Compatible Smart Home Devices with Alexa and Google Assistant
Enhance your smart home experience with devices that seamlessly integrate with Alexa and Google Assistant. Whether you want to control your cameras, lighting, or other smart accessories with simple voice commands, these products offer reliable compatibility and convenience.
Wyze and Google Nest Bundles for Ultimate Voice Control
Google Nest Hub (2nd Gen) + Wyze Bundles
Experience the perfect harmony of smart home control and entertainment with the Google Nest Hub (2nd Gen) bundled with Wyze cameras. This bundle lets you:
- Control your Wyze Cam v3 and Wyze Cam Pan v3 effortlessly using voice commands.
- Enjoy a vibrant display that shows live camera feeds, making home monitoring intuitive.
- Use Google Assistant to play music, manage smart devices, and even access Google’s Sleep Sense sleep assistant.
- Benefit from an improved speaker with 50% more bass for richer sound.
- Easily manage your privacy with a mic switch and clear your Google Assistant history anytime.
This bundle is ideal for families who want to keep an eye on their home while enjoying smart home convenience.
Control your home hands-free with Google Nest Hub
Compact Voice-Controlled Speakers Compatible with Wyze Devices
Google Nest Mini + Wyze Bundles
The 2nd generation Google Nest Mini is a compact smart speaker that responds to your voice commands with ease. When paired with Wyze smart devices, it offers:
- Voice control for Wyze bulbs, plugs, and switches.
- Richer, bigger sound for music streaming from Spotify, YouTube Music, and more.
- Personalized updates on weather, news, schedules, and reminders.
- Simple setup and integration with your existing Wyze smart home ecosystem.
Available in bundles with Wyze bulbs, plugs, and switches, the Nest Mini is perfect for those looking to add voice control to their smart home without taking up much space.
Google Nest Mini Standalone
For users who want just the voice assistant speaker, the standalone Google Nest Mini offers the same great features:
- Hands-free voice control for compatible Wyze devices.
- Access to a wide range of Google Assistant features.
- Compact design that fits anywhere in your home.
Essential Accessories for Wyze Cameras
Wyze Cam v3 Replacement Part Kit
Keep your Wyze Cam v2 and v3 running smoothly with this affordable replacement part kit. It’s perfect for:
- Replacing lost or damaged parts.
- Ensuring your camera stays functional without needing a full replacement.
- Easy installation and compatibility with both Wyze Cam v2 and v3 models.
Priced at just $7.99, this kit helps maintain your smart home security setup efficiently.
Wyze Universal Mount (Long)
Mount your Wyze cameras in versatile locations such as ceilings or patios with this durable, long-neck mount. Features include:
- Compatibility with Wyze cameras using a standard 1/4”-20 mount.
- Durable white finish designed for indoor and outdoor use.
- Ideal for creating the perfect camera angle for your smart home monitoring.
Voice control integration with Alexa and Google Assistant transforms your smart home into a hands-free, intuitive environment. These Wyze and Google Nest products provide seamless compatibility, making it easier than ever to manage your home security and smart devices.
Summary of Alexa and Google Assistant Compatible Products
- Google Nest Hub (2nd Gen) + Wyze Bundles: Smart display with voice control and camera integration.
- Google Nest Mini + Wyze Bundles: Compact speaker bundles for voice control of Wyze devices.
- Google Nest Mini: Standalone voice assistant speaker.
- Wyze Cam v3 Replacement Part Kit: Affordable maintenance for Wyze cameras.
- Wyze Universal Mount (Long): Flexible mounting solution for Wyze cameras.
Elevate your smart home with these Alexa and Google Assistant compatible devices and accessories.
Enjoy seamless voice control with Alexa and Google Assistant
Secure your home with versatile Wyze camera mounts
Which Wyze devices are compatible with Alexa and Google Assistant?
Wyze devices such as Wyze Cam v3, Wyze Cam Pan v3, Wyze bulbs, plugs, and switches are compatible with both Alexa and Google Assistant, allowing you to control them using simple voice commands.What features does the Google Nest Hub (2nd Gen) + Wyze bundle offer for smart home control?
The Google Nest Hub (2nd Gen) + Wyze bundle allows you to control Wyze cameras with voice commands, view live camera feeds on a vibrant display, play music, manage other smart devices, and access Google’s Sleep Sense assistant. It also features improved sound quality and privacy controls.How can I use the Google Nest Mini with Wyze smart devices?
The Google Nest Mini can be paired with Wyze bulbs, plugs, and switches to enable hands-free voice control. You can use it to stream music, get personalized updates, and manage your smart home devices easily.Is the Google Nest Mini available as a standalone device for voice control?
Yes, the Google Nest Mini is available as a standalone smart speaker, offering hands-free voice control for compatible Wyze devices and access to a wide range of Google Assistant features in a compact design.What is included in the Wyze Cam v3 Replacement Part Kit?
The Wyze Cam v3 Replacement Part Kit includes essential parts to replace lost or damaged components for Wyze Cam v2 and v3 models, ensuring your cameras remain functional without needing a full replacement.How does the Wyze Universal Mount (Long) enhance camera installation?
The Wyze Universal Mount (Long) is designed for versatile camera placement, allowing you to mount Wyze cameras on ceilings, patios, or other locations. It features a durable white finish and is compatible with cameras using a standard 1/4”-20 mount.Can I control my Wyze cameras and smart devices hands-free?
Yes, with Alexa or Google Assistant integration, you can control Wyze cameras, bulbs, plugs, and switches hands-free using voice commands for a seamless smart home experience.What are the benefits of using Alexa and Google Assistant with Wyze products?
Integrating Alexa and Google Assistant with Wyze products provides hands-free control, easy access to live camera feeds, smart device management, music streaming, and personalized updates, making your smart home more convenient and intuitive.Are the Wyze and Google Nest bundles suitable for families?
Yes, Wyze and Google Nest bundles are ideal for families who want to monitor their home, enjoy entertainment, and manage smart devices easily with voice commands and intuitive displays.
