Best Affordable Wired Security Cameras with 120° Field of View
When it comes to securing your home or business, having a reliable wired security camera with a wide field of view is essential. If you're searching for an affordable wired security camera that offers a 120-degree field of view, Wyze has several excellent options that combine advanced features, weather resistance, and smart technology — all without breaking the bank. Below, we highlight the best Wyze wired security cameras that meet your needs, focusing on their specs, usability, and value.
Wyze Cam OG – The Perfect 120° Field of View Wired Camera
Wide 120° Field of View & Crisp 1080p Video Quality
The Wyze Cam OG offers a 120° diagonal field of view, providing broad coverage to monitor large areas effectively. It captures video in full HD 1080p resolution with a CMOS-Starlight Sensor, ensuring clear and detailed footage both day and night.
Weather Resistant for Indoor & Outdoor Use
Rated IP65, this camera is built to withstand rain, snow, and harsh weather conditions, making it ideal for outdoor installation. Its compact size (1.89 in cube) and lightweight design (4.1 oz) allow for flexible mounting options.
Enhanced Night Vision & Built-in Spotlight
Equipped with 4 IR LEDs and a 40-lumen built-in spotlight, the Wyze Cam OG delivers excellent night vision with clear visibility in low-light environments. The spotlight also acts as a deterrent to unwanted visitors.
Two-Way Audio & Siren for Added Security
Communicate directly through the camera with upgraded microphone and speaker featuring noise and echo cancellation. The user-activated 90-decibel siren adds an extra layer of protection by scaring off intruders.
Local Storage & Smart Alerts
Supports up to 256GB microSD cards for continuous local recording without subscription fees. Customize detection zones and receive instant alerts for motion, sound, smoke, and CO alarms.
The Wyze Cam OG is a versatile, affordable wired security camera that balances wide coverage with smart features, perfect for those needing a dependable 120° field of view solution.
Wyze Cam Pan v3 – Panoramic Coverage with Weatherproof Durability
360° Pan and 180° Tilt with IP65 Weather Resistance
While the Wyze Cam Pan v3 offers a full 360° horizontal pan and 180° vertical tilt, it also covers a wide field of view that easily surpasses 120°. This makes it ideal for monitoring entire rooms or outdoor spaces with a single camera. Wyze Cam Pan v3 Outdoor Lifestyle Wyze Cam Pan v3 in snowy outdoor setting, showcasing weather resistance and wide coverage.
Affordable Price with Advanced Features
Starting at just $39.98, the Pan v3 is budget-friendly yet packed with features like automatic motion tracking, color night vision with a Starlight Sensor, and two-way audio. It requires the Wyze Outdoor Power Adapter for safe outdoor use.
Privacy Mode & Custom Patrol Routes
Easily enable Privacy Mode to turn off the camera and point it downward when you want privacy. Set up to 4 custom waypoints for the camera to patrol automatically, ensuring no blind spots.
Smart Notifications & Smoke/CO Alerts
Receive instant alerts for motion, sound, and smoke or carbon monoxide alarms. The upgraded tracking motor is quiet, so it won’t disturb pets or sleeping family members.
Wyze Cam v4 – Enhanced 2.5K QHD Resolution with 115.9° Field of View
Crisp 2.5K QHD Video & Enhanced Color Night Vision
Wyze Cam v4 offers superior image quality with 2.5K Quad HD resolution and enhanced color night vision, providing vibrant and detailed footage even in low light.
Weatherproof & Wired for Continuous Power
With an IP65 rating, the Cam v4 is suitable for both indoor and outdoor use. It supports wired power for uninterrupted monitoring and includes a motion-activated spotlight and 99 dB siren for added security.
Smart Features & Easy Setup
Supports Wi-Fi 6 for a stronger connection, Bluetooth setup for hassle-free installation, and compatibility with Alexa, Google Assistant, and IFTTT. It also offers 24/7 local recording with microSD card support up to 256GB.
Field of View
The Cam v4 has a diagonal field of view of 115.9°, slightly under 120°, but still wide enough to cover most home security needs effectively. Wyze Cam v4 Mounted Outdoor Wyze Cam v4 mounted outdoors, illustrating its sleek design and practical use.
Why Choose a Wired Security Camera with 120° Field of View?
A wired security camera with a wide field of view like 120° ensures you cover more area with fewer cameras, reducing installation complexity and cost. Wired cameras provide continuous power and reliable connectivity, essential for uninterrupted surveillance. Wyze’s wired cameras combine affordability with advanced features such as:
  • Weather resistance for outdoor durability
  • High-definition video quality for clear images
  • Two-way audio for communication
  • Smart alerts and detection zones for focused monitoring
  • Local storage options to avoid monthly fees
Summary of Recommended Affordable Wired Cameras with 120° Field of View
Camera ModelField of ViewResolutionWeather ResistancePrice RangeKey Features
Wyze Cam OG120°1080p HDIP65$29.98+Built-in spotlight, siren, 2-way audio
Wyze Cam Pan v3360° pan/180° tilt1080p HDIP65$39.98+Pan & tilt, motion tracking, privacy mode
Wyze Cam v4115.9°2.5K QHDIP65$35.98+Color night vision, spotlight, Wi-Fi 6
Conclusion
For those seeking an affordable wired security camera with a 120-degree field of view, Wyze offers multiple options tailored to different needs. The Wyze Cam OG is the direct match with a true 120° view and excellent features at a low price. For broader coverage and advanced pan-tilt functionality, the Wyze Cam Pan v3 is a versatile choice. If you want higher resolution and enhanced night vision with smart home integration, the Wyze Cam v4 is an outstanding option. Investing in any of these Wyze wired cameras ensures you get reliable, high-quality security without overspending.
Two-Way Audio Feature Communicate clearly with two-way audio on Wyze cameras.
FeatureWyze Cam OGWyze Cam v4Wyze Cam Pan v3
Resolution1080p (1920 x 1080)2.5K QHD (2560 x 1440)1080p (1920 x 1080)
Field of View (FOV)120°115.9° (D) x 98.5° (H) x 53.1° (V)120°
Night VisionColor Night Vision, Built-in SpotlightEnhanced Color Night Vision, Spotlight4 IR LEDs (850 nm)
AudioImproved 2-way audio, Built-in speaker & micEnhanced Two-Way Talk, AAC, Built-in speaker & micBuilt-in speaker & microphone; 2-way audio; Noise & Echo cancellation
SpotlightBuilt-in 40-lumen spotlightMotion-activated spotlightNo spotlight
Siren90 dB user-activated mini-siren99 dB built-in sirenNo siren
Weather ResistanceIP65 (Indoor/Outdoor)IP65IP65 (Indoor/Outdoor)
Connectivity802.11 b/g/n, 2.4 GHz Wi-FiWi-Fi 6, 2.4 GHz Wi-Fi802.11 b/g/n, 2.4 GHz Wi-Fi
Local Storage SupportmicroSD up to 256GBmicroSD up to 256GB (up to 512GB in some versions)microSD up to 256GB
Video FPSDaytime 20 FPS, Nighttime not specifiedDaytime 20 FPS, Nighttime 15 FPSDaytime 20 FPS, Nighttime 15 FPS
Zoom8x digital zoom8x digital zoom8x digital zoom
DimensionsNot specified2in x 2in x 2 3/8in124mm (H) x 60mm (W) x 63mm (D)
WeightNot specified0.49 lb (222 g)11.29 oz (320 g)
Mounting OptionsStand, Wall, CeilingStand, Wall, Ceiling, Magnetic wall mountScrew 1/4" - 20
Power SourceWiredWiredWired
Operating TemperatureNot specified-4°F to 122°F (-20°C to 50°C)-20°C to 50°C (-4°F to 122°F)
Smart FeaturesCustom Detection Zones, Smoke & CO AlertsMotion & Sound Detection, AI Auto-Zoom, Smoke & CO AlertsPush notifications
IntegrationsAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTT
Price (1 Pack)$29.98$35.98$39.98
What are the best affordable wired security cameras with a 120° field of view?The Wyze Cam OG is the top affordable wired security camera with a true 120° field of view. It offers full HD 1080p video, weather resistance, night vision, two-way audio, a built-in spotlight, and local storage support. Wyze also offers the Cam Pan v3, which provides panoramic coverage, and the Cam v4, which has a 115.9° field of view and 2.5K QHD resolution.
Does the Wyze Cam OG support outdoor installation?Yes, the Wyze Cam OG is rated IP65 for weather resistance, making it suitable for both indoor and outdoor use. It can withstand rain, snow, and harsh weather conditions.
What is the video quality of Wyze wired security cameras?Wyze wired security cameras offer high-definition video quality. The Wyze Cam OG and Cam Pan v3 provide 1080p HD resolution, while the Wyze Cam v4 delivers enhanced 2.5K QHD resolution for even clearer and more detailed footage.
Do Wyze wired security cameras have night vision?Yes, all recommended Wyze wired security cameras feature night vision. The Wyze Cam OG includes 4 IR LEDs and a built-in spotlight for clear night footage, while the Cam v4 offers enhanced color night vision for vibrant images in low-light conditions.
Can I use local storage with Wyze wired security cameras?Yes, Wyze wired security cameras support local storage via microSD cards up to 256GB. This allows for continuous recording without the need for monthly subscription fees.
What smart features do Wyze wired security cameras offer?Wyze wired security cameras offer smart features such as customizable detection zones, instant motion and sound alerts, smoke and CO alarm notifications, two-way audio, and integration with Alexa, Google Assistant, and IFTTT. The Cam Pan v3 also includes automatic motion tracking and privacy mode.
How does the Wyze Cam Pan v3 differ from other Wyze cameras?The Wyze Cam Pan v3 offers 360° horizontal pan and 180° vertical tilt, allowing it to cover entire rooms or outdoor spaces. It features automatic motion tracking, privacy mode, custom patrol routes, and is weather resistant with an IP65 rating.
Is the Wyze Cam v4 suitable for outdoor use?Yes, the Wyze Cam v4 is IP65 weatherproof, making it suitable for both indoor and outdoor installation. It also features a motion-activated spotlight and a 99 dB siren for added security.
Why choose a wired security camera with a 120° field of view?A wired security camera with a 120° field of view covers more area with fewer cameras, reducing installation complexity and cost. Wired cameras also provide continuous power and reliable connectivity for uninterrupted surveillance.
What is the price range for Wyze wired security cameras with a wide field of view?Wyze wired security cameras with a wide field of view are very affordable, with prices starting at $29.98 for the Wyze Cam OG, $35.98 for the Cam v4, and $39.98 for the Cam Pan v3.
What are the key features of the Wyze Cam OG?Can you tell me more about the night vision capabilities of the Wyze Cam v4?Are there any ongoing sales or discounts for Wyze cameras?
