Affordable Advanced Protection Bundle for Indoor and Outdoor Smart Security Cameras
Protect your home inside and out with an affordable, advanced security bundle featuring Wyze’s top-rated smart cameras and security devices. Whether you want crystal-clear video, smart motion tracking, or seamless integration with your smart home, this bundle covers all your security needs without breaking the bank.
Wyze Cam v4: Cutting-Edge Indoor & Outdoor Security
Experience unmatched clarity and smart features with the Wyze Cam v4, designed for both indoor and outdoor use with an IP65 weather-resistant rating.
Key Features:
- 2.5K QHD Resolution: Capture stunningly detailed video with Quad HD clarity, ensuring you never miss a detail.
- Enhanced Color Night Vision: See vibrant colors even in low light, thanks to advanced hardware that outperforms traditional night vision.
- Motion-Activated Spotlight & Siren: Deter intruders with a bright spotlight and a loud 99 dB siren activated by motion detection.
- 24/7 Local Recording: Continuous recording to a microSD card (up to 256GB) without subscription fees.
- Wi-Fi 6 Support: Enjoy a stronger, more reliable connection for seamless streaming and alerts.
- Smart Assistant Compatibility: Works effortlessly with Alexa, Google Assistant, and IFTTT for voice control and automation.
- Easy Installation: Screw-free magnetic mount and Bluetooth setup make installation quick and tool-free.
Why Choose Wyze Cam v4?
This camera is perfect for those who want a versatile, high-performance security camera that works rain or shine, day or night. Its advanced AI features like auto-zoom and smart focus help you track what matters most.
Enjoy clear two-way audio communication with your loved ones or visitors.
Wyze Cam Pan v3: 360° Pan & 180° Tilt for Full Coverage
Cover every angle with the Wyze Cam Pan v3, a weatherproof camera designed for both indoor and outdoor use (with optional outdoor power adapter).
Standout Features:
- 360° Pan & 180° Tilt: Complete room or yard coverage with smooth, quiet motorized movement.
- Automatic Motion Tracking: The camera detects and follows moving objects automatically, ensuring nothing escapes its view.
- Color Night Vision: See full-color video even in the dark with a powerful Starlight sensor.
- Privacy Mode: Instantly disable the camera’s view by pointing it downward for privacy when needed.
- IP65 Weather Resistance: Built to withstand rain, snow, and harsh outdoor conditions.
- Two-Way Audio: Communicate clearly through the camera’s built-in mic and speaker.
- Custom Detection Zones: Focus alerts on specific areas to reduce false alarms.
Ideal Use Cases:
Perfect for monitoring large indoor spaces or outdoor areas like backyards and driveways, the Pan v3 offers dynamic coverage and smart tracking at an affordable price.
Reliable outdoor protection with weather-resistant design.
The Front Porch Security Bundle: Complete Smart Entryway Protection
Secure your front door with this all-in-one bundle that combines video doorbell, smart lock, and chime for ultimate convenience and safety.
Bundle Highlights:
- Wyze Video Doorbell: View your porch in crisp 1080p HD with a wide 120° vertical and 88° horizontal field of view.
- Two-Way Audio: Greet visitors or delivery personnel with clear, noise-cancelled communication.
- Wyze Lock: Lock or unlock your door remotely and monitor lock history via the Wyze app.
- Wyze Chime: Choose from multiple doorbell sounds and intruder alarms to customize your alerts.
- IP65 Weather Resistance: Designed to withstand outdoor elements for reliable year-round use.
- Smart Home Integration: Compatible with Alexa and Google Assistant for voice commands and automation.
Why This Bundle?
This package is perfect for homeowners who want to secure their entryway with smart video and access control, all managed from a single app for ease and peace of mind.
Why Choose This Affordable Advanced Protection Bundle?
"Protect your home with smart, reliable, and budget-friendly security solutions that cover every angle — indoors and outdoors."
- Comprehensive Coverage: From front porch to backyard, monitor every corner with high-resolution cameras and smart tracking.
- Smart Features: Enjoy AI-powered alerts, two-way audio, and seamless smart home integration.
- Weatherproof & Durable: All outdoor cameras are IP65 rated, built to withstand rain, snow, and extreme temperatures.
- Easy Setup & Use: Bluetooth setup, magnetic mounts, and intuitive apps make installation and daily use hassle-free.
- Flexible Storage Options: Local microSD recording with optional cloud plans for extended video storage.
Summary of Products in This Bundle
Product | Price Range | Key Benefits |
Wyze Cam v4 | From $35.98 | 2.5K QHD, color night vision, spotlight, Wi-Fi 6 |
Wyze Cam Pan v3 | From $39.98 | 360° pan, motion tracking, weatherproof |
Front Porch Security Bundle | From $124.96 | Video doorbell, smart lock, chime, 1080p HD |
Secure your home affordably with Wyze’s advanced smart security cameras and devices — the perfect bundle for indoor and outdoor protection.
What is included in the Wyze Affordable Advanced Protection Bundle?
The Wyze Affordable Advanced Protection Bundle includes top-rated smart security devices such as the Wyze Cam v4, Wyze Cam Pan v3, and the Front Porch Security Bundle, which features a video doorbell, smart lock, and chime. This bundle provides comprehensive indoor and outdoor protection for your home.Are Wyze security cameras suitable for both indoor and outdoor use?
Yes, both the Wyze Cam v4 and Wyze Cam Pan v3 are designed for indoor and outdoor use. They feature IP65 weather resistance, making them durable and reliable in rain, snow, and harsh outdoor conditions.What video quality do Wyze security cameras offer?
The Wyze Cam v4 offers 2.5K QHD resolution for stunningly detailed video, while the Wyze Video Doorbell provides crisp 1080p HD video. Both cameras ensure you never miss a detail, day or night.Do Wyze cameras have night vision capabilities?
Yes, Wyze cameras feature advanced color night vision. The Wyze Cam v4 and Wyze Cam Pan v3 use enhanced hardware and Starlight sensors to deliver vibrant, full-color video even in low-light conditions.How do Wyze cameras help deter intruders?
The Wyze Cam v4 is equipped with a motion-activated spotlight and a loud 99 dB siren to deter intruders. Additionally, the Front Porch Security Bundle includes customizable chime sounds and intruder alarms for added security.Can I store video footage locally without a subscription?
Yes, Wyze cameras support 24/7 local recording to a microSD card (up to 256GB), allowing you to store video footage without any subscription fees. Optional cloud storage plans are also available.Are Wyze security devices compatible with smart home systems?
Yes, Wyze security devices work seamlessly with Alexa, Google Assistant, and IFTTT, enabling voice control and smart home automation for added convenience.How easy is it to install Wyze security cameras and devices?
Wyze cameras and devices are designed for easy installation. The Wyze Cam v4 features a screw-free magnetic mount and Bluetooth setup, making installation quick and tool-free. The intuitive Wyze app further simplifies the setup process.What are the key features of the Wyze Cam Pan v3?
The Wyze Cam Pan v3 offers 360° pan and 180° tilt for complete coverage, automatic motion tracking, color night vision, privacy mode, IP65 weather resistance, two-way audio, and custom detection zones for focused alerts.What makes the Front Porch Security Bundle ideal for entryway protection?
The Front Porch Security Bundle combines a Wyze Video Doorbell with HD video, a smart lock for remote access, and a customizable chime. It provides complete entryway protection, allowing you to monitor, communicate, and control access to your home from a single app.How does Wyze ensure reliable performance in extreme weather?
All outdoor Wyze cameras and devices are IP65 rated, ensuring they are weatherproof and can withstand rain, snow, and extreme temperatures for year-round reliable performance.What are the price ranges for the products in the Wyze security bundle?
The Wyze Cam v4 starts from $35.98, the Wyze Cam Pan v3 from $39.98, and the Front Porch Security Bundle from $124.96. These affordable prices make advanced home security accessible to everyone.
