Smart Plugs for Alexa & Google Assistant Home Automation
Smart Plugs Compatible with Alexa & Google Assistant for Home Automation
Looking to upgrade your home with smart plugs that seamlessly integrate with Alexa and Google Assistant? Whether you want to control indoor appliances or manage outdoor lighting, Wyze offers smart plugs designed to fit every need. These smart plugs empower you to automate your home, save energy, and enjoy hands-free voice control.
Wyze Plug: The Ultimate Indoor Smart Plug
Control your home devices effortlessly with Wyze Plug
Key Features:
- Voice Assistant Compatibility: Works flawlessly with Alexa, Google Assistant, and IFTTT for versatile voice commands.
- Easy App Control: Schedule devices, monitor energy usage, and turn appliances on/off remotely via the Wyze app.
- Compact Design: Small footprint (2.7" x 2.0" x 1.5") fits easily into any outlet without blocking adjacent sockets.
- Reliable Connectivity: Connects over 2.4GHz WiFi for stable and responsive control.
- Safe & Certified: ETL certified with a 15A max output, ensuring safe operation for most household devices.
- Warranty: Comes with a 1-year warranty for peace of mind.
Ideal For:
- Automating lamps, fans, coffee makers, and other indoor electronics.
- Setting schedules to save energy and enhance convenience.
- Voice controlling your home without lifting a finger.
Wyze Plug Outdoor: Smart Control for Your Outdoor Spaces
Power your outdoor lights and devices rain or shine
Why Choose Wyze Plug Outdoor?
- Weather-Resistant: Rated IP64, built to withstand rain, dust, and outdoor elements.
- Dual Outlets: Two independent outlets let you control multiple devices from one plug.
- Voice Control: Compatible with Alexa for hands-free outdoor automation.
- Energy Monitoring: Track power usage to optimize your outdoor energy consumption.
- Wide Operating Range: Works in temperatures from -4°F to 120°F, perfect for year-round use.
- Extended WiFi Range: Up to 300 feet connectivity ensures reliable control even in large yards.
Perfect For:
- Garden lights, holiday decorations, backyard speakers, and outdoor appliances.
- Remote scheduling and monitoring to enhance your outdoor living experience.
Enhance Your Smart Home with Wyze Cam Floodlight Pro + Plug-In Mount
Brighten and secure your home with smart floodlight and voice control
Features:
- 2.5K QHD Resolution: Crystal-clear video with color night vision for enhanced security.
- Alexa & Google Assistant Integration: Control lighting and camera functions with voice commands.
- Ultra-Wide 180° Field of View: Covers large outdoor areas for comprehensive monitoring.
- Powerful 3000 Lumens LED: Bright illumination for safety and visibility.
- Plug-In Mount: Easy installation without the need for complex wiring or junction boxes.
- Durable & Weatherproof: IP65 rating ensures reliable performance in harsh weather.
- Smart Alerts & Storage: Supports microSD cards up to 256GB for local recording.
Why It’s Great:
- Combines smart lighting and security camera in one device.
- Perfect for front porches, backyards, and driveways.
- Voice control lets you turn lights on/off or check camera status effortlessly.
Why Choose Wyze Smart Plugs for Your Home Automation?
"Wyze smart plugs bring convenience, energy savings, and voice control to your fingertips, whether indoors or outdoors."
- Seamless Integration: All Wyze smart plugs work with Alexa and Google Assistant, making them perfect for any smart home ecosystem.
- User-Friendly App: The Wyze app offers intuitive control, scheduling, and energy monitoring.
- Affordable & Reliable: High-quality smart plugs at competitive prices with trusted certifications.
- Versatile Options: From indoor compact plugs to rugged outdoor models, Wyze covers all your smart plug needs.
Upgrade your home automation today with Wyze smart plugs and enjoy the convenience of voice control and smart scheduling for a truly connected home.
Product Summary
Product Name | Key Features | Use Case |
Wyze Plug | Alexa & Google Assistant, Energy Monitor | Indoor smart plug |
Wyze Plug Outdoor | Weatherproof, Dual Outlets, Alexa | Outdoor smart plug |
Wyze Cam Floodlight Pro + Plug-In Mount | 2.5K QHD, 3000 lumens, Voice Control | Outdoor lighting & security |
Feature | Wyze Plug Outdoor | Wyze Plug | Wyze Cam Floodlight Pro + Plug-In Mount |
Type | Connected Home | Connected Home | Cameras |
Price | $15.99 (1 Pack), $34.98 (2 Pack) | $12.98 (1 Pack), $24.98 (2 Pack), $39.98 (4 Pack) | $169.96 |
Weather Resistance | IP64 (Outdoor rated) | Not specified (Indoor use) | IP65 |
Control | App control, Voice commands (Alexa, Google) | App control, Voice commands (Alexa, Google) | App control, Voice commands (Alexa, Google, IFTTT) |
Power Output | 15 AMP with Overload Protection | Not specified | Hardwired 110-120V AC |
Number of Outlets | 2 outlets with independent control | 1 outlet per plug | N/A (Camera with floodlight) |
WiFi Range | Up to 300 ft (open space) | Not specified | 2.4 GHz & 5 GHz dual-band WiFi |
Scheduling & Automation | Yes | Yes | Yes (AI-powered motion detection, light control) |
Energy Monitoring | Yes | No | No |
Lighting | N/A | N/A | 3 dimmable light panels, 3000 lumens, 5000K |
Video Quality | N/A | N/A | 2.5K QHD (2560x1440) with color night vision |
Field of View | N/A | N/A | 180° diagonal |
Mounting | N/A | N/A | Plug-in mount included |
Voice Assistant Integration | Alexa, Google | Alexa, Google | Alexa, Google, IFTTT |
Weatherproof Use | Yes | No | Yes |
Return Policy | 30-day hassle-free returns | 30-day hassle-free returns | Not specified |
Are Wyze smart plugs compatible with Alexa and Google Assistant?
Yes, all Wyze smart plugs are compatible with both Alexa and Google Assistant, allowing you to control your devices using simple voice commands for seamless home automation.What devices can I control with the Wyze Plug indoor smart plug?
The Wyze Plug indoor smart plug is ideal for automating lamps, fans, coffee makers, and other indoor electronics. You can schedule, monitor, and control these devices remotely using the Wyze app or voice assistants.Does the Wyze Plug support energy monitoring?
Yes, the Wyze Plug allows you to monitor energy usage through the Wyze app, helping you track and manage your household energy consumption efficiently.Is the Wyze Plug Outdoor weatherproof?
Yes, the Wyze Plug Outdoor is rated IP64, making it weather-resistant and suitable for use in rain, dust, and various outdoor conditions.How many devices can I control with the Wyze Plug Outdoor?
The Wyze Plug Outdoor features two independent outlets, allowing you to control multiple outdoor devices such as garden lights, holiday decorations, and backyard speakers from a single plug.What is the WiFi range for Wyze smart plugs?
Wyze smart plugs connect over 2.4GHz WiFi. The Wyze Plug Outdoor offers an extended WiFi range of up to 300 feet, ensuring reliable connectivity even in large outdoor spaces.Are Wyze smart plugs safe to use?
Yes, Wyze smart plugs are ETL certified and designed for safe operation. The indoor Wyze Plug supports a maximum output of 15A, suitable for most household devices.What warranty is provided with Wyze smart plugs?
Wyze smart plugs come with a 1-year warranty, giving you peace of mind with your purchase.Can I schedule devices with Wyze smart plugs?
Yes, you can easily set schedules for your devices using the Wyze app, allowing you to automate when your appliances turn on or off to save energy and enhance convenience.What are the benefits of the Wyze Cam Floodlight Pro + Plug-In Mount?
The Wyze Cam Floodlight Pro + Plug-In Mount combines a powerful 2.5K QHD security camera with a 3000 lumens LED floodlight. It offers voice control via Alexa and Google Assistant, color night vision, a wide 180° field of view, and easy plug-in installation for enhanced outdoor security and lighting.Do Wyze smart plugs require a hub for operation?
No, Wyze smart plugs connect directly to your 2.4GHz WiFi network and do not require a separate hub for operation.How do I control Wyze smart plugs remotely?
You can control Wyze smart plugs remotely using the Wyze app, which allows you to turn devices on or off, set schedules, and monitor energy usage from anywhere.What makes Wyze smart plugs a good choice for home automation?
Wyze smart plugs offer seamless integration with Alexa and Google Assistant, user-friendly app control, energy monitoring, affordable pricing, and reliable performance for both indoor and outdoor use, making them an excellent choice for home automation.
What are the key features of the Wyze Plug Outdoor?Can the Wyze Plug Outdoor be used for holiday decorations?What is the warranty policy for Wyze smart plugs?
