Easy Install Indoor Outdoor Security and Surveillance Camera Bundle
Protect your home or business effortlessly with a versatile security camera bundle designed for both indoor and outdoor use. Whether you want crystal-clear video, smart motion tracking, or weather-resistant durability, these Wyze cameras offer easy installation and advanced features to keep your property safe 24/7.
Wyze Cam v4: The Ultimate Indoor/Outdoor Security Camera
Experience unmatched security with the Wyze Cam v4, the clearest Wyze Cam ever made, perfect for both indoor and outdoor surveillance.
Key Features:
- 2.5K QHD Resolution: Capture stunningly detailed video with Quad HD clarity.
- Enhanced Color Night Vision: See vibrant colors even in low-light conditions, thanks to advanced hardware that outperforms traditional night vision.
- Motion-Activated Spotlight & Siren: Deter intruders with a bright spotlight and a loud 99 dB siren.
- 24/7 Local Recording: Continuous recording to a microSD card (up to 256GB) without subscription fees.
- Wi-Fi 6 Support: Enjoy a stronger, more reliable connection for seamless streaming.
- Smart Assistant Compatibility: Works with Alexa, Google Assistant, and IFTTT for voice control and automation.
- IP65 Weather Resistance: Built to withstand rain, snow, and extreme temperatures, making it ideal for outdoor use.
- Easy Setup: Bluetooth-enabled setup with a screw-free magnetic mount for quick installation.
Why Choose Wyze Cam v4?
This camera combines high-end features like Wide Dynamic Range (WDR) for vibrant colors and smart AI auto-zoom tracking to focus on what matters. It also supports smoke and carbon monoxide alerts, adding an extra layer of safety.
"Wyze Cam v4 is like giving your camera superhero vision with its enhanced color night vision and motion-activated spotlight."
Wyze Cam v4 installed outdoors, blending security with smart home convenience.
Wyze Cam Pan v3: 360° Pan and 180° Tilt for Full Coverage
For those who want to monitor every angle, the Wyze Cam Pan v3 offers dynamic pan and tilt capabilities with weatherproof durability.
Standout Features:
- 360° Horizontal Pan & 180° Vertical Tilt: Covers every corner of your room or yard with smooth, quiet motorized movement.
- Automatic Motion Tracking: The camera detects and follows moving objects automatically, ensuring nothing escapes its view.
- Color Night Vision: See clear, colorful images even at night with the Starlight Sensor.
- IP65 Weather Resistance: Perfect for outdoor use when paired with the Wyze Outdoor Power Adapter.
- Privacy Mode: Easily disable the camera’s view by pointing it downward for personal privacy.
- Two-Way Audio: Communicate through the camera with clear sound, ideal for interacting with family or pets.
- Custom Patrol Routes: Set up to 4 waypoints for the camera to patrol automatically.
Ideal For:
Both indoor and outdoor environments where comprehensive coverage and smart tracking are essential.
"Wyze Cam Pan v3 is your all-seeing eye, quietly patrolling your property rain or shine."
Wyze Cam Pan v3 enduring snowy weather, showcasing its rugged outdoor capability.
Wyze Cam v4 Home Security Bundle: Complete Protection Package
Get the best value and comprehensive coverage with the Wyze Cam v4 Home Security Bundle, which includes multiple cameras and a 128GB microSD card for extended local storage.
Bundle Highlights:
- Multiple Wyze Cam v4 Cameras: Ideal for securing multiple areas inside and outside your home.
- 128GB MicroSD Card Included: Store up to 192 hours of HD video locally without monthly fees.
- All Features of Wyze Cam v4: Including 2.5K QHD video, color night vision, motion-activated spotlight, and smart assistant compatibility.
- Multiple Mounting Options: Stand, wall, ceiling, or magnetic mounts for flexible installation.
- IP65 Weatherproof: Reliable performance in all weather conditions.
Why This Bundle?
Perfect for users who want a ready-to-go, easy-to-install security system with everything needed for indoor and outdoor surveillance.
"The Wyze Cam v4 Home Security Bundle offers peace of mind with extended storage and multiple cameras for full home coverage."
Additional Options for Specialized Needs
Wyze Cam OG: Reliable Indoor/Outdoor Monitoring
- 1080p Full HD Video: Crisp video quality with a 120° field of view.
- Built-in Spotlight & Siren: 40 lumens spotlight and 90 dB siren for added security.
- IP65 Weather Resistance: Suitable for outdoor use.
- Upgraded Two-Way Audio: Clear communication with noise and echo cancellation.
- Fast Live Streaming: 50% faster than previous Wyze models.
Wyze Cam OG Telephoto: Zoom In on Details
- 3x Telephoto Lens: Focus on distant objects with precision.
- 1080p HD Video: Clear images with 8x digital zoom.
- Indoor/Outdoor Use: IP65 weatherproof design.
- Smart Assistant Integration: Alexa, Google Assistant, and IFTTT compatible.
Why Choose Wyze Security Cameras?
Wyze cameras are designed for easy installation, smart home integration, and reliable performance in any environment. Their IP65 weather resistance ensures durability outdoors, while features like enhanced color night vision and motion-activated spotlights provide superior security day and night. With options ranging from fixed cameras to pan-tilt models and telephoto lenses, you can customize your surveillance setup to fit your unique needs.
"Secure your home effortlessly with Wyze’s easy install indoor/outdoor camera bundles that combine advanced technology with user-friendly design."
Summary of Featured Products
Product Name | Resolution | Key Features | Weather Resistance | Price Range |
Wyze Cam v4 | 2.5K QHD | Color Night Vision, Spotlight, Siren | IP65 | $35.98 - $107.94 |
Wyze Cam Pan v3 | 1080p | 360° Pan, Motion Tracking, Privacy | IP65 | $39.98 - $114.94 |
Wyze Cam v4 Home Security Bundle | 2.5K QHD | Multiple Cameras, 128GB Storage | IP65 | $169.99 |
Wyze Cam OG | 1080p | Spotlight, Siren, Fast Streaming | IP65 | $29.98 - $89.94 |
Wyze Cam OG Telephoto | 1080p + 3x Zoom | Telephoto Lens, Two-Way Audio | IP65 | $25.98 - $58.98 |
Secure your home with confidence using Wyze’s easy install indoor and outdoor security camera bundles. Whether you want high-resolution video, smart tracking, or a complete multi-camera system, Wyze has the perfect solution for your surveillance needs.
What makes the Wyze Cam v4 suitable for both indoor and outdoor security?
The Wyze Cam v4 is designed with IP65 weather resistance, making it durable for outdoor use in rain, snow, and extreme temperatures. Its versatile mounting options and advanced features like 2.5K QHD resolution, enhanced color night vision, and motion-activated spotlight also make it ideal for indoor security.How easy is it to install Wyze security cameras?
Wyze security cameras are built for easy installation. The Wyze Cam v4 features Bluetooth-enabled setup and a screw-free magnetic mount, allowing for quick and hassle-free installation on walls, ceilings, or flat surfaces.Do Wyze security cameras require a subscription for 24/7 recording?
No, Wyze cameras like the Wyze Cam v4 support continuous 24/7 local recording to a microSD card (up to 256GB) without any subscription fees, allowing you to store and access your footage locally.What is the video quality of Wyze security cameras?
Wyze security cameras offer high-definition video quality. The Wyze Cam v4 provides 2.5K QHD resolution for crystal-clear footage, while other models like the Wyze Cam Pan v3 and Wyze Cam OG offer 1080p Full HD video.Can Wyze cameras see in the dark?
Yes, Wyze cameras feature enhanced color night vision. The Wyze Cam v4 and Wyze Cam Pan v3 use advanced sensors to deliver vibrant, colorful images even in low-light conditions, outperforming traditional night vision.Are Wyze cameras compatible with smart home assistants?
Yes, Wyze cameras work with Alexa, Google Assistant, and IFTTT, allowing for voice control and smart home automation.What is included in the Wyze Cam v4 Home Security Bundle?
The Wyze Cam v4 Home Security Bundle includes multiple Wyze Cam v4 cameras and a 128GB microSD card for extended local storage. It offers comprehensive coverage for both indoor and outdoor areas and includes all the advanced features of the Wyze Cam v4.What are the benefits of the Wyze Cam Pan v3?
The Wyze Cam Pan v3 offers 360° horizontal pan and 180° vertical tilt for full coverage, automatic motion tracking, color night vision, two-way audio, privacy mode, and IP65 weather resistance when paired with the Wyze Outdoor Power Adapter.Can I use Wyze cameras to monitor specific areas in detail?
Yes, the Wyze Cam OG Telephoto features a 3x telephoto lens and 8x digital zoom, allowing you to focus on distant objects with precision while maintaining clear 1080p HD video quality.Are Wyze cameras weatherproof?
Most Wyze cameras, including the Wyze Cam v4, Wyze Cam Pan v3, Wyze Cam OG, and Wyze Cam OG Telephoto, are rated IP65 weather resistant, making them suitable for outdoor use in various weather conditions.Do Wyze cameras have two-way audio?
Yes, Wyze cameras such as the Wyze Cam Pan v3 and Wyze Cam OG offer two-way audio, allowing you to communicate clearly through the camera, which is ideal for interacting with family, pets, or visitors.What storage options are available for Wyze security cameras?
Wyze cameras support local storage via microSD cards (up to 256GB for Wyze Cam v4), enabling continuous recording without monthly fees. The Wyze Cam v4 Home Security Bundle includes a 128GB microSD card for extended storage.How do Wyze cameras help deter intruders?
Wyze cameras like the Wyze Cam v4 and Wyze Cam OG feature motion-activated spotlights and loud sirens (up to 99 dB), which can help deter intruders and alert you to suspicious activity.Can I set up patrol routes with Wyze cameras?
Yes, the Wyze Cam Pan v3 allows you to set up to 4 custom patrol waypoints, enabling the camera to automatically monitor multiple areas for comprehensive coverage.What makes Wyze security cameras a good value?
Wyze security cameras offer advanced features like high-resolution video, color night vision, smart motion tracking, and weather resistance at affordable prices. Bundles like the Wyze Cam v4 Home Security Bundle provide multiple cameras and storage for complete home protection.
