Wyze Cam v3 & v4: 24/7 Continuous Recording with microSD
Wyze Cam v3 24/7 Continuous Recording with microSD: Best Wyze Cam Options
If you're searching for a reliable Wyze Cam v3 alternative or upgrade that supports 24/7 continuous recording with microSD card storage, Wyze offers several advanced models that perfectly fit your needs. These cameras provide crystal-clear video, robust local storage options, and smart features to keep your home secure around the clock. Below, we explore the top Wyze Cam models and bundles that support continuous recording with microSD cards, highlighting their specs and benefits.
Wyze Cam v4 Series: The Ultimate Upgrade for Continuous Recording
Wyze Cam v4 (Standard Model)
The Wyze Cam v4 is a powerful indoor/outdoor security camera designed to deliver 24/7 local recording with a microSD card (up to 512GB). It features:
  • 2.5K QHD (2560x1440) video resolution for crystal-clear footage.
  • Enhanced Color Night Vision with 4 IR LEDs and 2 white spotlight LEDs (72 lumens) for vivid nighttime images.
  • Wide Field of View: 115.8° diagonal, 98.5° horizontal, and 53.1° vertical.
  • Local Storage: Supports microSD cards up to 512GB for continuous recording without cloud dependency.
  • Wi-Fi 6 Support: Faster and more reliable wireless connectivity.
  • Smart Features: Motion and sound detection, person detection, and motion detection zones.
  • Two-Way Audio & Built-in Siren: Communicate or deter intruders with 99dB waterproof speaker.
  • Weather Resistance: IP65 rating, suitable for indoor and outdoor use.
  • Mounting Options: Stand, wall, ceiling, or magnetic mounts for versatile placement.
This camera is perfect for users who want uninterrupted local recording with high-quality video and smart home integration.
"Wyze Cam v4 combines high resolution, color night vision, and 24/7 local recording for comprehensive home security."
Wyze Cam v4 Outdoor Lifestyle Wyze Cam v4 securing your outdoor space day and night
Wyze Cam v4 Outdoor Bundle
For those specifically looking for an outdoor security solution with continuous recording, the Wyze Cam v4 Outdoor Bundle is an excellent choice. It includes:
  • Wyze Cam v4 with all the features listed above.
  • Wyze Outdoor Power Adapter for reliable wired power outdoors.
  • Wyze MicroSD Card 128GB included for immediate 24/7 local recording.
  • Enhanced Color Night Vision and motion-activated spotlight to illuminate and capture clear footage in the dark.
  • Wide Dynamic Range (WDR) for balanced lighting in challenging environments.
  • Compatibility: Works seamlessly with Alexa and Google Assistant.
This bundle is ideal for users wanting a complete outdoor security setup with continuous recording and included microSD storage.
The Home Security Bundle offers a comprehensive package for indoor and outdoor security with continuous recording capabilities:
  • Wyze Cam v4 with 2.5K QHD resolution and enhanced color night vision.
  • 128GB microSD card (Class 10, UHS-3) included, supporting up to 192 hours of HD video storage.
  • Motion-activated spotlight and person detection for smarter alerts.
  • Improved 2-way audio and built-in siren for active home protection.
  • Weather-resistant design (IP65) for versatile indoor/outdoor use.
  • Multiple mounting options for flexible installation.
This bundle is perfect for users who want extended local storage and a full-featured security system with continuous recording.
Wyze Cam v4 + FREE 32GB MicroSD Card
For budget-conscious buyers, the Wyze Cam v4 with a free 32GB microSD card offers:
  • 2.5K QHD video quality with color night vision.
  • 24/7 local recording capability with included microSD card.
  • Motion-activated spotlight and person detection.
  • Wi-Fi 6 support and smart home compatibility.
  • IP65 weather resistance for indoor/outdoor use.
This option is great for those starting with continuous recording and local storage without investing in larger microSD cards upfront.
Why Choose Wyze Cam v4 for 24/7 Continuous Recording?
  • High-Resolution Video: 2.5K QHD ensures you capture every detail.
  • Local Storage Flexibility: Supports microSD cards up to 512GB, allowing days or weeks of continuous recording.
  • Smart Features: Motion zones, person detection, and sound alerts reduce false alarms.
  • Robust Night Vision: Enhanced color night vision and spotlight LEDs provide clear images in darkness.
  • Weatherproof Design: IP65 rating means reliable performance indoors and outdoors.
  • Easy Installation: Multiple mounting options and magnetic mounts simplify setup.
  • Smart Home Integration: Works with Alexa, Google Assistant, and IFTTT for voice control and automation.
Enhance Your Wyze Cam v3 with Accessories
If you still use the Wyze Cam v3 and want to improve its night visibility, consider the Wyze Cam v3 Spotlight Kit:
  • Motion-activated, IP65 rated spotlight with 70 lumens brightness.
  • 130-degree beam angle to illuminate dark areas.
  • Easy USB connection and compact design.
  • Extends night vision capabilities for better security footage.
This accessory complements your Wyze Cam v3 for enhanced continuous monitoring.
Summary
For users seeking Wyze Cam v3 alternatives or upgrades with 24/7 continuous recording on microSD cards, the Wyze Cam v4 series offers the best combination of video quality, local storage, and smart features. Whether you want a standalone camera, an outdoor bundle, or a full home security package, Wyze has you covered with reliable, weatherproof cameras that keep recording day and night.
Wyze Cam v4 Indoor Lifestyle Wyze Cam v4 monitoring your indoor spaces with clarity and color
Product Highlights at a Glance
ProductResolutionNight VisionmicroSD SupportContinuous RecordingWeather ResistanceIncluded microSDPrice (USD)
Wyze Cam v42.5K QHDColor Night VisionUp to 512GBYesIP65No$107.94
Wyze Cam v4 Outdoor Bundle2.5K QHDEnhanced Color NightYes (128GB)YesIP65128GB$69.99
Wyze Cam v4 Home Security Bundle2.5K QHDColor Night Vision128GBYesIP65128GB$169.99
Wyze Cam v4 + FREE 32GB microSD2.5K QHDColor Night Vision32GBYesIP6532GB$35.98
Wyze Cam v3 Spotlight KitAccessorySpotlight for v3N/AN/AIP65N/A$16.98
Choose the Wyze Cam v4 series for seamless 24/7 continuous recording with microSD cards and enjoy peace of mind knowing your home is monitored with the latest smart security technology.
FeatureWyze Cam v4Wyze Cam v4 Outdoor BundleWyze Cam v4 Home Security BundleWyze Cam v4 + FREE 32GB MicroSD Card
Price$35.98$69.99$169.99$35.98
Color VariantsBlack, Clear (Sold out), Grey, WhiteBlack, Grey, WhiteDefault (color not specified)Black, Grey, White
Resolution2.5K QHD (2560x1440)2.5K QHD (2560x1440)2.5K QHD (2560x1440)2.5K QHD
Night VisionEnhanced Color Night VisionEnhanced Color Night VisionEnhanced Color Night VisionEnhanced Color Night Vision
Motion-Activated SpotlightYesYesYesYes
AudioEnhanced Two-Way TalkImproved 2-way audioImproved 2-way audioEnhanced Two-Way Talk
SirenYes (99 dB)YesYesYes
Weather ResistanceIP65IP65IP65IP65
Wi-Fi SupportWi-Fi 6Wi-Fi 6Wi-Fi 6Wi-Fi 6
Local RecordingmicroSD card up to 512GB (sold separately)128GB microSD included128GB microSD includedmicroSD card required (32GB included)
Continuous 24/7 RecordingYesYesYesYes
Smart Assistant CompatibilityAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTT
Motion & Sound DetectionYesYesYesYes
Motion Detection ZonesYesYesYesYes
Smoke & CO AlertsYesYesYesYes
Mounting OptionsStand, Wall, Ceiling, MagneticNot specifiedStand, Wall, Ceiling, MagneticStand, Wall, Ceiling, Magnetic
Field of View (DFOV x HFOV x VFOV)115.8° x 98.5° x 53.1°115.8° x 98.5° x 53.1°115.8° x 98.5° x 53.1°115.8° x 98.5° x 53.1°
Digital Zoom8x8x8x8x
Video FPS (Day/Night)20 FPS / 15 FPS20 FPS / 15 FPS20 FPS / 15 FPSNot specified
Video EncodingH.264H.264H.264Not specified
Weight0.49 lb (222 g)Not specified0.49 lb (222 g)Not specified
Dimensions2in x 2in x 2 3/8inNot specified2in x 2in x 2 3/8inNot specified
Included AccessoriesUSB Power Adapter, Mounting Kit, CableOutdoor Power Adapter, 128GB microSD128GB microSD included32GB microSD included
Outdoor Use ReadyRequires Outdoor Power Adapter (sold separately)Yes (includes Outdoor Power Adapter)Yes (IP65 rated)Requires Outdoor Power Adapter (sold separately)
Warranty1 Year1 Year1 YearNot specified
Which Wyze cameras support 24/7 continuous recording with a microSD card?The Wyze Cam v4 series, including the standard Wyze Cam v4, Wyze Cam v4 Outdoor Bundle, Wyze Cam v4 Home Security Bundle, and Wyze Cam v4 + FREE 32GB microSD Card, all support 24/7 continuous recording with microSD card storage. These models allow you to record locally without relying on the cloud.
What is the maximum microSD card size supported by Wyze Cam v4 for continuous recording?Wyze Cam v4 supports microSD cards up to 512GB, enabling days or even weeks of continuous 24/7 local video recording.
Does Wyze Cam v4 offer color night vision for better nighttime security?Yes, Wyze Cam v4 features enhanced color night vision with 4 IR LEDs and 2 white spotlight LEDs, providing vivid and clear images even in complete darkness.
Is Wyze Cam v4 weatherproof and suitable for outdoor use?Wyze Cam v4 has an IP65 weather resistance rating, making it suitable for both indoor and outdoor use. It is designed to withstand various weather conditions.
What smart features are included with Wyze Cam v4 for home security?Wyze Cam v4 offers smart features such as motion and sound detection, person detection, customizable motion detection zones, two-way audio, a built-in 99dB siren, and compatibility with Alexa, Google Assistant, and IFTTT.
What is included in the Wyze Cam v4 Outdoor Bundle?The Wyze Cam v4 Outdoor Bundle includes a Wyze Cam v4, Wyze Outdoor Power Adapter for reliable outdoor power, a 128GB Wyze microSD card for immediate 24/7 local recording, enhanced color night vision, a motion-activated spotlight, and wide dynamic range for balanced lighting.
What is the difference between the Wyze Cam v4 Home Security Bundle and the standard Wyze Cam v4?The Wyze Cam v4 Home Security Bundle includes a Wyze Cam v4, a 128GB microSD card (Class 10, UHS-3) for extended local storage, motion-activated spotlight, person detection, improved two-way audio, a built-in siren, and multiple mounting options. The standard Wyze Cam v4 does not include a microSD card or the additional bundled accessories.
Can I use Wyze Cam v4 with my smart home devices?Yes, Wyze Cam v4 is compatible with Alexa, Google Assistant, and IFTTT, allowing for voice control and smart home automation.
What are the video resolution and field of view for Wyze Cam v4?Wyze Cam v4 records in 2.5K QHD (2560x1440) resolution and offers a wide field of view: 115.8° diagonal, 98.5° horizontal, and 53.1° vertical.
Is there an accessory to improve night vision on Wyze Cam v3?Yes, the Wyze Cam v3 Spotlight Kit is an accessory that adds a motion-activated, IP65-rated spotlight with 70 lumens brightness and a 130-degree beam angle, enhancing the night vision capabilities of your Wyze Cam v3.
What mounting options are available for Wyze Cam v4?Wyze Cam v4 offers versatile mounting options, including stand, wall, ceiling, and magnetic mounts, making installation easy in various locations.
How much video can a 128GB microSD card store on Wyze Cam v4?A 128GB microSD card can store up to approximately 192 hours (8 days) of HD video when used with Wyze Cam v4 for continuous 24/7 recording.
Is the Wyze Cam v4 a good upgrade from Wyze Cam v3 for continuous recording?Yes, Wyze Cam v4 is an excellent upgrade from Wyze Cam v3, offering higher 2.5K QHD resolution, enhanced color night vision, support for larger microSD cards (up to 512GB), Wi-Fi 6 connectivity, and advanced smart features for superior 24/7 continuous recording.
What are the key features of the Wyze Cam v4 compared to the Wyze Cam v3?Can you tell me more about the Wyze Cam v4 Outdoor Bundle and its benefits?Are there any ongoing promotions or discounts for the Wyze Cam v4?
