Wyze Battery Cam Pro: Discreet Garden Security Camera Solution
Discreet Design Cameras for Subtle Placement in Landscaped Gardens
When it comes to monitoring your landscaped garden without disrupting its natural beauty, choosing a discreet, reliable, and weatherproof camera is essential. The Wyze Battery Cam Pro series offers perfect solutions designed for subtle placement, blending seamlessly into outdoor environments while providing advanced security features.
Wyze Battery Cam Pro: Sleek, Powerful, and Wire-Free
Compact and Discreet Design
The Wyze Battery Cam Pro is designed with a matte finish and compact dimensions (2.5 x 1.8 x 3.5 inches), making it easy to place subtly among garden foliage or architectural features. Available in both black and white, it can blend into various outdoor settings without drawing attention.
High-Resolution Video and Night Vision
Capture every detail with stunning 2.5K HDR video resolution (2560 x 1440) and a CMOS-Starlight sensor paired with an F1.6 lens. The camera offers a wide field of view (134° diagonal) to cover large garden areas. Night vision is enhanced by 2 IR LEDs and 2 white LEDs, providing clear color night vision to monitor your garden even in low light.
Wire-Free and Long Battery Life
Powered by removable, rechargeable 6200mAh battery packs, the Wyze Battery Cam Pro supports up to 6 months of battery life on a single charge. This wire-free design allows for flexible placement anywhere in your garden without worrying about power outlets or cables.
Weatherproof and Durable
Built to withstand outdoor conditions, the camera features an IP65 weatherproof rating and operates reliably in temperatures ranging from -20°C to 50°C (-4°F to 122°F). This makes it ideal for all seasons and various climates.
Smart Features for Enhanced Security
  • Integrated spotlight and 100 dB siren for deterrence
  • Radar + PIR motion detection for accurate alerts
  • Two-way audio with built-in microphone and speaker
  • Supports 2.4 GHz and 5 GHz WiFi for stable connectivity
  • Compatible with Alexa, Google Assistant, and IFTTT for smart home integration
Wyze Battery Cam Pro + Solar Panel: Continuous Power for Extended Monitoring
For those seeking even more convenience, the Wyze Battery Cam Pro + Solar Panel bundle offers the same advanced camera features with the added benefit of solar charging. This option ensures your camera stays powered longer without manual recharging, perfect for remote garden spots.
Key Highlights:
  • Same 2.5K HDR video quality and wide field of view
  • Solar panel keeps the rechargeable battery topped up
  • Wire-free, weatherproof design with IP65 rating
  • Color night vision and radar + PIR motion detection
  • Easy installation with included wall mount
This solar-powered option is ideal for landscaped gardens where running power cables is impractical, providing continuous surveillance with minimal maintenance.
Essential Accessories for Optimal Performance
Wyze Removable Battery Pack
Extend your camera’s uptime with additional 6200mAh rechargeable battery packs. These replacement batteries are designed specifically for the Wyze Battery Cam Pro, allowing you to swap batteries quickly and keep your cameras running without interruption.
Wyze Battery Charging Dock
Charge two Wyze battery packs simultaneously with the dual charging dock. This accessory is perfect for users with multiple cameras, ensuring you always have fully charged batteries ready for quick replacement.
Why Choose Wyze Battery Cam Pro for Your Garden?
The Wyze Battery Cam Pro series combines discreet design, high-quality video, and smart features in a weatherproof, wire-free package. Whether you want to monitor your garden’s beauty or secure your outdoor space, these cameras offer reliable performance with minimal visual impact.
With flexible mounting options and long-lasting battery life, these cameras are tailored for subtle placement in landscaped gardens, providing peace of mind without compromising aesthetics.
Summary of Key Specs
FeatureWyze Battery Cam Pro / Pro + Solar Panel
Video Resolution2.5K HDR (2560 x 1440)
Field of View134° diagonal, 108° horizontal
Battery Capacity6200mAh rechargeable, up to 6 months life
Power SourceRemovable battery / Solar panel (optional)
Weather ResistanceIP65 rated, -20°C to 50°C operation
Night Vision2 IR LEDs + 2 white LEDs (color night vision)
Motion DetectionRadar + PIR sensors
AudioTwo-way audio with mic and speaker
Connectivity2.4 GHz & 5 GHz WiFi, BLE 5.1 Bluetooth
Smart Home IntegrationAlexa, Google Assistant, IFTTT
Dimensions2.5 x 1.8 x 3.5 inches
Weight0.94 lbs
Capture Your Garden’s Beauty and Security Seamlessly
The Wyze Battery Cam Pro series offers the perfect balance of subtlety and sophistication for garden surveillance. Its compact, weatherproof design and advanced features ensure your landscaped garden remains both beautiful and secure. Garden with discreet security camera
Protect your outdoor sanctuary with Wyze’s innovative, wire-free cameras designed for subtlety and performance.
FeatureWyze Battery Cam ProWyze Battery Cam Pro + Solar PanelWyze Removable Battery PackWyze Battery Charging Dock
TypeCameraCamera BundleAccessoryAccessory
Price$89.98 (1 Pack)$109.98$22.99$17.99
Video Resolution2.5K HDR2.5K HDRN/AN/A
Power SourceRemovable, Rechargeable Battery PacksRemovable Battery + Solar Panel6200mAh Rechargeable BatteryCharges up to 2 batteries simultaneously
Battery CapacityIncluded battery packsIncluded battery packs6200mAh Lithium IonN/A
Battery Charging TimeN/AN/A~9 hours at 25°C~8.5 hours at 25°C
Weatherproof RatingIP65IP65N/AN/A
WiFi Support2.4 & 5 GHz2.4 & 5 GHzN/AN/A
Motion DetectionRadar + PIRRadar + PIRN/AN/A
Integrated Spotlight & SirenYesYesN/AN/A
Local RecordingYes (with microSD card)Yes (with microSD card)N/AN/A
Mounting OptionsFlexible, includes ceiling mount optionFlexible, includes ceiling mount optionN/AN/A
Additional FeaturesWire-free, no hub required, Bluetooth setupSolar panel for continuous powerUSB-C charging portUSB-A to USB-C power cable included
CompatibilityWorks standaloneWyze Battery Cam Pro + Solar PanelCompatible with Wyze Battery Cam Pro & Duo Cam DoorbellCompatible with Wyze Battery Cam Pro batteries
WeightN/AN/A3.9 oz (110g)2.75 oz (78g)
DimensionsN/AN/A2.9 in x 1.6 in x 0.9 inDock: 2.6in x 2in x 1in; Adapter: 42mm x 40mm x 23mm
What makes the Wyze Battery Cam Pro suitable for discreet placement in landscaped gardens?The Wyze Battery Cam Pro features a compact, matte-finished design (2.5 x 1.8 x 3.5 inches) available in black or white, allowing it to blend seamlessly into garden foliage or architectural features. Its subtle appearance ensures effective monitoring without disrupting your garden’s natural beauty.
How does the Wyze Battery Cam Pro perform in different weather conditions?The Wyze Battery Cam Pro is IP65 weatherproof rated and operates reliably in temperatures from -20°C to 50°C (-4°F to 122°F), making it ideal for year-round outdoor use in various climates.
What video quality does the Wyze Battery Cam Pro offer for garden surveillance?The Wyze Battery Cam Pro delivers high-resolution 2.5K HDR video (2560 x 1440) with a wide 134° diagonal field of view, ensuring detailed and comprehensive coverage of your landscaped garden.
Does the Wyze Battery Cam Pro have night vision capabilities?Yes, the Wyze Battery Cam Pro is equipped with 2 IR LEDs and 2 white LEDs, providing enhanced color night vision to monitor your garden clearly even in low-light conditions.
How long does the Wyze Battery Cam Pro battery last, and is it wire-free?The Wyze Battery Cam Pro is completely wire-free and powered by a removable, rechargeable 6200mAh battery pack, offering up to 6 months of battery life on a single charge for flexible placement anywhere in your garden.
What smart security features are included with the Wyze Battery Cam Pro?The camera includes an integrated spotlight, a 100 dB siren for deterrence, radar and PIR motion detection for accurate alerts, and two-way audio with a built-in microphone and speaker. It also supports 2.4 GHz and 5 GHz WiFi and integrates with Alexa, Google Assistant, and IFTTT.
What is the benefit of the Wyze Battery Cam Pro + Solar Panel bundle?The Wyze Battery Cam Pro + Solar Panel bundle provides continuous power through solar charging, reducing the need for manual recharging. This is ideal for remote garden areas where running power cables is impractical, ensuring uninterrupted surveillance.
Are there accessories available to extend the Wyze Battery Cam Pro’s performance?Yes, you can purchase additional 6200mAh removable battery packs for quick swaps and a dual battery charging dock to charge two batteries simultaneously, ensuring your cameras remain operational without interruption.
Is the Wyze Battery Cam Pro easy to install in a garden setting?Absolutely. The camera’s wire-free design and included wall mount make installation simple and flexible, allowing you to position it anywhere in your landscaped garden for optimal coverage.
Can the Wyze Battery Cam Pro integrate with my smart home system?Yes, the Wyze Battery Cam Pro is compatible with Alexa, Google Assistant, and IFTTT, allowing seamless integration with your existing smart home devices for enhanced convenience and control.
What are the key features of the Wyze Battery Cam Pro?How does the night vision feature work on the Wyze Battery Cam Pro?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Battery Cam Pro?
