Trusted Wyze Outdoor Power Adapter for Secure Camera Connections
Trusted Brand Specific Adapter for Wyze Cameras with Secure Power Connections
When it comes to powering your Wyze cameras outdoors, having a reliable and secure power adapter is essential. The Wyze Outdoor Power Adapter is the trusted choice designed specifically for Wyze cameras, ensuring weather-resistant durability and secure connections for uninterrupted surveillance. Whether you own the Wyze Cam v3 Pro, Pan v3, or Battery Cam Pro, this adapter guarantees your camera stays powered safely in any weather condition.
Wyze Outdoor Power Adapter: Secure and Weather-Resistant Power Solution
Designed for Wyze Cameras
The Wyze Outdoor Power Adapter is engineered to work seamlessly with multiple Wyze camera models, including:
  • Wyze Cam v4 and OG series (direct compatibility)
  • Wyze Cam v3 Pro and Pan v3 (requires L-shaped Micro USB Adapter)
  • Wyze Battery Cam Pro (requires USB-C adapter)
This specificity ensures a perfect fit and secure power connection, preventing accidental disconnections or power issues.
Built to Withstand the Elements
With an IP67 weather-resistant rating, the adapter is ready for rain, snow, or shine. This means you can confidently install your Wyze cameras outdoors without worrying about moisture or dust damaging the power connection.
Multiple Variants for Your Needs
  • Outdoor Adapter + L-shaped Adapter + USB-C Adapter ($19.99) – Complete kit for most Wyze outdoor cameras.
  • L-shaped Micro USB Adapter only ($5.99) – For users who already have the outdoor adapter but need the L-shaped connector.
The adapters will NOT work with the OG Stack Kit, so ensure compatibility before purchase.
Wyze Cam Pan v3 Outdoor Setup Wyze Cam Pan v3 powered outdoors with secure, weather-resistant adapter
Wyze Cam Pan v3: Perfect Partner for the Outdoor Power Adapter
360° Pan and 180° Tilt with IP65 Weather Resistance
The Wyze Cam Pan v3 is a versatile indoor/outdoor camera that offers a full 360° horizontal and 180° vertical view, making it ideal for comprehensive home security. Its IP65 rating means it can handle outdoor environments when paired with the Wyze Outdoor Power Adapter.
Crisp 1080p HD Video and Night Vision
  • 1920 x 1080 resolution with H.264 video encoding
  • 4 IR LEDs for night vision
  • 8x digital zoom for detailed monitoring
Two-Way Audio and Smart Alerts
Built-in speaker and microphone enable two-way communication with noise and echo cancellation. Receive push notifications directly to your phone for instant alerts.
Easy Installation and Compatibility
The camera mounts easily with a screw mount and connects via micro USB port, perfectly matching the Wyze Outdoor Power Adapter’s secure connection.
Wyze Cam v4: Advanced Outdoor Security with Enhanced Power Support
Stunning 2.5K QHD Resolution and Color Night Vision
Wyze Cam v4 delivers crystal-clear 2.5K video quality with enhanced color night vision, ensuring you never miss a detail, day or night.
Wi-Fi 6 Support and Smart Home Integration
Supports the latest Wi-Fi 6 for faster, more reliable connections and integrates seamlessly with Alexa, Google Assistant, and IFTTT.
Weather-Resistant and Versatile Mounting
With an IP65 rating, the Cam v4 is built for outdoor use. It supports multiple mounting options including wall, ceiling, and magnetic mounts.
Powering Wyze Cam v4 Outdoors
While the Cam v4 has its own power adapter, pairing it with the Wyze Outdoor Power Adapter ensures a secure, weatherproof power connection for outdoor setups.
Why Choose Wyze Outdoor Power Adapter for Your Wyze Cameras?
  • Trusted Brand Compatibility: Designed specifically for Wyze cameras to ensure perfect fit and function.
  • Secure Power Connection: Prevents accidental unplugging and power interruptions.
  • Weatherproof Durability: IP67 rating protects against rain, snow, and dust.
  • Multiple Adapter Options: Supports various Wyze camera models with appropriate connectors.
  • Affordable and Reliable: Priced competitively with hassle-free returns.
For outdoor Wyze camera setups, the Wyze Outdoor Power Adapter is the essential accessory to keep your security system running smoothly and safely.
Summary of Key Products for Secure Outdoor Wyze Camera Power
ProductKey FeaturesPrice
Wyze Outdoor Power AdapterIP67 weather-resistant, compatible with Wyze Cam v3/v3 Pro, Pan v3, Battery Cam ProFrom $5.99 (adapter only) to $19.99 (full kit)
Wyze Cam Pan v3360° pan, 1080p HD, IP65 weather-resistant, two-way audioFrom $39.98
Wyze Cam v42.5K QHD, color night vision, Wi-Fi 6, IP65 weather-resistantFrom $35.98
Wyze Cam Floodlight v2 Outdoor Security Enhance your outdoor security with Wyze’s weatherproof cameras and accessories
Conclusion
For anyone seeking a trusted brand-specific adapter for Wyze cameras with secure power connections, the Wyze Outdoor Power Adapter stands out as the best choice. Its robust weather resistance, perfect compatibility, and secure connection make it indispensable for outdoor Wyze camera setups. Pair it with the Wyze Cam Pan v3 or Wyze Cam v4 for a comprehensive, reliable home security system that works rain or shine.
FeatureWyze Outdoor Power AdapterWyze Cam Pan v3Wyze Cam v4
TypeAccessoryCameraCamera
Weather ResistanceIP67IP65IP65
UsagePowers Wyze cameras outdoorsIndoor/outdoor 360° pan & 180° tilt security cameraIndoor/outdoor security camera
CompatibilityWyze Cam v4, OG series, Cam Pan v3, Cam v3 Pro, Battery Cam Pro (with adapters)Works with Wyze Outdoor Power Adapter (sold separately)Requires Outdoor Power Adapter (sold separately)
Power Adapter VariantsL-shaped Micro USB Adapter, Outdoor Adapter + L-shaped Adapter, Outdoor Adapter + L-shaped Adapter + USB-C AdapterIncluded power adapter (5V/2000mA)Indoor USB Power Adapter included (5V/1A), Outdoor adapter sold separately
Video ResolutionN/A1080p (1920x1080)2.5K QHD (2560x1440)
Field of ViewN/A360° horizontal, 180° vertical, 120° FOVDFOV 115.8°, HFOV 98.5°, VFOV 53.1°
Night VisionN/A4 IR LEDs (850 nm), Color Night Vision4 IR LEDs (850 nm) + 2 white spotlight LEDs, Color Night Vision
Audio FeaturesN/ABuilt-in speaker, microphone, 2-way audio, noise & echo cancellation99dB waterproof speaker, simultaneous 2-way talk, noise & echo cancellation
Motion TrackingN/AAutomatic motion trackingMotion-activated spotlight, person detection
ConnectivityN/A802.11 b/g/n 2.4 GHz Wi-Fi2.4 GHz Wi-Fi, Wi-Fi 6
StorageN/ASupports up to 256 GB microSDmicroSD card up to 512 GB, cloud storage with subscription
DimensionsN/A124mm x 60mm x 63mm2in x 2in x 2 3/8in
WeightN/A11.29 oz (320 g)0.49 lb (222 g)
Mounting OptionsN/AScrew 1/4" - 20 mountStand, Wall mount, Ceiling mount, Magnetic wall mount (adhesive)
Operating TemperatureN/A-4°F to 122°F (-20°C to 50°C)-4°F to 122°F (-20°C to 50°C)
WarrantyNot specified1 Year1 Year
Price Range$5.99 - $19.99 (depending on variant)$39.98 (single camera)$35.98 - $107.94 (depending on pack and variant)
What is the Wyze Outdoor Power Adapter and why is it important for Wyze cameras?The Wyze Outdoor Power Adapter is a weather-resistant power solution designed specifically for Wyze cameras. It ensures secure and uninterrupted power connections for outdoor surveillance, protecting against rain, snow, and dust with its IP67 rating. This adapter is essential for maintaining reliable operation of your Wyze cameras in any weather condition.
Which Wyze camera models are compatible with the Wyze Outdoor Power Adapter?The Wyze Outdoor Power Adapter is compatible with several Wyze camera models, including Wyze Cam v4 and OG series (direct compatibility), Wyze Cam v3 Pro and Pan v3 (with L-shaped Micro USB Adapter), and Wyze Battery Cam Pro (with USB-C adapter). Please note that it is not compatible with the OG Stack Kit.
Is the Wyze Outdoor Power Adapter weatherproof?Yes, the Wyze Outdoor Power Adapter has an IP67 weather-resistant rating, making it highly durable against rain, snow, and dust. This ensures your outdoor Wyze cameras remain powered and protected in harsh weather conditions.
What variants of the Wyze Outdoor Power Adapter are available?There are two main variants: the complete kit (Outdoor Adapter + L-shaped Adapter + USB-C Adapter) for $19.99, suitable for most Wyze outdoor cameras, and the L-shaped Micro USB Adapter only for $5.99, ideal for users who already have the outdoor adapter but need the L-shaped connector.
Can I use the Wyze Outdoor Power Adapter with the OG Stack Kit?No, the Wyze Outdoor Power Adapter and its included adapters are not compatible with the OG Stack Kit. Please check your camera model for compatibility before purchasing.
How does the Wyze Outdoor Power Adapter ensure a secure power connection?The adapter is engineered for a perfect fit with supported Wyze cameras, using specific connectors to prevent accidental disconnections and power interruptions. This secure connection is crucial for uninterrupted outdoor surveillance.
What are the key features of the Wyze Cam Pan v3 when used outdoors?The Wyze Cam Pan v3 offers 360° pan and 180° tilt, 1080p HD video, IP65 weather resistance, night vision, two-way audio, and smart alerts. When paired with the Wyze Outdoor Power Adapter, it becomes an ideal solution for comprehensive outdoor security.
Does the Wyze Cam v4 require the Wyze Outdoor Power Adapter for outdoor use?While the Wyze Cam v4 comes with its own power adapter, using the Wyze Outdoor Power Adapter provides a more secure and weatherproof power connection for outdoor installations, enhancing durability and reliability.
What are the benefits of choosing the Wyze Outdoor Power Adapter for my Wyze cameras?The Wyze Outdoor Power Adapter offers trusted brand compatibility, secure power connections, IP67 weatherproof durability, multiple adapter options for various camera models, and affordable pricing. It is designed to keep your Wyze security system running smoothly and safely outdoors.
How much does the Wyze Outdoor Power Adapter cost?The Wyze Outdoor Power Adapter is available from $5.99 for the adapter only to $19.99 for the full kit, making it an affordable and reliable solution for powering your Wyze cameras outdoors.
What are the key features of the Wyze Outdoor Power Adapter?Can the Wyze Outdoor Power Adapter be used with the Wyze Cam v4?Do you have any deals, ongoing sales, discounts, or promotions?
