Wyze Battery Cam Pro: Flexible Outdoor Camera with Multiple Mounts
Outdoor Cameras with Multiple Mounting Options for Flexible Placement
When it comes to securing your outdoor spaces, having a camera that supports multiple mounting options is essential for flexible placement. Whether you want to mount your camera on a wall, ceiling, or even use magnetic mounts, Wyze offers versatile solutions tailored to your needs. Among these, the Wyze Battery Cam Pro and its related bundles stand out as top choices for outdoor security with flexible installation and advanced features.
Wyze Battery Cam Pro: Ultimate Flexibility and Power
Key Features and Specs
  • 2.5K HDR Video Resolution: Capture crystal-clear, high dynamic range video with rich colors and sharp details, day or night.
  • Wire-Free & No Hub Required: Completely wireless design means no complicated wiring or hubs needed.
  • Multiple Mounting Options: Supports standard 1/4” - 20 mounts, including wall, ceiling, and third-party mounts. The Wyze Universal Mount (Long) is perfect for ceiling installations, providing a longer stem for flexible positioning.
  • Removable, Rechargeable Battery Packs: Easily swap batteries without taking down the camera, ensuring continuous protection.
  • IP65 Weatherproof: Built to withstand rain, dust, and extreme weather conditions.
  • Integrated Spotlight & Siren: 150 lumens LED spotlight and siren deter intruders effectively.
  • Radar + PIR Motion Detection: Dual sensors for earlier and more precise motion alerts.
  • Dual-Band Wi-Fi Support: Connects to both 2.4 GHz and 5 GHz networks for faster, more reliable streaming.
  • Local Recording: Supports microSD cards for local event recording without subscription.
  • Enhanced Two-Way Audio: Built-in microphone and speaker for clear communication.
Flexible Mounting for Any Outdoor Space
The Wyze Battery Cam Pro is designed with versatility in mind. Whether you want to mount it on a wall, under an eave, or even on a ceiling, the camera supports multiple mounting methods. The included wall mount and optional Wyze Universal Mount (Long) make it easy to position your camera exactly where you need it.
"No wires. No hubs. The ultimate battery-operated go-anywhere, see-everything home security camera."
Wyze Battery Cam Pro mounted outdoors Flexible wireless mounting with rechargeable battery packs
Wyze Battery Cam Pro + Solar Panel: Continuous Power for Extended Security
Why Choose the Solar Panel Bundle?
  • All Features of Wyze Battery Cam Pro: Enjoy the same 2.5K HDR video, dual motion sensors, and weatherproof design.
  • Solar Panel for Continuous Charging: Convert sunlight into power to keep your camera running longer without frequent battery swaps.
  • Easy Installation: The solar panel mounts easily alongside the camera, providing a sustainable power source.
  • Perfect for Remote or Hard-to-Reach Areas: Ideal for locations where regular battery charging is inconvenient.
This bundle is perfect for users who want the flexibility of wireless placement combined with the convenience of solar power, ensuring your camera stays active and ready to protect your property. Solar panel powering outdoor camera Solar panel providing continuous power for Wyze Battery Cam Pro
Bird Feeder Wireless Camera Bundle: Outdoor Security Meets Nature Watching
Bundle Includes:
  • Wyze Battery Cam Pro
  • Wyze Solar Panel
  • Wyze Bird Feeder with built-in camera
Features:
  • Weather-Resistant and Wire-Free: All components are IP65 rated and designed for outdoor use.
  • Flexible Mounting: The camera supports standard mounts for versatile placement around your yard or garden.
  • Birdwatching Made Easy: The vibrant bird feeder attracts a variety of birds, while the Wyze Battery Cam Pro captures live video of every visitor.
  • Integrated Solar Power: Keep your camera charged with the included solar panel.
  • Smart Home Integrations: Compatible with Alexa, Google Assistant, and IFTTT for seamless control.
This bundle is perfect for bird lovers who want to combine outdoor security with nature observation, all while enjoying flexible camera placement options.
Why Choose Wyze Outdoor Cameras for Flexible Mounting?
  • Multiple Mounting Methods: Screw mounts, magnetic mounts, and longer stems for ceiling or eave installation.
  • Wireless and Battery-Powered: No need for power outlets or complicated wiring.
  • Weatherproof Durability: IP65 rating ensures cameras withstand rain, dust, and temperature extremes.
  • Advanced Motion Detection: Radar + PIR sensors provide accurate alerts with customizable detection zones.
  • High-Resolution Video: 2.5K HDR resolution with color night vision captures every detail.
  • Expandable with Accessories: Add solar panels, extra batteries, and charging docks for extended use.
Conclusion
For outdoor security cameras that support multiple mounting options and flexible placement, the Wyze Battery Cam Pro and its solar-powered bundles offer unmatched versatility and performance. Whether you want a standalone wireless camera, a solar-powered setup, or a unique birdwatching bundle, Wyze has you covered with weatherproof, high-resolution cameras that are easy to install anywhere. Protect your home or enjoy nature with confidence, knowing your Wyze camera can be mounted exactly where you need it — no wires, no hassle.
FeatureWyze Battery Cam ProWyze Battery Cam Pro + Solar PanelBird Feeder Wireless Camera Bundle
Video Resolution2.5K HDR2.5K HDR2.5K HDR
Power SourceRemovable, Rechargeable BatteryBattery + Solar PanelBattery + Solar Panel
Solar Panel IncludedNoYesYes
Integrated Spotlight & SirenYesYesYes
Motion DetectionRadar + PIRRadar + PIRRadar + PIR
Weatherproof RatingIP65IP65IP65
WiFi Support2.4 & 5 GHz2.4 & 5 GHz2.4 & 5 GHz
Local Recording (MicroSD)YesYesYes
Color VariantsBlack, WhiteBlack, WhiteBlack, White (Camera)
Pack Options1, 2, 3 PacksSingle Unit OnlySingle Unit Only (Bundle includes Bird Feeder & Solar Panel)
Price (USD)From $89.98$109.98From $139.98
Additional Included Items-Wyze Solar PanelWyze Bird Feeder, Wyze Solar Panel
Bird Feeder IncludedNoNoYes (Blue or Brown color options)
Bird Feeder FeaturesN/AN/AWeather-Resistant, 1 Liter Seed Capacity, Macro Lens Adapter
Camera Dimensions2.5" x 1.8" x 3.5"Same as Battery Cam ProSame as Battery Cam Pro
Battery LifeUp to 6 months per chargeExtended with Solar PanelExtended with Solar Panel
Mounting OptionsWall, Ceiling (with Universal Mount)Same as Battery Cam ProSame as Battery Cam Pro
Smart Home IntegrationsAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTT
WarrantyStandard Wyze WarrantyStandard Wyze Warranty1 year
What mounting options are available for Wyze outdoor cameras?Wyze outdoor cameras, including the Wyze Battery Cam Pro, support multiple mounting options such as wall, ceiling, and third-party mounts. They are compatible with standard 1/4” - 20 mounts and can also be installed using the Wyze Universal Mount (Long) for flexible ceiling or eave placement.
Is the Wyze Battery Cam Pro wireless and easy to install?Yes, the Wyze Battery Cam Pro is completely wire-free and does not require a hub or complicated wiring. Its wireless design and multiple mounting options make installation quick and flexible for any outdoor space.
Are Wyze outdoor cameras weatherproof?Yes, Wyze outdoor cameras, including the Wyze Battery Cam Pro and its bundles, are IP65 weatherproof. This means they are built to withstand rain, dust, and extreme weather conditions, making them ideal for outdoor use.
What are the key features of the Wyze Battery Cam Pro?The Wyze Battery Cam Pro offers 2.5K HDR video resolution, wire-free installation, multiple mounting options, removable rechargeable battery packs, IP65 weatherproofing, integrated spotlight and siren, radar + PIR motion detection, dual-band Wi-Fi support, local microSD recording, and enhanced two-way audio.
How does the Wyze Battery Cam Pro + Solar Panel bundle work?The Wyze Battery Cam Pro + Solar Panel bundle includes all the features of the Wyze Battery Cam Pro, with the added benefit of a solar panel for continuous charging. The solar panel mounts easily alongside the camera, providing sustainable power and reducing the need for frequent battery swaps, especially in remote or hard-to-reach areas.
Can I use Wyze outdoor cameras for birdwatching?Yes, the Bird Feeder Wireless Camera Bundle combines the Wyze Battery Cam Pro, Wyze Solar Panel, and a bird feeder with a built-in camera. This bundle is perfect for bird lovers who want to observe and record birds while also enjoying the benefits of outdoor security and flexible camera placement.
Do Wyze outdoor cameras support local video recording?Yes, Wyze outdoor cameras support local event recording via microSD cards. This allows you to store video footage locally without the need for a subscription.
Are Wyze outdoor cameras compatible with smart home systems?Yes, Wyze outdoor cameras are compatible with Alexa, Google Assistant, and IFTTT, allowing for seamless integration and control within your smart home ecosystem.
What motion detection features do Wyze outdoor cameras offer?Wyze outdoor cameras feature advanced motion detection using both radar and PIR (Passive Infrared) sensors. This dual-sensor system provides earlier and more accurate motion alerts, with customizable detection zones for tailored security.
Can I expand my Wyze outdoor camera setup with accessories?Yes, Wyze outdoor cameras are expandable with accessories such as solar panels, extra rechargeable battery packs, and charging docks, allowing you to customize and extend your security system as needed.
What are the different mounting options available for the Wyze Battery Cam Pro?Can the Wyze Battery Cam Pro be used in extreme weather conditions?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Battery Cam Pro?
