Wired Security Cameras with Integrated Motion Detection and Low Light Enhancement
When it comes to securing your home or business, having a reliable wired security camera with advanced motion detection and superior low light capabilities is essential. Wyze offers a range of wired cameras designed to provide crystal-clear video, smart motion detection, and enhanced night vision to keep your property safe around the clock. Below, we explore the top Wyze wired security cameras that combine these features with smart home compatibility and rugged durability.
Wyze Cam v4: The Ultimate Wired Security Camera
Crystal-Clear 2.5K QHD Resolution & Enhanced Color Night Vision
Wyze Cam v4 delivers unmatched clarity with 2.5K Quad HD resolution, capturing every detail in stunning quality. Its enhanced color night vision uses advanced hardware to pierce through darkness, revealing vibrant colors and details that traditional night vision cameras miss. This makes it perfect for monitoring your property day and night with vivid imagery.
Integrated Motion-Activated Spotlight & Siren
This camera features a motion-activated spotlight that lights up your surroundings instantly when movement is detected, deterring intruders and illuminating your path. Additionally, a powerful 99 dB siren can be activated remotely for added security.
Continuous 24/7 Local Recording & Wi-Fi 6 Support
Wyze Cam v4 supports continuous local recording to a microSD card (up to 256GB), ensuring you never miss a moment without needing a subscription. With Wi-Fi 6 compatibility, it maintains a stronger, more reliable connection even at greater distances.
Smart Home Integration & Easy Setup
Compatible with Alexa, Google Assistant, and IFTTT, Wyze Cam v4 fits seamlessly into your smart home ecosystem. Its screw-free magnetic mount and Bluetooth setup make installation quick and hassle-free.
Weather Resistant for Indoor & Outdoor Use
Rated IP65 for weather resistance, this camera can be installed indoors or outdoors, standing up to rain, snow, and dust.
"The clearest Wyze Cam ever made with superhero vision in low light."
Enhanced two-way audio and night vision for home security
Wyze Cam OG: Reliable Wired Camera with Fast Motion Detection
Wide 120° Field of View & Built-In Spotlight
Wyze Cam OG offers a broad 120-degree field of view to capture more of your surroundings. Its built-in 40-lumen spotlight enhances visibility in low light, providing color night vision to identify people and objects clearly.
3X Faster Motion Notifications & Improved Two-Way Audio
Thanks to an upgraded chipset, this camera sends motion alerts three times faster than previous models, ensuring you’re notified immediately. The enhanced microphone and speaker deliver clearer two-way communication.
IP65 Weatherproof for Indoor and Outdoor Use
Designed to withstand harsh weather conditions, Wyze Cam OG is perfect for both indoor and outdoor security needs.
Easy Customization & Smart Alerts
Customize detection zones to focus on specific areas and receive alerts only when it matters. It also supports smoke and carbon monoxide alarm notifications for added safety.
"Back to basics with a huge leap forward in speed and clarity."
Wyze Cam Pan v3: 360° Coverage with Motion Tracking
360° Pan and 180° Tilt with Smart AI Tracking
Wyze Cam Pan v3 offers full 360-degree horizontal rotation and 180-degree vertical tilt, allowing you to monitor every corner of a room or outdoor area. Its AI-powered auto-zoom and smart tracking follow motion intelligently, focusing on what matters.
IP65 Weather Resistance for Outdoor Use
Built tough for outdoor environments, this camera requires the Wyze Outdoor Power Adapter for safe outdoor installation, making it ideal for porches, backyards, and garages.
Crisp Video Quality & Motion Detection
With 2.5K resolution and integrated motion detection, it captures detailed footage and alerts you instantly when movement is detected.
"Complete coverage with smart focus and weatherproof design."
Weather-resistant Wyze Cam Pan v3 providing 360° security
Wyze Cam OG Telephoto: Zoom In on Security
3X Telephoto Lens for Detailed Zoom
The Wyze Cam OG Telephoto enhances your security with a 3x telephoto lens, narrowing the field of view to 27° for detailed close-ups of distant objects or faces.
Fast Live Streaming & Motion Detection
Enjoy quicker live streaming and 3X faster motion notifications, ensuring you never miss important events.
Two-Way Audio & Weatherproof Design
Communicate clearly with upgraded two-way audio and install confidently outdoors with IP65 weather resistance.
"Zoom in on what matters with telephoto clarity."
Wyze Cam Floodlight v2: Bright Security with Motion Detection
Powerful 2800 Lumens LED Floodlight & 2K Video
Wyze Cam Floodlight v2 combines a bright 2800-lumen LED floodlight with 2K video resolution and color night vision, illuminating large outdoor areas like driveways and backyards.
Wide 160° Field of View & AI-Powered Light Control
Cover a broad area with a 160-degree view and enjoy smart light automation that adjusts based on ambient light and motion detection.
Two-Way Talk & Dusk-to-Dawn Automation
Communicate with visitors or deter intruders using two-way talk. The floodlight automatically turns on at dusk and off at dawn for energy efficiency.
IP65 Weather Resistance & Smart Assistant Compatibility
Built to withstand all weather conditions, it integrates seamlessly with Alexa, Google Assistant, and IFTTT for smart home control.
"Dominate the dark with powerful lighting and sharp video."
Bright floodlight security camera with motion detection
Conclusion
For those seeking wired security cameras with integrated motion detection and advanced low light enhancement, Wyze offers a versatile lineup tailored to various needs:
- Wyze Cam v4 for crystal-clear 2.5K video and enhanced color night vision with spotlight and siren.
- Wyze Cam OG for fast notifications and wide-angle coverage with built-in spotlight.
- Wyze Cam Pan v3 for 360° pan/tilt with smart tracking and weather resistance.
- Wyze Cam OG Telephoto for zoomed-in detail with telephoto lens.
- Wyze Cam Floodlight v2 for powerful illumination combined with 2K video and smart automation.
Each model supports continuous local recording, smart alerts, and works with popular voice assistants, making them ideal choices for comprehensive wired security solutions.
Protect your home day and night with Wyze’s wired cameras that see more, alert faster, and light the way to safety.
What are the key features of Wyze wired security cameras?
Wyze wired security cameras offer advanced motion detection, superior low light enhancement, crystal-clear video quality, smart home integration, weather resistance, and continuous local recording. Models include features like color night vision, motion-activated spotlights, sirens, two-way audio, and compatibility with Alexa, Google Assistant, and IFTTT.Which Wyze wired security camera is best for low light and night vision?
The Wyze Cam v4 is the best option for low light and night vision. It features 2.5K Quad HD resolution and enhanced color night vision, allowing it to capture vibrant colors and details even in complete darkness.Can Wyze wired security cameras be used outdoors?
Yes, most Wyze wired security cameras, including Wyze Cam v4, Wyze Cam OG, Wyze Cam Pan v3, Wyze Cam OG Telephoto, and Wyze Cam Floodlight v2, are rated IP65 for weather resistance, making them suitable for both indoor and outdoor use.Do Wyze wired security cameras support continuous local recording?
Yes, Wyze wired security cameras support continuous 24/7 local recording to a microSD card (up to 256GB), so you can store footage without a subscription.How does motion detection work on Wyze wired cameras?
Wyze wired cameras use advanced motion detection technology to instantly alert you when movement is detected. Some models, like Wyze Cam OG and Wyze Cam OG Telephoto, offer 3X faster motion notifications, while others allow you to customize detection zones for more precise alerts.What is the difference between Wyze Cam v4 and Wyze Cam OG?
Wyze Cam v4 offers 2.5K QHD resolution, enhanced color night vision, a motion-activated spotlight, a 99 dB siren, and Wi-Fi 6 support. Wyze Cam OG features a wide 120° field of view, a built-in 40-lumen spotlight, 3X faster motion notifications, and improved two-way audio.Does Wyze offer a wired security camera with pan and tilt capabilities?
Yes, the Wyze Cam Pan v3 provides 360° horizontal pan and 180° vertical tilt, along with AI-powered motion tracking and 2.5K resolution for comprehensive coverage.Which Wyze camera is best for zooming in on distant objects?
The Wyze Cam OG Telephoto is designed for detailed close-ups with its 3X telephoto lens and a 27° field of view, making it ideal for monitoring distant objects or faces.What are the benefits of the Wyze Cam Floodlight v2?
Wyze Cam Floodlight v2 combines a powerful 2800-lumen LED floodlight with 2K video resolution, color night vision, a wide 160° field of view, AI-powered light control, dusk-to-dawn automation, and two-way talk for enhanced outdoor security.Are Wyze wired security cameras compatible with smart home systems?
Yes, Wyze wired security cameras are compatible with Alexa, Google Assistant, and IFTTT, allowing for seamless integration into your smart home ecosystem.How easy is it to install Wyze wired security cameras?
Wyze wired security cameras are designed for easy installation, featuring screw-free magnetic mounts and Bluetooth setup for quick and hassle-free mounting indoors or outdoors.Do Wyze wired cameras have two-way audio?
Yes, most Wyze wired security cameras, including Wyze Cam v4, Wyze Cam OG, Wyze Cam Pan v3, Wyze Cam OG Telephoto, and Wyze Cam Floodlight v2, offer enhanced two-way audio for clear communication.
