Refurbished Wyze Hybrid Noise Cancelling Headphones for Music
Refurbished Wyze Headphones: Hybrid Active Noise Cancelling for Music Lovers
Experience music like never before with the Refurbished Wyze Noise-Cancelling Headphones. These headphones combine premium sound quality with advanced hybrid active noise cancellation technology, designed to immerse you fully in your favorite tunes while blocking out distractions. As a refurbished product, you get a like-new Wyze headphone at an unbeatable price, fully tested and guaranteed to perform flawlessly.
"Like a symphony playing just for you."
Premium Hybrid Active Noise Cancellation
The Wyze refurbished headphones feature hybrid active noise cancellation that reduces ambient noise by up to 40 dB. Whether you're commuting, working, or relaxing, these headphones create a private sound bubble so you can focus on your music or calls without interruption.
  • Noise Cancellation Depth: 40 dB
  • Transparency Mode: Allows you to hear your surroundings when needed
  • 6 Microphones: 4 dedicated to noise cancellation, 2 for voice pickup with omnidirectional sensitivity
Comfortable, Durable Design for Long Listening Sessions
Enjoy fatigue-free comfort with memory foam ear cushions covered in protein leather and a multilayer composite headband that blends stainless steel, EVA foam, and plastic for durability and flexibility. Weighing just 9.9 oz, these headphones are perfect for extended wear.
  • Ear Cushion Material: Memory foam with protein leather
  • Headband Material: Stainless steel composite with protein leather cover
  • Weight: 9.9 oz
Wireless Freedom with Long Battery Life
Stay unplugged with up to 20 hours of wireless playback or calls on a single charge. When you need a quick boost, a 10-minute quick charge provides 4 hours of additional use.
  • Battery Life: Up to 20 hours
  • Charging Time: Around 2 hours
  • Quick Charge: 10 minutes for 4 hours playback
  • Charging Method: USB Type-C
High-Fidelity Sound Quality
Equipped with 40 mm dome-type drivers and neodymium magnets, the Wyze headphones deliver rich, clear sound with a wide frequency response range.
  • Frequency Response (Bluetooth): 20 - 20,000 Hz
  • Frequency Response (Line-in): 20 - 38,000 Hz
  • Sensitivity: 113 dB/mW @1 kHz
  • Total Harmonic Distortion: <0.5%
Smart Features and Connectivity
  • Bluetooth 5.0 with 33 ft (10 m) range
  • Supports connection to two devices simultaneously
  • Touch controls for playback, calls, and noise cancellation
  • Compatible with Amazon Alexa and other voice assistants
  • Wear detection automatically pauses music when headphones are removed
Wyze Headphones Lifestyle Enjoy music anywhere with Wyze headphones featuring hybrid active noise cancellation.
Why Choose Refurbished Wyze Noise-Cancelling Headphones?
Opting for the refurbished Wyze headphones means you get all the premium features of the original model at a fraction of the price. Each unit is rigorously tested to ensure it meets Wyze’s high standards, offering you a reliable, high-quality audio experience with the added benefit of sustainability.
  • Price: $34.99 (compared to $89.99 new)
  • Condition: Like new, fully tested
  • Includes: Wyze Headphones, Soft Carrying Pouch, USB Type-C Cable, Audio Cable, Quick Start Guide
Perfect for Music, Calls, and More
Whether you're a music enthusiast, a remote worker, or a frequent traveler, these headphones provide crystal-clear sound and effective noise cancellation to enhance your daily audio experience.
  • Ideal for commuting, working from home, or relaxing
  • Voice-isolating microphones ensure clear calls
  • Touch controls and voice assistant compatibility add convenience
Summary of Key Specs
FeatureSpecification
Noise CancellationHybrid Active Noise Cancellation, 40 dB depth
Battery LifeUp to 20 hours
Quick Charge10 minutes for 4 hours playback
Weight9.9 oz
Bluetooth Version5.0
Frequency Response20 - 20,000 Hz (Bluetooth)
Microphones6 total (4 noise cancelling, 2 voice)
Ear Cushion MaterialMemory foam with protein leather
Headband MaterialStainless steel composite with protein leather
Voice Assistant CompatibilityAmazon Alexa and others
Elevate your music experience with the Refurbished Wyze Noise-Cancelling Headphones — premium sound, comfort, and noise cancellation at an unbeatable price.
Wyze Headphones Commuting Take your music anywhere with Wyze headphones designed for urban lifestyles and commuting.
Additional Wyze Audio Products
While the refurbished Wyze Noise-Cancelling Headphones are the perfect choice for hybrid active noise cancelling and music, Wyze also offers other audio solutions like the Google Nest Audio + Wyze Bundles for home audio environments, but for personal music listening and noise cancellation, the Wyze headphones stand out as the best option.
Product Tags Summary
This page highlights the best refurbished Wyze headphones with hybrid active noise cancelling technology, perfect for music lovers seeking quality sound and comfort at a great price.
Feature(Refurbished) Wyze Noise-Cancelling HeadphonesWyze Noise-Cancelling Headphones
ConditionRefurbished, like new, fully testedNew
Price$34.99 (compare at $89.99)$89.99 - $99.99 depending on variant
VariantsBlack / No Travel Case (sold out)Black, White; No Travel Case or With Travel Case
Return PolicyFinal sale, no returns30-day hassle-free returns
Noise Cancellation40dB Quick On/Off Hybrid Active Noise Cancellation (ANC)40dB Quick On/Off Hybrid Active Noise Cancellation (ANC)
MicrophonesFour noise-cancelling microphonesFour noise-cancelling microphones
Transparency ModeYesYes
Wear DetectionYesYes
Quick ConversationsYesYes
DriversDual TPU Composite Diaphragm Drivers, 40mmDual TPU Composite Diaphragm Drivers, 40mm
Frequency RangeUp to 38kHzUp to 38kHz
Customization via Wyze AppYesYes
ComfortResponsive memory foam, elongated earpadsResponsive memory foam, elongated earpads
ControlsIntuitive touch and tap controlsIntuitive touch and tap controls
Voice Assistant IntegrationAlexa built-in, supports Siri, Google Assistant, BixbyAlexa built-in, supports Siri, Google Assistant, Bixby
Voice Isolation MicrophonesDual voice-isolating microphonesDual voice-isolating microphones
Bluetooth VersionBluetooth 5.0Bluetooth 5.0
Multi-device ConnectionConnects to two devices simultaneouslyConnects to two devices simultaneously
WarrantyNot specifiedNot specified
What are Refurbished Wyze Noise-Cancelling Headphones?Refurbished Wyze Noise-Cancelling Headphones are pre-owned headphones that have been fully tested, restored to like-new condition, and guaranteed to perform flawlessly. They offer premium sound quality and advanced hybrid active noise cancellation at a fraction of the price of new headphones.
How effective is the noise cancellation on Wyze refurbished headphones?The Wyze refurbished headphones feature hybrid active noise cancellation that reduces ambient noise by up to 40 dB, allowing you to enjoy your music or calls without distractions.
What is included with the refurbished Wyze headphones?Each purchase includes the Wyze Headphones, a soft carrying pouch, a USB Type-C charging cable, an audio cable, and a quick start guide.
How long does the battery last on Wyze Noise-Cancelling Headphones?The Wyze Noise-Cancelling Headphones offer up to 20 hours of wireless playback or calls on a single charge. A quick 10-minute charge provides an additional 4 hours of use.
Are the Wyze refurbished headphones comfortable for long listening sessions?Yes, the headphones are designed for comfort with memory foam ear cushions covered in protein leather and a lightweight, durable headband, making them ideal for extended wear.
What smart features do Wyze Noise-Cancelling Headphones offer?Wyze headphones include Bluetooth 5.0 connectivity, support for two devices simultaneously, touch controls for playback and calls, compatibility with Amazon Alexa and other voice assistants, and wear detection that automatically pauses music when the headphones are removed.
What is the sound quality like on Wyze refurbished headphones?The headphones deliver high-fidelity sound with 40 mm dome-type drivers and neodymium magnets, offering a wide frequency response range (20 - 20,000 Hz via Bluetooth and up to 38,000 Hz via line-in) and low total harmonic distortion (<0.5%).
How do I charge the Wyze Noise-Cancelling Headphones?The headphones are charged using a USB Type-C cable. A full charge takes about 2 hours, and a 10-minute quick charge provides up to 4 hours of playback.
Are the Wyze refurbished headphones compatible with voice assistants?Yes, the Wyze Noise-Cancelling Headphones are compatible with Amazon Alexa and other popular voice assistants for hands-free control.
What is the price of refurbished Wyze Noise-Cancelling Headphones?The refurbished Wyze Noise-Cancelling Headphones are available for $34.99, compared to $89.99 for a new pair.
Why should I choose refurbished Wyze headphones over new ones?Choosing refurbished Wyze headphones allows you to enjoy all the premium features of the original model at a lower price. Each unit is rigorously tested for quality and performance, making it a reliable and sustainable choice.
Can I use Wyze Noise-Cancelling Headphones for phone calls?Yes, the headphones feature six microphones—four for noise cancellation and two for voice pickup—ensuring clear, voice-isolated calls.
What devices can I connect to Wyze Noise-Cancelling Headphones?With Bluetooth 5.0, you can connect the Wyze headphones to any compatible smartphone, tablet, or computer. They also support simultaneous connection to two devices.
Are the Wyze refurbished headphones suitable for commuting and travel?Absolutely. The combination of hybrid active noise cancellation, long battery life, and comfortable design makes them perfect for commuting, traveling, or working from home.
What are the key features of the Wyze refurbished headphones?How does the hybrid active noise cancellation work in these headphones?Are there any ongoing sales or discounts for the Wyze headphones?
