Top WiFi Thermostats Compatible with Alexa & Google Assistant
Best WiFi Connected Thermostats Compatible with Alexa and Google Assistant
Looking for a smart thermostat that seamlessly integrates with Alexa and Google Assistant? Discover the Wyze Thermostat lineup, designed to simplify your home heating and cooling while giving you full voice control and remote access. Whether you want a brand-new device or a budget-friendly refurbished option, Wyze offers smart solutions that keep your home comfortable and energy-efficient.
Wyze Thermostat: Smart Heating & Cooling Simplified
The Wyze Thermostat is a feature-packed smart thermostat that lets you control your home's temperature from anywhere using your smartphone or voice commands.
Key Features:
  • Voice Assistant Compatibility: Works effortlessly with Alexa and Google Assistant, allowing you to adjust your thermostat hands-free.
  • Remote Control: Adjust your home's temperature on the go via the Wyze app, ensuring you arrive to the perfect climate every time.
  • Wyze Room Sensor Support: Eliminate hot and cold spots by placing up to six Wyze Room Sensors around your home. These sensors detect motion and temperature to prioritize comfort in rooms you use most.
  • Motion-Sensing Comfort Mode: Automatically focuses heating or cooling on occupied rooms, saving energy without sacrificing comfort.
  • Always-On Display: Easy-to-read display that shows temperature and settings at a glance.
  • Simple Scheduling: Create daily schedules for weekdays and weekends to automate your home's climate control.
  • Energy-Saving Tips: Receive personalized recommendations based on your usage history to reduce energy waste.
  • Easy Installation: DIY installation guided step-by-step through the Wyze app, typically completed in 20 minutes.
"Arrive home to the perfect temperature, save energy, and keep your pets comfortable with Wyze Thermostat."
Why Choose Wyze Thermostat?
Wyze Thermostat combines smart technology with user-friendly design, making it accessible for everyone. Its integration with popular voice assistants means you can control your home's climate with simple voice commands or through the app, no matter where you are. Cozy living room with smart thermostat control Alt text: Family relaxing in living room controlling smart thermostat with voice assistant
(Refurbished) Wyze Thermostat: Affordable Smart Comfort
If you're looking for the same smart features at a more affordable price, the (Refurbished) Wyze Thermostat offers a like-new experience with full functionality.
Highlights:
  • Fully Tested & Guaranteed: Refurbished to work like new, offering a budget-friendly option without compromising quality.
  • Same Smart Features: Voice control with Alexa and Google Assistant, remote app access, Wyze Room Sensor compatibility, and scheduling.
  • Final Sale: Great value for those who want smart home comfort at a reduced price.
This option is perfect for those who want to enjoy smart thermostat benefits while saving money.
Enhance Your Smart Home Experience with Voice Control
Both Wyze Thermostat models integrate smoothly with Alexa and Google Assistant, enabling you to:
  • Adjust temperature with simple voice commands.
  • Include your thermostat in smart home routines.
  • Control your home's climate alongside other smart devices.
Voice control adds convenience and accessibility, making your home smarter and more responsive to your needs.
Summary
For a WiFi connected thermostat compatible with Alexa and Google Assistant, the Wyze Thermostat and its refurbished counterpart stand out as excellent choices. They offer:
  • Easy installation and setup.
  • Remote control from anywhere.
  • Energy-saving features.
  • Compatibility with Wyze Room Sensors for whole-home comfort.
  • Hands-free voice control with Alexa and Google Assistant.
Upgrade your home environment with Wyze Thermostat and enjoy smart, efficient heating and cooling tailored to your lifestyle.
FeatureWyze Thermostat (Refurbished)Wyze Thermostat (New)
Price$29.98$79.98
ConditionRefurbished, like new, fully testedNew
Return PolicyFinal sale, no returns (Wyze decision)30-day hassle-free returns
Smart ControlsYes, adjust on the go via appYes, adjust on the go via app
Voice Assistant CompatibilityAlexa, Google AssistantAlexa, Google Assistant
Wyze Room Sensor SupportYes, supports up to 6 sensorsYes, supports up to 6 sensors
Motion-Sensing Comfort ModeYesYes
SchedulingSimple daily schedulingSimple daily scheduling
Energy Saving TipsYes, based on usage historyYes, based on usage history
DisplayAlways-on displayAlways-on display
SetupWireless, 20-minute DIY installationWireless, 20-minute DIY installation
WarrantyNot specifiedNot specified
AvailabilitySold outSold out
What makes Wyze Thermostat compatible with Alexa and Google Assistant?Wyze Thermostat is designed to work seamlessly with both Alexa and Google Assistant, allowing you to control your home's temperature using simple voice commands. This integration enables hands-free adjustments and the ability to include your thermostat in smart home routines.
Can I control the Wyze Thermostat remotely?Yes, you can control the Wyze Thermostat from anywhere using the Wyze app on your smartphone. This remote access ensures you can adjust your home's temperature on the go, so you always arrive to a comfortable environment.
What are Wyze Room Sensors and how do they work with the thermostat?Wyze Room Sensors are additional devices you can place in up to six rooms to detect motion and temperature. They work with the Wyze Thermostat to eliminate hot and cold spots by prioritizing comfort in the rooms you use most, especially with the Motion-Sensing Comfort Mode.
Is the Wyze Thermostat easy to install?Yes, the Wyze Thermostat features a DIY installation process guided step-by-step through the Wyze app. Most users can complete the installation in about 20 minutes without professional help.
What energy-saving features does the Wyze Thermostat offer?Wyze Thermostat provides personalized energy-saving tips based on your usage history. It also includes scheduling and motion-sensing features to help reduce energy waste while maintaining comfort.
What is the difference between the new and refurbished Wyze Thermostat?The refurbished Wyze Thermostat offers the same smart features as the new model, including voice control, remote access, and room sensor compatibility. The refurbished version is fully tested, guaranteed to work like new, and is available at a more affordable price.
Can I schedule temperature changes with the Wyze Thermostat?Yes, the Wyze Thermostat allows you to create daily schedules for weekdays and weekends, automating your home's climate control to fit your routine.
How does voice control enhance the Wyze Thermostat experience?Voice control with Alexa and Google Assistant lets you adjust your home's temperature hands-free, include the thermostat in smart home routines, and control your climate alongside other smart devices for added convenience and accessibility.
Is the Wyze Thermostat suitable for budget-conscious buyers?Absolutely. The (Refurbished) Wyze Thermostat provides all the smart features of the new model at a reduced price, making it a great option for those seeking affordable smart home comfort.
What are the key features of the Wyze Thermostat?How does the Wyze Thermostat integrate with other smart devices in my home?Do you have any ongoing sales or discounts for the Wyze Thermostat?
