Refurbished Wyze Headphones: Quick Conversation & Auto Pause
Refurbished Wyze Headphones with Quick Conversation Mode and Auto Pause Feature
Discover the perfect blend of premium sound quality, smart features, and comfort with the refurbished Wyze Noise-Cancelling Headphones. Designed for those who want to immerse themselves in music or stay connected effortlessly, these headphones come packed with innovative technology like Quick Conversation Mode and Auto Pause, making them a top choice for everyday use.
Wyze Noise-Cancelling Headphones Overview
Experience sound like never before with Wyze’s expertly engineered headphones that deliver crystal-clear audio and smart convenience.
Key Features
  • Quick Conversation Mode: Simply tap the right earcup to pause your music and instantly enable Transparency Mode. This lets you hear and join conversations without removing your headphones.
  • Auto Pause Feature: Thanks to wear detection sensors, your audio automatically pauses when you take off the headphones and resumes when you put them back on, saving battery and keeping your place in the track.
  • Active Noise Cancellation (ANC): Hybrid ANC technology reduces up to 40dB of ambient noise using four noise-cancelling microphones and a fast processor, so you can focus in noisy environments.
  • Transparency Mode: Amplifies outside sounds with a touch, perfect for hearing announcements or your surroundings without interrupting your music.
  • Dual 40mm Drivers: Enjoy deep bass, stable mids, and crisp highs with dual TPU composite diaphragm drivers supporting frequencies up to 38kHz.
  • Customizable Sound: Use the Wyze app to tailor your listening experience with presets for music, movies, gaming, or create your own sound profile.
  • Comfort Fit: Responsive memory foam and elongated earpads provide a fatigue-free, comfortable fit for long listening sessions.
  • Intuitive Touch Controls: Manage calls, volume, playback, and voice assistants with simple taps on the earcups.
  • Voice Assistant Integration: Built-in Amazon Alexa and compatibility with Google Assistant and Siri let you control smart devices, get information, and more using your voice.
  • Bluetooth 5.0: Connect to two devices simultaneously and switch seamlessly between calls and music.
Available Variants and Pricing
  • Black, No Travel Case - $80.99
  • Black, With Travel Case - $99.99
  • White, With Travel Case - $94.98
30-day hassle-free returns available on all refurbished units.
Wyze Headphones Lifestyle Enjoy music anywhere with Wyze Noise-Cancelling Headphones
Why Choose Refurbished Wyze Headphones?
Refurbished Wyze headphones offer the same high-quality audio and smart features as new units but at a more affordable price point. Each refurbished product undergoes rigorous testing to ensure it meets Wyze’s standards for performance and reliability. This makes them an excellent choice for budget-conscious audiophiles who don’t want to compromise on sound or convenience.
Smart Features That Enhance Your Daily Life
"Pause and chat without removing your headphones."
This feature is perfect for busy environments like offices, cafes, or commuting. A gentle tap on the right earcup pauses your music and activates Transparency Mode, allowing you to hear conversations or announcements clearly without missing a beat.
Auto Pause with Wear Detection
Never miss a moment of your favorite song or podcast. When you remove the headphones, the audio automatically pauses, conserving battery and ensuring you pick up right where you left off when you put them back on.
Voice Assistant Control
Hands-free convenience is at your fingertips. Use Alexa, Google Assistant, or Siri to control your smart home devices, check the weather, set reminders, or play music — all without touching your phone.
Superior Comfort and Design
Wyze headphones are designed for all-day wear. The memory foam earpads gently hug your ears, reducing fatigue during long listening sessions. The sleek, modern design is available in classic black or white, with optional travel cases for protection on the go.
Technical Specifications
  • Noise Cancellation: 40dB Quick On/Off Hybrid ANC
  • Drivers: Dual 40mm TPU Composite Diaphragm
  • Frequency Response: Up to 38kHz
  • Connectivity: Bluetooth 5.0, dual device connection
  • Battery Life: Long-lasting with auto pause to extend usage
  • Controls: Touch and tap for calls, volume, playback, and voice assistant
  • Compatibility: Works with Alexa, Google Assistant, Siri
Wyze Headphones Lifestyle Comfort meets technology with Wyze headphones
Conclusion
If you’re searching for refurbished Wyze headphones with Quick Conversation Mode and Auto Pause feature, the Wyze Noise-Cancelling Headphones are your ideal choice. They combine premium sound, smart features, and comfort in a stylish package — all at a great value. Whether you’re working, commuting, or relaxing, these headphones keep you connected and immersed in your audio world.
FeatureWyze Noise-Cancelling Headphones (New)(Refurbished) Wyze Noise-Cancelling Headphones
Price$89.99 - $99.99 (varies by color and travel case option)$34.99
Color OptionsBlack, WhiteBlack
Style OptionsNo Travel Case, With Travel CaseNo Travel Case
Noise Cancellation40dB Quick On/Off Hybrid Active Noise Cancellation (ANC)Hybrid Active Noise Cancellation, 40 dB
Microphones6 total (4 for noise cancellation, 2 for voice pickup)6 total (4 for noise cancellation, 2 for voice pickup)
Battery LifeUp to 20 hoursUp to 20 hours
Charging MethodUSB Type-CUSB Type-C
Charging TimeAround 2 hoursAround 2 hours
Quick ChargeNot specified10 minutes for up to 4 hours playback
Bluetooth VersionBluetooth 5.0Bluetooth 5.0
Bluetooth RangeNot specified33 ft (10 m)
Speaker Driver SizeDual 40mm drivers40 mm dome type driver
Frequency Response (Bluetooth)Up to 38 kHz20 - 20,000 Hz
Frequency Response (Line-in)Up to 38 kHz20 - 38,000 Hz
SensitivityNot specified113 dB/mW @1 kHz
Total Harmonic DistortionNot specified<0.5%
ImpedanceNot specified32 Ω
Ear Cushion MaterialMemory foam covered in protein leatherMemory foam covered in protein leather
Headband MaterialMultilayer composite with protein leather coverMultilayer composite with protein leather cover
WeightNot specified9.9 oz
Special FeaturesTransparency Mode, Wear Detection, Quick Conversations, Voice Assistant Integration, Dual Voice-Isolating Mics, Customizable EQ via Wyze appTransparency Mode, Wear Detection, Quick Conversations, Voice Assistant Integration, Dual Voice-Isolating Mics, Customizable EQ via Wyze app
Included AccessoriesNot specifiedSoft Carrying Pouch, USB Type-C Cable, Audio Cable, Quick Start Guide
Return Policy30-day hassle-free returnsFinal sale, no returns
What are the key features of refurbished Wyze Noise-Cancelling Headphones?Refurbished Wyze Noise-Cancelling Headphones offer premium sound quality, Quick Conversation Mode, Auto Pause with wear detection, active noise cancellation (up to 40dB), Transparency Mode, dual 40mm drivers, customizable sound via the Wyze app, comfort fit with memory foam earpads, intuitive touch controls, voice assistant integration (Alexa, Google Assistant, Siri), and Bluetooth 5.0 with dual device connection.
How does Quick Conversation Mode work on Wyze headphones?Quick Conversation Mode allows you to pause your music and activate Transparency Mode with a simple tap on the right earcup. This feature lets you hear and join conversations or listen to announcements without removing your headphones.
What is the Auto Pause feature on Wyze Noise-Cancelling Headphones?The Auto Pause feature uses wear detection sensors to automatically pause your audio when you take off the headphones and resume playback when you put them back on. This helps conserve battery and ensures you never miss a moment of your music or podcast.
Are refurbished Wyze headphones reliable?Yes, refurbished Wyze headphones undergo rigorous testing to meet Wyze’s standards for performance and reliability. They offer the same high-quality audio and smart features as new units, making them a great value for budget-conscious buyers.
What is the difference between Active Noise Cancellation and Transparency Mode?Active Noise Cancellation (ANC) uses hybrid technology and four microphones to reduce up to 40dB of ambient noise, helping you focus in noisy environments. Transparency Mode, on the other hand, amplifies outside sounds so you can hear your surroundings or conversations without removing your headphones.
Can I customize the sound profile on Wyze headphones?Yes, you can use the Wyze app to customize your listening experience with presets for music, movies, gaming, or create your own sound profile to suit your preferences.
Do Wyze Noise-Cancelling Headphones support voice assistants?Yes, Wyze headphones have built-in Amazon Alexa and are compatible with Google Assistant and Siri, allowing you to control smart devices, get information, and more using your voice.
What are the available colors and variants for refurbished Wyze headphones?Refurbished Wyze headphones are available in Black (with or without a travel case) and White (with travel case). Pricing varies by variant.
Is there a return policy for refurbished Wyze headphones?Yes, all refurbished Wyze headphones come with a 30-day hassle-free return policy.
How comfortable are Wyze Noise-Cancelling Headphones for long-term use?Wyze headphones are designed for all-day comfort with responsive memory foam and elongated earpads that reduce fatigue during extended listening sessions.
Can Wyze headphones connect to multiple devices at once?Yes, with Bluetooth 5.0, Wyze Noise-Cancelling Headphones can connect to two devices simultaneously, allowing you to switch seamlessly between calls and music.
What are the key features of the Wyze Noise-Cancelling Headphones?How does the Quick Conversation Mode work on the Wyze headphones?Are there any ongoing sales or discounts for the Wyze headphones?
