Wyze Cam MicroSD Cards for Timelapse Video Recording
Wyze Cam MicroSD Card for Timelapse Video Recording
When it comes to capturing stunning timelapse videos with your Wyze Cam, having the right microSD card is essential. Wyze offers a dedicated Wyze MicroSD Card designed to unlock continuous recording and timelapse features, perfectly complementing Wyze cameras like the Wyze Cam v4. This combination ensures you never miss a moment, whether for home security, pet monitoring, or creative video projects.
Wyze MicroSD Card: Perfect for Timelapse and Continuous Recording
Features and Benefits
  • Available Sizes: 32GB, 128GB, and 256GB microSD cards to suit your storage needs.
  • Timelapse Support: Enables smooth timelapse video recording on compatible Wyze cameras.
  • Continuous Local Recording: Record 24/7 without interruptions.
  • Timeline Controls & Calendar View: Easily navigate through recorded footage.
  • Optimized for Wyze Cams: Ensures seamless integration and reliable performance.
Using a Wyze MicroSD card with your Wyze Cam guarantees that your timelapse videos are stored locally with high reliability, avoiding cloud storage delays or subscription fees.
Wyze Cam v4: Ideal Camera for Timelapse Video Recording
Key Specifications
  • Video Resolution: Crystal-clear 2.5K QHD (2560x1440) for sharp, detailed footage.
  • Color Night Vision: Enhanced color night vision with 4 IR LEDs and 2 white spotlight LEDs.
  • Field of View: Wide 115.8° diagonal, 98.5° horizontal, and 53.1° vertical for broad coverage.
  • Local Storage: Supports microSD cards up to 512GB, perfect for extended timelapse sessions.
  • Connectivity: Wi-Fi 6 support for fast and stable streaming.
  • Smart Features: Alexa, Google Assistant, and IFTTT integrations.
  • Mounting Options: Versatile mounting including stand, wall, ceiling, and magnetic mounts.
  • Weather Resistance: IP65 rating, suitable for indoor and outdoor use.
  • Audio & Alerts: Two-way talk, built-in siren, and noise echo cancellation.
Why Wyze Cam v4 for Timelapse?
The Wyze Cam v4’s high-resolution video and wide dynamic range make it perfect for capturing detailed timelapse videos. Its compatibility with large microSD cards means you can record longer timelapse sequences without worrying about storage limits.
Capture every sunrise, sunset, or busy day with vivid clarity and smooth playback.
Included in the Box
  • Wyze Cam v4
  • Quick Start Guide
  • Wall Mount Plate and Tape
  • Screw Kit
  • Indoor USB Power Adapter
  • 6-Foot Flat micro USB to USB-A Cable
Wyze Cam Pan v3 in snowy outdoor setting Experience reliable outdoor security with Wyze Cam Pan v3, weather resistant and perfect for all seasons.
Wyze Cam v4 + FREE 32GB MicroSD Card Bundle
For those looking to get started immediately with timelapse recording, the Wyze Cam v4 + FREE 32GB MicroSD Card bundle is an excellent choice. This package offers the same advanced camera features with the added convenience of a pre-included microSD card optimized for timelapse and continuous recording.
Bundle Highlights
  • Free 32GB MicroSD Card: Ready to use for timelapse and local storage.
  • Same 2.5K QHD Resolution and Night Vision: Ensures high-quality video day and night.
  • Motion-Activated Spotlight & Person Detection: Enhanced security features.
  • Wi-Fi 6 Support: Faster and more reliable connectivity.
  • Weather Resistant: IP65 rating for outdoor durability.
This bundle is perfect for users who want a hassle-free setup to start capturing timelapse videos right away.
Additional Wyze Cameras Supporting MicroSD Timelapse Recording
Wyze Battery Cam Pro
  • Resolution: 2.5K HDR video.
  • Wireless: Completely wire-free with rechargeable battery packs lasting up to 6 months.
  • Local Storage: Supports up to 256GB microSD cards.
  • Field of View: Wide 134° diagonal for extensive coverage.
  • Night Vision: Powerful IR and white LEDs for clear night footage.
  • Weatherproof: IP65 rating for outdoor use.
  • Integrated Spotlight & Siren: Added security features.
Ideal for flexible placement without wiring constraints, the Battery Cam Pro supports timelapse recording with compatible microSD cards.
Wyze Cam Pan v3
  • Video Resolution: 1080p Full HD.
  • Pan & Tilt: 360° horizontal and 180° vertical movement.
  • Weather Resistant: IP65 rating for indoor/outdoor use.
  • Night Vision: 4 IR LEDs.
  • Two-Way Audio: Built-in speaker and microphone.
Perfect for users needing dynamic camera angles combined with timelapse capabilities. Two-way audio feature with pet Stay connected with two-way audio on Wyze cameras, ideal for pet monitoring and home security.
Why Choose Wyze for Timelapse Video Recording?
Wyze combines affordability, advanced technology, and user-friendly features to deliver exceptional timelapse video recording solutions.
  • Seamless Integration: Cameras and microSD cards designed to work flawlessly together.
  • High Storage Capacity: Support for large microSD cards ensures long recording times.
  • Smart Home Compatibility: Works with Alexa, Google Assistant, and IFTTT.
  • Weatherproof Designs: Suitable for both indoor and outdoor timelapse projects.
  • Affordable Pricing: High-quality features without breaking the bank.
Summary
For capturing stunning timelapse videos with your Wyze Cam, pairing the Wyze Cam v4 or other Wyze cameras with the Wyze MicroSD Card is the best choice. Whether you opt for the standalone camera or the bundle with a free microSD card, you get reliable local storage, excellent video quality, and smart features that enhance your recording experience.
FeatureWyze Cam v4Wyze MicroSD CardWyze Cam v4 + FREE 32GB MicroSD CardWyze Battery Cam ProWyze Cam Pan v3
TypeWired CameraAccessory (Memory Card)Wired Camera BundleBattery CameraWired Pan/Tilt Camera
Video Resolution2.5K QHD (2560x1440)N/A2.5K QHD (2560x1440)2.5K HDR (2560x1440)1080p (1920x1080)
Night VisionEnhanced Color Night VisionN/AEnhanced Color Night VisionIR LEDs + White LEDsIR LEDs
SpotlightMotion-activated spotlightN/AMotion-activated spotlightIntegrated SpotlightNo
SirenYes (99 dB)N/AYes (99 dB)Yes (100 dB)No
AudioEnhanced Two-Way TalkN/AEnhanced Two-Way TalkTwo-way AudioTwo-way Audio
StoragemicroSD card up to 512GB (required)32GB, 128GB, 256GB microSD cardsIncludes 32GB microSD cardSupports up to 256GB microSDSupports up to 256GB microSD
Continuous Local RecordingYesEnables continuous recordingYesYesYes
WirelessNo (Wired)N/ANo (Wired)Yes (Wi-Fi 2.4 & 5 GHz)No (Wired)
Wi-Fi SupportWi-Fi 6, 2.4 GHzN/AWi-Fi 6, 2.4 GHz2.4 & 5 GHz Wi-Fi2.4 GHz Wi-Fi only
Weather ResistanceIP65N/AIP65IP65IP65
Field of View115.9° (D) x 98.5° (H) x 53.1° (V)N/A115.9° (D) x 98.5° (H) x 53.1° (V)134° (DFOV), 108° (HFOV), 56° (VFOV)120° FOV
Motion DetectionYesN/AYesRadar + PIR Motion DetectionYes
Sound DetectionYesN/AYesYesNo
Motion Detection ZonesYesN/AYesNoNo
Smoke & CO AlertsYesN/AYesNoNo
Power SourceWiredN/AWiredRemovable, Rechargeable BatteryWired
Battery LifeN/AN/AN/AUp to 6 monthsN/A
Mounting OptionsStand, Wall, Ceiling, MagneticN/AStand, Wall, Ceiling, MagneticWall mount includedScrew 1/4" - 20
Dimensions2in x 2in x 2 3/8in (51x51x60mm)N/A2in x 2in x 2 3/8in2.5 x 1.8 x 3.5 inches124mm x 60mm x 63mm
Weight0.49 lb (222 g)N/A0.49 lb (222 g)0.94 lbs11.29 oz (320 g)
IntegrationsAlexa, Google Assistant, IFTTTN/AAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTT
Bluetooth Version5.2N/A5.2BLE 5.1No
Price (Single Unit)$35.98$8.99 (32GB), $16.99 (128GB), $29.99 (256GB)$35.98 (includes 32GB card)$89.98 (1 Pack)$39.98 (1 Pack)
What is the best microSD card for timelapse video recording with Wyze Cam?The Wyze MicroSD Card is specifically designed for timelapse and continuous video recording with Wyze Cams. It is available in 32GB, 128GB, and 256GB sizes, ensuring reliable local storage and seamless integration with Wyze cameras like the Wyze Cam v4.
Which Wyze cameras support timelapse video recording with a microSD card?Wyze Cam v4, Wyze Battery Cam Pro, and Wyze Cam Pan v3 all support timelapse video recording when paired with a compatible microSD card. These cameras offer features like high-resolution video, night vision, and weather resistance for versatile timelapse projects.
How much storage do I need for timelapse video recording on Wyze Cam?The required storage depends on the length and quality of your timelapse videos. Wyze MicroSD Cards are available in 32GB, 128GB, and 256GB sizes, and Wyze Cam v4 supports microSD cards up to 512GB, allowing for extended recording sessions without worrying about running out of space.
Does the Wyze Cam v4 come with a microSD card for timelapse recording?Wyze offers a bundle that includes the Wyze Cam v4 and a FREE 32GB MicroSD Card, making it easy to start timelapse and continuous recording right out of the box.
What are the benefits of using a Wyze MicroSD Card with my Wyze Cam?Using a Wyze MicroSD Card ensures smooth timelapse and continuous local recording, easy navigation with timeline controls and calendar view, and avoids cloud storage delays or subscription fees. The cards are optimized for reliable performance with Wyze cameras.
Can I use Wyze cameras for outdoor timelapse video recording?Yes, Wyze Cam v4, Wyze Battery Cam Pro, and Wyze Cam Pan v3 all feature IP65 weather resistance, making them suitable for both indoor and outdoor timelapse video recording.
What video quality can I expect from Wyze Cam v4 for timelapse videos?Wyze Cam v4 records in crystal-clear 2.5K QHD (2560x1440) resolution, providing sharp, detailed footage for stunning timelapse videos, both day and night thanks to enhanced color night vision.
Are Wyze cameras compatible with smart home systems?Yes, Wyze cameras work with Alexa, Google Assistant, and IFTTT, allowing for easy integration into your smart home setup.
What is included in the Wyze Cam v4 package?The Wyze Cam v4 package includes the camera, a quick start guide, wall mount plate and tape, screw kit, indoor USB power adapter, and a 6-foot flat micro USB to USB-A cable.
Why should I choose Wyze for timelapse video recording?Wyze offers affordable, high-quality cameras and microSD cards designed for seamless integration, high storage capacity, smart home compatibility, weatherproof designs, and user-friendly features, making them an excellent choice for timelapse video recording.
What are the available sizes for the Wyze MicroSD card?Can the Wyze Cam v4 record continuously without interruptions?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Cam v4?
