Wyze Battery Cam Pro: Max 256GB Storage & Key Features
Wyze Battery Cam Pro Maximum Storage Capacity and Features
The Wyze Battery Cam Pro is a cutting-edge wireless security camera designed for flexible, high-quality home monitoring without the hassle of wires or hubs. One of the key concerns for users is the camera’s storage capacity, especially for local recording. Here’s a detailed look at the maximum storage capacity and other standout features of the Wyze Battery Cam Pro and its related accessories.
Maximum Storage Capacity of Wyze Battery Cam Pro
Local Storage via MicroSD Card
The Wyze Battery Cam Pro supports local recording through a microSD card, allowing you to save motion-triggered video clips directly on the device without requiring a cloud subscription. This is ideal for users who want to keep their footage private or avoid monthly fees.
  • Maximum microSD Card Capacity: The camera supports microSD cards up to 256GB.
  • Recording Type: Motion event recording and continuous recording (time lapses) are possible.
  • Battery Impact: Enabling local recording will impact battery life, so it’s recommended to balance recording needs with power management.
Recommended microSD Cards for Wyze Battery Cam Pro
Wyze offers compatible microSD cards in the following sizes:
  • 32GB microSDHC Card
  • 128GB microSDXC Card
  • 256GB microSDXC Card
Using a higher capacity card like the 256GB microSDXC allows for longer local storage before overwriting old footage, making it perfect for users who want extended video history without cloud dependency.
Wyze Battery Cam Pro Key Features
High-Resolution Video and Night Vision
  • 2.5K HDR Video Resolution: Capture crisp, detailed footage with high dynamic range for balanced images and richer colors.
  • Color Night Vision: See clear, colorful video even in low-light conditions.
Advanced Motion Detection
  • Radar + PIR Sensors: Dual motion detection technology provides earlier and more precise alerts.
  • Custom Detection Zones: Set specific areas to monitor and reduce false alarms.
  • Smart Notifications: Enhanced with Cam Plus subscription for person, package, and vehicle detection.
Power and Weather Resistance
  • Removable, Rechargeable Battery Packs: Hot-swap batteries to avoid downtime.
  • IP65 Weatherproof: Durable against rain, dust, and extreme temperatures.
  • Dual-Band Wi-Fi: Supports both 2.4 GHz and 5 GHz networks for reliable connectivity.
Integrated Spotlight & Siren
  • 150 Lumens LED Spotlight: Motion-activated light to deter intruders.
  • Siren: Built-in alarm to alert and scare off unwanted visitors.
Wyze Battery Cam Pro + Solar Panel Bundle
For users seeking extended battery life without manual recharging, the Wyze Battery Cam Pro + Solar Panel bundle is an excellent choice.
  • Continuous Power: The solar panel converts sunlight into energy, significantly reducing the need to remove and recharge batteries.
  • Weather Resistant Solar Panel: Rated IP65, designed to withstand outdoor conditions.
  • Easy Installation: Mount the solar panel anywhere with a 13-foot power cable for flexible placement.
This bundle combines the full features of the Battery Cam Pro with the convenience of solar power, ideal for remote or hard-to-reach locations. Outdoor Security Camera in Use
Essential Accessories to Maximize Usage
Wyze Removable Battery Pack
  • Capacity: 6200mAh rechargeable lithium-ion battery.
  • Battery Life: Lasts up to 6 months on a single charge under typical usage.
  • Convenient USB-C Charging: Fast and easy to recharge.
  • Lightweight and Compact: Easy to swap without interrupting camera operation.
Wyze Battery Charging Dock
  • Dual Charging: Charge two battery packs simultaneously.
  • Compact Design: Small footprint for easy placement.
  • Fast Charging: Approximately 8.5 hours for full charge.
Wyze Battery Cam Solar Panel
  • Extend Recording Time: Keeps your camera powered longer using solar energy.
  • Weatherproof and Durable: IP65 rating ensures reliable outdoor use.
  • Includes Mount and Cables: Everything needed for quick setup.
Solar Panel Powering Camera
Why Choose Wyze Battery Cam Pro for Your Security Needs?
"The Wyze Battery Cam Pro offers a perfect blend of high-resolution video, flexible power options, and robust local storage capabilities, making it a top choice for wireless home security."
  • No Hub Required: Simplifies installation and setup.
  • Flexible Mounting: Use the Wyze Universal Mount for ceiling or wall installation.
  • Smart Home Integration: Compatible with Alexa, Google Assistant, and IFTTT.
  • Affordable Cloud Storage: Optional Cam Plus subscription for enhanced smart detection and unlimited cloud video storage.
Family Using Wyze App
Summary
The Wyze Battery Cam Pro supports up to 256GB microSD card for local storage, providing ample space for motion-triggered recordings without a subscription. Pairing it with the Wyze Solar Panel or additional removable battery packs ensures continuous monitoring with minimal maintenance. Whether you want local storage or cloud backup, the Wyze Battery Cam Pro offers versatile, high-quality security for any home or outdoor environment.
Product Tags Recap
  • Wyze Battery Cam Pro:
  • Wyze Battery Cam Pro + Solar Panel:
  • Wyze Removable Battery Pack:
  • Wyze Battery Charging Dock:
  • Wyze Battery Cam Solar Panel:
FeatureWyze Battery Cam ProWyze Battery Cam Pro + Solar PanelWyze Removable Battery PackWyze Battery Charging DockWyze Battery Cam Solar Panel
TypeCameraCameraAccessoryAccessoryAccessory
Video Resolution2560 x 1440 (2.5K)2560 x 1440 (2.5K)N/AN/AN/A
Video EncodingH.264H.264N/AN/AN/A
WirelessYesYesN/AN/AN/A
Power SourceRemovable, Rechargeable Battery PacksRemovable, Rechargeable Battery Packs6200mAh Rechargeable BatteryCharges BatteriesSolar Panel (2.5W, 5VDC)
Battery Capacity6200mAh6200mAh6200mAhN/AN/A
Battery LifeUp to 6 MonthsUp to 6 MonthsUp to 6 MonthsN/AExtends Battery Life
Charging TimeApproximately 9 hoursApproximately 9 hoursApproximately 9 hoursApproximately 8.5 hoursN/A
Weather ResistanceIP65IP65N/AN/AIP65
Operating Temperature-20°C to +50°C (-4°F to +122°F)-20°C to +50°C (-4°F to +122°F)-20°C to +50°C (-4°F to +122°F)+10°C to +40°C (+50°F to +104°F)N/A
Local StorageSupports up to 256 GB microSD cardsSupports up to 256 GB microSD cardsN/AN/AN/A
Cloud StorageN/ARecord to cloud with Cam PlusN/AN/AN/A
Image SensorCMOS-Starlight SensorCMOS-Starlight SensorN/AN/AN/A
Lens ApertureF1.6F1.6N/AN/AN/A
Field of View134° DFOV, 108° HFOV, 56° VFOV134° DFOV, 108° HFOV, 56° VFOVN/AN/AN/A
Night Vision2 IR LEDs (850 nm), 2 White LEDs (5500K, 187 lumens)2 IR LEDs (850 nm), 2 White LEDs (5500K, 187 lumens)N/AN/AN/A
AudioTwo-way Audio with built-in speaker and microphoneTwo-way AudioN/AN/AN/A
Siren100 dB SPL @ 0.1m100 dB SPL @ 0.1mN/AN/AN/A
CPU Speed500 MHz500 MHzN/AN/AN/A
Memory128 MB RAM128 MB RAMN/AN/AN/A
Mounting Methods1/4” - 20 standard1/4” - 20 standardN/AN/AN/A
Wall Mount IncludedYesYesN/AN/AN/A
Dimensions2.5 x 1.8 x 3.5 inches2.5 x 1.8 x 3.5 inches2.9 x 1.6 x 0.9 inchesCharging Dock: 2.6 x 2 x 1 in173 x 120 x 17 mm
Weight0.94 lbs0.94 lbs3.9 oz (110 g)2.75 oz (78 g)N/A
Color OptionsBlack, WhiteBlack, WhiteWhiteWhiteWhite frame and mount, Black solar cells
BluetoothBLE 5.1BLE 5.1N/AN/AN/A
WiFi2.4 GHz and 5 GHz, 802.11a/n/g/b2.4 GHz and 5 GHz, 802.11a/n/g/bN/AN/AN/A
Phone CompatibilityAndroid 9.0+, iOS 15.0+Android 9.0+, iOS 15.0+N/AN/AN/A
Additional FeaturesIntegrated Spotlight, Radar + PIR Motion DetectionIntegrated Spotlight, Radar + PIR Motion Detection, Color Night VisionUSB-C charging portCharges two batteries simultaneouslyIP65 Weather Resistant, 360° Mount, 13 ft Cable
Price$89.98 - $219.98 (varies by pack)$109.98$22.99$17.99$24.99
What is the maximum microSD card capacity supported by the Wyze Battery Cam Pro?The Wyze Battery Cam Pro supports microSD cards up to 256GB, allowing for extensive local video storage without the need for a cloud subscription.
Can the Wyze Battery Cam Pro record continuously to a microSD card?Yes, the Wyze Battery Cam Pro supports both motion event recording and continuous recording (including time lapses) to a microSD card.
Which microSD card sizes are recommended for the Wyze Battery Cam Pro?Wyze recommends using 32GB, 128GB, or 256GB microSD cards for optimal performance and extended local storage.
Does using local recording on the Wyze Battery Cam Pro affect battery life?Enabling local recording on the Wyze Battery Cam Pro can impact battery life, so it’s important to balance your recording needs with power management.
What video resolution does the Wyze Battery Cam Pro offer?The Wyze Battery Cam Pro features 2.5K HDR video resolution, providing crisp, detailed footage with high dynamic range for balanced images and richer colors.
Does the Wyze Battery Cam Pro have night vision?Yes, the Wyze Battery Cam Pro is equipped with color night vision, allowing you to see clear, colorful video even in low-light conditions.
What motion detection features are included in the Wyze Battery Cam Pro?The Wyze Battery Cam Pro uses dual motion detection technology with radar and PIR sensors, custom detection zones, and offers smart notifications for person, package, and vehicle detection with a Cam Plus subscription.
Is the Wyze Battery Cam Pro weatherproof?Yes, the Wyze Battery Cam Pro is IP65 weatherproof, making it durable against rain, dust, and extreme temperatures for reliable outdoor use.
What power options are available for the Wyze Battery Cam Pro?The Wyze Battery Cam Pro uses removable, rechargeable battery packs and can also be powered continuously with the Wyze Solar Panel for extended battery life.
How long does the Wyze removable battery pack last on a single charge?The Wyze removable battery pack has a capacity of 6200mAh and can last up to 6 months on a single charge under typical usage conditions.
What is included in the Wyze Battery Cam Pro + Solar Panel bundle?The Wyze Battery Cam Pro + Solar Panel bundle includes the camera and a weather-resistant solar panel with a 13-foot power cable, providing continuous power and reducing the need for manual recharging.
Can I charge multiple Wyze battery packs at once?Yes, the Wyze Battery Charging Dock allows you to charge two battery packs simultaneously, with a compact design and fast charging capabilities.
Does the Wyze Battery Cam Pro require a hub for installation?No, the Wyze Battery Cam Pro does not require a hub, making installation and setup simple and straightforward.
Is the Wyze Battery Cam Pro compatible with smart home systems?Yes, the Wyze Battery Cam Pro is compatible with Alexa, Google Assistant, and IFTTT for seamless smart home integration.
What are the benefits of using the Wyze Solar Panel with the Battery Cam Pro?Using the Wyze Solar Panel with the Battery Cam Pro provides continuous power, extends recording time, and minimizes the need for manual battery recharging, making it ideal for remote or hard-to-reach locations.
What security features does the Wyze Battery Cam Pro offer to deter intruders?The Wyze Battery Cam Pro includes a 150 lumens LED spotlight and a built-in siren, both of which can be activated to deter intruders and alert you to suspicious activity.
Is cloud storage available for the Wyze Battery Cam Pro?Yes, the Wyze Battery Cam Pro offers optional cloud storage through the Cam Plus subscription, which provides enhanced smart detection and unlimited cloud video storage.
What is the maximum capacity of the microSD card that can be used with the Wyze Battery Cam Pro?Can you explain how the local recording feature works on the Wyze Battery Cam Pro?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Battery Cam Pro?
