cam Battery Doorbell mounted on a porch, providing dual camera views for enhanced security.
Wyze Video Doorbell Pro: Wireless or Wired with Ultra-Wide View
The Wyze Video Doorbell Pro combines flexibility and performance with its battery or wired power options. It features a wider ultra-wide viewing angle and faster notifications thanks to a dual-band Wi-Fi extender chime.
Features at a Glance:
  • HD Video Quality: Crystal-clear video with smart detection alerts.
  • Ultra-Wide Viewing Angle: Capture more of your porch and surroundings.
  • Motion-Activated Security Light: Illuminates your porch when motion is detected.
  • Two-Way Audio & Quick Responses: Easily communicate with visitors.
  • 20 Unique Chime Tunes: Customize your doorbell sound with multiple volume levels.
  • Smart Home Integration: Works seamlessly with Alexa and Google Assistant.
  • Includes Chime: Compatible with existing chimes or use the included chime for easy setup.
"Wired or Wireless with battery power. Install in 30 seconds."
Wyze Video Doorbell Pro lifestyle Wyze Video Doorbell Pro installed on a modern home porch, highlighting easy installation and smart features.
The Front Porch Security Bundle: Complete Smart Home Security Solution
For a comprehensive porch security setup, consider the Front Porch Security Bundle. This package includes the Wyze Video Doorbell (1080p HD) with two-way audio and the Wyze Lock, allowing you to remotely lock or unlock your door and monitor lock history—all from the Wyze app.
Bundle Benefits:
  • Integrated Doorbell and Lock: Control access and monitor your porch from one app.
  • 1080p HD Video Doorbell: Reliable video quality with essential smart features.
  • Two-Way Audio: Communicate with visitors or delivery personnel.
  • Remote Lock Control: Lock or unlock your door remotely for trusted guests.
  • Lock History Tracking: View who accessed your door and when.
"Meet the ultimate smart home front porch security bundle."
Wyze Video Doorbell v2 Wedge Kit: Perfect Angle Adjustment Accessory
Maximize your Wyze Video Doorbell v2’s coverage with the Wedge Kit accessory. Ideal for angled door frames or porches with stairs, this kit includes horizontal and vertical brackets to eliminate blind spots and ensure the best viewing angle.
Features:
  • Adjustable Angles: 15° horizontal and 7.5° vertical brackets included.
  • Weather Resistant: Durable plastic construction suitable for outdoor use.
  • Easy Installation: Quick setup with included screws and guide.
  • Compatible: Designed exclusively for Wyze Video Doorbell v2.
"Goodbye to blind spots, hello to superior home security."
Why Choose a 2K Resolution Video Doorbell with AI Detection?
"Protect your porch with crystal-clear video and smart AI alerts."
2K resolution video doorbells provide sharper, more detailed images than standard HD, allowing you to clearly identify visitors, packages, and potential threats. AI detection enhances security by filtering out false alarms and sending you instant notifications only when important events occur, such as a person approaching your door or a package delivery. With options ranging from wired to battery-powered, dual-camera setups, and complete security bundles, Wyze offers versatile solutions tailored to your porch security needs.
Summary of Featured Products
Product NameVideo ResolutionPower TypeAI Detection FeaturesSpecial Features
Wyze Video Doorbell v22K (2048 x 1536)WiredPerson, Package DetectionLocal microSD storage, voice deterrence
Wyze Duo Cam Battery DoorbellFront 2K + Bottom 1080pBatteryPerson, Package, Vehicle DetectionDual cameras, removable battery, Wi-Fi chime
Wyze Video Doorbell ProHDWired or BatteryPerson, Package, Vehicle, Pet DetectionUltra-wide view, security light, dual-band chime
Front Porch Security Bundle1080pWired or BatteryBasic AI DetectionIncludes Wyze Lock for door control
Wyze Video Doorbell v2 Wedge KitN/AAccessoryN/AAngle adjustment for Doorbell v2
Protect your home with the best 2K resolution video doorbells featuring AI detection. Choose the Wyze model that fits your porch setup and enjoy peace of mind with smart, reliable security.
FeatureWyze Video Doorbell v2Wyze Duo Cam Battery DoorbellWyze Video Doorbell ProThe Front Porch Security BundleWyze Video Doorbell v2 Wedge Kit
TypeWired Video DoorbellBattery-Powered Dual Camera DoorbellWired or Battery-Powered Video DoorbellBundle (includes Wyze Video Doorbell v2 + Lock)Accessory for Doorbell v2
Video Resolution2K (2048 x 1536)Top: 2K, Bottom: 1080pHD (Crystal-clear)1080p HD (Wyze Video Doorbell v2)N/A
Field of View135° x 103°Top: 132° x 100°, Bottom: 121° x 60°Ultra-wide viewing angle120° Vertical x 88° Horizontal (Doorbell v2)N/A
PowerWired (AC 16-24V)Battery (Removable) or WiredWired or BatteryWired (Doorbell v2)N/A
Local StoragemicroSD (supports 24/7 recording)microSD (24/7 recording with hardwire + card)Not specifiedmicroSD (Doorbell v2)N/A
Cloud StorageOptional Cam Plus subscriptionOptional Cam Plus subscriptionOptional Cam Plus subscriptionNot specifiedN/A
Two-Way AudioYesYesYesYesN/A
Motion-Activated Voice DeterrenceYes (requires Cam Plus or Cam Protect)YesYesNot specifiedN/A
Night VisionColor Night Vision (Starlight sensor)Color Night Vision (Starlight sensor)Color Night VisionColor Night Vision (Wyze Cam Pan v3, Cam OG)N/A
Weather ResistanceIP65IP65Not specifiedIP65 (Doorbell v2 and cameras)Weather resistant
Chime CompatibilityWorks with existing mechanical chime (with included chime controller)Wyze Wi-Fi Chime included; compatible with Wyze Chime ControllerChime included (dual-band Wi-Fi extender chime)Wyze Chime included (Doorbell v2)N/A
InstallationScrew mounting, requires existing wiringAdhesive or screw mounting; battery or wiredScrew or adhesive mountingIncludes Doorbell v2 (wired) and LockQuick installation; includes mounting brackets
Special FeaturesPre-roll motion recording (3-6 sec), AI detections with Cam PlusDual cameras for people and packages, facial recognition, pet & vehicle detectionMotion-activated security light, 20 chime tunes, smart detection alertsIncludes Wyze Lock Bolt, Wyze Cam Pan v3, 2x Wyze Cam OGAdjusts viewing angle for Doorbell v2
Price$44.98$89.98 - $109.99 (sold out)$99.98$123.99 - $173.97$8.99 (Wedge Kit Only), $51.97 (Doorbell v2 + Wedge)
Included AccessoriesChime ControllerWyze Wi-Fi Chime, Removable Battery PackChime includedWyze Video Doorbell v2, Wyze Lock Bolt, Wyze Cam Pan v3, 2x Wyze Cam OG15° Horizontal bracket, 2x 7.5° Vertical brackets, screws
Compatible WithExisting mechanical chimesWyze Wi-Fi Chime, Wyze Chime ControllerAlexa, Google AssistantAlexa, Google AssistantDoorbell v2 only
What are the benefits of a 2K resolution video doorbell with AI detection?A 2K resolution video doorbell provides sharper, more detailed images than standard HD, making it easier to clearly identify visitors, packages, and potential threats. AI detection enhances security by filtering out false alarms and sending instant notifications only for important events, such as a person approaching your door or a package delivery.
Which Wyze video doorbell models offer 2K resolution?The Wyze Video Doorbell v2 and the Wyze Duo Cam Battery Doorbell both offer 2K resolution. The Wyze Video Doorbell v2 provides 2K video with a 130° field of view, while the Wyze Duo Cam Battery Doorbell features a front camera with 2K resolution and a bottom camera with 1080p for package monitoring.
Does the Wyze Video Doorbell v2 support local storage?Yes, the Wyze Video Doorbell v2 supports local storage via an onboard microSD card slot, allowing for continuous 24/7 recording without relying solely on cloud storage.
What is the difference between the Wyze Video Doorbell v2 and the Wyze Duo Cam Battery Doorbell?The Wyze Video Doorbell v2 is a wired doorbell with 2K resolution, local microSD storage, and a 130° field of view. The Wyze Duo Cam Battery Doorbell is battery-powered, features dual cameras (2K front and 1080p bottom), and offers up to 6 months of battery life. Both models include AI detection for people, packages, and vehicles.
Can I use Wyze video doorbells with Alexa or Google Home?Yes, Wyze video doorbells, including the Wyze Video Doorbell v2 and Wyze Video Doorbell Pro, are compatible with Alexa and Google Home. You can view live feeds and receive smart alerts on your voice assistant devices.
What power options are available for Wyze video doorbells?Wyze offers both wired and battery-powered video doorbells. The Wyze Video Doorbell v2 is wired, the Wyze Duo Cam Battery Doorbell is battery-powered, and the Wyze Video Doorbell Pro can be installed as either wired or wireless (battery-powered).
How does the Wyze Video Doorbell Pro differ from other models?The Wyze Video Doorbell Pro offers flexible installation with both wired and battery-powered options, an ultra-wide viewing angle, motion-activated security light, and a dual-band Wi-Fi extender chime for faster notifications. It also supports smart home integration and customizable chime tunes.
What is included in the Wyze Front Porch Security Bundle?The Wyze Front Porch Security Bundle includes a 1080p HD video doorbell with two-way audio and the Wyze Lock. This allows you to monitor your porch, communicate with visitors, and remotely lock or unlock your door from the Wyze app.
What is the purpose of the Wyze Video Doorbell v2 Wedge Kit?The Wyze Video Doorbell v2 Wedge Kit is an accessory designed to help you adjust the angle of your doorbell for optimal coverage. It includes 15° horizontal and 7.5° vertical brackets, making it ideal for angled door frames or porches with stairs, and helps eliminate blind spots.
Are Wyze video doorbells weatherproof?Yes, Wyze video doorbells such as the Wyze Video Doorbell v2 and Wyze Duo Cam Battery Doorbell are weatherproof with an IP65 rating, making them durable and suitable for all outdoor weather conditions.
Do Wyze video doorbells support two-way audio?Yes, all Wyze video doorbells feature two-way audio, allowing you to speak directly to visitors from anywhere using the Wyze app.
Can Wyze video doorbells detect packages and vehicles?Yes, Wyze video doorbells with AI detection, such as the Wyze Video Doorbell v2, Wyze Duo Cam Battery Doorbell, and Wyze Video Doorbell Pro, can detect people, packages, and vehicles, sending you instant notifications for these events.
Is there a wireless chime included with Wyze video doorbells?Yes, the Wyze Duo Cam Battery Doorbell and Wyze Video Doorbell Pro include a Wi-Fi chime, allowing you to hear alerts inside your home without relying on your existing chime.
How long does the battery last on the Wyze Duo Cam Battery Doorbell?The Wyze Duo Cam Battery Doorbell includes a removable 6200mAh rechargeable battery pack that can last up to 6 months on a single charge, depending on usage.
What are the key features of the Wyze Video Doorbell v2?Can you tell me more about the AI detection capabilities of the Wyze Duo Cam Battery Doorbell?Do you have any ongoing sales or discounts for the video doorbells?
