Best Indoor Smart Plugs Compatible with Alexa and Google Assistant
Looking to make your home smarter and more convenient? Indoor smart plugs that work seamlessly with Alexa and Google Assistant are the perfect solution to automate your everyday devices. Control your lamps, fans, coffee makers, and more with simple voice commands or through an intuitive app. Below, we highlight the top Wyze smart plugs designed for indoor use, offering reliable connectivity, easy setup, and smart home integration.
Control your home appliances effortlessly with Wyze Plug
Wyze Plug: Your Ultimate Indoor Smart Plug
Seamless Voice Control and App Integration
Wyze Plug is designed to bring your regular devices into the smart home era. Compatible with Alexa, Google Assistant, and IFTTT, it allows you to control your appliances hands-free or remotely via the Wyze app. Whether you want to turn off your living room lamp or schedule your coffee maker to start brewing before you wake up, Wyze Plug makes it simple.
Compact and Efficient Design
- Dimensions: 2.7" x 2.0" x 1.5"
- Weight: 5.3 oz
- Color: White
Indoor Use Only
- Operating Temperature: -4°F to 104°F (-20°C to 40°C)
Powerful Specs for Everyday Use
- Input: 100-120 VAC, 60Hz
- Output: 15A Max
- Connectivity: 2.4GHz WiFi
- Certifications: ETL certified for safety
- Warranty: 1 Year
Convenient Packaging Options
Available in 2-pack and 4-pack bundles, Wyze Plug offers flexibility for outfitting multiple rooms or devices.
Why Choose Wyze Plug?
"Start living in the future. Make your normal ol' devices smart!"
With Wyze Plug, you get reliable indoor smart control with energy-efficient performance and easy scheduling features.
Wyze Plug Outdoor: Smart Plug for Outdoor Use (Bonus)
While your query focuses on indoor smart plugs, it's worth mentioning the
Wyze Plug Outdoor for those who want smart control beyond the walls of their home. This plug is weather-resistant (IP64), supports two independent outlets, and offers a long WiFi range of up to 300 feet in open space. It also integrates with Alexa and Google Assistant for voice control.
- Perfect for: Garden lights, holiday inflatables, pond pumps, and outdoor heaters
- Features: Energy monitoring, overload protection, app & voice control
- Output: 15 AMP with overload protection
Power your outdoor devices smartly, rain or shine.
Enhance Your Smart Home Experience
Pair your indoor smart plugs with other Wyze smart home devices for a fully integrated system. From smart cameras to lighting solutions, Wyze offers a comprehensive ecosystem that works together effortlessly.
Summary
Product Name | Indoor/Outdoor | Alexa & Google Assistant | Key Features | Price Range |
Wyze Plug | Indoor | Yes | Compact, ETL certified, 15A output | $24.98 (2-pack) |
Wyze Plug Outdoor | Outdoor | Yes | Weather-resistant, 2 outlets, 15A | $15.99 (1-pack) |
Why Choose Wyze Indoor Smart Plugs?
- Easy voice control with Alexa and Google Assistant
- Simple app scheduling and remote control
- Compact design fits any outlet without blocking neighbors
- Reliable 2.4GHz WiFi connectivity
- Energy-efficient and ETL certified for safety
Use voice commands to control your air purifier or other devices with Wyze Plug
Make your home smarter today with Wyze Plug — the perfect indoor smart plug that works flawlessly with Alexa and Google Assistant.
### Product Tags and Highlights
What devices are Wyze indoor smart plugs compatible with?
Wyze indoor smart plugs are compatible with Alexa, Google Assistant, and IFTTT, allowing you to control a wide range of home appliances such as lamps, fans, coffee makers, and more using voice commands or the Wyze app.How do I control Wyze Plug smart plugs?
You can control Wyze Plug smart plugs using simple voice commands through Alexa or Google Assistant, or remotely via the Wyze app on your smartphone. The app also allows you to schedule devices and monitor their status.Are Wyze smart plugs easy to set up?
Yes, Wyze smart plugs are designed for easy setup. Simply plug them into a standard indoor outlet, connect to your 2.4GHz WiFi network, and follow the instructions in the Wyze app to get started.Can Wyze Plug be used outdoors?
Wyze Plug is designed for indoor use only. For outdoor applications, Wyze offers the Wyze Plug Outdoor, which is weather-resistant and features two independent outlets.What are the key features of Wyze Plug indoor smart plugs?
Wyze Plug indoor smart plugs offer compact design, ETL certification for safety, 15A maximum output, 2.4GHz WiFi connectivity, easy scheduling, and compatibility with Alexa and Google Assistant.What is the maximum output supported by Wyze Plug?
Wyze Plug supports a maximum output of 15A, making it suitable for most household appliances.What are the available packaging options for Wyze Plug?
Wyze Plug is available in convenient 2-pack and 4-pack bundles, allowing you to outfit multiple rooms or devices in your home.Is Wyze Plug energy efficient and safe?
Yes, Wyze Plug is ETL certified for safety and designed to be energy efficient, providing reliable smart control for your indoor devices.What is the warranty period for Wyze Plug?
Wyze Plug comes with a 1-year warranty, ensuring peace of mind with your purchase.What are the dimensions and color of Wyze Plug?
Wyze Plug measures 2.7" x 2.0" x 1.5", weighs 5.3 oz, and comes in a white color, making it compact and suitable for any indoor outlet.What is the operating temperature range for Wyze Plug?
Wyze Plug operates in temperatures ranging from -4°F to 104°F (-20°C to 40°C), making it suitable for most indoor environments.What makes Wyze Plug Outdoor different from the indoor version?
Wyze Plug Outdoor is weather-resistant (IP64 rated), supports two independent outlets, offers a long WiFi range up to 300 feet in open space, and includes features like energy monitoring and overload protection, making it ideal for outdoor devices.Can I integrate Wyze Plug with other Wyze smart home devices?
Yes, Wyze Plug can be paired with other Wyze smart home devices, such as cameras and lighting solutions, for a fully integrated and automated smart home experience.
