Refurbished Wyze Thermostat: Alexa & Google Assistant Compatible
Refurbished Wyze Thermostat Compatible with Alexa and Google Assistant
Looking for a smart thermostat that simplifies your home heating and cooling while seamlessly integrating with your smart home ecosystem? The Refurbished Wyze Thermostat offers an affordable, eco-friendly, and reliable solution. Fully tested and guaranteed to work like new, this thermostat supports both Alexa and Google Assistant, making voice control and automation effortless.
Why Choose the Refurbished Wyze Thermostat?
Smart Heating & Cooling Made Simple
The Wyze Thermostat is designed to provide precise temperature control with an easy-to-use interface. Its sleek design fits any modern home, and the IPS display offers a clear 180° viewing angle for effortless monitoring.
Key Features:
  • Compatibility: Works flawlessly with Alexa and Google Assistant for voice commands and smart routines.
  • Connectivity: Supports Bluetooth and 2.4GHz WiFi for reliable remote control via your smartphone.
  • Eco-Friendly: Comes in recyclable packaging and is mercury, arsenic, and PVC free.
  • Installation: Includes a C-wire adapter and all necessary mounting hardware for quick setup.
  • Operating Range: Suitable for indoor use with an operating temperature range of 32°F to 130°F.
  • Warranty: Backed by a 1-year warranty for peace of mind.
The refurbished model offers the same premium features as new units but at a significantly reduced price, making smart home upgrades more accessible.
Seamless Integration with Your Smart Home
The Wyze Thermostat integrates smoothly with popular smart assistants:
  • Alexa: Adjust your home's temperature hands-free with simple voice commands.
  • Google Assistant: Control your thermostat from anywhere using Google-enabled devices.
This compatibility ensures you can include the thermostat in your existing smart home routines, enhancing comfort and energy efficiency.
Product Specifications at a Glance
FeatureDetails
Dimensions (Thermostat)120mm (L) x 65mm (W) x 33mm (D)
DisplayIPS Display, 180° viewing angle
Power Source24VAC through C terminal
ConnectivityBluetooth, 2.4GHz WiFi
Operating Temperature32°F - 130°F (0°C - 55°C)
WeightLess than 1 lb
Included AccessoriesC-Wire Adapter, Mounting Plate, Wall Cover, Screws, Wire Labels, Screwdriver, Quick Start Guide
CertificationsFCC, IC, California Proposition 65
Enhance Your Smart Home with Wyze Ecosystem
While the Wyze Thermostat is a standout for smart climate control, Wyze also offers a range of smart cameras compatible with Alexa and Google Assistant to complement your home automation setup.
Wyze Cam v4 Series Highlights:
  • 2.5K QHD Resolution: Crystal-clear video quality for indoor and outdoor security.
  • Enhanced Color Night Vision: See vibrant colors even in low light.
  • Motion-Activated Spotlight & Siren: Deter intruders and illuminate your property.
  • Wi-Fi 6 Support: Stronger, more reliable connections.
  • 24/7 Local Recording: Continuous monitoring with microSD card support.
  • Smart Detection: Person, pet, package, and vehicle alerts with subscription.
  • Weather Resistant: IP65 rating for outdoor use.
These cameras also integrate with Alexa and Google Assistant, allowing you to view live feeds and control settings via voice commands. Wyze Cam v4 Outdoor Lifestyle Experience enhanced security with Wyze Cam v4’s color night vision and motion-activated spotlight.
Summary
If you want a refurbished Wyze Thermostat that is fully compatible with Alexa and Google Assistant, this product offers smart, efficient heating and cooling control at a great value. Paired with Wyze’s smart cameras, you can build a comprehensive smart home system that enhances comfort, security, and convenience.
Product Tags Recap
Feature(Refurbished) Wyze ThermostatWyze Thermostat
ConditionRefurbished, like new, fully testedNew, A-grade
Price$29.98 (compare at $79.98)$79.98
Return PolicyFinal sale, no returns30-day hassle-free returns
Smart Heating & CoolingYesYes
Remote Control via AppYesYes
Voice Assistant CompatibilityAlexa, Google AssistantAlexa, Google Assistant
Wyze Room Sensor SupportYes, supports up to 6 sensorsYes, supports up to 6 sensors
Motion-Sensing Comfort ModeYesYes
Always-on DisplayYesYes
Wireless SetupYesYes
SchedulingSimple daily schedulingSimple daily scheduling
Energy-saving TipsYesYes
Installation20-minute DIY with app guidance20-minute DIY with app guidance
AvailabilitySold outSold out
What is the Refurbished Wyze Thermostat?The Refurbished Wyze Thermostat is a smart thermostat that offers precise temperature control, seamless integration with Alexa and Google Assistant, and eco-friendly features. It is fully tested, guaranteed to work like new, and comes at a reduced price compared to new units.
Is the Refurbished Wyze Thermostat compatible with Alexa and Google Assistant?Yes, the Refurbished Wyze Thermostat works flawlessly with both Alexa and Google Assistant, allowing you to control your home's temperature using voice commands and integrate it into your smart home routines.
What are the key features of the Refurbished Wyze Thermostat?Key features include compatibility with Alexa and Google Assistant, Bluetooth and 2.4GHz WiFi connectivity, eco-friendly materials and packaging, an easy-to-read IPS display, included C-wire adapter and mounting hardware, and a 1-year warranty.
How easy is it to install the Refurbished Wyze Thermostat?The Refurbished Wyze Thermostat is designed for quick and easy installation. It comes with a C-wire adapter, mounting plate, wall cover, screws, wire labels, screwdriver, and a quick start guide to help you set it up efficiently.
What is the operating temperature range for the Wyze Thermostat?The Wyze Thermostat is suitable for indoor use and operates within a temperature range of 32°F to 130°F (0°C to 55°C).
What accessories are included with the Refurbished Wyze Thermostat?Included accessories are a C-wire adapter, mounting plate, wall cover, screws, wire labels, screwdriver, and a quick start guide.
Is the Refurbished Wyze Thermostat eco-friendly?Yes, the thermostat is eco-friendly. It comes in recyclable packaging and is free from mercury, arsenic, and PVC.
Does the Refurbished Wyze Thermostat come with a warranty?Yes, the Refurbished Wyze Thermostat is backed by a 1-year warranty for peace of mind.
What are the dimensions and weight of the Wyze Thermostat?The thermostat measures 120mm (L) x 65mm (W) x 33mm (D) and weighs less than 1 lb.
Can the Wyze Thermostat be integrated with other Wyze smart home products?Yes, the Wyze Thermostat can be paired with other Wyze smart home products, such as Wyze Cam v4 series cameras, to create a comprehensive smart home system.
What are the benefits of choosing a refurbished Wyze Thermostat?Choosing a refurbished Wyze Thermostat provides the same premium features as a new unit at a significantly reduced price, making smart home upgrades more affordable and accessible.
What certifications does the Wyze Thermostat have?The Wyze Thermostat is certified by FCC, IC, and complies with California Proposition 65.
What are the connectivity options for the Wyze Thermostat?The Wyze Thermostat supports Bluetooth and 2.4GHz WiFi, allowing for reliable remote control via your smartphone.
Can you tell me more about the installation process for the Wyze Thermostat?What are the dimensions of the Wyze Thermostat?What is the warranty period for the refurbished Wyze Thermostat?
