Where to Buy Wyze Lock Keypad for Home Security Online
If you're looking to enhance your home security with a reliable and convenient smart lock keypad, Wyze offers an excellent range of products designed to keep your home safe and accessible without the hassle of traditional keys. This guide highlights the Wyze Lock Keypad and related Wyze smart lock products that integrate seamlessly for a smarter, safer home.
Wyze Lock Keypad: Unlock Without Your Phone or Key
The Wyze Lock Keypad is the perfect accessory for those who want keyless entry without relying on their smartphone. Designed specifically for the Wyze Lock, this keypad allows you to unlock your door using a secure code, making it ideal for family members, guests, or service providers who may not have the app.
Key Features:
  • Easy Keyless Entry: Unlock your door with a simple code, no phone or physical key needed.
  • Bluetooth Connectivity: Pairs directly with the Wyze Lock for quick and secure access.
  • Weather Resistant: Rated IPX5, it withstands rain and outdoor conditions.
  • Battery Powered: Runs on 2x AA batteries with 4-6 months battery life depending on temperature.
  • Compact and Sleek Design: Measures 3.7" x 1.3" x 1.0" and fits discreetly near your door.
Note: The Wyze Lock Keypad requires the Wyze Lock to function and does not work as a standalone device or with the Wyze Lock Bolt.
Wyze Lock Keypad Lifestyle Wyze Lock Keypad offers convenient keyless home entry
Wyze Lock Bolt: The Ultimate Smart Deadbolt Replacement
For a more advanced smart lock solution, the Wyze Lock Bolt replaces your existing deadbolt with a high-tech, Bluetooth-enabled lock that offers multiple ways to secure and access your home.
Why Choose Wyze Lock Bolt?
  • Ultra-Fast Fingerprint Sensor: Unlock your door instantly with a touch of your finger.
  • Backlit Keypad with Anti-Peep: Enter your code discreetly even in low light.
  • Auto-Lock Feature: Automatically locks your door if you forget to do so.
  • Lock and Unlock History: Track access events directly from the Wyze app.
  • Weather Resistant: IPX5 rating ensures durability in various weather conditions.
  • Easy Installation: Fits standard door thicknesses (1-3/8" to 1-3/4") and backsets (2-3/8" or 2-3/4").
  • Battery Life: Powered by 4 AA batteries lasting 10-12 months.
Available in Matte Black and Satin Nickel finishes, the Wyze Lock Bolt combines security with style and convenience. Wyze Lock Bolt Lifestyle Wyze Lock Bolt with fingerprint sensor and keypad for secure access
Wyze Sense Keypad & Hub: Remote Home Security Control
If you want to integrate your Wyze Lock Keypad into a broader home security system, consider the Wyze Sense Keypad and Wyze Sense Hub. These devices work together to provide remote arm/disarm control and alert notifications for your home monitoring setup.
Wyze Sense Keypad:
  • Disarm your home security system remotely.
  • Requires Wyze Home Monitoring and the Wyze Sense Hub.
  • Features an emergency button for quick alerts.
  • Indoor use with permanent adhesive mounting.
Wyze Sense Hub:
  • The central unit connecting all Wyze monitoring components.
  • Supports up to 100 sensors with a 500 ft RF range.
  • Sends alerts and triggers sirens (88db at 2 feet).
  • Connects via Ethernet, WiFi, and Bluetooth.
Together, these devices enhance your home security by allowing you to control and monitor your system from anywhere.
Additional Accessories: Wyze Lock Replacement Part Kit
To keep your Wyze Lock functioning smoothly, the Wyze Lock Replacement Part Kit offers essential components compatible with your smart lock. This kit ensures your lock stays in top condition without needing a full replacement.
Why Choose Wyze for Your Home Security?
Wyze smart locks and accessories provide a seamless blend of convenience, security, and smart home integration. Whether you want quick keyless entry with the Wyze Lock Keypad or advanced biometric access with the Wyze Lock Bolt, Wyze products are designed to fit your lifestyle and security needs.
With Wyze, you get:
  • Easy installation and setup.
  • Remote control and monitoring via the Wyze app.
  • Durable, weather-resistant hardware.
  • Affordable pricing without compromising quality.
Summary of Wyze Lock Keypad and Related Products
ProductPrice (USD)Key FeaturesCompatibility
Wyze Lock Keypad$23.99Keyless code entry, Bluetooth, IPX5 weatherproofRequires Wyze Lock
Wyze Lock Bolt$79.98Fingerprint sensor, backlit keypad, auto-lockReplaces deadbolt
Wyze Sense Keypad$27.98Arm/disarm system, emergency buttonRequires Wyze Sense Hub
Wyze Sense Hub$45.98Connects sensors, sends alertsHome monitoring system
Wyze Lock Replacement Kit$4.99-$19.99Replacement parts for Wyze LockWyze Lock only
Enhance your home security today with the Wyze Lock Keypad and smart lock solutions designed for modern living.
FeatureWyze Lock KeypadWyze Lock BoltWyze Sense KeypadWyze Sense Hub
TypeAccessoriesConnected HomeHome MonitoringHome Monitoring
Price$23.99$79.98$27.98$45.98
PurposeUnlock Wyze Lock without phone/keyReplace deadbolt with smart lock, fingerprint, keypadDisarm home security remotely (requires Wyze Home Monitoring)Connects monitoring components, sends alerts
Key FeaturesKeypad for Wyze LockFingerprint sensor, backlit keypad, auto-lock, anti-peep tech, pick-proof, weatherproof (IPX5)Arm/disarm system, emergency buttonSupports up to 100 sensors, siren (88db), multiple communication methods
CompatibilityFor Wyze LockReplaces existing deadboltRequires Wyze Sense HubWorks with Wyze Sense sensors and Home Monitoring
Battery2x AA Batteries (included)4x AA Batteries (included), USB-C charging portNot specifiedBuilt-in rechargeable battery (10 hr backup)
Weather ResistanceIPX5IPX5Indoor use onlyIndoor use only
Communication MethodBluetoothBluetoothNot specifiedEthernet, WiFi 2.4 GHz, Bluetooth, 915MHz RF
Operating Temperature-4°F to 140°F (-20°C to 60°C)Keypad: -13°F to 122°F; Indoor assembly: 32°F to 122°FNot specified32°F to 104°F (0°C to 40°C)
Installation TimeNot specifiedAbout 20 minutesNot applicableNot applicable
Additional FeaturesUnlock without phone or keyAuto-lock timer, lock/unlock history, emergency one-time codes, hardware encryption, two-factor authenticationEmergency button, max 100 accessoriesSiren, supports up to 100 sensors
What is the Wyze Lock Keypad and how does it work?The Wyze Lock Keypad is an accessory designed for the Wyze Lock that allows you to unlock your door using a secure code, providing keyless entry without needing your phone or a physical key. It connects via Bluetooth to the Wyze Lock and is ideal for family members, guests, or service providers who do not have the Wyze app.
Is the Wyze Lock Keypad weather resistant?Yes, the Wyze Lock Keypad is rated IPX5 for weather resistance, making it suitable for outdoor use and able to withstand rain and various weather conditions.
Does the Wyze Lock Keypad work as a standalone device?No, the Wyze Lock Keypad requires the Wyze Lock to function and does not work as a standalone device. It is also not compatible with the Wyze Lock Bolt.
How long does the Wyze Lock Keypad battery last?The Wyze Lock Keypad is powered by 2 AA batteries, which typically last between 4 to 6 months depending on usage and temperature.
What is the Wyze Lock Bolt and how is it different from the Wyze Lock Keypad?The Wyze Lock Bolt is a smart deadbolt replacement that features a fingerprint sensor, backlit keypad, auto-lock, and Bluetooth connectivity. Unlike the Wyze Lock Keypad, which is an accessory for the Wyze Lock, the Wyze Lock Bolt replaces your existing deadbolt and offers multiple ways to unlock your door, including fingerprint and code entry.
Can the Wyze Lock Keypad be used with the Wyze Lock Bolt?No, the Wyze Lock Keypad is not compatible with the Wyze Lock Bolt. It is designed specifically to work with the Wyze Lock.
What are the main features of the Wyze Lock Bolt?The Wyze Lock Bolt offers ultra-fast fingerprint unlocking, a backlit keypad with anti-peep technology, auto-locking, lock and unlock history tracking via the Wyze app, weather resistance (IPX5), and easy installation on standard doors. It is available in Matte Black and Satin Nickel finishes.
What is the Wyze Sense Keypad and how does it enhance home security?The Wyze Sense Keypad is part of the Wyze home monitoring system, allowing you to arm or disarm your security system remotely. It features an emergency button for quick alerts and requires the Wyze Sense Hub and Wyze Home Monitoring subscription to function.
What does the Wyze Sense Hub do?The Wyze Sense Hub is the central unit that connects all Wyze monitoring components, supporting up to 100 sensors with a 500 ft RF range. It sends alerts, triggers sirens, and connects via Ethernet, WiFi, and Bluetooth to provide comprehensive home security monitoring.
Are there replacement parts available for Wyze Lock products?Yes, the Wyze Lock Replacement Part Kit offers essential components to keep your Wyze Lock functioning smoothly. This kit is compatible only with the Wyze Lock and helps maintain your smart lock without needing a full replacement.
Why should I choose Wyze smart locks and accessories for home security?Wyze smart locks and accessories offer easy installation, remote control and monitoring via the Wyze app, durable weather-resistant hardware, and affordable pricing without compromising on quality. They provide a seamless blend of convenience, security, and smart home integration.
Where can I buy the Wyze Lock Keypad and other Wyze smart lock products?You can purchase the Wyze Lock Keypad, Wyze Lock Bolt, Wyze Sense Keypad, Wyze Sense Hub, and Wyze Lock Replacement Part Kit directly from the official Wyze website or authorized retailers.
What are the prices of Wyze smart lock products?As of the latest update, the Wyze Lock Keypad is $23.99, Wyze Lock Bolt is $79.98, Wyze Sense Keypad is $27.98, Wyze Sense Hub is $45.98, and the Wyze Lock Replacement Part Kit ranges from $4.99 to $19.99.
Can you tell me more about the features of the Wyze Lock Keypad?How does the Wyze Lock Bolt compare to the Wyze Lock Keypad?What is the warranty policy for Wyze products?
