Smart Voice-Controlled Thermostats for Alexa & Google Assistant
Smart Voice Controlled Heating and Cooling Thermostats for Alexa and Google Assistant
Discover the convenience and energy efficiency of smart thermostats that seamlessly integrate with your Alexa or Google Assistant devices. These smart thermostats allow you to control your home’s heating and cooling with simple voice commands or through an intuitive app, ensuring your home is always at the perfect temperature while saving energy and money.
Wyze Thermostat: Smart Heating & Cooling Simplified
The Wyze Thermostat is designed to make your home environment comfortable and energy-efficient with smart features tailored for modern living.
Key Features:
  • Voice Control Compatibility: Easily adjust your thermostat using Alexa or Google Assistant. Whether you’re cozy on the couch or busy in the kitchen, just ask your voice assistant to set the perfect temperature.
  • Remote Temperature Adjustment: Control your thermostat from anywhere in the world via the Wyze app. Arrive home to a perfectly heated or cooled house without lifting a finger.
  • Wyze Room Sensor Integration: Eliminate hot and cold spots by placing up to six Wyze Room Sensors around your home. These sensors detect motion and temperature, prioritizing rooms you use most to maximize comfort and energy savings.
  • Motion-Sensing Comfort Mode: Automatically adjusts heating or cooling based on room occupancy, saving energy without sacrificing comfort.
  • Simple Scheduling: Create daily or weekly schedules to automate your home’s climate control, ensuring your home is warm in the morning and cool at night.
  • Energy-Saving Tips: Receive personalized recommendations based on your usage history to reduce energy waste.
  • Easy Installation: A 20-minute DIY setup guided step-by-step through the Wyze app makes installation accessible for anyone.
  • Always-On Display: Clear, easy-to-read IPS display with a wide 180° viewing angle.
  • Wireless Setup & Mounting: Includes a magnetic table stand and wall mount for flexible placement.
"Wake up to a warm welcome, save energy when away, and enjoy the perfect temperature all day long."
Technical Specs:
  • Power Source: 24VAC through C terminal (C-wire adapter included)
  • Operating Temperature: 32°F - 130°F (0°C - 55°C)
  • Compatible with Android 9.0+ and iOS 15.0+
  • Certifications: FCC, IC, California Proposition 65
  • Eco-Friendly: Recyclable packaging, mercury-free, arsenic-free, PVC-free
(Refurbished) Wyze Thermostat: Affordable Smart Climate Control
For those looking for a budget-friendly option without compromising on features, the refurbished Wyze Thermostat offers the same smart heating and cooling capabilities at a reduced price.
Highlights:
  • Fully tested and guaranteed to work like new.
  • Includes all original accessories: C-wire adapter, mounting plates, screws, and quick start guide.
  • Same voice assistant compatibility with Alexa and Google Assistant.
  • One-year warranty included.
  • Environmentally conscious choice with recyclable packaging and mercury-free components.
This option is perfect for eco-conscious buyers or those seeking a smart thermostat solution at a lower cost.
Cozy Living Room with Smart Thermostat Control your home environment effortlessly with smart voice commands.
Why Choose a Voice-Controlled Smart Thermostat?
"Smart thermostats with voice control bring convenience, comfort, and savings to your fingertips — or simply your voice."
  • Hands-Free Control: Adjust temperature without interrupting your activities.
  • Energy Efficiency: Intelligent scheduling and room sensors reduce wasted energy.
  • Remote Access: Manage your home climate from anywhere, ensuring comfort upon arrival.
  • Integration: Works seamlessly with popular voice assistants like Alexa and Google Assistant.
  • User-Friendly: Easy installation and intuitive app controls make smart home upgrades accessible to everyone.
Enhance Your Smart Home Environment
Pair your Wyze Thermostat with other Wyze smart home devices for a fully integrated experience. While the Wyze Bulb Color is not a thermostat, it complements your smart home by offering voice-controlled lighting that can set the perfect ambiance alongside your ideal temperature.
Summary
The Wyze Thermostat and its refurbished counterpart provide an affordable, easy-to-use, and highly compatible solution for smart heating and cooling. With voice control support for Alexa and Google Assistant, remote app management, and smart room sensors, these thermostats bring comfort and energy savings to your home effortlessly.
FeatureWyze Thermostat (Refurbished)Wyze Thermostat
Price$29.98 USD$79.98 USD
ConditionRefurbished, like new, fully testedNew
Return PolicyFinal sale, no returns30-day hassle-free returns
Smart Heating & CoolingYesYes
Remote Control via AppYesYes
Voice Assistant CompatibilityAlexa, Google AssistantAlexa, Google Assistant
Wyze Room Sensor CompatibilityYesYes
Motion-Sensing Comfort ModeYesYes
Always-on DisplayYesYes
Wireless SetupYesYes
SchedulingSimple daily schedulingSimple daily scheduling
Energy-saving TipsYesYes
Installation20-minute DIY guided by app20-minute DIY guided by app
AvailabilitySold outSold out
What is a smart voice-controlled thermostat and how does it work with Alexa and Google Assistant?A smart voice-controlled thermostat is a device that allows you to manage your home's heating and cooling using voice commands through Alexa or Google Assistant. You can adjust the temperature, set schedules, and control your climate remotely using either your voice or an intuitive mobile app.
What are the main features of the Wyze Thermostat?The Wyze Thermostat offers voice control compatibility with Alexa and Google Assistant, remote temperature adjustment via the Wyze app, integration with up to six Wyze Room Sensors, motion-sensing comfort mode, simple scheduling, personalized energy-saving tips, easy 20-minute DIY installation, an always-on IPS display, and flexible wireless setup with a magnetic table stand and wall mount.
How do Wyze Room Sensors improve home comfort and energy efficiency?Wyze Room Sensors detect motion and temperature in different rooms, allowing the thermostat to prioritize heating or cooling in the rooms you use most. This eliminates hot and cold spots, maximizes comfort, and helps reduce energy waste.
Can I control the Wyze Thermostat remotely?Yes, you can control the Wyze Thermostat from anywhere in the world using the Wyze app on your smartphone. This allows you to adjust your home's temperature before you arrive or while you're away.
Is the Wyze Thermostat easy to install?Yes, the Wyze Thermostat features a simple 20-minute DIY installation process, guided step-by-step through the Wyze app. It includes a C-wire adapter, mounting plates, screws, and a quick start guide for easy setup.
What is the difference between the new and refurbished Wyze Thermostat?The refurbished Wyze Thermostat offers the same smart heating and cooling features as the new model, including voice assistant compatibility and remote control. The refurbished version is fully tested, includes all original accessories, comes with a one-year warranty, and is available at a reduced price, making it a budget-friendly and eco-conscious choice.
Is the Wyze Thermostat compatible with my smartphone?The Wyze Thermostat is compatible with Android devices running version 9.0 or higher and iOS devices running version 15.0 or higher.
What are the environmental benefits of the Wyze Thermostat?The Wyze Thermostat is designed with eco-friendly materials, including recyclable packaging, and is mercury-free, arsenic-free, and PVC-free. Choosing the refurbished model further reduces environmental impact.
What certifications does the Wyze Thermostat have?The Wyze Thermostat is certified by the FCC, IC, and meets California Proposition 65 standards.
How does voice control with the Wyze Thermostat enhance convenience?Voice control allows you to adjust your home's temperature hands-free using Alexa or Google Assistant, making it easy to stay comfortable without interrupting your activities.
Can I integrate the Wyze Thermostat with other smart home devices?Yes, the Wyze Thermostat can be paired with other Wyze smart home devices, such as the Wyze Bulb Color, for a fully integrated and voice-controlled smart home experience.
What are the key features of the Wyze Thermostat?How does the Wyze Thermostat integrate with other Wyze smart home devices?Is there a warranty included with the refurbished Wyze Thermostat?
