Wyze Battery Cam Pro: Top Features, Specs & Solar Power Options
Wyze Battery Cam Pro Features Overview
The Wyze Battery Cam Pro is a cutting-edge wireless security camera designed to provide flexible, high-quality home protection without the hassle of wires or hubs. With its advanced technology and user-friendly features, it’s perfect for monitoring your home, RV, or any outdoor space with ease.
Stunning 2.5K HDR Video Quality
Experience crystal-clear video with the Wyze Battery Cam Pro’s 2.5K HDR resolution. This high dynamic range technology ensures balanced images with richer colors, capturing every detail day or night. Whether it’s bright sunlight or low-light conditions, the camera delivers vibrant and sharp footage, making it easier to identify people, packages, or vehicles.
Wire-Free and Weatherproof Design
Say goodbye to complicated wiring and power outlets. The Wyze Battery Cam Pro is completely wire-free and requires no hub, allowing you to place it anywhere you need security. Its IP65 weatherproof rating means it can withstand rain, dust, and extreme temperatures, ensuring reliable performance in all weather conditions.
Advanced Motion Detection with Radar + PIR Sensors
This camera features a powerful combination of radar and PIR (Passive Infrared) motion sensors. This dual-sensor system detects motion earlier and more accurately, reducing false alerts. Customize detection zones in the Wyze app to focus on specific areas, and enjoy smarter notifications with the optional Cam Plus subscription.
Integrated Spotlight and Siren for Enhanced Security
The built-in 150-lumen LED spotlight activates automatically when motion is detected, illuminating potential intruders and deterring unwanted visitors. You can also manually control the spotlight via the Wyze app for added safety during nighttime activities. Additionally, the camera includes a siren to alert you and scare off intruders.
Flexible Power Options with Removable Battery Packs
The Wyze Battery Cam Pro comes with rechargeable, removable battery packs that provide up to 6 months of power on a single charge. Easily swap batteries without taking down the camera, minimizing security downtime. For continuous power, pair the camera with the Wyze Battery Charging Dock to charge two batteries simultaneously.
Solar Panel Compatibility for Extended Use
Transform your Wyze Battery Cam Pro into a solar-powered security camera by adding the Wyze Solar Panel. This eco-friendly option converts sunlight into power, allowing your camera to stay up longer with less frequent charging. Ideal for remote locations or areas without easy access to power outlets.
Local Recording and Dual-Band Wi-Fi Support
Record motion events locally with a microSD card (sold separately), so you never miss a moment without needing a subscription. The camera supports both 2.4 GHz and 5 GHz Wi-Fi networks for faster, more reliable connectivity. Setup is quick and easy with Bluetooth, eliminating the need for QR code scanning.
Enhanced Two-Way Audio
Communicate clearly through the camera’s built-in microphone and speaker. Whether you want to greet visitors or warn off intruders, the enhanced two-way audio feature lets you talk or yell remotely with ease.
Wyze Battery Cam Pro + Solar Panel Bundle
For those seeking uninterrupted security, the Wyze Battery Cam Pro + Solar Panel bundle offers all the features of the Battery Cam Pro with the added benefit of solar power. This bundle is perfect for outdoor enthusiasts, RV owners, or anyone wanting a sustainable power solution.
  • Includes one Wyze Battery Cam Pro and one Wyze Solar Panel.
  • Continuous power from solar energy reduces the need for manual recharging.
  • Same 2.5K HDR video, radar + PIR motion detection, integrated spotlight, and siren.
  • Weatherproof and wire-free for ultimate placement flexibility.
Protect your home or outdoor space with a smart, eco-friendly security solution that keeps watch day and night without interruption.
Essential Accessories for Wyze Battery Cam Pro
Wyze Removable Battery Pack
Keep your camera powered longer with the Wyze Removable Battery Pack. This 6200mAh rechargeable lithium-ion battery is designed specifically for the Battery Cam Pro and Duo Cam Doorbell.
  • Lasts up to 6 months on a single charge.
  • Convenient USB-C charging port.
  • Compact and lightweight for easy swapping.
Charge two battery packs simultaneously with the Wyze Battery Charging Dock. This accessory helps you maintain continuous security by keeping spare batteries ready to go.
  • Compact design with included power adapter and USB-A to USB-C cable.
  • Fully charges batteries in approximately 8.5 hours.
  • Compatible with Wyze Battery Cam Pro battery packs.
Why Choose Wyze Battery Cam Pro?
"The ultimate wire-free, weatherproof security camera with pro-grade features."
  • 2.5K HDR video for crystal-clear images.
  • Radar + PIR motion detection for precise alerts.
  • Integrated spotlight and siren for active deterrence.
  • Removable rechargeable batteries for hassle-free power management.
  • Solar panel compatibility for eco-friendly continuous operation.
  • Dual-band Wi-Fi and Bluetooth setup for fast, reliable connectivity.
  • Local microSD recording option for subscription-free video storage.
Whether you want to secure your home, monitor your RV, or keep an eye on your outdoor spaces, the Wyze Battery Cam Pro offers versatile, high-quality protection that adapts to your lifestyle.
Outdoor security camera in use at night with spotlight illuminating a driveway Wyze Battery Cam Pro providing clear night vision and spotlight security. Solar panel powering a wireless security camera on a sunny day Eco-friendly solar power extends camera runtime. Person swapping rechargeable battery pack on a wireless security camera Easy battery swaps keep your camera running longer.
FeatureWyze Battery Cam ProWyze Battery Cam Pro + Solar PanelWyze Removable Battery PackWyze Battery Charging Dock
TypeCameraCamera BundleAccessoryAccessory
Price$89.98 (1 Pack)$109.98$22.99$17.99
Video Resolution2.5K HDR2.5K HDRN/AN/A
Power SourceRemovable, Rechargeable Battery PacksBattery Cam Pro + Solar Panel (continuous power)Replacement 6200mAh rechargeable batteryCharges up to two batteries simultaneously
Battery CapacityIncluded (6200mAh)Included (6200mAh)6200mAh Lithium IonN/A
Battery Charging PortUSB-CUSB-CUSB-CUSB-A to USB-C cable included
Charging TimeApprox. 9 hoursApprox. 9 hoursApprox. 9 hoursApprox. 8.5 hours
Weatherproof RatingIP65IP65N/AN/A
Wi-Fi Support2.4 & 5 GHz2.4 & 5 GHzN/AN/A
Motion DetectionRadar + PIRRadar + PIRN/AN/A
Integrated Spotlight & SirenYesYesN/AN/A
Local RecordingYes (with microSD card)Yes (with microSD card)N/AN/A
Mounting OptionsFlexible, includes ceiling mount optionFlexible, includes ceiling mount optionN/AN/A
Additional FeaturesWire-free, no hub required, two-way audioWire-free, no hub required, two-way audioReplacement battery for uninterrupted useDual battery charging dock
WeightNot specifiedNot specified3.9 oz (110g)2.75 oz (78g)
DimensionsNot specifiedNot specified2.9 in x 1.6 in x 0.9 in (75 x 40 x 22 mm)Dock: 2.6in x 2in x 1in; Adapter: 42mm x 40mm x 23mm
CompatibilityN/AN/AWyze Battery Cam Pro and Wyze Duo Cam DoorbellWyze Battery Cam Pro battery packs
What is the Wyze Battery Cam Pro?The Wyze Battery Cam Pro is a wireless, weatherproof security camera designed for flexible home and outdoor monitoring. It features 2.5K HDR video quality, advanced motion detection, integrated spotlight and siren, and supports both battery and solar power options.
Does the Wyze Battery Cam Pro require any wires or a hub?No, the Wyze Battery Cam Pro is completely wire-free and does not require a hub. You can place it anywhere you need security without worrying about complicated wiring or power outlets.
What video quality does the Wyze Battery Cam Pro offer?The Wyze Battery Cam Pro delivers stunning 2.5K HDR video quality, providing crystal-clear images with rich colors and sharp details, even in low-light or bright sunlight conditions.
Is the Wyze Battery Cam Pro weatherproof?Yes, the Wyze Battery Cam Pro has an IP65 weatherproof rating, making it suitable for use in rain, dust, and extreme temperatures. It is designed for reliable performance in all weather conditions.
How does motion detection work on the Wyze Battery Cam Pro?The Wyze Battery Cam Pro uses a combination of radar and PIR (Passive Infrared) sensors for advanced motion detection. This dual-sensor system detects motion earlier and more accurately, reducing false alerts. You can also customize detection zones in the Wyze app.
Does the Wyze Battery Cam Pro have a spotlight and siren?Yes, the camera features a built-in 150-lumen LED spotlight that activates automatically when motion is detected, as well as a siren to deter intruders and alert you to suspicious activity.
What are the power options for the Wyze Battery Cam Pro?The Wyze Battery Cam Pro comes with rechargeable, removable battery packs that last up to 6 months on a single charge. You can also use the Wyze Solar Panel for continuous, eco-friendly power.
Can I use a solar panel with the Wyze Battery Cam Pro?Yes, the Wyze Battery Cam Pro is compatible with the Wyze Solar Panel, allowing you to power your camera with sunlight for extended use and less frequent charging.
Does the Wyze Battery Cam Pro support local video recording?Yes, you can record motion events locally using a microSD card (sold separately), so you never miss a moment without needing a subscription.
What Wi-Fi networks does the Wyze Battery Cam Pro support?The Wyze Battery Cam Pro supports both 2.4 GHz and 5 GHz Wi-Fi networks, providing faster and more reliable connectivity.
How do I set up the Wyze Battery Cam Pro?Setup is quick and easy with Bluetooth, eliminating the need for QR code scanning. Simply follow the instructions in the Wyze app to get started.
Does the Wyze Battery Cam Pro have two-way audio?Yes, the camera features enhanced two-way audio, allowing you to communicate clearly with visitors or warn off intruders through the built-in microphone and speaker.
What is included in the Wyze Battery Cam Pro + Solar Panel bundle?The bundle includes one Wyze Battery Cam Pro and one Wyze Solar Panel, providing all the features of the camera with the added benefit of continuous solar power for uninterrupted security.
What accessories are available for the Wyze Battery Cam Pro?Essential accessories include the Wyze Removable Battery Pack for extended battery life and the Wyze Battery Charging Dock, which allows you to charge two battery packs simultaneously.
How long does the Wyze Removable Battery Pack last on a single charge?The Wyze Removable Battery Pack can last up to 6 months on a single charge, depending on usage and environmental conditions.
How long does it take to charge the Wyze Battery Cam Pro battery packs?Using the Wyze Battery Charging Dock, you can fully charge two battery packs in approximately 8.5 hours.
What are the benefits of using the Wyze Solar Panel with the Battery Cam Pro?How does the radar and PIR motion detection work in the Wyze Battery Cam Pro?Do you have any ongoing sales or discounts for the Wyze Battery Cam Pro?
