Wired Indoor Security Cameras for 24/7 Continuous Power and Local Recording
When it comes to securing your home or office with reliable, wired indoor security cameras, continuous power and local recording capabilities are essential. Wired cameras ensure uninterrupted monitoring without worrying about battery life, while local recording offers privacy and instant access to your footage without monthly fees. Wyze offers a range of wired indoor security cameras designed to meet these needs with advanced features, crystal-clear video, and smart home compatibility.
Wyze Cam v4: The Ultimate Wired Indoor Security Camera
Experience unmatched security with the
Wyze Cam v4, the clearest Wyze Cam ever made, designed for 24/7 continuous power and local recording.
Key Features:
- 2.5K QHD Resolution: Capture every detail with crystal-clear 2560x1440 video quality.
- Enhanced Color Night Vision: See vibrant colors even in low-light conditions, thanks to advanced hardware and Wide Dynamic Range (WDR).
- Motion-Activated Spotlight & Siren: Deter intruders with a built-in spotlight and a loud 99 dB siren.
- 24/7 Local Recording: Supports continuous recording to microSD cards up to 256GB without any subscription.
- Wi-Fi 6 Support: Enjoy a stronger, more reliable connection for seamless streaming.
- Smart Home Integration: Compatible with Alexa, Google Assistant, and IFTTT for voice control and automation.
- Weather Resistant (IP65): Suitable for indoor and outdoor use with the optional outdoor power adapter.
- Easy Setup & Mounting: Screw-free magnetic mount for quick installation.
Why Choose Wyze Cam v4?
This camera is perfect for those who want continuous power and local storage without sacrificing video quality or smart features. Its enhanced night vision and spotlight make it ideal for monitoring dark rooms or entryways.
Wyze Cam v4 providing continuous indoor security with wired power
Wyze Cam Pan v3: Wired 360° Pan & Tilt Indoor Security
For those who want full-room coverage with wired reliability, the
Wyze Cam Pan v3 offers a dynamic 360° pan and 180° tilt with continuous power and local recording.
Key Features:
- 360° Pan & 180° Tilt: Covers every corner of your room with smooth, quiet motorized movement.
- Automatic Motion Tracking: The camera automatically follows moving objects for detailed monitoring.
- Color Night Vision: Starlight sensor technology delivers vibrant night images.
- IP65 Weather Resistance: Use indoors or outdoors with the Wyze Outdoor Power Adapter.
- Two-Way Audio: Communicate through the camera with clear sound.
- Local Storage Support: Records continuously to microSD cards up to 256GB.
- Privacy Mode: Easily disable the camera view by pointing it downward when privacy is needed.
- Smart Alerts: Motion and sound detection with customizable detection zones.
Ideal Use Cases:
Perfect for monitoring large indoor spaces like living rooms, nurseries, or offices where you want to track movement across the entire area.
Wyze Cam Pan v3 with weather resistance for versatile indoor/outdoor use
Wyze Cam OG: Reliable Wired 1080p Indoor Security Camera
The
Wyze Cam OG is a solid choice for those seeking a wired indoor camera with dependable 1080p video and local recording.
Key Features:
- 1080p Full HD Video: Clear and smooth video streaming and recording.
- 120° Field of View: Wide coverage for most indoor spaces.
- CMOS Starlight Sensor: Enhanced low-light performance with 4 IR LEDs.
- Built-in Spotlight & Siren: 40 lumens spotlight and 90 dB siren for added security.
- Two-Way Audio: Noise and echo cancellation for clear communication.
- Local Storage: Supports up to 256GB microSD cards for continuous recording.
- IP65 Weather Resistance: Suitable for indoor and outdoor use.
- Fast Live Streaming: 50% faster than previous Wyze models.
Why It Stands Out:
Wyze Cam OG balances affordability with essential wired security features, making it a great entry-level wired camera for continuous power and local recording.
Wyze Cam OG Telephoto: Wired Indoor Camera with Zoom
For users needing detailed zoom capabilities, the
Wyze Cam OG Telephoto offers a 3x telephoto lens with wired power and local recording.
Key Features:
- 3x Telephoto Lens: Narrow field of view (27° diagonal) for focused monitoring.
- 1080p Video Resolution: Crisp video quality with 20 FPS daytime and 10 FPS nighttime.
- Local Storage: Supports microSD cards up to 256GB for continuous recording.
- Two-Way Audio: Enhanced microphone and speaker for clear communication.
- IP65 Weather Resistance: Indoor/outdoor use with wired power.
- Compact Design: Easy to mount on walls, ceilings, or stands.
Best For:
Ideal for monitoring specific areas or objects indoors where zoomed-in detail is critical, such as safes, entrances, or valuable items.
Wyze Cam v4 Home Security Bundle: Complete Wired Security Solution
Get the full benefits of the Wyze Cam v4 with the
Home Security Bundle, which includes multiple cameras and a 128GB microSD card for extensive local recording.
Bundle Highlights:
- Multiple Wyze Cam v4 Cameras: Cover several rooms or angles with 2.5K QHD clarity.
- 128GB MicroSD Card Included: Store up to 192 hours of HD video locally.
- All Features of Wyze Cam v4: Enhanced color night vision, spotlight, siren, Wi-Fi 6, and smart assistant compatibility.
- Multiple Mounting Options: Stand, wall, ceiling, or magnetic mounts included.
- Ideal for Whole-Home Coverage: Perfect for users wanting wired continuous power and local recording across multiple indoor locations.
Why Choose Wired Indoor Security Cameras with Local Recording?
Wired indoor security cameras provide uninterrupted power, eliminating the need to recharge or replace batteries. Local recording to microSD cards ensures your footage is stored securely on-site, giving you instant access without monthly fees or cloud dependency. This setup is ideal for privacy-conscious users and those wanting reliable, continuous surveillance.
Wyze’s wired cameras combine these benefits with advanced features like color night vision, motion tracking, two-way audio, and smart home integration, making them top choices for indoor security.
Summary of Wyze Wired Indoor Security Cameras
Model | Resolution | Field of View | Night Vision | Local Storage Support | Special Features | Price Range |
Wyze Cam v4 | 2.5K QHD (2560x1440) | 115.9° D / 98.5° H / 53.1° V | Enhanced Color Night Vision | Up to 256GB microSD | Spotlight, Siren, Wi-Fi 6, Magnetic Mount | From $35.98 |
Wyze Cam Pan v3 | 1080p | 360° Pan / 180° Tilt | Color Night Vision | Up to 256GB microSD | Auto Motion Tracking, Privacy Mode | From $39.98 |
Wyze Cam OG | 1080p | 120° | IR LEDs + Spotlight | Up to 256GB microSD | Built-in Spotlight, Siren, Fast Streaming | From $29.98 |
Wyze Cam OG Telephoto | 1080p | 27° Diagonal (Telephoto) | IR LEDs | Up to 256GB microSD | 3x Telephoto Lens, Compact Design | From $25.98 |
Wyze Cam v4 Home Security Bundle | 2.5K QHD | Same as v4 | Enhanced Color Night Vision | 128GB microSD included | Multiple Cameras, Full Coverage | $169.99 |
Secure your home with Wyze’s wired indoor security cameras that offer continuous power and local recording, ensuring you never miss a moment while keeping your data private and accessible.
What are the benefits of using wired indoor security cameras with local recording?
Wired indoor security cameras provide uninterrupted power, so you never have to worry about recharging or replacing batteries. Local recording to microSD cards ensures your footage is stored securely on-site, giving you instant access without monthly fees or cloud dependency. This setup is ideal for privacy-conscious users and those wanting reliable, continuous surveillance.Which Wyze indoor security cameras support continuous local recording?
All Wyze wired indoor security cameras, including Wyze Cam v4, Wyze Cam Pan v3, Wyze Cam OG, and Wyze Cam OG Telephoto, support continuous local recording to microSD cards up to 256GB. The Wyze Cam v4 Home Security Bundle also includes a 128GB microSD card for extensive local storage.What is the video resolution of Wyze wired indoor security cameras?
Wyze offers a range of resolutions for their wired indoor security cameras: Wyze Cam v4 features 2.5K QHD (2560x1440) resolution, while Wyze Cam Pan v3, Wyze Cam OG, and Wyze Cam OG Telephoto offer 1080p Full HD video.Do Wyze wired indoor security cameras have night vision?
Yes, all Wyze wired indoor security cameras are equipped with night vision. Wyze Cam v4 and Wyze Cam Pan v3 offer enhanced color night vision, while Wyze Cam OG and Wyze Cam OG Telephoto use IR LEDs for clear low-light performance.Can Wyze wired indoor security cameras be used outdoors?
Yes, all featured Wyze wired cameras are IP65 weather resistant and can be used both indoors and outdoors when paired with the appropriate Wyze Outdoor Power Adapter.What smart home integrations are available with Wyze wired indoor cameras?
Wyze Cam v4 supports integration with Alexa, Google Assistant, and IFTTT for voice control and smart home automation. Other Wyze cameras also offer smart alerts and compatibility with popular smart home platforms.What is the difference between Wyze Cam v4 and Wyze Cam Pan v3?
Wyze Cam v4 offers 2.5K QHD resolution, enhanced color night vision, a built-in spotlight and siren, and Wi-Fi 6 support. Wyze Cam Pan v3 features 1080p resolution, 360° pan and 180° tilt for full-room coverage, automatic motion tracking, and privacy mode, making it ideal for monitoring large spaces.How much local video storage do Wyze wired indoor cameras support?
Wyze wired indoor security cameras support microSD cards up to 256GB, allowing for extensive continuous local video recording. The Wyze Cam v4 Home Security Bundle includes a 128GB microSD card, capable of storing up to 192 hours of HD video.What is the Wyze Cam OG Telephoto best used for?
The Wyze Cam OG Telephoto is ideal for monitoring specific areas or objects indoors where detailed, zoomed-in footage is needed, such as safes, entrances, or valuable items. It features a 3x telephoto lens with a narrow 27° field of view for focused monitoring.Is there a bundle option for whole-home wired security coverage?
Yes, the Wyze Cam v4 Home Security Bundle includes multiple Wyze Cam v4 cameras and a 128GB microSD card, providing comprehensive wired security coverage and local recording for multiple rooms or angles in your home.How easy is it to install Wyze wired indoor security cameras?
Wyze wired indoor security cameras are designed for easy setup and mounting. For example, Wyze Cam v4 features a screw-free magnetic mount for quick installation, and all models include multiple mounting options for walls, ceilings, or stands.
