WiFi Light Switches for Alexa & Google – No Hub Needed
WiFi Light Switches Compatible with Alexa & Google Assistant – No Hub Required
Looking to upgrade your home lighting with a smart WiFi light switch that works seamlessly with Alexa and Google Assistant without the hassle of a hub installation? The Wyze Switch is your perfect solution. Designed for easy installation and smart home integration, it transforms your regular lights into smart lights controllable from anywhere.
Wyze Switch: Smart WiFi Light Switch with Voice Assistant Compatibility
Effortless Smart Control Without a Hub
The Wyze Switch allows you to control your home lighting using just your voice or smartphone app, with no need for a separate hub. It works directly over your WiFi network, making setup straightforward and quick.
  • Works with Alexa and Google Assistant for hands-free voice control.
  • No hub installation required — just connect to your existing WiFi.
  • Compatible with regular bulbs and Wyze bulbs.
  • Supports multi-tap controls to trigger other Wyze devices like Wyze Cams, Wyze Lock, and Wyze Robot Vacuum.
  • Set timers, schedules, and automations for personalized lighting experiences.
  • Vacation mode to simulate occupancy when you’re away.
  • Power loss recovery ensures your settings are retained after outages.
Installation & Compatibility
  • Requires a neutral wire for installation.
  • Installation takes about 20 minutes.
  • Supports single pole switch setups.
  • Available in 1-pack or 3-pack options.
  • Compatible with multi-gang switch boxes (up to 3 gangs with specific load limits).
“Wyze Switch only works if a neutral wire is connected to it. If you do not have a neutral wire, Wyze Switch will not work for you.”
Wyze Switch in Kitchen with Voice Assistants Smart Wyze Switch controlled by Alexa and Google Assistant in a modern kitchen
Enhance Your Smart Home with Wyze Cam v4 – Voice Assistant Compatible Security
While upgrading your lighting, consider complementing your smart home with the Wyze Cam v4 for security that also integrates with Alexa and Google Assistant.
Key Features of Wyze Cam v4
  • 2.5K QHD resolution for crystal-clear video.
  • Enhanced Color Night Vision and motion-activated spotlight for 24/7 security.
  • Supports Wi-Fi 6 for faster, more reliable connections.
  • Compatible with Alexa and Google Assistant for voice commands.
  • Offers 24/7 local recording with microSD card support.
  • Weather-resistant with IP65 rating, suitable for indoor and outdoor use.
  • Advanced features like person detection, motion detection zones, and smoke/CO alerts.
For a complete package, the Wyze Cam v4 Home Security Bundle includes everything you need for indoor and outdoor protection with improved two-way audio and extended storage options. Wyze Cam v4 Outdoor Lifestyle Wyze Cam v4 providing outdoor security with night vision and spotlight
Why Choose Wyze for Your Smart Home?
Wyze products are designed to work together seamlessly, offering a comprehensive smart home experience without complicated setups or expensive hubs. The Wyze Switch and Wyze Cam v4 both support Alexa and Google Assistant, enabling you to control lighting and security with simple voice commands.
  • No hub required: Connect directly to your WiFi.
  • Affordable pricing with high-end features.
  • Easy installation and user-friendly apps.
  • Integration with other Wyze devices for automation and multi-device control.
“Turn normal lights into smart lights and control them from anywhere with Wyze Switch.”
Summary of Products for Hub-Free Smart Home Control
Wyze Switch Turn your existing lights into smart lights with voice control and app management. Requires neutral wire and installs in about 20 minutes. Compatible with Alexa and Google Assistant. Wyze Cam v4 High-resolution smart security camera with color night vision, spotlight, and voice assistant compatibility. Suitable for indoor and outdoor use. Wyze Cam v4 Home Security Bundle Complete security solution with multiple mounting options, enhanced audio, and extended storage.
FeatureWyze SwitchWyze Cam v4Wyze Cam v4 Home Security Bundle
TypeConnected Home SwitchSecurity CameraSecurity Camera Bundle
Price$14.99 (1 Pack), $41.98 (3 Pack)$35.98 (1 Pack)$169.99
DescriptionTurns normal lights into smart lights; multi-tap controls other Wyze devices2.5K QHD resolution, Enhanced Color Night Vision, motion-activated spotlight, 24/7 local recording, Wi-Fi 6 supportIncludes Wyze Cam v4 with 2.5K QHD, Enhanced Color Night Vision, motion-activated spotlight, 24/7 local recording, Wi-Fi 6 support
ControlWyze app; multi-tap for other Wyze devicesWyze app; Alexa, Google Assistant, IFTTTWyze app; Alexa, Google Assistant, IFTTT
Smart FeaturesTimers, schedules, vacation mode, power loss recoveryMotion & sound detection, person detection, smoke & CO alerts, AI auto-zoom, motion detection zonesMotion & sound detection, person detection, smoke & CO alerts, AI auto-zoom, motion detection zones
ConnectivityWi-FiWi-Fi 6, Bluetooth 5.2Wi-Fi 6, Bluetooth 5.2
Video ResolutionN/A2.5K QHD (2560x1440)2.5K QHD (2560x1440)
Night VisionN/AEnhanced Color Night VisionEnhanced Color Night Vision
AudioN/AImproved 2-way audio, built-in sirenImproved 2-way audio, built-in siren
Weather ResistanceN/AIP65IP65
Power SourceWired (light switch)WiredWired
StorageN/AmicroSD card support up to 512GBmicroSD card support up to 128GB
DimensionsStandard switch size2in x 2in x 2 3/8in2in x 2in x 2 3/8in
WeightN/A0.49 lb (222 g)0.49 lb (222 g)
Mounting OptionsWall switchStand, wall, ceiling, magnetic mountStand, wall, ceiling, magnetic mount
Warranty30-day hassle-free returns1 Year1 Year
Additional FeaturesMulti-tap controls Wyze Cams, Locks, Robot Vacuum; Smart Control with Wyze BulbsMotion-activated spotlight, siren, AI auto-zoom, smoke & CO alertsMotion-activated spotlight, siren, AI auto-zoom, smoke & CO alerts
What is the Wyze Switch and how does it work?The Wyze Switch is a smart WiFi light switch that allows you to control your home lighting using your voice or smartphone app. It connects directly to your existing WiFi network and does not require a separate hub. The switch is compatible with Alexa and Google Assistant, enabling hands-free voice control of your lights.
Do I need a hub to use the Wyze Switch?No, the Wyze Switch does not require a hub. It connects directly to your WiFi network, making installation and setup simple and hassle-free.
Is the Wyze Switch compatible with Alexa and Google Assistant?Yes, the Wyze Switch works seamlessly with both Alexa and Google Assistant, allowing you to control your lights with voice commands.
What type of bulbs can I use with the Wyze Switch?The Wyze Switch is compatible with regular bulbs as well as Wyze bulbs, giving you flexibility in your lighting choices.
Does the Wyze Switch require a neutral wire for installation?Yes, the Wyze Switch requires a neutral wire for installation. If your switch box does not have a neutral wire, the Wyze Switch will not work.
How long does it take to install the Wyze Switch?Installation of the Wyze Switch typically takes about 20 minutes. It is designed for easy setup in single pole switch configurations.
Can I use the Wyze Switch in a multi-gang switch box?Yes, the Wyze Switch is compatible with multi-gang switch boxes, supporting up to 3 gangs with specific load limits.
What smart features does the Wyze Switch offer?The Wyze Switch offers features such as multi-tap controls to trigger other Wyze devices, timers, schedules, automations, vacation mode to simulate occupancy, and power loss recovery to retain your settings after outages.
What is the Wyze Cam v4 and what are its main features?The Wyze Cam v4 is a high-resolution smart security camera with 2.5K QHD video, enhanced color night vision, a motion-activated spotlight, and Wi-Fi 6 support. It is compatible with Alexa and Google Assistant, offers 24/7 local recording with microSD card support, and is weather-resistant with an IP65 rating for indoor and outdoor use.
Does the Wyze Cam v4 work with voice assistants?Yes, the Wyze Cam v4 is compatible with both Alexa and Google Assistant, allowing you to control and monitor your security camera using voice commands.
What is included in the Wyze Cam v4 Home Security Bundle?The Wyze Cam v4 Home Security Bundle includes everything you need for comprehensive indoor and outdoor protection, such as multiple mounting options, improved two-way audio, and extended storage capabilities.
Why should I choose Wyze products for my smart home?Wyze products are designed for easy installation, affordable pricing, and seamless integration with Alexa and Google Assistant. They do not require a hub, connect directly to WiFi, and work together for a comprehensive smart home experience with automation and multi-device control.
What are the installation requirements for the Wyze Switch?Can the Wyze Switch be used with multi-gang switch boxes?Do you have any ongoing sales or discounts for the Wyze Switch?
