Wireless Active Noise Cancelling Headphones with USB Type-C Charging and Bluetooth Connection
Discover the perfect blend of cutting-edge technology and comfort with the
Wyze Noise-Cancelling Headphones — your ultimate companion for immersive sound, seamless connectivity, and long-lasting battery life. Designed for those who demand premium audio performance with the convenience of modern wireless features, these headphones deliver an exceptional listening experience whether you're commuting, working, or relaxing.
Experience vibrant music enjoyment with Wyze Noise-Cancelling Headphones
Advanced Active Noise Cancellation Technology
Put the outside world on mute with Wyze’s
40dB Quick On/Off Hybrid Active Noise Cancellation (ANC). Equipped with four noise-cancelling microphones and an ultra-fast processor, these headphones reduce ambient noise to a whisper, allowing you to focus on your music, podcasts, or calls without distractions.
- Transparency Mode: Amplify outside sounds with a simple touch to stay aware of your surroundings without removing your headphones.
- Quick Conversations: Pause audio and enable Transparency Mode instantly by gently tapping the right earcup, so you can join conversations effortlessly.
- Wear Detection: Audio automatically pauses when you remove the headphones and resumes when you put them back on, saving battery and your place in the track.
Superior Sound Quality and Customization
Enjoy a rich, balanced soundstage with
dual 40mm TPU composite diaphragm drivers delivering deep bass, stable mids, and crisp highs across a frequency range up to 38kHz. Whether you’re into music, movies, or gaming, the Wyze app lets you customize EQ settings or select from presets tailored to your favorite content.
- World-class engineering combined with proprietary AI and premium hardware.
- Customizable EQ through the Wyze app for a personalized audio experience.
- Dual voice-isolating microphones ensure crystal-clear calls even in noisy environments.
Wireless Freedom and Smart Features
Stay connected and move freely with
Bluetooth 5.0 technology that supports simultaneous connection to two devices. Seamlessly switch between your laptop and phone without reconnecting.
- USB Type-C charging for fast, convenient power-ups.
- Up to 24 hours of playback on a single charge.
- Intuitive touch controls on the earcups for volume, calls, voice assistant activation, and track navigation.
- Built-in voice assistants: Use Amazon Alexa or your device’s native assistant (Siri, Google Assistant, Bixby) hands-free to control music, check weather, set reminders, and more.
Comfort Designed for All-Day Wear
Crafted with
responsive memory foam and elongated earpads, these headphones provide a fatigue-free fit that you’ll forget you’re wearing. The lightweight design and premium materials make them ideal for long listening sessions at home, work, or on the go.
Relax in comfort with memory foam ear cushions
Why Choose Wyze Noise-Cancelling Headphones?
"Few headsets cancel noise better than these Wyze Headphones, which are also one of the most comfortable headsets I’ve worn." – TechHive
- Affordable premium audio with features usually reserved for high-end brands.
- Seamless integration with smart home ecosystems via voice assistants.
- Durable and stylish with color options in black and white, with or without a travel case.
Summary of Key Features
Feature | Description |
Noise Cancellation | 40dB Quick On/Off Hybrid ANC |
Microphones | 4 noise-cancelling + 2 voice-isolating |
Drivers | Dual 40mm TPU composite diaphragm |
Frequency Response | Up to 38kHz |
Connectivity | Bluetooth 5.0, USB Type-C charging |
Battery Life | Up to 24 hours playback |
Controls | Touch controls for calls, volume, voice assistant |
Voice Assistants | Alexa built-in, Siri, Google Assistant, Bixby |
Comfort | Memory foam ear pads, lightweight design |
Color Options | Black, White |
Travel Case | Optional |
Perfect for urban commuting and daily lifestyle
Wyze Noise-Cancelling Headphones are the ideal choice for anyone seeking wireless headphones with active noise cancellation, USB Type-C charging, and Bluetooth connectivity. Elevate your audio experience with Wyze — where innovation meets comfort and style.
What is the noise cancellation capability of Wyze Noise-Cancelling Headphones?
Wyze Noise-Cancelling Headphones feature 40dB Quick On/Off Hybrid Active Noise Cancellation (ANC) with four noise-cancelling microphones and an ultra-fast processor, effectively reducing ambient noise for an immersive listening experience.How do I switch between noise cancellation and hearing my surroundings?
You can activate Transparency Mode with a simple touch, which amplifies outside sounds so you can stay aware of your environment without removing your headphones. Quick Conversations are also possible by gently tapping the right earcup to pause audio and enable Transparency Mode instantly.What is the battery life of Wyze Noise-Cancelling Headphones?
Wyze Noise-Cancelling Headphones offer up to 24 hours of playback on a single charge, ensuring long-lasting performance for all-day use.How do I charge the Wyze Noise-Cancelling Headphones?
These headphones use USB Type-C charging for fast and convenient power-ups.Can I connect Wyze Noise-Cancelling Headphones to multiple devices at once?
Yes, the headphones support Bluetooth 5.0 technology, allowing you to connect to two devices simultaneously and switch between them seamlessly.Are the Wyze Noise-Cancelling Headphones comfortable for long-term wear?
Yes, they are designed with responsive memory foam and elongated earpads for a fatigue-free fit, making them ideal for extended listening sessions.What kind of sound quality can I expect from Wyze Noise-Cancelling Headphones?
The headphones feature dual 40mm TPU composite diaphragm drivers, delivering deep bass, stable mids, and crisp highs across a frequency range up to 38kHz. You can also customize the EQ settings via the Wyze app.Do Wyze Noise-Cancelling Headphones support voice assistants?
Yes, they have built-in support for Amazon Alexa and are compatible with Siri, Google Assistant, and Bixby for hands-free control.What controls are available on the Wyze Noise-Cancelling Headphones?
The headphones feature intuitive touch controls on the earcups for managing volume, calls, voice assistant activation, and track navigation.Are there different color options and accessories available?
Wyze Noise-Cancelling Headphones are available in black and white, with an optional travel case for added convenience.How does the wear detection feature work?
The headphones automatically pause audio when you remove them and resume playback when you put them back on, helping to save battery and keep your place in your track.Are Wyze Noise-Cancelling Headphones suitable for making calls?
Yes, they are equipped with dual voice-isolating microphones that ensure crystal-clear calls even in noisy environments.
