Smart Locks & Switches for Alexa, Google Assistant & Smart Switch
Smart Locks and Switches Compatible with Alexa, Google Assistant, and Smart Switches
Looking for a smart lock that seamlessly integrates with Alexa, Google Assistant, and smart switches? Discover the perfect combination of security, convenience, and smart home compatibility with Wyze’s innovative smart lock and smart switch solutions. These devices not only enhance your home security but also bring effortless voice control and automation to your fingertips.
Wyze Lock Bolt: Advanced Smart Lock with Fingerprint Access
Experience keyless entry like never before with the Wyze Lock Bolt, a Bluetooth smart lock designed to replace your existing deadbolt. This lock offers ultra-fast fingerprint recognition and a luxurious backlit keypad, making home access both secure and convenient.
Key Features of Wyze Lock Bolt
Fingerprint Unlock & Keypad Access Unlock your door in less than a second with a simple fingerprint tap or by entering your code on the backlit keypad. The ultra-fast fingerprint reader ensures quick and secure access without fumbling for keys. Auto-Lock for Peace of Mind Never worry about leaving your door unlocked. The Wyze Lock Bolt auto-locks after a set delay, configurable via the Wyze app, ensuring your home stays secure even if you forget to lock up. Anti-Peep Technology Protect your passcode from prying eyes by entering extra digits before or after your code. The lock will still recognize the correct code and unlock, enhancing your security. Durable and Weatherproof Design Crafted from solid metal with an IPX5 weatherproof rating, the Wyze Lock Bolt withstands the elements and is fully pick-proof by eliminating the need for physical keys. Long Battery Life with Backup Charging Powered by 4 AA batteries lasting up to 12 months, the lock alerts you when battery life is low. In emergencies, a USB-C port allows a quick charge to regain access. Local Bluetooth Control & Security The lock operates primarily via local Bluetooth connection, ensuring your data stays private with hardware encryption and two-factor authentication through the Wyze app.
Smart Home Compatibility
While the Wyze Lock Bolt focuses on local Bluetooth access and fingerprint convenience, it pairs perfectly with other Wyze smart devices for a connected home experience. For full Alexa and Google Assistant voice control, consider pairing it with the Wyze Lock (not covered here) or integrating it with Wyze Switch for smart automation.
Installation and Design
  • Easy Installation: Replaces your existing deadbolt in about 20 minutes without professional help.
  • Stylish Finish: Available in Matte Black and Satin Nickel to complement your door’s exterior.
  • Interior Convenience: One-touch lock button on the inside for quick securing.
"Wyze Lock Bolt is a solid, no frills smart lock with perfect fingerprint scans."
Wyze Lock Bolt Lifestyle Secure your home effortlessly with Wyze Lock Bolt’s fingerprint access and sleek design.
Wyze Switch: Smart Light Switch for Voice and App Control
Complement your smart lock with the Wyze Switch, a WiFi-enabled smart light switch that transforms your regular lights into smart lights controllable from anywhere. It integrates smoothly with Alexa, Google Assistant, and other Wyze devices, including the Wyze Lock Bolt.
Why Choose Wyze Switch?
Voice Assistant Compatibility Control your lights hands-free using Alexa or Google Assistant. Turn lights on/off, dim, or create scenes with simple voice commands. Multi-Tap Custom Actions Program up to four custom actions on the switch: single-press to toggle lights, double-press to lock doors, triple-press to start your robot vacuum, and press-and-hold to activate the sprinkler controller. Smart Control with Wyze Bulbs Designed to work flawlessly with Wyze Bulbs, the switch maintains power to bulbs to preserve automations and smart features. Automations and Scheduling Set timers, schedules, and vacation modes to simulate occupancy or save energy. The switch automatically reconnects after power outages, restoring your settings. Easy Installation Fits standard wall boxes and replaces your existing switch with minimal effort. Wyze Switch Lifestyle Control your home lighting and smart devices effortlessly with Wyze Switch and voice assistants.
Enhance Your Smart Home with Wyze Accessories
To keep your Wyze Lock Bolt functioning smoothly, consider these replacement parts and accessories: Wyze Lock Bolt Screws Replacement screws compatible with Wyze Lock Bolt for secure installation. Wyze Lock Bolt Interior Assembly Battery Cover Replacement battery cover to protect the interior assembly. Wyze Lock Bolt Interior Assembly Metal Plate Metal plate to anchor the interior assembly firmly to your door. Wyze Lock Replacement Part Kit Comprehensive kit for repairs and maintenance of your Wyze Lock. These parts ensure your smart lock remains reliable and secure over time.
Why Choose Wyze for Your Smart Home?
Wyze products are designed with user convenience, security, and affordability in mind. The Wyze Lock Bolt and Wyze Switch offer seamless integration with popular voice assistants like Alexa and Google Assistant, enabling you to control your home effortlessly. Whether you want to unlock your door with a fingerprint or control your lights with a voice command, Wyze smart devices bring modern technology to your doorstep.
"Upgrade your home security and automation with Wyze’s smart lock and switch solutions."
Summary of Products
Product NameKey FeaturesPrice
Wyze Lock BoltFingerprint unlock, backlit keypad, auto-lock, weatherproof$79.98
Wyze SwitchWiFi smart switch, voice control, multi-tap actions$14.99 (1 pack)
Wyze Lock Bolt Replacement PartsScrews, battery cover, metal plate, repair kits$2.99 - $19.99
Secure your home and simplify your life with Wyze smart locks and switches that work perfectly with Alexa, Google Assistant, and your smart home ecosystem.
Feature / ProductWyze Lock BoltWyze SwitchWyze Lock Bolt ScrewsWyze Lock Bolt Interior Assembly Battery CoverWyze Lock Bolt Interior Assembly Metal PlateWyze Lock Replacement Part Kit
TypeConnected Home Smart LockConnected Home Smart Light SwitchReplacement PartsReplacement PartsReplacement PartsReplacement Parts
DescriptionBluetooth smart lock replacing deadbolt with fingerprint reader and backlit keypadSmart WiFi light switch to control lights and Wyze devicesSet of screws compatible with Wyze Lock BoltInterior battery cover for Wyze Lock BoltMetal plate to anchor interior assembly to doorReplacement part kit for Wyze Lock
Key FeaturesFingerprint unlock, backlit keypad, auto-lock, anti-peep tech, pick-proof, weatherproof (IPX5), 12-month battery lifeControl lights remotely, multi-tap for Wyze devices, timers, schedules, vacation modeScrews for Wyze Lock Bolt installationBattery cover replacement for interior assemblyMetal plate replacement for interior assemblyReplacement parts for Wyze Lock
CompatibilityReplaces existing deadboltWorks with Wyze ecosystemCompatible with Wyze Lock BoltCompatible with Wyze Lock BoltCompatible with Wyze Lock BoltCompatible with Wyze Lock
Installation Time~20 minutesEasy installationN/AN/AN/AN/A
ConnectivityBluetoothWiFiN/AN/AN/AN/A
Battery LifeUp to 12 months (4 AA batteries)N/AN/AN/AN/AN/A
Price$79.98$14.99 (1 Pack), $41.98 (3 Pack)$2.99$9.99$4.99$4.99 (Replacement Part Kit), $19.99 (Adapter Kit)
Return Policy30-day hassle-free returns30-day hassle-free returns30-day hassle-free returns30-day hassle-free returns30-day hassle-free returns30-day hassle-free returns
Weather ResistanceIPX5N/AN/AN/AN/AN/A
Additional FeaturesEmergency one-time codes, local Bluetooth, hardware encryption, two-factor authenticationSmart control actions, power loss recovery, vacation modeN/AN/AN/AN/A
What smart locks and switches are compatible with Alexa and Google Assistant?Wyze offers smart home devices such as the Wyze Lock Bolt and Wyze Switch that are compatible with Alexa and Google Assistant. The Wyze Switch provides direct voice control, while the Wyze Lock Bolt can be integrated into your smart home ecosystem for enhanced automation.
What are the key features of the Wyze Lock Bolt smart lock?The Wyze Lock Bolt features ultra-fast fingerprint recognition, a backlit keypad, auto-lock functionality, anti-peep technology, a durable weatherproof design, long battery life with backup charging, and secure local Bluetooth control.
How does the Wyze Lock Bolt enhance home security?The Wyze Lock Bolt enhances home security with keyless fingerprint access, a secure backlit keypad, auto-locking, anti-peep technology to protect your passcode, and a pick-proof design that eliminates the need for physical keys.
Can I control the Wyze Lock Bolt with Alexa or Google Assistant?The Wyze Lock Bolt primarily uses local Bluetooth for control and does not offer direct voice assistant integration. However, it can be paired with other Wyze smart devices, such as the Wyze Switch, for smart home automation and indirect voice control.
What is the installation process for the Wyze Lock Bolt?The Wyze Lock Bolt is designed for easy installation, replacing your existing deadbolt in about 20 minutes without the need for professional help. It comes in Matte Black and Satin Nickel finishes to match your door.
What are the main features of the Wyze Switch smart light switch?The Wyze Switch is a WiFi-enabled smart light switch that offers voice control with Alexa and Google Assistant, multi-tap custom actions, compatibility with Wyze Bulbs, automations and scheduling, and easy installation in standard wall boxes.
How does the Wyze Switch work with voice assistants?The Wyze Switch integrates seamlessly with Alexa and Google Assistant, allowing you to control your lights and other smart devices using simple voice commands for hands-free convenience.
Can I automate my home lighting with the Wyze Switch?Yes, the Wyze Switch allows you to set timers, schedules, and vacation modes to automate your home lighting. It also automatically reconnects after power outages, preserving your settings.
What replacement parts are available for the Wyze Lock Bolt?Wyze offers replacement screws, an interior assembly battery cover, an interior assembly metal plate, and a comprehensive replacement part kit to keep your Wyze Lock Bolt functioning reliably.
Why should I choose Wyze smart locks and switches for my home?Wyze smart locks and switches are designed for security, convenience, and affordability. They offer seamless integration with Alexa and Google Assistant, easy installation, and advanced features like fingerprint access and smart automation to upgrade your home.
Can you tell me more about the features of the Wyze Lock Bolt?How does the Wyze Switch integrate with other Wyze devices?Do you have any ongoing sales or discounts for the Wyze Lock Bolt or Wyze Switch?
